[PATCH v2] lwip: wget: pass port and server_name via wget_ctx
Commit 5907c81 ("net: lwip: Enable https:// support for wget") was not correctly rebased on top of the changes introduced by Commit 6cc4d04 ("net/lwip: wget: put server_name and port into wget_ctx") in next. This commit re-applies a couple of lines from 6cc4d04.
Fixes: Commit 5907c81 ("net: lwip: Enable https:// support for wget") Signed-off-by: Adriano Cordova adrianox@gmail.com Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes in v2: changed commit name net/lwip/wget.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/net/lwip/wget.c b/net/lwip/wget.c index af48d741a4..8b3e5cf29b 100644 --- a/net/lwip/wget.c +++ b/net/lwip/wget.c @@ -288,7 +288,6 @@ static err_t httpc_headers_done_cb(httpc_state_t *connection, void *arg, struct
static int wget_loop(struct udevice *udev, ulong dst_addr, char *uri) { - char server_name[SERVER_NAME_SIZE]; #if defined CONFIG_WGET_HTTPS altcp_allocator_t tls_allocator; #endif @@ -297,7 +296,6 @@ static int wget_loop(struct udevice *udev, ulong dst_addr, char *uri) struct netif *netif; struct wget_ctx ctx; char *path; - u16 port; bool is_https;
ctx.daddr = dst_addr; @@ -307,7 +305,7 @@ static int wget_loop(struct udevice *udev, ulong dst_addr, char *uri) ctx.prevsize = 0; ctx.start_time = 0;
- if (parse_url(uri, server_name, &port, &path, &is_https)) + if (parse_url(uri, ctx.server_name, &ctx.port, &path, &is_https)) return CMD_RET_USAGE;
netif = net_lwip_new_netif(udev);
Reviewed-by: Jerome Forissier jerome.forissier@linaro.org
Thanks,
Adriano Cordova
Jerome Forissier
