[PATCH] pci: kconfig: layerscape: Change LX2162A PCIe node compatible string
LX2162A is not like LX2160A which has different PCIe controller in rev1 and rev2 silicon. It supports only one configuration of PCIe controller, which is same as LS2088A. So update PCIe compatible string same as LS2088A.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/Kconfig | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index b1de38f766..ba41787f64 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -219,7 +219,8 @@ config FSL_PCIE_COMPAT default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A default "fsl,ls1088a-pcie" if ARCH_LS1088A - default "fsl,lx2160a-pcie" if ARCH_LX2160A || ARCH_LX2162A + default "fsl,lx2160a-pcie" if ARCH_LX2160A + default "fsl,ls2088a-pcie" if ARCH_LX2162A default "fsl,ls1021a-pcie" if ARCH_LS1021A help This compatible is used to find pci controller node in Kernel DT @@ -228,7 +229,7 @@ config FSL_PCIE_COMPAT config FSL_PCIE_EP_COMPAT string "PCIe EP compatible of Kernel DT" depends on PCIE_LAYERSCAPE_RC || PCIE_LAYERSCAPE_GEN4 - default "fsl,lx2160a-pcie-ep" if ARCH_LX2160A || ARCH_LX2162A + default "fsl,lx2160a-pcie-ep" if ARCH_LX2160A default "fsl,ls-pcie-ep" help This compatible is used to find pci controller ep node in Kernel DT
-----Original Message----- From: Z.q. Hou zhiqiang.hou@nxp.com Sent: Friday, January 29, 2021 10:52 AM To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; Wasim Khan wasim.khan@nxp.com Cc: Z.q. Hou zhiqiang.hou@nxp.com Subject: [PATCH] pci: kconfig: layerscape: Change LX2162A PCIe node compatible string
Reviewed-by: Wasim Khan wasim.khan@nxp.com Tested-by: Wasim Khan wasim.khan@nxp.com
Wasim Khan
Zhiqiang Hou
