[PATCH 1/3] arm: dts: imx8mm: move firmware/optee node to common imx8mm-u-boot.dtsi
Move the firmware/optee node to the common imx8mm-u-boot.dtsi and protect it with an ifdef CONFIG_OPTEE as it is a meaningless node without the optee driver enabled.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mm-phg-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mm-u-boot.dtsi | 9 +++++++++ arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi | 7 ------- 7 files changed, 9 insertions(+), 42 deletions(-)
diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi index 484e31824b85..d12ce6069cc7 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi @@ -6,13 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; - wdt-reboot { compatible = "wdt-reboot"; bootph-pre-ram; diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index 1878c4e13fbe..219504f61105 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -6,13 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; - wdt-reboot { compatible = "wdt-reboot"; bootph-pre-ram; diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index 13688ec0d0f2..155670da18d1 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -11,13 +11,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
&aips4 { diff --git a/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi index 65dfd33725ee..1ad9d49a1118 100644 --- a/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi @@ -16,13 +16,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
&crypto { diff --git a/arch/arm/dts/imx8mm-phg-u-boot.dtsi b/arch/arm/dts/imx8mm-phg-u-boot.dtsi index 3ced97cfaafa..c9e0b4420500 100644 --- a/arch/arm/dts/imx8mm-phg-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-phg-u-boot.dtsi @@ -11,13 +11,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
&aips4 { diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 7fd5a05fad3c..c48b5f2ef026 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -7,6 +7,15 @@ binman: binman { multiple-images; }; + +#ifdef CONFIG_OPTEE + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +#endif };
&soc { diff --git a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi index 494229e4e62a..f2c7bd919970 100644 --- a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi @@ -6,13 +6,6 @@ #include "imx8mm-u-boot.dtsi"
Move the firmware/optee node to the common imx8mp-u-boot.dtsi and protect it with an ifdef CONFIG_OPTEE as it is a meaningless node without the optee driver enabled.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mp-evk-u-boot.dtsi | 6 ------ arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mp-u-boot.dtsi | 9 +++++++++ arch/arm/dts/imx8mp-venice-gw74xx-u-boot.dtsi | 7 ------- arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi | 7 ------- 7 files changed, 9 insertions(+), 41 deletions(-)
diff --git a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi index 5ca631e9d8c4..bb0f9bd0c8d3 100644 --- a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi @@ -11,13 +11,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
&{/soc@0/bus@30800000/i2c@30a20000/pmic@25} { diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 6784ed2e7c92..17965c58ba10 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -11,12 +11,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
®_usdhc2_vmmc { diff --git a/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi b/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi index d411cf79e85d..fe20938af536 100644 --- a/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi @@ -12,13 +12,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
®_usdhc2_vmmc { diff --git a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi index f3fb44046d5c..8f1df232b1b7 100644 --- a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi @@ -12,13 +12,6 @@ wdt = <&wdog1>; bootph-pre-ram; }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; };
&iomuxc { diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 18d1728e1d2a..e8fe92485cd1 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -8,6 +8,15 @@ binman: binman { multiple-images; }; + +#ifdef CONFIG_OPTEE + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +#endif };
&soc { diff --git a/arch/arm/dts/imx8mp-venice-gw74xx-u-boot.dtsi b/arch/arm/dts/imx8mp-venice-gw74xx-u-boot.dtsi index c3fb040080b6..44ac315a1241 100644 --- a/arch/arm/dts/imx8mp-venice-gw74xx-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-venice-gw74xx-u-boot.dtsi @@ -6,13 +6,6 @@ #include "imx8mp-u-boot.dtsi"
/ { - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - }; - wdt-reboot { compatible = "wdt-reboot"; bootph-pre-ram; diff --git a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi index 9c6c417f7eea..a985645ff8c3 100644 --- a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi @@ -6,13 +6,6 @@ #include "imx8mp-u-boot.dtsi"
Reviewed-by: Fabio Estevam festevam@denx.de
There is no need to include the firmware/optee node if the optee driver is not enabled.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx8mn-u-boot.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index cef20dab4688..8191b973b464 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -8,12 +8,14 @@ multiple-images; };
+#ifdef CONFIG_OPTEE firmware { optee { compatible = "linaro,optee-tz"; method = "smc"; }; }; +#endif
Fabio Estevam
Tim Harvey
