[U-Boot-Users] Lowering memory footprint
Hi Wolfgang et all,
I ported U-Boot to OMAP5910 based board and before submiting patch I'd like to discuss few issues.
Board has 64M RAM and 32M bit mirror flash, which is quite sufficient to run U-Boot under normal circumstancies. During production of prototypes I met few boards with bad printed circuit board or bad soldering. Therefore I decided to run U-Boot from OMAP's 192kB internal RAM located at 2000'0000-2002'ffff with TEXT_BASE set to 2001'2000. That way I have 64kB heap and 8kB stack, which I found is sufficient for my needs. Such setup helps a lot while debugging hardware problems, despite I know it could be done different way, but it would be pity not to use U-Boot's power :)
Because CFG_MALLOC_LEN is 64k-128 something like this is needed to startup code:
Index: cpu/arm925t/start.S =================================================================== RCS file: /cvsroot/u-boot/u-boot/cpu/arm925t/start.S,v retrieving revision 1.8 diff -u -r1.8 start.S --- cpu/arm925t/start.S 9 Jan 2005 17:12:29 -0000 1.8 +++ cpu/arm925t/start.S 12 Jan 2005 12:45:27 -0000 @@ -83,6 +83,10 @@
_TEXT_BASE: .word TEXT_BASE +_STACK_OFS: + .word CFG_MALLOC_LEN + CFG_GBL_DATA_SIZE +_BAD_STACK_OFS: + .word CFG_MALLOC_LEN + CFG_GBL_DATA_SIZE + CONFIG_STACKSIZE + 8
.globl _armboot_start _armboot_start: @@ -188,8 +192,8 @@ /* Set up the stack */ stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ - sub r0, r0, #CFG_MALLOC_LEN /* malloc area */ - sub r0, r0, #CFG_GBL_DATA_SIZE /* bdinfo */ + ldr r1, _STACK_OFS + sub r0, r0, r1 /* malloc area and bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -293,8 +297,8 @@ stmia sp, {r0 - r12} @ Save user registers (now in svc mode) r0-r12
ldr r2, _armboot_start - sub r2, r2, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN) - sub r2, r2, #(CFG_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + ldr r13, _BAD_STACK_OFS + sub r2, r2, r13 ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack
@@ -326,8 +330,8 @@
.macro get_bad_stack ldr r13, _armboot_start @ setup our mode stack - sub r13, r13, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN) - sub r13, r13, #(CFG_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + ldr r2, _BAD_STACK_OFS + sub r13, r13, r2
str lr, [r13] @ save caller lr in position 0 of saved stack mrs lr, spsr @ get the spsr
Flash is partitioned this way: 128k - U-Boot 128k - env 16256k - data1 16256k - data2
Kernel is loaded directly from jffs2 partition to ease firmware upgrating. New firmware is unpacked into other partion (after user data are backed out) and if it boots sucessfuly U-Boot env is changed permanetly. Otherwise watchdog resets board and old firmware is used again.
Although only following commands are enabled: CFG_CMD_BDI, CFG_CMD_LOADB, CFG_CMD_IMI, CFG_CMD_FLASH, CFG_CMD_MEMORY, CFG_CMD_NET, CFG_CMD_ENV, CFG_CMD_BOOTD, CFG_CMD_DHCP, CFG_CMD_PING, CFG_CMD_JFFS2, there is not enough space to fit U-Boot into 120kB without ripping out CramFS support. My question is whenever I should make only CramFS selectable or allow choice between JFFS2 and/or CramFS and how should be such configuration handled (you know it's quite hard for me to come with some nice short descriptive names :))
And finally ~64k heap is not sufficient for zlib to decompress kernel after it is loaded from jffs2 partition, because node structures are still allocated. I hope it is reasonable to expect, that once file is loaded it is intended to execute it and free memory used by jffs2 private structures.
Index: fs/jffs2/jffs2_1pass.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/fs/jffs2/jffs2_1pass.c,v retrieving revision 1.15 diff -u -p -r1.15 jffs2_1pass.c --- fs/jffs2/jffs2_1pass.c 12 May 2004 22:54:39 -0000 1.15 +++ fs/jffs2/jffs2_1pass.c 12 Jan 2005 13:17:58 -0000 @@ -467,8 +467,8 @@ jffs2_scan_empty(u32 start_offset, struc return offset - part->offset; }
-static u32 -jffs_init_1pass_list(struct part_info *part) +static void +jffs_1pass_free_nodes(struct part_info *part) { struct b_lists *pL;
@@ -478,6 +478,16 @@ jffs_init_1pass_list(struct part_info *p free_nodes(&pL->dir); free(pL); } + part->jffs2_priv = NULL; +} + +static u32 +jffs_init_1pass_list(struct part_info *part) +{ + struct b_lists *pL; + + jffs_1pass_free_nodes(part); + if (NULL != (part->jffs2_priv = malloc(sizeof(struct b_lists)))) { pL = (struct b_lists *)part->jffs2_priv;
@@ -1267,6 +1277,9 @@ jffs2_1pass_load(char *dest, struct part
DEBUGF ("load: loaded '%s' to 0x%lx (%ld bytes)\n", fname, (unsigned long) dest, ret); + + jffs_1pass_free_nodes(part); + return ret; }
Comments and suggestions are welcome (even those which suggest to use completely different solution ;)). I'll eventually send final patches based on eventual discussion.
Best regards, ladis
Wolfgang, so far it seems that you answer only those my mails you completely disagree with :). However it would be silly to assume that you do not have any objection in this case. Please understand that I want maintain board support inside U-Boot tree. If you do not like proposed changes, one word is enough, I'll roll them back and will use main system memory again.
thanks, ladis
That would mean semy-complete disagreement, as I try to answer all questions - at least those for which I (think I) know an answer, and which haven't been answered by others before.
This seems unlikely...
Your patch is maked as "open" on my list. I don't have any chance to test it as we don't have such hardware. So far I didn't receive any other feedback on is. Assume that it's on my list of poatches to work on - it's number 90 out of a total of 116 so far :-(
I see, I do not want to push on you. To make things easier, I'm dropping this idea and will use 64M SDRAM. That will allow me to provide board specific patch first, which doesn't interact with the rest of U-Boot code. We can discuss it later and there is also possibility to provide you testing hardware.
Best regards, ladis
Just to be sure: does that mean that I can / shall drop your patch?
Yes, except cpu/arm925t/start.S part. I would be happy if anyone could review it for correctness. I'm not sure if it is safe to use new register in get_bad_stack.
Thanks, ladis
Dear Ladislav,
- .word CFG_MALLOC_LEN + CFG_GBL_DATA_SIZE
+_BAD_STACK_OFS:
- .word CFG_MALLOC_LEN + CFG_GBL_DATA_SIZE + CONFIG_STACKSIZE + 8
- ldr r1, _STACK_OFS
- sub r0, r0, r1 /* malloc area and bdinfo */
- ldr r13, _BAD_STACK_OFS
- sub r2, r2, r13 ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack
@@ -326,8 +330,8 @@
sub r13, r13, r2
So far I haven't seen any comments on this list.
Anybody out there to check if this is OK?
At first glance I don't see much difference between using the constants as immediate operands versus your version (except that you're using additional registers). Can you please explain (again) what the modification is trying to fix?
Ladislav Michl
