[U-Boot] [PATCH] arm: Add Prep subcommand support to bootm
Adds prep subcommand to bootm implementation of ARM. When bootm is called with the subcommand prep the function stops right after ATAGS creation and before announce_and_cleanup.
This is used in savebp command
Signed-off-by: Simon Schwarz simonschwarzcor@gmail.com ----
V2 changes: nothing
V3 changes: nothing
changes after slicing this from patch http://article.gmane.org/gmane.comp.boot-loaders.u-boot/106422: DEL Prototype declaration - not necessary if reordered DEL Most #ifdefs - relying on -ffunction-sections and --gc-sections to handle unused CHG reorganized bootm. powerpc implementation was the model ADD get_board_serial fake implementation - this is needed if setup_serial_tag is compiled but the board doesn't support it - tradeoff for removing #ifdefs --- arch/arm/lib/bootm.c | 330 +++++++++++++++++++++++++------------------------ 1 files changed, 168 insertions(+), 162 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 802e833..5f112e2 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -1,4 +1,8 @@ -/* +/* Copyright (C) 2011 + * Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de + * - Added prep subcommand support + * - Reorganized source - modeled after powerpc version + * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de @@ -32,31 +36,16 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) -static void setup_start_tag (bd_t *bd); - -# ifdef CONFIG_SETUP_MEMORY_TAGS -static void setup_memory_tags (bd_t *bd); -# endif -static void setup_commandline_tag (bd_t *bd, char *commandline); - -# ifdef CONFIG_INITRD_TAG -static void setup_initrd_tag (bd_t *bd, ulong initrd_start, - ulong initrd_end); -# endif -static void setup_end_tag (bd_t *bd); - +static void (*kernel_entry)(int zero, int arch, uint params); static struct tag *params; -#endif /* CONFIG_SETUP_MEMORY_TAGS || CONFIG_CMDLINE_TAG || CONFIG_INITRD_TAG */
-static ulong get_sp(void); -#if defined(CONFIG_OF_LIBFDT) -static int bootm_linux_fdt(int machid, bootm_headers_t *images); -#endif +static ulong get_sp(void) +{ + ulong ret; + + asm("mov %0, sp" : "=r"(ret) : ); + return ret; +}
void arch_lmb_reserve(struct lmb *lmb) { @@ -80,85 +69,6 @@ void arch_lmb_reserve(struct lmb *lmb) gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size - sp); }
-static void announce_and_cleanup(void) -{ - printf("\nStarting kernel ...\n\n"); - -#ifdef CONFIG_USB_DEVICE - { - extern void udc_disconnect(void); - udc_disconnect(); - } -#endif - cleanup_before_linux(); -} - -int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) -{ - bd_t *bd = gd->bd; - char *s; - int machid = bd->bi_arch_number; - void (*kernel_entry)(int zero, int arch, uint params); - -#ifdef CONFIG_CMDLINE_TAG - char *commandline = getenv ("bootargs"); -#endif - - if ((flag != 0) && (flag != BOOTM_STATE_OS_GO)) - return 1; - - s = getenv ("machid"); - if (s) { - machid = simple_strtoul (s, NULL, 16); - printf ("Using machid 0x%x from environment\n", machid); - } - - show_boot_progress (15); - -#ifdef CONFIG_OF_LIBFDT - if (images->ft_len) - return bootm_linux_fdt(machid, images); -#endif - - kernel_entry = (void (*)(int, int, uint))images->ep; - - debug ("## Transferring control to Linux (at address %08lx) ...\n", - (ulong) kernel_entry); - -#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) - setup_start_tag (bd); -#ifdef CONFIG_SERIAL_TAG - setup_serial_tag (¶ms); -#endif -#ifdef CONFIG_REVISION_TAG - setup_revision_tag (¶ms); -#endif -#ifdef CONFIG_SETUP_MEMORY_TAGS - setup_memory_tags (bd); -#endif -#ifdef CONFIG_CMDLINE_TAG - setup_commandline_tag (bd, commandline); -#endif -#ifdef CONFIG_INITRD_TAG - if (images->rd_start && images->rd_end) - setup_initrd_tag (bd, images->rd_start, images->rd_end); -#endif - setup_end_tag(bd); -#endif - - announce_and_cleanup(); - - kernel_entry(0, machid, bd->bi_boot_params); - /* does not return */ - - return 1; -} - -#if defined(CONFIG_OF_LIBFDT) static int fixup_memory_node(void *blob) { bd_t *bd = gd->bd; @@ -174,54 +84,19 @@ static int fixup_memory_node(void *blob) return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); }
-static int bootm_linux_fdt(int machid, bootm_headers_t *images) +static void announce_and_cleanup(void) { - ulong rd_len; - void (*kernel_entry)(int zero, int dt_machid, void *dtblob); - ulong of_size = images->ft_len; - char **of_flat_tree = &images->ft_addr; - ulong *initrd_start = &images->initrd_start; - ulong *initrd_end = &images->initrd_end; - struct lmb *lmb = &images->lmb; - int ret; - - kernel_entry = (void (*)(int, int, void *))images->ep; - - boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); - - rd_len = images->rd_end - images->rd_start; - ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, - initrd_start, initrd_end); - if (ret) - return ret; - - ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); - if (ret) - return ret; - - debug("## Transferring control to Linux (at address %08lx) ...\n", - (ulong) kernel_entry); - - fdt_chosen(*of_flat_tree, 1); - - fixup_memory_node(*of_flat_tree); - - fdt_initrd(*of_flat_tree, *initrd_start, *initrd_end, 1); - - announce_and_cleanup(); - - kernel_entry(0, machid, *of_flat_tree); - /* does not return */ + printf("\nStarting kernel ...\n\n");
- return 1; -} +#ifdef CONFIG_USB_DEVICE + { + extern void udc_disconnect(void); + udc_disconnect(); + } #endif + cleanup_before_linux(); +}
-#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) static void setup_start_tag (bd_t *bd) { params = (struct tag *) bd->bi_boot_params; @@ -237,7 +112,6 @@ static void setup_start_tag (bd_t *bd) }
-#ifdef CONFIG_SETUP_MEMORY_TAGS static void setup_memory_tags (bd_t *bd) { int i; @@ -252,8 +126,6 @@ static void setup_memory_tags (bd_t *bd) params = tag_next (params); } } -#endif /* CONFIG_SETUP_MEMORY_TAGS */ -
static void setup_commandline_tag (bd_t *bd, char *commandline) { @@ -280,8 +152,6 @@ static void setup_commandline_tag (bd_t *bd, char *commandline) params = tag_next (params); }
- -#ifdef CONFIG_INITRD_TAG static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end) { /* an ATAG_INITRD node tells the kernel where the compressed @@ -295,9 +165,18 @@ static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end)
params = tag_next (params); } -#endif /* CONFIG_INITRD_TAG */
-#ifdef CONFIG_SERIAL_TAG +/* This is a workaround - if boards don't implement + * get_board_serial */ +__attribute__((weak)) +void get_board_serial(struct tag_serialnr *serialnr) +{ + printf("This board does not implement get_board_serial() \ + but calls it serialnr is filled with junk!\n"); + serialnr->high = 0xABCDF; + serialnr->low = 0xABCDF; +} + void setup_serial_tag (struct tag **tmp) { struct tag *params = *tmp; @@ -312,9 +191,7 @@ void setup_serial_tag (struct tag **tmp) params = tag_next (params); *tmp = params; } -#endif
-#ifdef CONFIG_REVISION_TAG void setup_revision_tag(struct tag **in_params) { u32 rev = 0; @@ -326,19 +203,148 @@ void setup_revision_tag(struct tag **in_params) params->u.revision.rev = rev; params = tag_next (params); } -#endif /* CONFIG_REVISION_TAG */
static void setup_end_tag (bd_t *bd) { params->hdr.tag = ATAG_NONE; params->hdr.size = 0; } -#endif /* CONFIG_SETUP_MEMORY_TAGS || CONFIG_CMDLINE_TAG || CONFIG_INITRD_TAG */
-static ulong get_sp(void) +static void create_atags(bootm_headers_t *images) { - ulong ret; + bd_t *bd = gd->bd; + char *commandline = getenv("bootargs");
- asm("mov %0, sp" : "=r"(ret) : ); - return ret; + setup_start_tag(bd); +#ifdef CONFIG_SERIAL_TAG + setup_serial_tag(¶ms); +#endif +#ifdef CONFIG_CMDLINE_TAG + setup_commandline_tag(gd->bd, commandline); +#endif +#ifdef CONFIG_REVISION_TAG + setup_revision_tag(¶ms); +#endif +#ifdef CONFIG_SETUP_MEMORY_TAGS + setup_memory_tags(bd); +#endif +#ifdef CONFIG_INITRD_TAG + if (images->rd_start && images->rd_end) + setup_initrd_tag(bd, images->rd_start, images->rd_end); +#endif + setup_end_tag(bd); +} + +static int create_fdt(bootm_headers_t *images) +{ + ulong of_size = images->ft_len; + char **of_flat_tree = &images->ft_addr; + ulong *initrd_start = &images->initrd_start; + ulong *initrd_end = &images->initrd_end; + struct lmb *lmb = &images->lmb; + ulong rd_len; + int ret; + + debug("using: FDT\n"); + + boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); + + rd_len = images->rd_end - images->rd_start; + ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, + initrd_start, initrd_end); + if (ret) + return ret; + + ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); + if (ret) + return ret; + + fdt_chosen(*of_flat_tree, 1); + fixup_memory_node(*of_flat_tree); + fdt_initrd(*of_flat_tree, *initrd_start, *initrd_end, 1); + + return 0; +} + +/* Subcommand: CMDLINE */ +static int boot_cmdline_linux(bootm_headers_t *images) +{ + return -1; /* not implemented */ +} + +/* Subcommand: BDT */ +static int boot_bd_t_linux(bootm_headers_t *images) +{ + return -1; /* not implemented */ +} + +/* Subcommand: PREP */ +static void boot_prep_linux(bootm_headers_t *images) +{ +#ifdef CONFIG_OF_LIBFDT + if (images->ft_len) { + debug("using: FDT\n"); + if (create_fdt(images)) { + printf("FDT creation failed! hanging..."); + hang(); + } + } else +#endif + { +#if defined(CONFIG_SETUP_MEMORY_TAGS) || \ + defined(CONFIG_CMDLINE_TAG) || \ + defined(CONFIG_INITRD_TAG) || \ + defined(CONFIG_SERIAL_TAG) || \ + defined(CONFIG_REVISION_TAG) + debug("using: ATAGS\n"); + create_atags(images); +#else + printf("FDT and ATAGS failed - hanging\n"); + hang(); +#endif + } + + kernel_entry = (void (*)(int, int, uint))images->ep; +} + +/* Subcommand: GO */ +static void boot_jump_linux(bootm_headers_t *images) +{ + int machid = gd->bd->bi_arch_number; + char *s; + s = getenv("machid"); + if (s) { + strict_strtoul(s, 16, (long unsigned int *) &machid); + debug("Using machid 0x%x from environment\n", machid); + } + + debug("Using machid 0x%x from bd\n", machid); + debug("## Transferring control to Linux (at address %08lx)" \ + "...\n", (ulong) kernel_entry); + show_boot_progress(15); + announce_and_cleanup(); + kernel_entry(0, machid, gd->bd->bi_boot_params); +} + +/* Main Entry point for arm bootm implementation + * + * Modeled after the powerpc implementation + * DIFFERENCE: Instead of calling prep and go at the end + * they are called if subommand is equal 0. + */ +int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +{ + if (flag & BOOTM_STATE_OS_CMDLINE) + boot_cmdline_linux(images); + + if (flag & BOOTM_STATE_OS_BD_T) + boot_bd_t_linux(images); + + if (flag & BOOTM_STATE_OS_PREP || flag == 0) + boot_prep_linux(images); + + if (flag & BOOTM_STATE_OS_GO || flag == 0) + boot_jump_linux(images); + + return 0; }
Dear Simon,
savebp? I thought this command is now 'spl' with some subcommands.
this four times '-' will not be recognized as comment section by git am
V2 changes: nothing
V3 changes: nothing
#ifdefs
- Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
@@ -32,31 +36,16 @@
ulong initrd_end);
NAK (see later on)
- ulong ret;
- return ret;
udc_disconnect();
-#endif
I can not see why git decided to remove that here and add it later on .. did you change anything in announce_and_cleanup()?
- char *s;
-#endif
return 1;
- if (s) {
-#endif
-#endif
-#endif
- return 1;
- ulong rd_len;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- return 1;
udc_disconnect();
#endif
- get_board_serial */
- printf("This board does not implement get_board_serial() \
WARNING: Avoid line continuations in quoted strings #282: FILE: arch/arm/lib/bootm.c:174: + printf("This board does not implement get_board_serial() \
- serialnr->high = 0xABCDF;
- serialnr->low = 0xABCDF;
This was not mentioned in commit message, please split this into another patch (if really required). I vote for 'remove that snipped completely' cause we should see at compiletime that this funtion is mising.
BTW: you could remove the forward declaration for 'void get_board_serial(struct tag_serialnr *serialnr)' from setup_serial_tag() if you implement it some lines above.
------------------------^ Remove whitespace between function name and parameter list (fix globally when you edit that file).
- ulong ret;
no tab here ^
- char *commandline = getenv("bootargs");
- return ret;
- setup_start_tag(bd);
- setup_serial_tag(¶ms);
- setup_commandline_tag(gd->bd, commandline);
- setup_revision_tag(¶ms);
- setup_memory_tags(bd);
- ulong rd_len;
- int ret;
- debug("using: FDT\n");
- if (ret)
return ret;
- if (ret)
return ret;
- return -1; /* not implemented */
Shouldn't that return 0 for 'no error' even if not implemented?
- if (images->ft_len) {
hang();
- } else
- defined(CONFIG_CMDLINE_TAG) || \
- defined(CONFIG_INITRD_TAG) || \
- defined(CONFIG_SERIAL_TAG) || \
- defined(CONFIG_REVISION_TAG)
I can not see any reason why we should keep create_atags() as another function here, I think it is cleaner to move the content of create_atags() to boot_prep_linux() and remove this large list of requirements for create_atags().
+#else
- printf("FDT and ATAGS failed - hanging\n");
Wrong text here, only FDT did fail, ATAGS where not defined at build time.
- hang();
NAK, setting (and using) kernel_entry is part of GO subcommand.
- int machid = gd->bd->bi_arch_number;
- char *s;
No tab here ^
Declare kernel_entry function pointer here.
- s = getenv("machid");
- if (s) {
How about strict_strtoul() returning something wrong?
Yoiu should use printf() here as it was bfore so one could see that fact when booting.
Set kernel_entry function pointer here.
- debug("Using machid 0x%x from bd\n", machid);
This statement is wrong ... you need to set this in an else statement. Or reword the content. How about:
debug("Using machid 0x%x\n", machid); ?
- debug("## Transferring control to Linux (at address %08lx)" \
Use kernel_entry function pointer here ...
- show_boot_progress(15);
- kernel_entry(0, machid, gd->bd->bi_boot_params);
and here.
- Modeled after the powerpc implementation
- DIFFERENCE: Instead of calling prep and go at the end
- they are called if subommand is equal 0.
s/subommand/subcommand/
- if (flag & BOOTM_STATE_OS_CMDLINE)
- if (flag & BOOTM_STATE_OS_BD_T)
NAK, remove these two functions. Since the ARM linux boot requirements are different to powerpc we do not need these two states of bootm at all.
The powerpc entry_32.S (in linux) show they need commandline pointer apart from 'residual board info' pointer. The arm implementation in head.S (also linux source) says:
---8<--- * This is normally called from the decompressor code. The requirements * are: MMU = off, D-cache = off, I-cache = dont care, r0 = 0, * r1 = machine nr, r2 = atags or dtb pointer. --->8---
For arm we do not need to prepare the cmdline apart from 'bd_t', we just need to setup the ATAGS (ord FDT) which contains all information we need. This could all be done in the prep state.
- if (flag & BOOTM_STATE_OS_PREP || flag == 0)
- if (flag & BOOTM_STATE_OS_GO || flag == 0)
NAK, the ppc implementation does here
if (flag & FLAG) { do_flag_specific() return } ... do whatever to do without any flag set
which seems much cleaner to me.
I personally dislike the 'if specific flag set or no flag set then do ...' logic here.
best regards
Andreas Bießmann
Dear Andreas,
On 09/05/2011 12:58 PM, Andreas Bießmann wrote:
Dear Simon,
fixed.
Signed-off-by: Simon Schwarzsimonschwarzcor@gmail.com
fixed
V2 changes: nothing
V3 changes: nothing
#ifdefs
- Corscience GmbH& Co. KG - Simon Schwarzschwarz@corscience.de
- Sysgo Real-Time Solutions, GmbH<www.elinos.com>
- Marius Groegermgroeger@sysgo.de
@@ -32,31 +36,16 @@
ulong initrd_end);
NAK (see later on)
done.
- ulong ret;
- return ret;
udc_disconnect();
-#endif
Nope. I added something before and there were major changes in the file (moved large codejunks around)- not the best environment for a pretty diff i guess...
- char *s;
-#endif
- if ((flag != 0)&& (flag != BOOTM_STATE_OS_GO))
return 1;
- if (s) {
-#endif
- if (images->rd_start&& images->rd_end)
-#endif
-#endif
- return 1;
- ulong rd_len;
- char **of_flat_tree =&images->ft_addr;
- ulong *initrd_start =&images->initrd_start;
- ulong *initrd_end =&images->initrd_end;
- struct lmb *lmb =&images->lmb;
- int ret;
- if (ret)
return ret;
- ret = boot_relocate_fdt(lmb, of_flat_tree,&of_size);
- if (ret)
return ret;
- return 1;
udc_disconnect();
- } #endif
Hmmm. This warning is not emitted with my checkpatch.pl (V 0.31)
I readded the #ifdef CONFIG_SERIAL_TAG. This avoids the above problems.
- void setup_serial_tag (struct tag **tmp)
done.
- ulong ret;
no tab here ^
done.
- return ret;
- ulong rd_len;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
common/bootm.c calls subcommands like this: case BOOTM_STATE_OS_BD_T: ret = boot_fn(BOOTM_STATE_OS_BD_T, argc, argv, &images); if (ret) printf ("bdt subcommand not supported\n"); break;
So I assume a value different from zero is interpreted as not implemented. But as I just saw these returns were never returned to common/bootm.c ...
Anyway, removed theses functions.
hang();
- } else
My reasons to do it that way: - It is similar to create_fdt - duno if it is just me but I see this as more consistent - The requirements list will be there anyway setup_start_tag and setup_end_tag have to be protected. The only way to make it smaller would be a macro doing the same.
I have no strong feeling about how to do that but IMHO it is better readable now - if there are more votes for moving this to boot_prep_linux i will do it.
+#else
Actually it is that both aren't defined because the FDT has it's own hang in case of failure. So I will change to "FDT and ATAGS support not compiled in - hanging".
- hang();
changed.
- char *s;
No tab here ^
changed.
done.
- if (s) {
strict_strtoul(s, 16, (long unsigned int *)&machid);
Hm. I considered it too noisy since the the machid is normally not displayed on boot. Will change anyway...
Ha, this was a leftover from debugging - I deleted it.
- show_boot_progress(15);1
and here.
done
- if (flag& BOOTM_STATE_OS_CMDLINE)
- if (flag& BOOTM_STATE_OS_BD_T)
---8<---
- This is normally called from the decompressor code. The requirements
- are: MMU = off, D-cache = off, I-cache = dont care, r0 = 0,
- r1 = machine nr, r2 = atags or dtb pointer.
--->8---
changed.
But they are shown in bootm help message regardles of the architecture. Shouldn't we add #ifdefs in the help message then? (or, and I really hate to bring this up, change the way the helpmessage is created if the function is arch dependent)
- if (flag& BOOTM_STATE_OS_PREP || flag == 0)
- if (flag& BOOTM_STATE_OS_GO || flag == 0)
- return 0; }
if (flag& FLAG) { do_flag_specific() return } ... do whatever to do without any flag set
I already changed this. Just waited for more comments to send in a new version.
best regards
Andreas Bießmann
Regards & thx Simon
Dear Simon,
Am 05.09.2011 16:06, schrieb Simon Schwarz:
Dear Andreas,
Dear Simon,
<snip>
done
---8<---
--->8---
changed.
No, I don't think we should change the bootm command. We could either return 'not implemented' or 'everything is ok' here for these two flags. But we do not need extra empty functions for that.
How about:
/* OS_CMDLINE is not needed by ARM cause of ... the bootargs (==cmdline) is set in ATAGS/FDT ... */ if (flag& BOOTM_STATE_OS_CMDLINE) return 0; /* pretend everything is ok */
/* OS_BD_T is not needed by ARM casue of ... */ if (flag& BOOTM_STATE_OS_BD_T) return 0; /* pretend everything is ok */
best regards
Andreas Bießmann
This is used in command "cmd_spl export"
V2 changes: nothing
V3 changes: nothing
changes after slicing this from patch http://article.gmane.org/gmane.comp.boot-loaders.u-boot/106422: DEL Prototype declaration - not necessary if reordered DEL Most #ifdefs - relying on -ffunction-sections and --gc-sections to handle unused CHG reorganized bootm. powerpc implementation was the model ADD get_board_serial fake implementation - this is needed if setup_serial_tag is compiled but the board doesn't support it - tradeoff for removing #ifdefs CHG changed back to former not checking for zero approach
V2 changes (after split): CHG wrong comment using old savebp DEL file-wide kernel-entry forward-defintion (moved to funciton using it) DEL get_board_serial added #ifdef CONFIG_SERIAL_TAG to setup_serial_tag instead DEL boot_bd_t_linux and boot_cmdline_linux, do_bootm_linux returns -1 if they are called CHG boot_prep_linux: error text emitted CHG some typos and style problems CHG logic in do_bootm_linux to do it exactly like ppc no == 0 DEL extern from udc_disconnect - gc should do it
squash! 7d85f60647af20c52e40a8422cdb8eb91a94d0a2 --- arch/arm/lib/bootm.c | 320 ++++++++++++++++++++++++-------------------------- 1 files changed, 154 insertions(+), 166 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 802e833..e5afc7e 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -1,4 +1,8 @@ -/* +/* Copyright (C) 2011 + * Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de + * - Added prep subcommand support + * - Reorganized source - modeled after powerpc version + * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de @@ -32,31 +36,15 @@
-#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) -static void setup_start_tag (bd_t *bd); - -# ifdef CONFIG_SETUP_MEMORY_TAGS -static void setup_memory_tags (bd_t *bd); -# endif -static void setup_commandline_tag (bd_t *bd, char *commandline); - -# ifdef CONFIG_INITRD_TAG -static void setup_initrd_tag (bd_t *bd, ulong initrd_start, - ulong initrd_end); -# endif -static void setup_end_tag (bd_t *bd); - static struct tag *params; -#endif /* CONFIG_SETUP_MEMORY_TAGS || CONFIG_CMDLINE_TAG || CONFIG_INITRD_TAG */
void arch_lmb_reserve(struct lmb *lmb) { @@ -80,85 +68,6 @@ void arch_lmb_reserve(struct lmb *lmb) gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size - sp); }
-static void announce_and_cleanup(void) -{ - printf("\nStarting kernel ...\n\n"); - -#ifdef CONFIG_USB_DEVICE - { - extern void udc_disconnect(void); - udc_disconnect(); - } -#endif - cleanup_before_linux(); -} - -int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) -{ - bd_t *bd = gd->bd; - char *s; - int machid = bd->bi_arch_number; - void (*kernel_entry)(int zero, int arch, uint params); - -#ifdef CONFIG_CMDLINE_TAG - char *commandline = getenv ("bootargs"); -#endif - - if ((flag != 0) && (flag != BOOTM_STATE_OS_GO)) - return 1; - - s = getenv ("machid"); - if (s) { - machid = simple_strtoul (s, NULL, 16); - printf ("Using machid 0x%x from environment\n", machid); - } - - show_boot_progress (15); - -#ifdef CONFIG_OF_LIBFDT - if (images->ft_len) - return bootm_linux_fdt(machid, images); -#endif - - kernel_entry = (void (*)(int, int, uint))images->ep; - - debug ("## Transferring control to Linux (at address %08lx) ...\n", - (ulong) kernel_entry); - -#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) - setup_start_tag (bd); -#ifdef CONFIG_SERIAL_TAG - setup_serial_tag (¶ms); -#endif -#ifdef CONFIG_REVISION_TAG - setup_revision_tag (¶ms); -#endif -#ifdef CONFIG_SETUP_MEMORY_TAGS - setup_memory_tags (bd); -#endif -#ifdef CONFIG_CMDLINE_TAG - setup_commandline_tag (bd, commandline); -#endif -#ifdef CONFIG_INITRD_TAG - if (images->rd_start && images->rd_end) - setup_initrd_tag (bd, images->rd_start, images->rd_end); -#endif - setup_end_tag(bd); -#endif - - announce_and_cleanup(); - - kernel_entry(0, machid, bd->bi_boot_params); - /* does not return */ - - return 1; -} - -#if defined(CONFIG_OF_LIBFDT) static int fixup_memory_node(void *blob) { bd_t *bd = gd->bd; @@ -174,57 +83,21 @@ static int fixup_memory_node(void *blob) return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); }
- return 1; -} +#ifdef CONFIG_USB_DEVICE + { + udc_disconnect(); + } #endif + cleanup_before_linux(); +}
-#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) static void setup_start_tag (bd_t *bd) { - params = (struct tag *) bd->bi_boot_params; + params = (struct tag *)bd->bi_boot_params;
params->hdr.tag = ATAG_CORE; params->hdr.size = tag_size (tag_core); @@ -237,8 +110,7 @@ static void setup_start_tag (bd_t *bd) }
-#ifdef CONFIG_SETUP_MEMORY_TAGS -static void setup_memory_tags (bd_t *bd) +static void setup_memory_tags(bd_t *bd) { int i;
@@ -252,10 +124,8 @@ static void setup_memory_tags (bd_t *bd) params = tag_next (params); } } -#endif /* CONFIG_SETUP_MEMORY_TAGS */ -
-static void setup_commandline_tag (bd_t *bd, char *commandline) +static void setup_commandline_tag(bd_t *bd, char *commandline) { char *p;
@@ -280,9 +150,7 @@ static void setup_commandline_tag (bd_t *bd, char *commandline) params = tag_next (params); }
- -#ifdef CONFIG_INITRD_TAG -static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end) +static void setup_initrd_tag(bd_t *bd, ulong initrd_start, ulong initrd_end) { /* an ATAG_INITRD node tells the kernel where the compressed * ramdisk can be found. ATAG_RDIMG is a better name, actually. @@ -295,10 +163,9 @@ static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end)
#ifdef CONFIG_SERIAL_TAG -void setup_serial_tag (struct tag **tmp) +void setup_serial_tag(struct tag **tmp) { struct tag *params = *tmp; struct tag_serialnr serialnr; @@ -314,7 +181,6 @@ void setup_serial_tag (struct tag **tmp) } #endif
-#ifdef CONFIG_REVISION_TAG void setup_revision_tag(struct tag **in_params) { u32 rev = 0; @@ -326,19 +192,141 @@ void setup_revision_tag(struct tag **in_params) params->u.revision.rev = rev; params = tag_next (params); } -#endif /* CONFIG_REVISION_TAG */
-static void setup_end_tag (bd_t *bd) +static void setup_end_tag(bd_t *bd) { params->hdr.tag = ATAG_NONE; params->hdr.size = 0; } -#endif /* CONFIG_SETUP_MEMORY_TAGS || CONFIG_CMDLINE_TAG || CONFIG_INITRD_TAG */
- asm("mov %0, sp" : "=r"(ret) : ); - return ret; + setup_start_tag(bd); +#ifdef CONFIG_SERIAL_TAG + setup_serial_tag(¶ms); +#endif +#ifdef CONFIG_CMDLINE_TAG + setup_commandline_tag(gd->bd, commandline); +#endif +#ifdef CONFIG_REVISION_TAG + setup_revision_tag(¶ms); +#endif +#ifdef CONFIG_SETUP_MEMORY_TAGS + setup_memory_tags(bd); +#endif +#ifdef CONFIG_INITRD_TAG + if (images->rd_start && images->rd_end) + setup_initrd_tag(bd, images->rd_start, images->rd_end); +#endif + setup_end_tag(bd); +} + +static int create_fdt(bootm_headers_t *images) +{ + ulong of_size = images->ft_len; + char **of_flat_tree = &images->ft_addr; + ulong *initrd_start = &images->initrd_start; + ulong *initrd_end = &images->initrd_end; + struct lmb *lmb = &images->lmb; + ulong rd_len; + int ret; + + debug("using: FDT\n"); + + boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); + + rd_len = images->rd_end - images->rd_start; + ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, + initrd_start, initrd_end); + if (ret) + return ret; + + ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); + if (ret) + return ret; + + fdt_chosen(*of_flat_tree, 1); + fixup_memory_node(*of_flat_tree); + fdt_initrd(*of_flat_tree, *initrd_start, *initrd_end, 1); + + return 0; +} + +/* Subcommand: PREP */ +static void boot_prep_linux(bootm_headers_t *images) +{ +#ifdef CONFIG_OF_LIBFDT + if (images->ft_len) { + debug("using: FDT\n"); + if (create_fdt(images)) { + printf("FDT creation failed! hanging..."); + hang(); + } + } else +#endif + { +#if defined(CONFIG_SETUP_MEMORY_TAGS) || \ + defined(CONFIG_CMDLINE_TAG) || \ + defined(CONFIG_INITRD_TAG) || \ + defined(CONFIG_SERIAL_TAG) || \ + defined(CONFIG_REVISION_TAG) + debug("using: ATAGS\n"); + create_atags(images); +#else + printf("FDT and ATAGS support not compiled in - hanging\n"); + hang(); +#endif + } +} + +/* Subcommand: GO */ +static void boot_jump_linux(bootm_headers_t *images) +{ + int machid = gd->bd->bi_arch_number; + char *s; + void (*kernel_entry)(int zero, int arch, uint params); + + kernel_entry = (void (*)(int, int, uint))images->ep; + + s = getenv("machid"); + if (s) { + strict_strtoul(s, 16, (long unsigned int *) &machid); + printf("Using machid 0x%x from environment\n", machid); + } + + debug("## Transferring control to Linux (at address %08lx)" \ + "...\n", (ulong) kernel_entry); + show_boot_progress(15); + announce_and_cleanup(); + kernel_entry(0, machid, gd->bd->bi_boot_params); +} + +/* Main Entry point for arm bootm implementation + * + * Modeled after the powerpc implementation + * DIFFERENCE: Instead of calling prep and go at the end + * they are called if subcommand is equal 0. + */ +int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +{ + /* No need for those on ARM */ + if (flag & BOOTM_STATE_OS_BD_T || flag & BOOTM_STATE_OS_CMDLINE) + return -1; + + if (flag & BOOTM_STATE_OS_PREP) { + boot_prep_linux(images); + return 0; + } + + if (flag & BOOTM_STATE_OS_GO) { + boot_jump_linux(images); + return 0; + } + + boot_prep_linux(images); + boot_jump_linux(images); + return 0; }
V2 changes: nothing
V3 changes: nothing
V3 changes: ADD some #ifdefs to prevent compile errors and warnings FIX build warnings regarding atags creation functions. Added #ifdefs FIX compile warning implicit declaration of udc_disconnect. added bootm.h REBASED on u-boot-ti --- arch/arm/include/asm/bootm.h | 26 ++++ arch/arm/lib/bootm.c | 339 ++++++++++++++++++++++-------------------- 2 files changed, 202 insertions(+), 163 deletions(-) create mode 100644 arch/arm/include/asm/bootm.h
diff --git a/arch/arm/include/asm/bootm.h b/arch/arm/include/asm/bootm.h new file mode 100644 index 0000000..db2ff94 --- /dev/null +++ b/arch/arm/include/asm/bootm.h @@ -0,0 +1,26 @@ +/* Copyright (C) 2011 + * Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ +#ifndef ARM_BOOTM_H +#define ARM_BOOTM_H + +#ifdef CONFIG_USB_DEVICE +extern void udc_disconnect(void); +#endif + +#endif diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 802e833..03c25e9 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -1,4 +1,8 @@ -/* +/* Copyright (C) 2011 + * Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de + * - Added prep subcommand support + * - Reorganized source - modeled after powerpc version + * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de @@ -29,35 +33,26 @@ #include <fdt.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/bootm.h>
-#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) -static void setup_start_tag (bd_t *bd); - -# ifdef CONFIG_SETUP_MEMORY_TAGS -static void setup_memory_tags (bd_t *bd); -# endif -static void setup_commandline_tag (bd_t *bd, char *commandline); - -# ifdef CONFIG_INITRD_TAG -static void setup_initrd_tag (bd_t *bd, ulong initrd_start, - ulong initrd_end); -# endif -static void setup_end_tag (bd_t *bd); - +#if defined(CONFIG_SETUP_MEMORY_TAGS) || \ + defined(CONFIG_CMDLINE_TAG) || \ + defined(CONFIG_INITRD_TAG) || \ + defined(CONFIG_SERIAL_TAG) || \ + defined(CONFIG_REVISION_TAG) static struct tag *params; -#endif /* CONFIG_SETUP_MEMORY_TAGS || CONFIG_CMDLINE_TAG || CONFIG_INITRD_TAG */ - -static ulong get_sp(void); -#if defined(CONFIG_OF_LIBFDT) -static int bootm_linux_fdt(int machid, bootm_headers_t *images); #endif
+static ulong get_sp(void) +{ + ulong ret; + + asm("mov %0, sp" : "=r"(ret) : ); + return ret; +} + void arch_lmb_reserve(struct lmb *lmb) { ulong sp; @@ -80,85 +75,7 @@ void arch_lmb_reserve(struct lmb *lmb) gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size - sp); }
-static void announce_and_cleanup(void) -{ - printf("\nStarting kernel ...\n\n"); - -#ifdef CONFIG_USB_DEVICE - { - extern void udc_disconnect(void); - udc_disconnect(); - } -#endif - cleanup_before_linux(); -} - -int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) -{ - bd_t *bd = gd->bd; - char *s; - int machid = bd->bi_arch_number; - void (*kernel_entry)(int zero, int arch, uint params); - -#ifdef CONFIG_CMDLINE_TAG - char *commandline = getenv ("bootargs"); -#endif - - if ((flag != 0) && (flag != BOOTM_STATE_OS_GO)) - return 1; - - s = getenv ("machid"); - if (s) { - machid = simple_strtoul (s, NULL, 16); - printf ("Using machid 0x%x from environment\n", machid); - } - - show_boot_progress (15); - #ifdef CONFIG_OF_LIBFDT - if (images->ft_len) - return bootm_linux_fdt(machid, images); -#endif - - kernel_entry = (void (*)(int, int, uint))images->ep; - - debug ("## Transferring control to Linux (at address %08lx) ...\n", - (ulong) kernel_entry); - -#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) - setup_start_tag (bd); -#ifdef CONFIG_SERIAL_TAG - setup_serial_tag (¶ms); -#endif -#ifdef CONFIG_REVISION_TAG - setup_revision_tag (¶ms); -#endif -#ifdef CONFIG_SETUP_MEMORY_TAGS - setup_memory_tags (bd); -#endif -#ifdef CONFIG_CMDLINE_TAG - setup_commandline_tag (bd, commandline); -#endif -#ifdef CONFIG_INITRD_TAG - if (images->rd_start && images->rd_end) - setup_initrd_tag (bd, images->rd_start, images->rd_end); -#endif - setup_end_tag(bd); -#endif - - announce_and_cleanup(); - - kernel_entry(0, machid, bd->bi_boot_params); - /* does not return */ - - return 1; -} - -#if defined(CONFIG_OF_LIBFDT) static int fixup_memory_node(void *blob) { bd_t *bd = gd->bd; @@ -173,58 +90,26 @@ static int fixup_memory_node(void *blob)
return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); } +#endif
- return 1; -} +#ifdef CONFIG_USB_DEVICE + udc_disconnect(); #endif + cleanup_before_linux(); +}
-#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) +#if defined(CONFIG_SETUP_MEMORY_TAGS) || \ + defined(CONFIG_CMDLINE_TAG) || \ + defined(CONFIG_INITRD_TAG) || \ + defined(CONFIG_SERIAL_TAG) || \ + defined(CONFIG_REVISION_TAG) static void setup_start_tag (bd_t *bd) { - params = (struct tag *) bd->bi_boot_params; + params = (struct tag *)bd->bi_boot_params;
params->hdr.tag = ATAG_CORE; params->hdr.size = tag_size (tag_core); @@ -235,10 +120,10 @@ static void setup_start_tag (bd_t *bd)
params = tag_next (params); } - +#endif
@@ -252,10 +137,10 @@ static void setup_memory_tags (bd_t *bd) params = tag_next (params); } } -#endif /* CONFIG_SETUP_MEMORY_TAGS */ - +#endif
-static void setup_commandline_tag (bd_t *bd, char *commandline) +#ifdef CONFIG_CMDLINE_TAG +static void setup_commandline_tag(bd_t *bd, char *commandline) { char *p;
@@ -279,10 +164,10 @@ static void setup_commandline_tag (bd_t *bd, char *commandline)
#ifdef CONFIG_INITRD_TAG -static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end) +static void setup_initrd_tag(bd_t *bd, ulong initrd_start, ulong initrd_end) { /* an ATAG_INITRD node tells the kernel where the compressed * ramdisk can be found. ATAG_RDIMG is a better name, actually. @@ -295,10 +180,10 @@ static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end)
params = tag_next (params); } -#endif /* CONFIG_INITRD_TAG */ +#endif
#ifdef CONFIG_SERIAL_TAG -void setup_serial_tag (struct tag **tmp) +void setup_serial_tag(struct tag **tmp) { struct tag *params = *tmp; struct tag_serialnr serialnr; @@ -326,19 +211,147 @@ void setup_revision_tag(struct tag **in_params) params->u.revision.rev = rev; params = tag_next (params); } -#endif /* CONFIG_REVISION_TAG */ +#endif
-static void setup_end_tag (bd_t *bd) +#if defined(CONFIG_SETUP_MEMORY_TAGS) || \ + defined(CONFIG_CMDLINE_TAG) || \ + defined(CONFIG_INITRD_TAG) || \ + defined(CONFIG_SERIAL_TAG) || \ + defined(CONFIG_REVISION_TAG) +static void setup_end_tag(bd_t *bd) { params->hdr.tag = ATAG_NONE; params->hdr.size = 0; } -#endif /* CONFIG_SETUP_MEMORY_TAGS || CONFIG_CMDLINE_TAG || CONFIG_INITRD_TAG */ +#endif
-static ulong get_sp(void) +#ifdef CONFIG_OF_LIBFDT +static int create_fdt(bootm_headers_t *images) { - ulong ret; + ulong of_size = images->ft_len; + char **of_flat_tree = &images->ft_addr; + ulong *initrd_start = &images->initrd_start; + ulong *initrd_end = &images->initrd_end; + struct lmb *lmb = &images->lmb; + ulong rd_len; + int ret;
- asm("mov %0, sp" : "=r"(ret) : ); - return ret; + debug("using: FDT\n"); + + boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); + + rd_len = images->rd_end - images->rd_start; + ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, + initrd_start, initrd_end); + if (ret) + return ret; + + ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); + if (ret) + return ret; + + fdt_chosen(*of_flat_tree, 1); + fixup_memory_node(*of_flat_tree); + fdt_initrd(*of_flat_tree, *initrd_start, *initrd_end, 1); + + return 0; +} +#endif + +/* Subcommand: PREP */ +static void boot_prep_linux(bootm_headers_t *images) +{ +#ifdef CONFIG_CMDLINE_TAG + char *commandline = getenv("bootargs"); +#endif + +#ifdef CONFIG_OF_LIBFDT + if (images->ft_len) { + debug("using: FDT\n"); + if (create_fdt(images)) { + printf("FDT creation failed! hanging..."); + hang(); + } + } else +#endif + { +#if defined(CONFIG_SETUP_MEMORY_TAGS) || \ + defined(CONFIG_CMDLINE_TAG) || \ + defined(CONFIG_INITRD_TAG) || \ + defined(CONFIG_SERIAL_TAG) || \ + defined(CONFIG_REVISION_TAG) + debug("using: ATAGS\n"); + setup_start_tag(gd->bd); +#ifdef CONFIG_SERIAL_TAG + setup_serial_tag(¶ms); +#endif +#ifdef CONFIG_CMDLINE_TAG + setup_commandline_tag(gd->bd, commandline); +#endif +#ifdef CONFIG_REVISION_TAG + setup_revision_tag(¶ms); +#endif +#ifdef CONFIG_SETUP_MEMORY_TAGS + setup_memory_tags(gd->bd); +#endif +#ifdef CONFIG_INITRD_TAG + if (images->rd_start && images->rd_end) + setup_initrd_tag(gd->bd, images->rd_start, + images->rd_end); +#endif + setup_end_tag(gd->bd); +#else /* all tags */ + printf("FDT and ATAGS support not compiled in - hanging\n"); + hang(); +#endif /* all tags */ + } +} + +/* Subcommand: GO */ +static void boot_jump_linux(bootm_headers_t *images) +{ + int machid = gd->bd->bi_arch_number; + char *s; + void (*kernel_entry)(int zero, int arch, uint params); + + kernel_entry = (void (*)(int, int, uint))images->ep; + + s = getenv("machid"); + if (s) { + strict_strtoul(s, 16, (long unsigned int *) &machid); + printf("Using machid 0x%x from environment\n", machid); + } + + debug("## Transferring control to Linux (at address %08lx)" \ + "...\n", (ulong) kernel_entry); + show_boot_progress(15); + announce_and_cleanup(); + kernel_entry(0, machid, gd->bd->bi_boot_params); +} + +/* Main Entry point for arm bootm implementation + * + * Modeled after the powerpc implementation + * DIFFERENCE: Instead of calling prep and go at the end + * they are called if subcommand is equal 0. + */ +int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) +{ + /* No need for those on ARM */ + if (flag & BOOTM_STATE_OS_BD_T || flag & BOOTM_STATE_OS_CMDLINE) + return -1; + + if (flag & BOOTM_STATE_OS_PREP) { + boot_prep_linux(images); + return 0; + } + + if (flag & BOOTM_STATE_OS_GO) { + boot_jump_linux(images); + return 0; + } + + boot_prep_linux(images); + boot_jump_linux(images); + return 0; }
V2 changes: nothing
V3 changes: nothing
V4 changes: REBASED on u-boot --- arch/arm/include/asm/bootm.h | 26 ++++ arch/arm/lib/bootm.c | 339 ++++++++++++++++++++++-------------------- 2 files changed, 202 insertions(+), 163 deletions(-) create mode 100644 arch/arm/include/asm/bootm.h
--- V2 changes: nothing
V3 changes: nothing
V5 changes: REBASED on u-boot 2012/01/15 --- arch/arm/include/asm/bootm.h | 26 ++++ arch/arm/lib/bootm.c | 341 ++++++++++++++++++++++-------------------- 2 files changed, 202 insertions(+), 165 deletions(-) create mode 100644 arch/arm/include/asm/bootm.h
diff --git a/arch/arm/include/asm/bootm.h b/arch/arm/include/asm/bootm.h new file mode 100644 index 0000000..db2ff94 --- /dev/null +++ b/arch/arm/include/asm/bootm.h @@ -0,0 +1,26 @@ +/* Copyright (C) 2011 + * Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ +#ifndef ARM_BOOTM_H +#define ARM_BOOTM_H + +#ifdef CONFIG_USB_DEVICE +extern void udc_disconnect(void); +#endif + +#endif diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index afa0093..03c25e9 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -1,4 +1,8 @@ -/* +/* Copyright (C) 2011 + * Corscience GmbH & Co. KG - Simon Schwarz schwarz@corscience.de + * - Added prep subcommand support + * - Reorganized source - modeled after powerpc version + * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de @@ -29,35 +33,26 @@ #include <fdt.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/bootm.h>
-static void announce_and_cleanup(void) -{ - printf("\nStarting kernel ...\n\n"); - -#ifdef CONFIG_USB_DEVICE - { - extern void udc_disconnect(void); - udc_disconnect(); - } -#endif - cleanup_before_linux(); -} - -int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) -{ - bd_t *bd = gd->bd; - char *s; - int machid = bd->bi_arch_number; - void (*kernel_entry)(int zero, int arch, uint params); - -#ifdef CONFIG_CMDLINE_TAG - char *commandline = getenv ("bootargs"); -#endif - - if ((flag != 0) && (flag != BOOTM_STATE_OS_GO)) - return 1; - - s = getenv ("machid"); - if (s) { - machid = simple_strtoul (s, NULL, 16); - printf ("Using machid 0x%x from environment\n", machid); - } - - show_boot_progress (15); - #ifdef CONFIG_OF_LIBFDT - if (images->ft_len) - return bootm_linux_fdt(machid, images); -#endif - - kernel_entry = (void (*)(int, int, uint))images->ep; - - debug ("## Transferring control to Linux (at address %08lx) ...\n", - (ulong) kernel_entry); - -#if defined (CONFIG_SETUP_MEMORY_TAGS) || \ - defined (CONFIG_CMDLINE_TAG) || \ - defined (CONFIG_INITRD_TAG) || \ - defined (CONFIG_SERIAL_TAG) || \ - defined (CONFIG_REVISION_TAG) - setup_start_tag (bd); -#ifdef CONFIG_SERIAL_TAG - setup_serial_tag (¶ms); -#endif -#ifdef CONFIG_REVISION_TAG - setup_revision_tag (¶ms); -#endif -#ifdef CONFIG_SETUP_MEMORY_TAGS - setup_memory_tags (bd); -#endif -#ifdef CONFIG_CMDLINE_TAG - setup_commandline_tag (bd, commandline); -#endif -#ifdef CONFIG_INITRD_TAG - if (images->rd_start && images->rd_end) - setup_initrd_tag (bd, images->rd_start, images->rd_end); -#endif - setup_end_tag(bd); -#endif - - announce_and_cleanup(); - - kernel_entry(0, machid, bd->bi_boot_params); - /* does not return */ - - return 1; -} - -#if defined(CONFIG_OF_LIBFDT) static int fixup_memory_node(void *blob) { bd_t *bd = gd->bd; @@ -173,60 +90,26 @@ static int fixup_memory_node(void *blob)
-static int bootm_linux_fdt(int machid, bootm_headers_t *images) +static void announce_and_cleanup(void) { - ulong rd_len; - void (*kernel_entry)(int zero, int dt_machid, void *dtblob); - ulong of_size = images->ft_len; - char **of_flat_tree = &images->ft_addr; - ulong *initrd_start = &images->initrd_start; - ulong *initrd_end = &images->initrd_end; - struct lmb *lmb = &images->lmb; - int ret; - - kernel_entry = (void (*)(int, int, void *))images->ep; - - boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); - - rd_len = images->rd_end - images->rd_start; - ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, - initrd_start, initrd_end); - if (ret) - return ret; - - ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); - if (ret) - return ret; - - debug("## Transferring control to Linux (at address %08lx) ...\n", - (ulong) kernel_entry); - - fdt_chosen(*of_flat_tree, 1); - - fixup_memory_node(*of_flat_tree); - - fdt_fixup_ethernet(*of_flat_tree); - - fdt_initrd(*of_flat_tree, *initrd_start, *initrd_end, 1); - - announce_and_cleanup(); - - kernel_entry(0, machid, *of_flat_tree); - /* does not return */ + printf("\nStarting kernel ...\n\n");
params->hdr.tag = ATAG_CORE; params->hdr.size = tag_size (tag_core); @@ -237,10 +120,10 @@ static void setup_start_tag (bd_t *bd)
@@ -254,10 +137,10 @@ static void setup_memory_tags (bd_t *bd) params = tag_next (params); } } -#endif /* CONFIG_SETUP_MEMORY_TAGS */ - +#endif
@@ -281,10 +164,10 @@ static void setup_commandline_tag (bd_t *bd, char *commandline)
#ifdef CONFIG_INITRD_TAG -static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end) +static void setup_initrd_tag(bd_t *bd, ulong initrd_start, ulong initrd_end) { /* an ATAG_INITRD node tells the kernel where the compressed * ramdisk can be found. ATAG_RDIMG is a better name, actually. @@ -297,10 +180,10 @@ static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end)
#ifdef CONFIG_SERIAL_TAG -void setup_serial_tag (struct tag **tmp) +void setup_serial_tag(struct tag **tmp) { struct tag *params = *tmp; struct tag_serialnr serialnr; @@ -328,19 +211,147 @@ void setup_revision_tag(struct tag **in_params) params->u.revision.rev = rev; params = tag_next (params); } -#endif /* CONFIG_REVISION_TAG */ +#endif
Acked-by: Stefano Babic sbabic@denx.de Tested-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Andreas Bießmann
Simon Schwarz
Stefano Babic
