[U-Boot] [PATCH 0/4] arm: zynq: migrate to DM I2C driver
This series migrate most zynq boards to using the Cadence DM I2C driver
The first patch adds kconfig options to generalize the concept of reading the MAC address from an I2C EEPROM. Then the zynq and zynqmp boards were migrated with patches two and three to use the options
Finally, the last patch migrates the boards to the Cadence I2C driver. The boards ZC702 and ZC706 were not migrated because they have I2C multiplexers and I don't have a board with a multiplexer to perform testing and validation
I ran a round of reproducible builds on master and another one after the third patch for all zynq and zynqmp boards, and the same binaries where generated for all boards
All commits were tested on a Digilent Zybo board
Luis Araneda (4): drivers/misc: add options to read MAC address from EEPROM arm: zynq: migrate EEPROM MAC address options to kconfig arm64: zynqmp: migrate EEPROM MAC address options to kconfig arm: zynq: use i2c cadence DM driver
arch/arm/dts/zynq-syzygy-hub.dts | 1 + arch/arm/dts/zynq-zybo.dts | 10 ++++++ board/xilinx/zynq/board.c | 27 ++++++++++++---- board/xilinx/zynqmp/zynqmp.c | 10 +++--- configs/syzygy_hub_defconfig | 9 +++--- configs/topic_miami_defconfig | 5 ++- configs/topic_miamilite_defconfig | 5 ++- configs/topic_miamiplus_defconfig | 5 ++- configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 5 ++- configs/xilinx_zynqmp_zcu102_revA_defconfig | 5 ++- configs/xilinx_zynqmp_zcu102_revB_defconfig | 5 ++- configs/xilinx_zynqmp_zcu106_revA_defconfig | 5 ++- configs/xilinx_zynqmp_zcu111_revA_defconfig | 5 ++- configs/zynq_zybo_defconfig | 10 +++--- drivers/misc/Kconfig | 32 +++++++++++++++---- include/configs/syzygy_hub.h | 3 -- include/configs/xilinx_zynqmp_zcu102.h | 2 -- include/configs/xilinx_zynqmp_zcu106.h | 2 -- include/configs/xilinx_zynqmp_zcu111.h | 2 -- include/configs/zynq_zybo.h | 2 -- 20 files changed, 98 insertions(+), 52 deletions(-)
Add generic kconfig options to read MAC address(es) from an EEPROM connected to an I2C bus
The SYS_I2C_EEPROM_* options can't be used because they depend on I2C_EEPROM, which requires a DM driver, and not all boards have DM I2C drivers yet
Signed-off-by: Luis Araneda luaraneda@gmail.com --- drivers/misc/Kconfig | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 17b3a805a2..ff694871bf 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -272,6 +272,32 @@ config SYS_I2C_EEPROM_ADDR_OVERFLOW
endif
+config MAC_ADDR_IN_I2C_EEPROM + bool "MAC address in I2C EEPROM" + help + Read MAC address(es) from an EEPROM + connected to an I2C bus + +if MAC_ADDR_IN_I2C_EEPROM + +config MAC_ADDR_I2C_EEPROM_BUS + int "I2C bus connected to the EEPROM device" + default 0 + +config MAC_ADDR_I2C_EEPROM_CHIP_ADDR + hex "Chip address of the EEPROM device" + default 0 + +config MAC_ADDR_I2C_EEPROM_DATA_ADDR_LEN + int "Length in bytes of EEPROM data addresses" + default 1 + +config MAC_ADDR_I2C_EEPROM_DATA_ADDR_START + hex "Start address of MAC data in EEPROM" + default 0 + +endif + config GDSYS_RXAUI_CTRL bool "Enable gdsys RXAUI control driver" depends on MISC
Migrate boards to use the generic kconfig options to read the MAC address
Signed-off-by: Luis Araneda luaraneda@gmail.com --- board/xilinx/zynq/board.c | 7 +++---- configs/syzygy_hub_defconfig | 4 +++- configs/zynq_zybo_defconfig | 4 +++- include/configs/syzygy_hub.h | 1 - include/configs/zynq_zybo.h | 1 - 5 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 1106f5c2a8..dcbf788918 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -75,10 +75,9 @@ int board_late_init(void)
int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) { -#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ - defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) - if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, - CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, +#if defined(CONFIG_MAC_ADDR_IN_I2C_EEPROM) + if (eeprom_read(CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR, + CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START, ethaddr, 6)) printf("I2C EEPROM MAC address read failed\n"); #endif diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 6fb56afbe9..221349ba6f 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -39,7 +39,9 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C1=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x57 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0xFA CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_PHY_MARVELL=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 3dfc62162f..03958f399d 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -46,7 +46,9 @@ CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x50 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0xFA CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/include/configs/syzygy_hub.h b/include/configs/syzygy_hub.h index 88ee772848..17938398c2 100644 --- a/include/configs/syzygy_hub.h +++ b/include/configs/syzygy_hub.h @@ -11,7 +11,6 @@ #define __CONFIG_SYZYGY_HUB_H
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x57
#define CONFIG_EXTRA_ENV_SETTINGS \ "fit_image=fit.itb\0" \ diff --git a/include/configs/zynq_zybo.h b/include/configs/zynq_zybo.h index 547ecb68fd..c3abf41f76 100644 --- a/include/configs/zynq_zybo.h +++ b/include/configs/zynq_zybo.h @@ -11,7 +11,6 @@ #define __CONFIG_ZYNQ_ZYBO_H
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x50 #define CONFIG_DISPLAY #define CONFIG_I2C_EDID
Additionally, remove the ZYNQ_GEM_I2C_MAC_OFFSET kconfig option, since no boards is using it now
Signed-off-by: Luis Araneda luaraneda@gmail.com --- board/xilinx/zynqmp/zynqmp.c | 10 ++++------ configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 5 ++++- configs/xilinx_zynqmp_zcu102_revA_defconfig | 5 ++++- configs/xilinx_zynqmp_zcu102_revB_defconfig | 5 ++++- configs/xilinx_zynqmp_zcu106_revA_defconfig | 5 ++++- configs/xilinx_zynqmp_zcu111_revA_defconfig | 5 ++++- drivers/misc/Kconfig | 6 ------ include/configs/xilinx_zynqmp_zcu102.h | 2 -- include/configs/xilinx_zynqmp_zcu106.h | 2 -- include/configs/xilinx_zynqmp_zcu111.h | 2 -- 10 files changed, 24 insertions(+), 23 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 81c10fcf8a..1f7b3a4c48 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -372,13 +372,11 @@ int board_early_init_r(void)
int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) { -#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ - defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) && \ - defined(CONFIG_ZYNQ_EEPROM_BUS) - i2c_set_bus_num(CONFIG_ZYNQ_EEPROM_BUS); +#if defined(CONFIG_MAC_ADDR_IN_I2C_EEPROM) + i2c_set_bus_num(CONFIG_MAC_ADDR_I2C_EEPROM_BUS);
- if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, - CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, + if (eeprom_read(CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR, + CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START, ethaddr, 6)) printf("I2C EEPROM MAC address read failed\n"); #endif diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 49a14d87a8..a693663cbe 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -63,7 +63,10 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_BUS=5 +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x54 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0x20 CONFIG_DM_MMC=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 05dad41acb..2c271fc691 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -62,7 +62,10 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_BUS=5 +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x54 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index b3711b43e8..c28654c5a6 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -62,7 +62,10 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_BUS=5 +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x54 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index e644914070..97841eefa4 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -59,7 +59,10 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_BUS=5 +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x54 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index c88ba522c7..18e7b2ce49 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -53,7 +53,10 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_MAC_ADDR_IN_I2C_EEPROM=y +CONFIG_MAC_ADDR_I2C_EEPROM_BUS=5 +CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x54 +CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index ff694871bf..0c98dce73b 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -223,12 +223,6 @@ config SPL_I2C_EEPROM This option is an SPL-variant of the I2C_EEPROM option. See the help of I2C_EEPROM for details.
-config ZYNQ_GEM_I2C_MAC_OFFSET - hex "Set the I2C MAC offset" - default 0x0 - help - Set the MAC offset for i2C. - if I2C_EEPROM
config SYS_I2C_EEPROM_ADDR diff --git a/include/configs/xilinx_zynqmp_zcu102.h b/include/configs/xilinx_zynqmp_zcu102.h index ad6bc3d1bf..4a40d416a2 100644 --- a/include/configs/xilinx_zynqmp_zcu102.h +++ b/include/configs/xilinx_zynqmp_zcu102.h @@ -36,8 +36,6 @@ #define CONFIG_PCA953X
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_ZYNQ_EEPROM_BUS 5 -#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x54
#define CONFIG_SPD_EEPROM #define CONFIG_DDR_SPD diff --git a/include/configs/xilinx_zynqmp_zcu106.h b/include/configs/xilinx_zynqmp_zcu106.h index cc2d145ddd..16ac1d0dc6 100644 --- a/include/configs/xilinx_zynqmp_zcu106.h +++ b/include/configs/xilinx_zynqmp_zcu106.h @@ -36,8 +36,6 @@ #define CONFIG_PCA953X
#include <configs/xilinx_zynqmp.h>
diff --git a/include/configs/xilinx_zynqmp_zcu111.h b/include/configs/xilinx_zynqmp_zcu111.h index 8f8cb4f087..f8f52ef639 100644 --- a/include/configs/xilinx_zynqmp_zcu111.h +++ b/include/configs/xilinx_zynqmp_zcu111.h @@ -39,8 +39,6 @@ #define CONFIG_PCA953X
Migrate most boards to the Cadence I2C driver and use DM functions to read the MAC address from EEPROM
Additionally, remove the legacy eeprom command from defconfig since it was only used to provide the functions to read the MAC address
Boards ZC702 and ZC706 were not migrated because they have I2C multiplexers and require extended validation and testing
Signed-off-by: Luis Araneda luaraneda@gmail.com --- arch/arm/dts/zynq-syzygy-hub.dts | 1 + arch/arm/dts/zynq-zybo.dts | 10 ++++++++++ board/xilinx/zynq/board.c | 24 ++++++++++++++++++++---- configs/syzygy_hub_defconfig | 5 ++--- configs/topic_miami_defconfig | 5 ++--- configs/topic_miamilite_defconfig | 5 ++--- configs/topic_miamiplus_defconfig | 5 ++--- configs/zynq_zybo_defconfig | 6 ++---- include/configs/syzygy_hub.h | 2 -- include/configs/zynq_zybo.h | 1 - 10 files changed, 41 insertions(+), 23 deletions(-)
diff --git a/arch/arm/dts/zynq-syzygy-hub.dts b/arch/arm/dts/zynq-syzygy-hub.dts index a30d667146..d89e669b71 100644 --- a/arch/arm/dts/zynq-syzygy-hub.dts +++ b/arch/arm/dts/zynq-syzygy-hub.dts @@ -15,6 +15,7 @@ aliases { ethernet0 = &gem0; serial0 = &uart0; + i2c0 = &i2c1; mmc0 = &sdhci0; };
diff --git a/arch/arm/dts/zynq-zybo.dts b/arch/arm/dts/zynq-zybo.dts index 3844822305..b5e0f3d9b3 100644 --- a/arch/arm/dts/zynq-zybo.dts +++ b/arch/arm/dts/zynq-zybo.dts @@ -14,6 +14,8 @@ ethernet0 = &gem0; serial0 = &uart1; spi0 = &qspi; + i2c0 = &i2c0; + i2c1 = &i2c1; mmc0 = &sdhci0; };
@@ -49,6 +51,14 @@ }; };
+&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + &qspi { u-boot,dm-pre-reloc; status = "okay"; diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index dcbf788918..5b9ee10a90 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -8,6 +8,7 @@ #include <dm/uclass.h> #include <fdtdec.h> #include <fpga.h> +#include <i2c.h> #include <mmc.h> #include <watchdog.h> #include <wdt.h> @@ -76,10 +77,25 @@ int board_late_init(void) int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) { #if defined(CONFIG_MAC_ADDR_IN_I2C_EEPROM) - if (eeprom_read(CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR, - CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START, - ethaddr, 6)) - printf("I2C EEPROM MAC address read failed\n"); + int ret; + struct udevice *bus, *dev; + + ret = uclass_get_device_by_seq(UCLASS_I2C, + CONFIG_MAC_ADDR_I2C_EEPROM_BUS, + &bus); + if (!ret) + ret = i2c_get_chip(bus, + CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR, + 1, &dev); + if (!ret) + ret = i2c_set_chip_offset_len(dev, + CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_LEN); + if (!ret) + ret = dm_i2c_read(dev, + CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START, + ethaddr, 6); + if (ret) + printf("I2C EEPROM MAC address read failed (%i)\n", ret); #endif
return 0; diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 221349ba6f..bcc3ecda49 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -18,7 +18,6 @@ CONFIG_BOOTCOMMAND="run $modeboot || run distro_bootcmd" CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="Zynq> " -CONFIG_CMD_EEPROM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y @@ -37,8 +36,8 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y -CONFIG_SYS_I2C_ZYNQ=y -CONFIG_ZYNQ_I2C1=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y CONFIG_MAC_ADDR_IN_I2C_EEPROM=y CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x57 CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0xFA diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index af5b92cd34..408a5485f3 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -34,9 +34,8 @@ CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y -CONFIG_SYS_I2C_ZYNQ=y -CONFIG_ZYNQ_I2C0=y -CONFIG_ZYNQ_I2C1=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index ad7ba04d85..ee5f512513 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -34,9 +34,8 @@ CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y -CONFIG_SYS_I2C_ZYNQ=y -CONFIG_ZYNQ_I2C0=y -CONFIG_ZYNQ_I2C1=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 7455e86622..89512df26d 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -33,9 +33,8 @@ CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y -CONFIG_SYS_I2C_ZYNQ=y -CONFIG_ZYNQ_I2C0=y -CONFIG_ZYNQ_I2C1=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 03958f399d..236bc4ff70 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_EEPROM=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y @@ -43,9 +42,8 @@ CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y -CONFIG_SYS_I2C_ZYNQ=y -CONFIG_ZYNQ_I2C0=y -CONFIG_ZYNQ_I2C1=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y CONFIG_MAC_ADDR_IN_I2C_EEPROM=y CONFIG_MAC_ADDR_I2C_EEPROM_CHIP_ADDR=0x50 CONFIG_MAC_ADDR_I2C_EEPROM_DATA_ADDR_START=0xFA diff --git a/include/configs/syzygy_hub.h b/include/configs/syzygy_hub.h index 17938398c2..e31b77c0c0 100644 --- a/include/configs/syzygy_hub.h +++ b/include/configs/syzygy_hub.h @@ -10,8 +10,6 @@ #ifndef __CONFIG_SYZYGY_HUB_H #define __CONFIG_SYZYGY_HUB_H
-#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - #define CONFIG_EXTRA_ENV_SETTINGS \ "fit_image=fit.itb\0" \ "bitstream_image=download.bit\0" \ diff --git a/include/configs/zynq_zybo.h b/include/configs/zynq_zybo.h index c3abf41f76..f3b628cbac 100644 --- a/include/configs/zynq_zybo.h +++ b/include/configs/zynq_zybo.h @@ -10,7 +10,6 @@ #ifndef __CONFIG_ZYNQ_ZYBO_H #define __CONFIG_ZYNQ_ZYBO_H
-#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_DISPLAY #define CONFIG_I2C_EDID
mmc0 = &sdhci0; };i2c0 = &i2c1;
This can be separate patch.
i2c0 = &i2c0;
mmc0 = &sdhci0; };i2c1 = &i2c1;
+&i2c0 {
- status = "okay";
+&i2c1 {
- status = "okay";
IIRC zybo has no connection from PS to i2c and it is done via PL. And deal was that only things which are in PS part should be listed in DTS file. It means this shouldn't be here.
ethaddr, 6))
- int ret;
- struct udevice *bus, *dev;
- ret = uclass_get_device_by_seq(UCLASS_I2C,
&bus);
- if (!ret)
1, &dev);
- if (!ret)
- if (!ret)
ethaddr, 6);
- if (ret)
#endif
In ZynqMP there is also call i2c_set_bus_num which is what you do above.
I don't think that make sense to duplicate this code in board files. This should go to core. I think eeprom hasn't been converted to DM and that's the thing which should happen first. Then calling sequence should be the same in board files.
this will caused regression.
convert this board is fine. Mike: Are you ok with it?
ditto
regression.
as above.
Thanks, Michal
Hi Michal,
[...] --- a/arch/arm/dts/zynq-syzygy-hub.dts +++ b/arch/arm/dts/zynq-syzygy-hub.dts @@ -15,6 +15,7 @@ aliases { ethernet0 = &gem0; serial0 = &uart0;
Ok
i2c0 = &i2c0;
+&i2c0 {
status = "okay";
+&i2c1 {
status = "okay";
The PS has I2C peripherals. For the Zybo in particular, there are two I2Cs, which must be routed through the PL to be connected to the EEPROM and HDMI port respectively. That means that if the PL is not programmed, the I2C driver binds and works properly but the SCL and SDA signals of the I2C peripherals are not connected to anything. So, I'm not sure if the rule is applicable here, because the I2Cs are in PS, but to properly use them you have to program the PL.
Besides, adding the aliases and nodes was the only way I could find to make the driver work (bind) automatically. If I don't add the aliases, the I2C devices are not assigned a bus (-1), and if I don't add the nodes, the driver does not bind.
If the I2C nodes don't belong in the .dts file, and I'm using DM (which will eventually be mandatory), does that means I would have to bind the driver manually to obtain the current functionality without DM? I suppose that's possible (don't know how). It sounds like the functionality provided by device-tree overlays.
ethaddr, 6))
int ret;
&bus);
if (!ret)
1, &dev);
if (!ret)
if (!ret)
ethaddr, 6);
if (ret)
#endif
Ok. I'm assuming that you are referring to the eeprom command? because I found the i2c_eeprom driver (CONFIG_I2C_EEPROM), which is using DM. But, I'm not sure if we can use it because it has the same problems of the I2C nodes above, and this is even worse, as the driver won't bind unless the PL is programmed first.
Is it because someone could have been using the command?
Thanks,
Luis Araneda.
Please take a look at https://lists.denx.de/pipermail/u-boot/2016-November/274068.html which was the series which should replace all these boards setting in a generic way. Unfortunately I don't know why it didn't go through.
And then regarding DM i2c. Driver is in the driver for a while but for i2c muxes support it requires all subbusses to be listed in DTS file which is not what it is common in Linux dt binding. That's why some work needs to be done in this area to convert all platforms.
Thanks, Michal
Hi Michal,
The last version of that series [1] (v6, 28 patches) has the state "Changes Requested" on patchwork, and it even has some TODOs. It's a generic way of reading a MAC address from an EEPROM with helper functions. I'm not proposing something as generic and elaborated as that series, but an improvement to what is used today.
I sent this series to move some legacy options to Kconfig. Additionally, the Zybo Z7 has its MAC address stored on an SPI FLASH, which will likely require a new Kconfig option (MAC_ADDR_IN_SPI_FLASH) eventually. Something that [1] doesn't cover (from what I read).
It just occurred to me that what I'm really doing in the fourth patch is reading the MAC address from a generic memory connected to I2C, because it's a generic memory read operation (device address, memory address, read operation). So I think the name of the Kconfigs could be CONFIG_MAC_ADDR_IN_I2C_MEMORY instead of CONFIG_MAC_ADDR_IN_I2C_EEPROM. It can even be more generic like CONFIG_MAC_ADDR_IN_I2C. What do yo think?
Yes, I realize that I2C muxes are a pending issue, but that's why I only migrated the boards that are not using I2C muxes. From my point of view, it's less work to be done when porting
Anyway, I just wanted to improve the current state of the code, I don't need these changes for what I'm doing. So if you like to wait for [1] to be merged, it's fine with me and we can drop this series, otherwise, please review it so I can make changes if necessary.
[1] https://lists.denx.de/pipermail/u-boot/2017-May/291401.html
Thanks,
Luis Araneda.
On 20.7.2018 08:12, Luis Araneda wrote:
Hi Michal,
I have no problem to move ZYNQ_GEM_EEPROM_ADDR to Kconfig without changing the name.
Oliver: Any comment about your patch series?
And I would let Joe to handle that mac address reading. That v6 series contains a lot of patches which have been acked. The biggest problem was about sunxi which is something what can be ignored. If Oliver doesn't want to send v7 then I would recommend you simply take his v6 version and that patches which are required and just send them again. I think it won't take so much time because a lot of things were already done.
Thanks, Michal
[...] Anyway, I just wanted to improve the current state of the code, I don't need these changes for what I'm doing. So if you like to wait for [1] to be merged, it's fine with me and we can drop this series, otherwise, please review it so I can make changes if necessary.
Ok, I'll send one patch moving ZYNQ_GEM_EEPROM_ADDR to Kconfig, maintaining its name and I'm dropping my proposal for a generic option.
Thanks,
Luis Araneda.
Hi all,
Hi Michal,
Neither do I :) some of them where 'done' as far as I remember, but it has been a while and I have somewhat forgotten about them a little. They have been used in production since then however for us.
There are plans to work on our u-boot again in the next few months and my intention was to pick up the ones that did not get merged.
No, I did not have SPI memory available at the time, and was sort of waiting for the generic EEPROM framework to progress (that died).
Having said that, adding SPI eeprom would have been trivial.
Well I think the generic memory framework did make sense at the time, and didn't compulab merge something like this at some point?
What I just wrote above :)
I don't mind starting to work on a v7; i think one of the issues I ran into was turn around time which took quite a while. I may even have v7 locally actually! I'll see what can be done within the comming period; but again, we are going to update/add more support to our u-boot so I should be working on this again soon-ish.
Thanks, Michal
Luis Araneda
Michal Simek
Michal Simek
Olliver Schinagl
