[U-Boot] [PATCH 1/1] efi_selftest: rename setup_ok
The variable name setup_ok might suggest a boolean with true indicating OK. Let's avoid the misleading name.
%s/setup_ok/setup_status/g
Suggested-by: Simon Glass sjg@chromium.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/efi_selftest.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest.c b/lib/efi_selftest/efi_selftest.c index fc7866365d..5b01610eca 100644 --- a/lib/efi_selftest/efi_selftest.c +++ b/lib/efi_selftest/efi_selftest.c @@ -18,7 +18,7 @@ static const struct efi_boot_services *boottime; static const struct efi_runtime_services *runtime; static efi_handle_t handle; static u16 reset_message[] = L"Selftest completed"; -static int *setup_ok; +static int *setup_status;
/* * Exit the boot services. @@ -199,8 +199,8 @@ void efi_st_do_tests(const u16 *testname, unsigned int phase, if (test->phase != phase) continue; if (steps & EFI_ST_SETUP) - setup_ok[i] = setup(test, failures); - if (steps & EFI_ST_EXECUTE && setup_ok[i] == EFI_ST_SUCCESS) + setup_status[i] = setup(test, failures); + if (steps & EFI_ST_EXECUTE && setup_status[i] == EFI_ST_SUCCESS) execute(test, failures); if (steps & EFI_ST_TEARDOWN) teardown(test, failures); @@ -278,7 +278,7 @@ efi_status_t EFIAPI efi_selftest(efi_handle_t image_handle, ret = boottime->allocate_pool(EFI_RUNTIME_SERVICES_DATA, sizeof(int) * ll_entry_count(struct efi_unit_test, efi_unit_test), - (void **)&setup_ok); + (void **)&setup_status); if (ret != EFI_SUCCESS) { efi_st_error("Allocate pool failed\n"); return ret;
