[U-Boot] [PATCH] at91: Introduction of at91sam9g45 SOC.
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals.
The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons.
Signed-off-by: Sedji Gaouaou sedji.gaouaou@atmel.com --- MAINTAINERS | 3 + MAKEALL | 37 ++-- Makefile | 25 ++ board/atmel/at91sam9m10g45ek/Makefile | 55 ++++ board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 334 +++++++++++++++++++++++ board/atmel/at91sam9m10g45ek/config.mk | 1 + board/atmel/at91sam9m10g45ek/led.c | 41 +++ cpu/arm926ejs/at91/Makefile | 2 + cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 175 ++++++++++++ cpu/arm926ejs/at91/clock.c | 12 +- doc/README.at91 | 20 ++ drivers/net/macb.c | 6 +- include/asm-arm/arch-at91/at91_pmc.h | 1 + include/asm-arm/arch-at91/at91sam9_matrix.h | 2 + include/asm-arm/arch-at91/at91sam9g45.h | 139 ++++++++++ include/asm-arm/arch-at91/at91sam9g45_matrix.h | 153 +++++++++++ include/asm-arm/arch-at91/clk.h | 5 + include/asm-arm/arch-at91/hardware.h | 6 + include/asm-arm/arch-at91/memory-map.h | 1 + include/configs/at91sam9m10g45ek.h | 225 +++++++++++++++ 20 files changed, 1221 insertions(+), 22 deletions(-) create mode 100644 board/atmel/at91sam9m10g45ek/Makefile create mode 100644 board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c create mode 100644 board/atmel/at91sam9m10g45ek/config.mk create mode 100644 board/atmel/at91sam9m10g45ek/led.c create mode 100644 cpu/arm926ejs/at91/at91sam9m10g45_devices.c create mode 100644 include/asm-arm/arch-at91/at91sam9g45.h create mode 100644 include/asm-arm/arch-at91/at91sam9g45_matrix.h create mode 100644 include/configs/at91sam9m10g45ek.h
diff --git a/MAINTAINERS b/MAINTAINERS index c874a67..41a0ac5 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -543,6 +543,9 @@ Daniel Gorsulowski daniel.gorsulowski@esd.eu
meesc ARM926EJS (AT91SAM9263 SoC)
+Sedji Gaouaousedji.gaouaou@atmel.com + at91sam9m10g45ek ARM926EJS (AT91SAM9G45 SoC) + Marius Gröger mag@sysgo.de
impa7 ARM720T (EP7211) diff --git a/MAKEALL b/MAKEALL index a935211..563e871 100755 --- a/MAKEALL +++ b/MAKEALL @@ -571,24 +571,25 @@ LIST_ARM_CORTEX_A8=" \ ## AT91 Systems #########################################################################
-LIST_at91=" \ - afeb9260 \ - at91cap9adk \ - at91rm9200dk \ - at91rm9200ek \ - at91sam9260ek \ - at91sam9261ek \ - at91sam9263ek \ - at91sam9g20ek \ - at91sam9rlek \ - cmc_pu2 \ - csb637 \ - kb9202 \ - meesc \ - mp2usb \ - m501sk \ - pm9261 \ - pm9263 \ +LIST_at91=" \ + afeb9260 \ + at91cap9adk \ + at91rm9200dk \ + at91rm9200ek \ + at91sam9260ek \ + at91sam9261ek \ + at91sam9263ek \ + at91sam9m10g45ek \ + at91sam9g20ek \ + at91sam9rlek \ + cmc_pu2 \ + csb637 \ + kb9202 \ + meesc \ + mp2usb \ + m501sk \ + pm9261 \ + pm9263 \ "
######################################################################### diff --git a/Makefile b/Makefile index e89c592..2f1df61 100644 --- a/Makefile +++ b/Makefile @@ -2775,6 +2775,31 @@ meesc_config : unconfig pm9261_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9261 ronetix at91
+at91sam9m10g45ek_nandflash_config \ +at91sam9m10g45ek_dataflash_config \ +at91sam9m10g45ek_dataflash_cs0_config \ +at91sam9m10g45ek_config \ +at91sam9g45ekes_nandflash_config \ +at91sam9g45ekes_dataflash_config \ +at91sam9g45ekes_dataflash_cs0_config \ +at91sam9g45ekes_config : unconfig + @mkdir -p $(obj)include + @if [ "$(findstring 9m10,$@)" ] ; then \ + echo "#define CONFIG_AT91SAM9M10G45EK 1" >>$(obj)include/config.h ; \ + $(XECHO) "... 9M10G45 Variant" ; \ + else \ + echo "#define CONFIG_AT91SAM9G45EKES 1" >>$(obj)include/config.h ; \ + fi; + + @if [ "$(findstring _nandflash,$@)" ] ; then \ + echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in NAND FLASH" ; \ + else \ + echo "#define CONFIG_ATMEL_SPI 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in SPI DATAFLASH CS0" ; \ + fi; + @$(MKCONFIG) -a at91sam9m10g45ek arm arm926ejs at91sam9m10g45ek atmel at91 + pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
diff --git a/board/atmel/at91sam9m10g45ek/Makefile b/board/atmel/at91sam9m10g45ek/Makefile new file mode 100644 index 0000000..4caf1e4 --- /dev/null +++ b/board/atmel/at91sam9m10g45ek/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += at91sam9m10g45ek.o +COBJS-y += led.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c new file mode 100644 index 0000000..ebac956 --- /dev/null +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -0,0 +1,334 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9g45.h> +#include <asm/arch/at91sam9_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#include <lcd.h> +#include <atmel_lcdc.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void at91sam9m10g45ek_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(2)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(4)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(3)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void at91sam9m10g45ek_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PA15) => PHY normal mode (not Test mode) + * ERX0 (PA12) => PHY ADDR0 + * ERX1 (PA13) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA12) | + pin_to_mask(AT91_PIN_PA13), + pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR); + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0D << 8)) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA12) | + pin_to_mask(AT91_PIN_PA13), + pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +#ifdef CONFIG_LCD + +vidinfo_t panel_info = { + vl_col: 480, + vl_row: 272, + vl_clk: 9000000, + vl_sync: ATMEL_LCDC_INVLINE_NORMAL | + ATMEL_LCDC_INVFRAME_NORMAL, + vl_bpix: 3, + vl_tft: 1, + vl_hsync_len: 45, + vl_left_margin: 1, + vl_right_margin:1, + vl_vsync_len: 1, + vl_upper_margin:40, + vl_lower_margin:1, + mmio: AT91SAM9G45_LCDC_BASE, +}; + + +void lcd_enable(void) +{ + at91_set_A_periph(AT91_PIN_PE6, 1); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_A_periph(AT91_PIN_PE6, 0); /* power down */ +} + +static void at91sam9m10g45ek_lcd_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PE0, 0); /* LCDDPWR */ + at91_set_A_periph(AT91_PIN_PE2, 0); /* LCDCC */ + at91_set_A_periph(AT91_PIN_PE3, 0); /* LCDVSYNC */ + at91_set_A_periph(AT91_PIN_PE4, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PE5, 0); /* LCDDOTCK */ + + at91_set_A_periph(AT91_PIN_PE7, 0); /* LCDD0 */ + at91_set_A_periph(AT91_PIN_PE8, 0); /* LCDD1 */ + at91_set_A_periph(AT91_PIN_PE9, 0); /* LCDD2 */ + at91_set_A_periph(AT91_PIN_PE10, 0); /* LCDD3 */ + at91_set_A_periph(AT91_PIN_PE11, 0); /* LCDD4 */ + at91_set_A_periph(AT91_PIN_PE12, 0); /* LCDD5 */ + at91_set_A_periph(AT91_PIN_PE13, 0); /* LCDD6 */ + at91_set_A_periph(AT91_PIN_PE14, 0); /* LCDD7 */ + at91_set_A_periph(AT91_PIN_PE15, 0); /* LCDD8 */ + at91_set_A_periph(AT91_PIN_PE16, 0); /* LCDD9 */ + at91_set_A_periph(AT91_PIN_PE17, 0); /* LCDD10 */ + at91_set_A_periph(AT91_PIN_PE18, 0); /* LCDD11 */ + at91_set_A_periph(AT91_PIN_PE19, 0); /* LCDD12 */ + at91_set_B_periph(AT91_PIN_PE20, 0); /* LCDD13 */ + at91_set_A_periph(AT91_PIN_PE21, 0); /* LCDD14 */ + at91_set_A_periph(AT91_PIN_PE22, 0); /* LCDD15 */ + at91_set_A_periph(AT91_PIN_PE23, 0); /* LCDD16 */ + at91_set_A_periph(AT91_PIN_PE24, 0); /* LCDD17 */ + at91_set_A_periph(AT91_PIN_PE25, 0); /* LCDD18 */ + at91_set_A_periph(AT91_PIN_PE26, 0); /* LCDD19 */ + at91_set_A_periph(AT91_PIN_PE27, 0); /* LCDD20 */ + at91_set_B_periph(AT91_PIN_PE28, 0); /* LCDD21 */ + at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ + at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */ + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_LCDC); + + gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; +} + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf ("%s\n", U_BOOT_VERSION); + lcd_printf ("(C) 2008 ATMEL Corp\n"); + lcd_printf ("at91support@atmel.com\n"); + lcd_printf ("%s CPU at %s MHz\n", + AT91_CPU_NAME, + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20 ); +} +#endif /* CONFIG_LCD_INFO */ +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of AT91SAM9M10G45EK-Board */ +#ifdef CONFIG_AT91SAM9M10G45EK + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9M10G45EK; +#elif defined CONFIG_AT91SAM9G45EKES + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G45EKES; +#endif + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9m10g45ek_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_ATMEL_SPI + at91_spi0_hw_init(1 << 4); +#endif + +#ifdef CONFIG_MACB + at91sam9m10g45ek_macb_hw_init(); +#endif + +#ifdef CONFIG_LCD + at91sam9m10g45ek_lcd_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9G45_BASE_EMAC, 0x00); +#endif + return rc; +} + +/* SPI chip select control */ +#ifdef CONFIG_ATMEL_SPI +#include <spi.h> + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs < 2; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + switch(slave->cs) { + case 1: + at91_set_gpio_output(AT91_PIN_PB18, 0); + break; + case 0: + default: + at91_set_gpio_output(AT91_PIN_PB3, 0); + break; + } +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + switch(slave->cs) { + case 1: + at91_set_gpio_output(AT91_PIN_PB18, 1); + break; + case 0: + default: + at91_set_gpio_output(AT91_PIN_PB3, 1); + break; + } +} +#endif /* CONFIG_ATMEL_SPI */ diff --git a/board/atmel/at91sam9m10g45ek/config.mk b/board/atmel/at91sam9m10g45ek/config.mk new file mode 100644 index 0000000..7fe9d03 --- /dev/null +++ b/board/atmel/at91sam9m10g45ek/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x73f00000 diff --git a/board/atmel/at91sam9m10g45ek/led.c b/board/atmel/at91sam9m10g45ek/led.c new file mode 100644 index 0000000..ff59a2d --- /dev/null +++ b/board/atmel/at91sam9m10g45ek/led.c @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9g45.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIODE); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); +} diff --git a/cpu/arm926ejs/at91/Makefile b/cpu/arm926ejs/at91/Makefile index 3da89f4..69051c1 100644 --- a/cpu/arm926ejs/at91/Makefile +++ b/cpu/arm926ejs/at91/Makefile @@ -31,6 +31,8 @@ COBJS-$(CONFIG_AT91SAM9G20) += at91sam9260_devices.o COBJS-$(CONFIG_AT91SAM9261) += at91sam9261_devices.o COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o +COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o +COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o COBJS-$(CONFIG_AT91_LED) += led.o COBJS-y += clock.o COBJS-y += cpu.o diff --git a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c new file mode 100644 index 0000000..98d90f2 --- /dev/null +++ b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -0,0 +1,175 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void at91_serial0_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PB19, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PB18, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US0); +} + +void at91_serial1_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US1); +} + +void at91_serial2_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PD6, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD7, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US2); +} + +void at91_serial3_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PB12, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PB13, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS);; +} + +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_serial0_hw_init(); +#endif + +#ifdef CONFIG_USART1 + at91_serial1_hw_init(); +#endif + +#ifdef CONFIG_USART2 + at91_serial2_hw_init(); +#endif + +#ifdef CONFIG_USART3 /* DBGU */ + at91_serial3_hw_init(); +#endif +} + +#ifdef CONFIG_ATMEL_SPI +void at91_spi0_hw_init(unsigned long cs_mask) +{ + at91_set_A_periph(AT91_PIN_PB0, 0); /* SPI0_MISO */ + at91_set_A_periph(AT91_PIN_PB1, 0); /* SPI0_MOSI */ + at91_set_A_periph(AT91_PIN_PB2, 0); /* SPI0_SPCK */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_SPI0); + + if (cs_mask & (1 << 0)) { + at91_set_A_periph(AT91_PIN_PB3, 0); + } + if (cs_mask & (1 << 1)) { + at91_set_B_periph(AT91_PIN_PB18, 0); + } + if (cs_mask & (1 << 2)) { + at91_set_B_periph(AT91_PIN_PB19, 0); + } + if (cs_mask & (1 << 3)) { + at91_set_B_periph(AT91_PIN_PD27, 0); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PB3, 0); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PB18, 0); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PB19, 0); + } + if (cs_mask & (1 << 7)) { + at91_set_gpio_output(AT91_PIN_PD27, 0); + } +} + +void at91_spi1_hw_init(unsigned long cs_mask) +{ + at91_set_A_periph(AT91_PIN_PB14, 0); /* SPI1_MISO */ + at91_set_A_periph(AT91_PIN_PB15, 0); /* SPI1_MOSI */ + at91_set_A_periph(AT91_PIN_PB16, 0); /* SPI1_SPCK */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_SPI1); + + if (cs_mask & (1 << 0)) { + at91_set_A_periph(AT91_PIN_PB17, 0); + } + if (cs_mask & (1 << 1)) { + at91_set_B_periph(AT91_PIN_PD28, 0); + } + if (cs_mask & (1 << 2)) { + at91_set_A_periph(AT91_PIN_PD18, 0); + } + if (cs_mask & (1 << 3)) { + at91_set_A_periph(AT91_PIN_PD19, 0); + } + if (cs_mask & (1 << 4)) { + at91_set_gpio_output(AT91_PIN_PB17, 0); + } + if (cs_mask & (1 << 5)) { + at91_set_gpio_output(AT91_PIN_PD28, 0); + } + if (cs_mask & (1 << 6)) { + at91_set_gpio_output(AT91_PIN_PD18, 0); + } + if (cs_mask & (1 << 7)) { + at91_set_gpio_output(AT91_PIN_PD19, 0); + } + +} +#endif + +#ifdef CONFIG_MACB +void at91_macb_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PA17, 0); /* ETXCK_EREFCK */ + at91_set_A_periph(AT91_PIN_PA15, 0); /* ERXDV */ + at91_set_A_periph(AT91_PIN_PA12, 0); /* ERX0 */ + at91_set_A_periph(AT91_PIN_PA13, 0); /* ERX1 */ + at91_set_A_periph(AT91_PIN_PA16, 0); /* ERXER */ + at91_set_A_periph(AT91_PIN_PA14, 0); /* ETXEN */ + at91_set_A_periph(AT91_PIN_PA10, 0); /* ETX0 */ + at91_set_A_periph(AT91_PIN_PA11, 0); /* ETX1 */ + at91_set_A_periph(AT91_PIN_PA19, 0); /* EMDIO */ + at91_set_A_periph(AT91_PIN_PA18, 0); /* EMDC */ +#ifndef CONFIG_RMII + at91_set_B_periph(AT91_PIN_PA29, 0); /* ECRS */ + at91_set_B_periph(AT91_PIN_PA30, 0); /* ECOL */ + at91_set_B_periph(AT91_PIN_PA8, 0); /* ERX2 */ + at91_set_B_periph(AT91_PIN_PA9, 0); /* ERX3 */ + at91_set_B_periph(AT91_PIN_PA28, 0); /* ERXCK */ + at91_set_B_periph(AT91_PIN_PA6, 0); /* ETX2 */ + at91_set_B_periph(AT91_PIN_PA7, 0); /* ETX3 */ + at91_set_B_periph(AT91_PIN_PA27, 0); /* ETXER */ +#endif +} +#endif diff --git a/cpu/arm926ejs/at91/clock.c b/cpu/arm926ejs/at91/clock.c index 9f03468..574f488 100644 --- a/cpu/arm926ejs/at91/clock.c +++ b/cpu/arm926ejs/at91/clock.c @@ -183,15 +183,23 @@ int at91_clock_init(unsigned long main_clock) * For now, assume this parentage won't change. */ mckr = at91_sys_read(AT91_PMC_MCKR); +#if defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) + /* plla divisor by 2 */ + plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12)); +#endif freq = mck_rate_hz = at91_css_to_rate(mckr & AT91_PMC_CSS); + freq /= (1 << ((mckr & AT91_PMC_PRES) >> 2)); /* prescale */ #if defined(CONFIG_AT91RM9200) mck_rate_hz = freq / (1 + ((mckr & AT91_PMC_MDIV) >> 8)); /* mdiv */ #elif defined(CONFIG_AT91SAM9G20) mck_rate_hz = (mckr & AT91_PMC_MDIV) ? - freq / ((mckr & AT91_PMC_MDIV) >> 7) : freq; /* mdiv ; (x >> 7) = ((x >> 8) * 2) */ + freq / ((mckr & AT91_PMC_MDIV) >> 7) : freq; /* mdiv ; (x >> 7) = ((x >> 8) * 2) */ if (mckr & AT91_PMC_PDIV) - freq /= 2; /* processor clock division */ + freq /= 2; /* processor clock division */ +#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) + mck_rate_hz = (mckr & AT91_PMC_MDIV) == AT91SAM9_PMC_MDIV_3 ? + freq / 3 : freq / (1 << ((mckr & AT91_PMC_MDIV) >> 8)); /* mdiv */ #else mck_rate_hz = freq / (1 << ((mckr & AT91_PMC_MDIV) >> 8)); /* mdiv */ #endif diff --git a/doc/README.at91 b/doc/README.at91 index 4a2c56b..269d072 100644 --- a/doc/README.at91 +++ b/doc/README.at91 @@ -75,6 +75,26 @@ Environment variables
------------------------------------------------------------------------------ +AT91SAM9M10G45EK +------------------------------------------------------------------------------ + +Memory map + 0x20000000 - 23FFFFFF SDRAM (64 MB) + 0xC0000000 - Cxxxxxxx Atmel Dataflash card (J12) + +Environment variables + + U-Boot environment variables can be stored at different places: + - Dataflash on SPI chip select 0 (dataflash card) + - Nand flash. + + You can choose your storage location at config step (here for at91sam9m10g45ek) : + make at91sam9m10g45ek_config - use data flash (spi cs0) (default) + make at91sam9m10g45ek_nandflash_config - use nand flash + make at91sam9m10g45ek_dataflash_cs0_config - use data flash (spi cs0) + + +------------------------------------------------------------------------------ AT91SAM9RLEK ------------------------------------------------------------------------------
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 6de0a04..c184353 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -447,14 +447,16 @@ static int macb_init(struct eth_device *netdev, bd_t *bd) /* choose RMII or MII mode. This depends on the board */ #ifdef CONFIG_RMII #if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) + defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ + defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) macb_writel(macb, USRIO, MACB_BIT(RMII) | MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, 0); #endif #else #if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) + defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ + defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) macb_writel(macb, USRIO, MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, MACB_BIT(MII)); diff --git a/include/asm-arm/arch-at91/at91_pmc.h b/include/asm-arm/arch-at91/at91_pmc.h index a82955c..9fe94c7 100644 --- a/include/asm-arm/arch-at91/at91_pmc.h +++ b/include/asm-arm/arch-at91/at91_pmc.h @@ -89,6 +89,7 @@ #define AT91SAM9_PMC_MDIV_1 (0 << 8) /* [SAM9,CAP9 only] */ #define AT91SAM9_PMC_MDIV_2 (1 << 8) #define AT91SAM9_PMC_MDIV_4 (2 << 8) +#define AT91SAM9_PMC_MDIV_3 (3 << 8) /* [some SAM9 only] */ #define AT91SAM9_PMC_MDIV_6 (3 << 8) #define AT91_PMC_PDIV (1 << 12) /* Processor Clock Division [some SAM9 only] */ #define AT91_PMC_PDIV_1 (0 << 12) diff --git a/include/asm-arm/arch-at91/at91sam9_matrix.h b/include/asm-arm/arch-at91/at91sam9_matrix.h index 913f374..6d97189 100644 --- a/include/asm-arm/arch-at91/at91sam9_matrix.h +++ b/include/asm-arm/arch-at91/at91sam9_matrix.h @@ -21,6 +21,8 @@ #include <asm/arch/at91sam9rl_matrix.h> #elif defined(CONFIG_AT91CAP9) #include <asm/arch/at91cap9_matrix.h> +#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) +#include <asm/arch/at91sam9g45_matrix.h> #else #error "Unsupported AT91SAM9/CAP9 processor" #endif diff --git a/include/asm-arm/arch-at91/at91sam9g45.h b/include/asm-arm/arch-at91/at91sam9g45.h new file mode 100644 index 0000000..0feed9c --- /dev/null +++ b/include/asm-arm/arch-at91/at91sam9g45.h @@ -0,0 +1,139 @@ +/* + * Chip-specific header file for the AT91SAM9M1x family + * + * Copyright (C) 2008 Atmel Corporation. + * + * Common definitions. + * Based on AT91SAM9G45 preliminary datasheet. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9G45_H +#define AT91SAM9G45_H + +/* + * Peripheral identifiers/interrupts. + */ +#define AT91_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define AT91_ID_SYS 1 /* System Controller Interrupt */ +#define AT91SAM9G45_ID_PIOA 2 /* Parallel I/O Controller A */ +#define AT91SAM9G45_ID_PIOB 3 /* Parallel I/O Controller B */ +#define AT91SAM9G45_ID_PIOC 4 /* Parallel I/O Controller C */ +#define AT91SAM9G45_ID_PIODE 5 /* Parallel I/O Controller D and E */ +#define AT91SAM9G45_ID_TRNG 6 /* True Random Number Generator */ +#define AT91SAM9G45_ID_US0 7 /* USART 0 */ +#define AT91SAM9G45_ID_US1 8 /* USART 1 */ +#define AT91SAM9G45_ID_US2 9 /* USART 2 */ +#define AT91SAM9G45_ID_US3 10 /* USART 3 */ +#define AT91SAM9G45_ID_MCI0 11 /* High Speed Multimedia Card Interface 0 */ +#define AT91SAM9G45_ID_TWI0 12 /* Two-Wire Interface 0 */ +#define AT91SAM9G45_ID_TWI1 13 /* Two-Wire Interface 1 */ +#define AT91SAM9G45_ID_SPI0 14 /* Serial Peripheral Interface 0 */ +#define AT91SAM9G45_ID_SPI1 15 /* Serial Peripheral Interface 1 */ +#define AT91SAM9G45_ID_SSC0 16 /* Synchronous Serial Controller 0 */ +#define AT91SAM9G45_ID_SSC1 17 /* Synchronous Serial Controller 1 */ +#define AT91SAM9G45_ID_TCB 18 /* Timer Counter 0, 1, 2, 3, 4 and 5 */ +#define AT91SAM9G45_ID_PWMC 19 /* Pulse Width Modulation Controller */ +#define AT91SAM9G45_ID_TSC 20 /* Touch Screen ADC Controller */ +#define AT91SAM9G45_ID_DMA 21 /* DMA Controller */ +#define AT91SAM9G45_ID_UHPHS 22 /* USB Host High Speed */ +#define AT91SAM9G45_ID_LCDC 23 /* LCD Controller */ +#define AT91SAM9G45_ID_AC97C 24 /* AC97 Controller */ +#define AT91SAM9G45_ID_EMAC 25 /* Ethernet MAC */ +#define AT91SAM9G45_ID_ISI 26 /* Image Sensor Interface */ +#define AT91SAM9G45_ID_UDPHS 27 /* USB Device High Speed */ +#define AT91SAM9G45_ID_AESTDESSHA 28 /* AES + T-DES + SHA */ +#define AT91SAM9G45_ID_MCI1 29 /* High Speed Multimedia Card Interface 1 */ +#define AT91SAM9G45_ID_VDEC 30 /* Video Decoder */ +#define AT91SAM9G45_ID_IRQ0 31 /* Advanced Interrupt Controller */ + +/* + * User Peripheral physical base addresses. + */ +#define AT91SAM9G45_BASE_UDPHS 0xfff78000 +#define AT91SAM9G45_BASE_TC0 0xfff7c000 +#define AT91SAM9G45_BASE_TC1 0xfff7c040 +#define AT91SAM9G45_BASE_TC2 0xfff7c080 +#define AT91SAM9G45_BASE_MCI0 0xfff80000 +#define AT91SAM9G45_BASE_TWI0 0xfff84000 +#define AT91SAM9G45_BASE_TWI1 0xfff88000 +#define AT91SAM9G45_BASE_US0 0xfff8c000 +#define AT91SAM9G45_BASE_US1 0xfff90000 +#define AT91SAM9G45_BASE_US2 0xfff94000 +#define AT91SAM9G45_BASE_US3 0xfff98000 +#define AT91SAM9G45_BASE_SSC0 0xfff9c000 +#define AT91SAM9G45_BASE_SSC1 0xfffa0000 +#define AT91SAM9G45_BASE_SPI0 0xfffa4000 +#define AT91SAM9G45_BASE_SPI1 0xfffa8000 +#define AT91SAM9G45_BASE_AC97C 0xfffac000 +#define AT91SAM9G45_BASE_TSC 0xfffb0000 +#define AT91SAM9G45_BASE_ISI 0xfffb4000 +#define AT91SAM9G45_BASE_PWMC 0xfffb8000 +#define AT91SAM9G45_BASE_EMAC 0xfffbc000 +#define AT91SAM9G45_BASE_AES 0xfffc0000 +#define AT91SAM9G45_BASE_TDES 0xfffc4000 +#define AT91SAM9G45_BASE_SHA 0xfffc8000 +#define AT91SAM9G45_BASE_TRNG 0xfffcc000 +#define AT91SAM9G45_BASE_MCI1 0xfffd0000 +#define AT91SAM9G45_BASE_TC3 0xfffd4000 +#define AT91SAM9G45_BASE_TC4 0xfffd4040 +#define AT91SAM9G45_BASE_TC5 0xfffd4080 +#define AT91_BASE_SYS 0xffffe200 + +/* + * System Peripherals (offset from AT91_BASE_SYS) + */ +#define AT91_ECC (0xffffe200 - AT91_BASE_SYS) +#define AT91_DDRSDRC1 (0xffffe400 - AT91_BASE_SYS) +#define AT91_DDRSDRC0 (0xffffe600 - AT91_BASE_SYS) +#define AT91_SMC (0xffffe800 - AT91_BASE_SYS) +#define AT91_MATRIX (0xffffea00 - AT91_BASE_SYS) +#define AT91_DMA (0xffffec00 - AT91_BASE_SYS) +#define AT91_DBGU (0xffffee00 - AT91_BASE_SYS) +#define AT91_AIC (0xfffff000 - AT91_BASE_SYS) +#define AT91_PIOA (0xfffff200 - AT91_BASE_SYS) +#define AT91_PIOB (0xfffff400 - AT91_BASE_SYS) +#define AT91_PIOC (0xfffff600 - AT91_BASE_SYS) +#define AT91_PIOD (0xfffff800 - AT91_BASE_SYS) +#define AT91_PIOE (0xfffffa00 - AT91_BASE_SYS) +#define AT91_PMC (0xfffffc00 - AT91_BASE_SYS) +#define AT91_RSTC (0xfffffd00 - AT91_BASE_SYS) +#define AT91_SHDWC (0xfffffd10 - AT91_BASE_SYS) +#define AT91_RTT (0xfffffd20 - AT91_BASE_SYS) +#define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) +#define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) +#define AT91_GPBR (0xfffffd60 - AT91_BASE_SYS) +#define AT91_RTC (0xfffffdb0 - AT91_BASE_SYS) + +#define AT91_USART0 AT91SAM9G45_BASE_US0 +#define AT91_USART1 AT91SAM9G45_BASE_US1 +#define AT91_USART2 AT91SAM9G45_BASE_US2 +#define AT91_USART3 AT91SAM9G45_BASE_US3 + +/* + * Internal Memory. + */ +#define AT91SAM9G45_SRAM_BASE 0x00300000 /* Internal SRAM base address */ +#define AT91SAM9G45_SRAM_SIZE SZ_64K /* Internal SRAM size (64Kb) */ + +#define AT91SAM9G45_ROM_BASE 0x00400000 /* Internal ROM base address */ +#define AT91SAM9G45_ROM_SIZE SZ_64K /* Internal ROM size (64Kb) */ + +#define AT91SAM9G45_LCDC_BASE 0x00500000 /* LCD Controller */ +#define AT91SAM9G45_UDPHS_FIFO 0x00600000 /* USB Device HS controller */ +#define AT91SAM9G45_HCI_BASE 0x00700000 /* USB Host controller (OHCI) */ +#define AT91SAM9G45_EHCI_BASE 0x00800000 /* USB Host controller (EHCI) */ +#define AT91SAM9G45_VDEC_BASE 0x00900000 /* Video Decoder Controller */ + +#define CONFIG_DRAM_BASE AT91_CHIPSELECT_6 + +/* + * Cpu Name + */ +#define AT91_CPU_NAME "AT91SAM9G45" + +#endif diff --git a/include/asm-arm/arch-at91/at91sam9g45_matrix.h b/include/asm-arm/arch-at91/at91sam9g45_matrix.h new file mode 100644 index 0000000..1620e1b --- /dev/null +++ b/include/asm-arm/arch-at91/at91sam9g45_matrix.h @@ -0,0 +1,153 @@ +/* + * Matrix-centric header file for the AT91SAM9M1x family + * + * Copyright (C) 2008 Atmel Corporation. + * + * Memory Controllers (MATRIX, EBI) - System peripherals registers. + * Based on AT91SAM9G45 preliminary datasheet. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9G45_MATRIX_H +#define AT91SAM9G45_MATRIX_H + +#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ +#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ +#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ +#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ +#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ +#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ +#define AT91_MATRIX_MCFG6 (AT91_MATRIX + 0x18) /* Master Configuration Register 6 */ +#define AT91_MATRIX_MCFG7 (AT91_MATRIX + 0x1C) /* Master Configuration Register 7 */ +#define AT91_MATRIX_MCFG8 (AT91_MATRIX + 0x20) /* Master Configuration Register 8 */ +#define AT91_MATRIX_MCFG9 (AT91_MATRIX + 0x24) /* Master Configuration Register 9 */ +#define AT91_MATRIX_MCFG10 (AT91_MATRIX + 0x28) /* Master Configuration Register 10 */ +#define AT91_MATRIX_MCFG11 (AT91_MATRIX + 0x2C) /* Master Configuration Register 11 */ +#define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0) +#define AT91_MATRIX_ULBT_THIRTYTWO (5 << 0) +#define AT91_MATRIX_ULBT_SIXTYFOUR (6 << 0) +#define AT91_MATRIX_ULBT_128 (7 << 0) + +#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SCFG5 (AT91_MATRIX + 0x54) /* Slave Configuration Register 5 */ +#define AT91_MATRIX_SCFG6 (AT91_MATRIX + 0x58) /* Slave Configuration Register 6 */ +#define AT91_MATRIX_SCFG7 (AT91_MATRIX + 0x5C) /* Slave Configuration Register 7 */ +#define AT91_MATRIX_SLOT_CYCLE (0x1ff << 0) /* Maximum Number of Allowed Cycles for a Burst */ +#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR (0xf << 18) /* Fixed Index of Default Master */ + +#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ +#define AT91_MATRIX_PRBS0 (AT91_MATRIX + 0x84) /* Priority Register B for Slave 0 */ +#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ +#define AT91_MATRIX_PRBS1 (AT91_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ +#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ +#define AT91_MATRIX_PRBS2 (AT91_MATRIX + 0x94) /* Priority Register B for Slave 2 */ +#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ +#define AT91_MATRIX_PRBS3 (AT91_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ +#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ +#define AT91_MATRIX_PRBS4 (AT91_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ +#define AT91_MATRIX_PRAS5 (AT91_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ +#define AT91_MATRIX_PRBS5 (AT91_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ +#define AT91_MATRIX_PRAS6 (AT91_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ +#define AT91_MATRIX_PRBS6 (AT91_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ +#define AT91_MATRIX_PRAS7 (AT91_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ +#define AT91_MATRIX_PRBS7 (AT91_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ +#define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ +#define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ +#define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ +#define AT91_MATRIX_M3PR (3 << 12) /* Master 3 Priority */ +#define AT91_MATRIX_M4PR (3 << 16) /* Master 4 Priority */ +#define AT91_MATRIX_M5PR (3 << 20) /* Master 5 Priority */ +#define AT91_MATRIX_M6PR (3 << 24) /* Master 6 Priority */ +#define AT91_MATRIX_M7PR (3 << 28) /* Master 7 Priority */ +#define AT91_MATRIX_M8PR (3 << 0) /* Master 8 Priority (in Register B) */ +#define AT91_MATRIX_M9PR (3 << 4) /* Master 9 Priority (in Register B) */ +#define AT91_MATRIX_M10PR (3 << 8) /* Master 10 Priority (in Register B) */ +#define AT91_MATRIX_M11PR (3 << 12) /* Master 11 Priority (in Register B) */ + +#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ +#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ +#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ +#define AT91_MATRIX_RCB2 (1 << 2) +#define AT91_MATRIX_RCB3 (1 << 3) +#define AT91_MATRIX_RCB4 (1 << 4) +#define AT91_MATRIX_RCB5 (1 << 5) +#define AT91_MATRIX_RCB6 (1 << 6) +#define AT91_MATRIX_RCB7 (1 << 7) +#define AT91_MATRIX_RCB8 (1 << 8) +#define AT91_MATRIX_RCB9 (1 << 9) +#define AT91_MATRIX_RCB10 (1 << 10) +#define AT91_MATRIX_RCB11 (1 << 11) + +#define AT91_MATRIX_TCMR (AT91_MATRIX + 0x110) /* TCM Configuration Register */ +#define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ +#define AT91_MATRIX_ITCM_0 (0 << 0) +#define AT91_MATRIX_ITCM_32 (6 << 0) +#define AT91_MATRIX_DTCM_SIZE (0xf << 4) /* Size of DTCM enabled memory block */ +#define AT91_MATRIX_DTCM_0 (0 << 4) +#define AT91_MATRIX_DTCM_32 (6 << 4) +#define AT91_MATRIX_DTCM_64 (7 << 4) +#define AT91_MATRIX_TCM_NWS (0x1 << 11) /* Wait state TCM register */ +#define AT91_MATRIX_TCM_NO_WS (0x0 << 11) +#define AT91_MATRIX_TCM_ONE_WS (0x1 << 11) + +#define AT91_MATRIX_VIDEO (AT91_MATRIX + 0x118) /* Video Mode Configuration Register */ +#define AT91C_VDEC_SEL (0x1 << 0) /* Video Mode Selection */ +#define AT91C_VDEC_SEL_OFF (0 << 0) +#define AT91C_VDEC_SEL_ON (1 << 0) + +#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x128) /* EBI Chip Select Assignment Register */ +#define AT91_MATRIX_EBI_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_EBI_CS1A_SMC (0 << 1) +#define AT91_MATRIX_EBI_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_EBI_CS3A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_EBI_CS3A_SMC (0 << 3) +#define AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_EBI_CS4A (1 << 4) /* Chip Select 4 Assignment */ +#define AT91_MATRIX_EBI_CS4A_SMC (0 << 4) +#define AT91_MATRIX_EBI_CS4A_SMC_CF0 (1 << 4) +#define AT91_MATRIX_EBI_CS5A (1 << 5) /* Chip Select 5 Assignment */ +#define AT91_MATRIX_EBI_CS5A_SMC (0 << 5) +#define AT91_MATRIX_EBI_CS5A_SMC_CF1 (1 << 5) +#define AT91_MATRIX_EBI_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_EBI_DBPU_ON (0 << 8) +#define AT91_MATRIX_EBI_DBPU_OFF (1 << 8) +#define AT91_MATRIX_EBI_VDDIOMSEL (1 << 16) /* Memory voltage selection */ +#define AT91_MATRIX_EBI_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_EBI_VDDIOMSEL_3_3V (1 << 16) +#define AT91_MATRIX_EBI_EBI_IOSR (1 << 17) /* EBI I/O slew rate selection */ +#define AT91_MATRIX_EBI_EBI_IOSR_REDUCED (0 << 17) +#define AT91_MATRIX_EBI_EBI_IOSR_NORMAL (1 << 17) +#define AT91_MATRIX_EBI_DDR_IOSR (1 << 18) /* DDR2 dedicated port I/O slew rate selection */ +#define AT91_MATRIX_EBI_DDR_IOSR_REDUCED (0 << 18) +#define AT91_MATRIX_EBI_DDR_IOSR_NORMAL (1 << 18) + +#define AT91_MATRIX_WPMR (AT91_MATRIX + 0x1E4) /* Write Protect Mode Register */ +#define AT91_MATRIX_WPMR_WPEN (1 << 0) /* Write Protect ENable */ +#define AT91_MATRIX_WPMR_WP_WPDIS (0 << 0) +#define AT91_MATRIX_WPMR_WP_WPEN (1 << 0) +#define AT91_MATRIX_WPMR_WPKEY (0xFFFFFF << 8) /* Write Protect KEY */ + +#define AT91_MATRIX_WPSR (AT91_MATRIX + 0x1E8) /* Write Protect Status Register */ +#define AT91_MATRIX_WPSR_WPVS (1 << 0) /* Write Protect Violation Status */ +#define AT91_MATRIX_WPSR_NO_WPV (0 << 0) +#define AT91_MATRIX_WPSR_WPV (1 << 0) +#define AT91_MATRIX_WPSR_WPVSRC (0xFFFF << 8) /* Write Protect Violation Source */ + +#endif diff --git a/include/asm-arm/arch-at91/clk.h b/include/asm-arm/arch-at91/clk.h index 6aaf82e..f642dd9 100644 --- a/include/asm-arm/arch-at91/clk.h +++ b/include/asm-arm/arch-at91/clk.h @@ -49,6 +49,11 @@ static inline unsigned long get_lcdc_clk_rate(unsigned int dev_id) return get_mck_clk_rate(); }
+static inline unsigned long get_spi_clk_rate(unsigned int dev_id) +{ + return get_mck_clk_rate(); +} + static inline unsigned long get_twi_clk_rate(unsigned int dev_id) { return get_mck_clk_rate(); diff --git a/include/asm-arm/arch-at91/hardware.h b/include/asm-arm/arch-at91/hardware.h index 8704106..c42709e 100644 --- a/include/asm-arm/arch-at91/hardware.h +++ b/include/asm-arm/arch-at91/hardware.h @@ -37,6 +37,12 @@ #include <asm/arch/at91sam9rl.h> #define AT91_BASE_SPI AT91SAM9RL_BASE_SPI #define AT91_ID_UHP AT91SAM9RL_ID_UHP +#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) +#include <asm/arch/at91sam9g45.h> +#define AT91_BASE_EMAC AT91SAM9G45_BASE_EMAC +#define AT91_BASE_SPI AT91SAM9G45_BASE_SPI0 +#define AT91_ID_UHP AT91SAM9G45_ID_UHPHS +#define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91CAP9) #include <asm/arch/at91cap9.h> #define AT91_BASE_SPI AT91CAP9_BASE_SPI0 diff --git a/include/asm-arm/arch-at91/memory-map.h b/include/asm-arm/arch-at91/memory-map.h index 8015dad..f605f37 100644 --- a/include/asm-arm/arch-at91/memory-map.h +++ b/include/asm-arm/arch-at91/memory-map.h @@ -30,5 +30,6 @@ #define USART1_BASE AT91_USART1 #define USART2_BASE AT91_USART2 #define USART3_BASE (AT91_BASE_SYS + AT91_DBGU) +#define SPI0_BASE AT91_BASE_SPI
#endif /* __ASM_ARM_ARCH_MEMORYMAP_H__ */ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h new file mode 100644 index 0000000..712ce95 --- /dev/null +++ b/include/configs/at91sam9m10g45ek.h @@ -0,0 +1,225 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * Configuation settings for the AT91SAM9M10G45EK board(and AT91SAM9G45EKES). + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#ifdef CONFIG_AT91SAM9M10G45EK +#define CONFIG_AT91SAM9M10G45 1 /* It's an Atmel AT91SAM9M10G45 SoC*/ +#else +#define CONFIG_AT91SAM9G45 1 /* It's an Atmel AT91SAM9G45 SoC*/ +#endif +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LCD */ +#define CONFIG_LCD 1 +#define LCD_BPP LCD_COLOR8 +#define CONFIG_LCD_LOGO 1 +#undef LCD_TEST_PATTERN +#define CONFIG_LCD_INFO 1 +#define CONFIG_LCD_INFO_BELOW_LOGO 1 +#define CONFIG_SYS_WHITE_ON_BLACK 1 +#define CONFIG_ATMEL_LCD 1 +#define CONFIG_ATMEL_LCD_RGB565 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +/* board specific(not enough SRAM) */ +#define CONFIG_AT91SAM9G45_LCD_BASE 0x73E00000 + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PD31 /* this is the user1 led */ +#define CONFIG_GREEN_LED AT91_PIN_PD0 /* this is the user2 led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_LOADS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x70000000 +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* DataFlash */ +#ifdef CONFIG_ATMEL_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_SPI_FLASH 1 +#define CONFIG_SPI_FLASH_ATMEL 1 +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#endif + +/* NOR flash, if populated */ +#ifndef CONFIG_CMD_NAND +#define CONFIG_SYS_NO_FLASH 1 +#else +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define PHYS_FLASH_1 0x10000000 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#endif + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_MAX_CHIPS 1 +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC8 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* AT91SAM9G45_UHP_OHCI_BASE */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +#ifdef CONFIG_SYS_USE_DATAFLASH + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_SYS_MONITOR_BASE (0xC0000000 + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (0xC0000000 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) "\ + "rw rootfstype=jffs2" + +#else /* CONFIG_SYS_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x72000000 0x200000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro, \ + 256k(uboot)ro,128k(env1)ro,128k(env2)ro, \ + 2M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Sedji Gaouaou
