[U-Boot] [PATCH] mmc: Fix mmc bus width
After setting the bus width, the extended CSD register is read. Some selected fields are compared with previously read extended CSD register fields. In this comparison the EXT_CSD_ERASE_GROUP_DEF field is compared. But this field is previously written under certain circumstances. And then the comparison fails.
Only compare read-only fields. Therefore compare field EXT_CSD_HC_WP_GRP_SIZE instead of field EXT_CSD_ERASE_GROUP_DEF.
Signed-off-by: Mario Schuknecht mario.schuknecht@dresearch-fe.de --- drivers/mmc/mmc.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index a26f3ce..d1faa9f 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1127,10 +1127,11 @@ static int mmc_startup(struct mmc *mmc) mmc_set_bus_width(mmc, widths[idx]);
err = mmc_send_ext_csd(mmc, test_csd); + /* Only compare read only fields */ if (!err && ext_csd[EXT_CSD_PARTITIONING_SUPPORT] \ == test_csd[EXT_CSD_PARTITIONING_SUPPORT] - && ext_csd[EXT_CSD_ERASE_GROUP_DEF] \ - == test_csd[EXT_CSD_ERASE_GROUP_DEF] \ + && ext_csd[EXT_CSD_HC_WP_GRP_SIZE] \ + == test_csd[EXT_CSD_HC_WP_GRP_SIZE] \ && ext_csd[EXT_CSD_REV] \ == test_csd[EXT_CSD_REV] && ext_csd[EXT_CSD_HC_ERASE_GRP_SIZE] \
Hi Mario,
On Sep 30, 2014, at 6:04 PM, Mario Schuknecht mario.schuknecht@dresearch-fe.de wrote:
-- 1.8.4.5
Applied, thanks.
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Mario Schuknecht
Pantelis Antoniou
