[U-Boot] [PATCH] patman: Use Patch-cc: instead of Cc:
Add a new Patch-cc: tag which performs the service now provided by the Cc: tag. The Cc: tag is interpreted by git send-email but ignored by patman.
So now:
Cc: patman does nothing. (git send-email can cc patches) Patch-cc: patman Cc's patch and removes this tag from the patch
tools/patman/README | 21 ++++++++++++--------- tools/patman/patchstream.py | 4 ++-- 2 files changed, 14 insertions(+), 11 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 59f1776..b3aba13 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -217,8 +217,10 @@ Series-changes: n to update the log there and then, knowing that the script will do the rest.
- Cc: Their Name <email> - This copies a single patch to another email address. +Patch-cc: Their Name <email> + This copies a single patch to another email address. Note that the + Cc: used by git send-email is ignored by patman, but will be + interpreted by git send-email if you use it.
Series-process-log: sort, uniq This tells patman to sort and/or uniq the change logs. It is @@ -246,8 +248,9 @@ Where Patches Are Sent
Once the patches are created, patman sends them using git send-email. The whole series is sent to the recipients in Series-to: and Series-cc. -You can Cc individual patches to other people with the Cc: tag. Tags in the -subject are also picked up to Cc patches. For example, a commit like this: +You can Cc individual patches to other people with the Patch-cc: tag. Tags +in the subject are also picked up to Cc patches. For example, a commit like +this:
commit 10212537b85ff9b6e09c82045127522c0f0db981 @@ -258,16 +261,16 @@ Date: Mon Nov 7 23:18:44 2011 -0500
This should make sending out e-mails to the right people easier.
- Cc: sandbox, mikef, ag - Cc: afleming + Patch-cc: sandbox, mikef, ag + Patch-cc: afleming <<<<
will create a patch which is copied to x86, arm, sandbox, mikef, ag and afleming.
-If you have a cover letter it will get sent to the union of the CC lists of -all of the other patches. If you want to sent it to additional people you -can add a tag: +If you have a cover letter it will get sent to the union of the Patch-cc +lists of all of the other patches. If you want to sent it to additional +people you can add a tag:
Cover-letter-cc: <list of addresses>
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 684204c..c4017e0 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -36,7 +36,7 @@ re_series_tag = re.compile('^Series-([a-z-]*): *(.*)') re_commit_tag = re.compile('^Commit-([a-z-]*): *(.*)')
# Commit tags that we want to collect and keep -re_tag = re.compile('^(Tested-by|Acked-by|Reviewed-by|Cc): (.*)') +re_tag = re.compile('^(Tested-by|Acked-by|Reviewed-by|Patch-cc): (.*)')
# The start of a new commit in the git log re_commit = re.compile('^commit ([0-9a-f]*)$') @@ -267,7 +267,7 @@ class PatchStream: if (tag_match.group(1) == 'Tested-by' and tag_match.group(2).find(os.getenv('USER') + '@') != -1): self.warn.append("Ignoring %s" % line) - elif tag_match.group(1) == 'Cc': + elif tag_match.group(1) == 'Patch-cc': self.commit.AddCc(tag_match.group(2).split(',')) else: self.tags.append(line);
Hello Simon,
So now:
This patch is really helpful and I wish it will be merged to the code base. Thanks!
Best Regards Masahiro Yamada
Masahiro Yamada
