[U-Boot] [PATCH 00/14] dm: Fix various issues reported by coverity
A lot of issues have been found in the error handling with recent additions to the FIT handling code in mkimage. In some cases buffers are not freed or files are not closed. Fix these problems and a few others in existing code that coverity noticed due to recent patches.
Simon Glass (14): mkimage: Fix munmap() call when importing data mkimage: Correct file being closed twice in fit_import_data() mkimage: Correct file being closed twice in fit_extract_data() part_iso: Drop the customer unaligned access functions part_efi: Drop the NULL check on dev_desc in part_print_efi() part_efi: Drop NULL check in part_get_info_efi() mkimage: Close the file when unable to get its size mkimage: Add a missing free() to fit_import_data() mkimage: Fix error path in fit_extract_data() mkimage: Fix missing free() in fit_extract_data() mkimage: Fix missing free() and close() in fit_build() mkimage: Ensure file is closed in fdt_property_file() mkimage: Don't close the file if it wasn't opened usb: Correct return value in usb_stor_info()
common/usb_storage.c | 2 +- disk/part_efi.c | 6 +----- disk/part_iso.c | 27 ++++----------------------- tools/fit_image.c | 28 ++++++++++++++++++---------- tools/imagetool.c | 1 + 5 files changed, 25 insertions(+), 39 deletions(-)
The munmap() call unmaps the wrong memory buffer. Fix it.
Reported-by: Coverity (CID: 138505) Reported-by: Coverity (CID: 138495) Signed-off-by: Simon Glass sjg@chromium.org ---
tools/fit_image.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 3ecc88f..2c8d92f 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -517,7 +517,7 @@ static int fit_import_data(struct image_tool_params *params, const char *fname) } }
- munmap(fdt, sbuf.st_size); + munmap(old_fdt, sbuf.st_size); close(fd);
/* Pack the FDT and place the data after it */
Reported-by: Coverity (CID: 138505) Reported-by: Coverity (CID: 138495) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
The code flows through to the end of the function, so we don't need another close() before this. Remove it.
Reported-by: Coverity (CID: 138504)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 2c8d92f..31aa43c 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -530,6 +530,7 @@ static int fit_import_data(struct image_tool_params *params, const char *fname) if (fd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", params->cmdname, fname, strerror(errno)); + ret = -EIO; goto err; } if (write(fd, fdt, new_size) != new_size) { @@ -538,7 +539,6 @@ static int fit_import_data(struct image_tool_params *params, const char *fname) ret = -EIO; goto err; } - close(fd);
ret = 0;
Reported-by: Coverity (CID: 138503)
tools/fit_image.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 31aa43c..8a93ea3 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -446,8 +446,6 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) ret = -EIO; goto err; } - close(fd); - ret = 0;
err:
One of these is causing a coverity warning. Drop these functions and use the standard U-Boot ones instead.
Reported-by: Coverity (CID: 138499)
disk/part_iso.c | 27 ++++----------------------- 1 file changed, 4 insertions(+), 23 deletions(-)
diff --git a/disk/part_iso.c b/disk/part_iso.c index b83983b..2114faf 100644 --- a/disk/part_iso.c +++ b/disk/part_iso.c @@ -7,6 +7,7 @@
#include <common.h> #include <command.h> +#include <asm/unaligned.h> #include "part_iso.h"
#ifdef HAVE_BLOCK_DEVICE @@ -25,26 +26,6 @@
static unsigned char tmpbuf[CD_SECTSIZE];
-/* Convert char[4] in little endian format to the host format integer - */ -static inline unsigned long le32_to_int(unsigned char *le32) -{ - return ((le32[3] << 24) + - (le32[2] << 16) + - (le32[1] << 8) + - le32[0] - ); -} -/* Convert char[2] in little endian format to the host format integer - */ -static inline unsigned short le16_to_int(unsigned char *le16) -{ - return ((le16[1] << 8) + - le16[0] - ); -} - - /* only boot records will be listed as valid partitions */ int part_get_info_iso_verb(struct blk_desc *dev_desc, int part_num, disk_partition_t *info, int verb) @@ -103,7 +84,7 @@ int part_get_info_iso_verb(struct blk_desc *dev_desc, int part_num, pbr->ident_str, dev_desc->devnum, part_num); return (-1); } - bootaddr=le32_to_int(pbr->pointer); + bootaddr = get_unaligned_le32(pbr->pointer); PRINTF(" Boot Entry at: %08lX\n",bootaddr); if (blk_dread(dev_desc, bootaddr, 1, (ulong *)tmpbuf) != 1) { if(verb) @@ -203,7 +184,7 @@ found: } switch(pide->boot_media) { case 0x00: /* no emulation */ - info->size=le16_to_int(pide->sec_cnt)>>2; + info->size = get_unaligned_le16(pide->sec_cnt)>>2; break; case 0x01: info->size=2400>>2; break; /* 1.2MByte Floppy */ case 0x02: info->size=2880>>2; break; /* 1.44MByte Floppy */ @@ -211,7 +192,7 @@ found: case 0x04: info->size=2880>>2; break; /* dummy (HD Emulation) */ default: info->size=0; break; } - newblkaddr=le32_to_int(pide->rel_block_addr); + newblkaddr = get_unaligned_le32(pide->rel_block_addr); info->start=newblkaddr; PRINTF(" part %d found @ %lx size %lx\n",part_num,newblkaddr,info->size); return 0;
... but the subject says customer not custom.
This cannot be NULL since part_print() calls this function and requires it to be non-NULL.
Reported-by: Coverity (CID: 138498) Signed-off-by: Simon Glass sjg@chromium.org ---
disk/part_efi.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index 77bdfcb..93a7e81 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -184,10 +184,6 @@ void part_print_efi(struct blk_desc *dev_desc) char uuid[37]; unsigned char *uuid_bin;
- if (!dev_desc) { - printf("%s: Invalid Argument(s)\n", __func__); - return; - } /* This function validates AND fills in the GPT header and PTE */ if (is_gpt_valid(dev_desc, GPT_PRIMARY_PARTITION_TABLE_LBA, gpt_head, &gpt_pte) != 1) {
Reported-by: Coverity (CID: 138498) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
This cannot be NULL since part_get_info() calls this function and requires it to be non-NULL.
Reported-by: Coverity (CID: 138497)
disk/part_efi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index 93a7e81..fe308d7 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -240,7 +240,7 @@ int part_get_info_efi(struct blk_desc *dev_desc, int part, gpt_entry *gpt_pte = NULL;
/* "part" argument must be at least 1 */ - if (!dev_desc || !info || part < 1) { + if (part < 1) { printf("%s: Invalid Argument(s)\n", __func__); return -1; }
There is a missing close() on the error path. Add it.
Reported-by: Coverity (CID: 138496) Signed-off-by: Simon Glass sjg@chromium.org ---
tools/imagetool.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/imagetool.c b/tools/imagetool.c index 351211c..916ab96 100644 --- a/tools/imagetool.c +++ b/tools/imagetool.c @@ -107,6 +107,7 @@ int imagetool_get_filesize(struct image_tool_params *params, const char *fname) if (fstat(fd, &sbuf) < 0) { fprintf(stderr, "%s: Can't stat %s: %s\n", params->cmdname, fname, strerror(errno)); + close(fd); return -1; } close(fd);
Reported-by: Coverity (CID: 138496) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
The space allocated to fdt is not freed on error. Fix it.
Reported-by: Coverity (CID: 138494)
tools/fit_image.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 8a93ea3..8d58370 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -541,6 +541,7 @@ static int fit_import_data(struct image_tool_params *params, const char *fname) ret = 0;
err: + free(fdt); close(fd); return ret; }
The 'fdt' variable is not unmapped in all error cases. Fix this.
Reported-by: Coverity (CID: 138493)
tools/fit_image.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 8d58370..bfb43b2 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -385,7 +385,7 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) buf = malloc(fit_size); if (!buf) { ret = -ENOMEM; - goto err; + goto err_munmap; } buf_ptr = 0;
@@ -393,7 +393,7 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) if (images < 0) { debug("%s: Cannot find /images node: %d\n", __func__, images); ret = -EINVAL; - goto err; + goto err_munmap; }
for (node = fdt_first_subnode(fdt, images); @@ -411,7 +411,7 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) ret = fdt_delprop(fdt, node, "data"); if (ret) { ret = -EPERM; - goto err; + goto err_munmap; } fdt_setprop_u32(fdt, node, "data-offset", buf_ptr); fdt_setprop_u32(fdt, node, "data-size", len); @@ -446,8 +446,11 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) ret = -EIO; goto err; } - ret = 0; + close(fd); + return 0;
+err_munmap: + munmap(fdt, sbuf.st_size); err: close(fd); return ret;
The 'buf' variable is not freed. Fix it.
Reported-by: Coverity (CID: 138492) Signed-off-by: Simon Glass sjg@chromium.org ---
tools/fit_image.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/tools/fit_image.c b/tools/fit_image.c index bfb43b2..e628212 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -452,6 +452,8 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) err_munmap: munmap(fdt, sbuf.st_size); err: + if (buf) + free(buf); close(fd); return ret; }
Reported-by: Coverity (CID: 138492) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
Make sure that both the error path and normal return free the buffer and close the file.
Reported-by: Coverity (CID: 138491) Signed-off-by: Simon Glass sjg@chromium.org ---
tools/fit_image.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index e628212..9d553d1 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -329,7 +329,7 @@ static int fit_build(struct image_tool_params *params, const char *fname) if (ret < 0) { fprintf(stderr, "%s: Failed to build FIT image\n", params->cmdname); - goto err; + goto err_buf; } size = ret; fd = open(fname, O_RDWR | O_CREAT | O_TRUNC | O_BINARY, 0666); @@ -346,9 +346,12 @@ static int fit_build(struct image_tool_params *params, const char *fname) goto err; } close(fd); + free(buf);
return 0; err: + close(fd); +err_buf: free(buf); return -1; }
Reported-by: Coverity (CID: 138491) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
The file that is opened is not closed in all cases. Fix it.
Reported-by: Coverity (CID: 138490) Signed-off-by: Simon Glass sjg@chromium.org ---
tools/fit_image.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 9d553d1..6e5c143 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -123,13 +123,14 @@ static int fdt_property_file(struct image_tool_params *params,
ret = fdt_property_placeholder(fdt, "data", sbuf.st_size, &ptr); if (ret) - return ret; + goto err; ret = read(fd, ptr, sbuf.st_size); if (ret != sbuf.st_size) { fprintf(stderr, "%s: Can't read %s: %s\n", params->cmdname, fname, strerror(errno)); goto err; } + close(fd);
return 0; err:
Reported-by: Coverity (CID: 138490) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
The error path for fit_import_data() is incorrect if the second open() call fails.
Reported-by: Coverity (CID: 138489) Signed-off-by: Simon Glass sjg@chromium.org ---
tools/fit_image.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 6e5c143..ddefa72 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -537,8 +537,8 @@ static int fit_import_data(struct image_tool_params *params, const char *fname) if (fd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", params->cmdname, fname, strerror(errno)); - ret = -EIO; - goto err; + free(fdt); + return -EIO; } if (write(fd, fdt, new_size) != new_size) { debug("%s: Failed to write external data to file %s\n",
Reported-by: Coverity (CID: 138489) Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
This should return 0 on success, not 1. Fix it.
common/usb_storage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index 1472824..18fdf73 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -193,7 +193,7 @@ int usb_stor_info(void) return 1; }
- return 1; + return 0; }
static unsigned int usb_get_max_lun(struct us_data *us)
Yikes. Thanks for finding this.
Acked-by: Marek Vasut marex@denx.de
- return 1;
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Marek Vasut marex@denx.de Reviewed-by: Tom Rini trini@konsulko.com
