[U-Boot] (no subject)
Hi All,
Here's a couple of patches to help building on gcc-6. We're rebasing Fedora to gcc-6 for Fedora 24 so this was the first build I've attempted with it. It doesn't fix all problems as I also see an issue that the generated/generic-asm-offsets.h isn't generated early enough in the build process but I couldn't quite work out how to move the generation of that earlier in the process. Full logs of that at the link below.
Cheers, Peter
https://kojipkgs.fedoraproject.org//work/tasks/1747/12801747/build.log
Add initial support for gcc6 by taking a copy of compiler-gcc5.h
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- include/linux/compiler-gcc6.h | 65 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 65 insertions(+) create mode 100644 include/linux/compiler-gcc6.h
diff --git a/include/linux/compiler-gcc6.h b/include/linux/compiler-gcc6.h new file mode 100644 index 0000000..622117b --- /dev/null +++ b/include/linux/compiler-gcc6.h @@ -0,0 +1,65 @@ +#ifndef __LINUX_COMPILER_H +#error "Please don't include <linux/compiler-gcc6.h> directly, include <linux/compiler.h> instead." +#endif + +#define __used __attribute__((__used__)) +#define __must_check __attribute__((warn_unused_result)) +#define __compiler_offsetof(a, b) __builtin_offsetof(a, b) + +/* Mark functions as cold. gcc will assume any path leading to a call + to them will be unlikely. This means a lot of manual unlikely()s + are unnecessary now for any paths leading to the usual suspects + like BUG(), printk(), panic() etc. [but let's keep them for now for + older compilers] + + Early snapshots of gcc 4.3 don't support this and we can't detect this + in the preprocessor, but we can live with this because they're unreleased. + Maketime probing would be overkill here. + + gcc also has a __attribute__((__hot__)) to move hot functions into + a special section, but I don't see any sense in this right now in + the kernel context */ +#define __cold __attribute__((__cold__)) + +#define __UNIQUE_ID(prefix) __PASTE(__PASTE(__UNIQUE_ID_, prefix), __COUNTER__) + +#ifndef __CHECKER__ +# define __compiletime_warning(message) __attribute__((warning(message))) +# define __compiletime_error(message) __attribute__((error(message))) +#endif /* __CHECKER__ */ + +/* + * Mark a position in code as unreachable. This can be used to + * suppress control flow warnings after asm blocks that transfer + * control elsewhere. + * + * Early snapshots of gcc 4.5 don't support this and we can't detect + * this in the preprocessor, but we can live with this because they're + * unreleased. Really, we need to have autoconf for the kernel. + */ +#define unreachable() __builtin_unreachable() + +/* Mark a function definition as prohibited from being cloned. */ +#define __noclone __attribute__((__noclone__)) + +/* + * Tell the optimizer that something else uses this function or variable. + */ +#define __visible __attribute__((externally_visible)) + +/* + * GCC 'asm goto' miscompiles certain code sequences: + * + * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 + * + * Work it around via a compiler barrier quirk suggested by Jakub Jelinek. + * + * (asm goto is automatically volatile - the naming reflects this.) + */ +#define asm_volatile_goto(x...) do { asm goto(x); asm (""); } while (0) + +#ifdef CONFIG_ARCH_USE_BUILTIN_BSWAP +#define __HAVE_BUILTIN_BSWAP32__ +#define __HAVE_BUILTIN_BSWAP64__ +#define __HAVE_BUILTIN_BSWAP16__ +#endif /* CONFIG_ARCH_USE_BUILTIN_BSWAP */
When compiling with gcc 6 we get the following error due to ARRAY_SIZE being defined elsewhere.
common/env_flags.c:155: undefined reference to `ARRAY_SIZE'
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- common/env_flags.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/env_flags.c b/common/env_flags.c index 9c3aed1..696adef 100644 --- a/common/env_flags.c +++ b/common/env_flags.c @@ -7,6 +7,7 @@
#include <linux/string.h> #include <linux/ctype.h> +#include <common.h>
#ifdef USE_HOSTCC /* Eliminate "ANSI does not permit..." warnings */ #include <stdint.h> @@ -16,7 +17,6 @@ #include <env_flags.h> #define getenv fw_getenv #else -#include <common.h> #include <environment.h> #endif
Hello Peter,
On Wed, 3 Feb 2016 12:42:51 +0000, Peter Robinson pbrobinson@gmail.com wrote:
How come this happens only with gcc-6? Previous compilers surely did not 'guess' the proper value of ARRAY_SIZE, right?
-- 2.5.0
Amicalement,
Hi Albert,
On Wed, Feb 3, 2016 at 1:41 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hello Peter,
So testing this RC on on Fedora 23 with gcc 5.3.1 I see the same failure, I didn't see it with 2016.01 when using 5.3.1 so I'm not sure what's changed there
Peter
Hello Peter,
On Wed, 3 Feb 2016 16:11:38 +0000, Peter Robinson pbrobinson@gmail.com wrote:
Hi Albert,
Hello Peter,
OK, so maybe unrelated to gcc 6. Could you git bisect?
Peter
Amicalement,
On Wed, Feb 03, 2016 at 06:53:11PM +0100, Albert ARIBAUD wrote:
Hello Peter,
Hi Albert,
Hello Peter,
Please, gcc 5.3.x is one of my regular tests now. But I don't do a tools only build (tossing that on my TODO list..).
I'm going to take http://patchwork.ozlabs.org/patch/582527/ to fix this instead as I don't want to say that common.h must work in the case of USE_HOSTCC==true (I'm surprised it did, in fact). Thanks!
What ever was pulled into RC2 works for me but I still needed my gcc6 patch.
Peter
Somewhere along the lines, Linux stopped having compiler-gccN.h and just has compiler-gcc.h and compiler-clang.h. Would you feel up to making a pass at migrating those changes or should I? Thanks!
On Wed, Feb 03, 2016 at 12:42:49PM +0000, Peter Robinson wrote:
Hi All,
Cheers, Peter
Oh fun, I saw some gcc-6 packages in debian/unstable but not a way to make them be "$arch-gcc" and not "$arch-gcc-6". At least with respect to this error, do you see it in the kernel too? If not, maybe there's a semi recent patch we need?
Cheers, Peter
I'm not sure if there was issues with the kernel, there could have been since it landed as was fixed before I noticed or maybe the kernel was tested by the toolchains team, I'll see if I can find out.
Peter
Albert ARIBAUD
Peter Robinson
