[U-Boot] [PATCH] ARM:tegra20: Remove aes debug prints
In 6e7b9f4 some of the debug prints for AES code moved into the generic code, so we remove these additional calls.
Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/tegra20-common/crypto.c | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/arch/arm/cpu/tegra20-common/crypto.c b/arch/arm/cpu/tegra20-common/crypto.c index b18e67c..1382425 100644 --- a/arch/arm/cpu/tegra20-common/crypto.c +++ b/arch/arm/cpu/tegra20-common/crypto.c @@ -62,14 +62,11 @@ static void sign_object(u8 *key, u8 *key_schedule, u8 *src, u8 *dst, tmp_data[i] = 0;
aes_cbc_encrypt_blocks(key_schedule, tmp_data, left, 1); - debug_print_vector("AES(key, nonce)", AES_KEY_LENGTH, left);
left_shift_vector(left, k1, sizeof(left)); - debug_print_vector("L", AES_KEY_LENGTH, left);
if ((left[0] >> 7) != 0) /* get MSB of L */ k1[AES_KEY_LENGTH-1] ^= AES_CMAC_CONST_RB; - debug_print_vector("K1", AES_KEY_LENGTH, k1);
/* compute the AES-CMAC value */ for (i = 0; i < num_aes_blocks; i++) { @@ -84,16 +81,11 @@ static void sign_object(u8 *key, u8 *key_schedule, u8 *src, u8 *dst, aes_encrypt(tmp_data, key_schedule, dst);
debug("sign_obj: block %d of %d\n", i, num_aes_blocks); - debug_print_vector("AES-CMAC Src", AES_KEY_LENGTH, src); - debug_print_vector("AES-CMAC Xor", AES_KEY_LENGTH, tmp_data); - debug_print_vector("AES-CMAC Dst", AES_KEY_LENGTH, dst);
/* Update pointers for next loop. */ cbc_chain_data = dst; src += AES_KEY_LENGTH; } - - debug_print_vector("AES-CMAC Hash", AES_KEY_LENGTH, dst); }
/** @@ -112,7 +104,6 @@ static int encrypt_and_sign(u8 *key, enum security_op oper, u8 *src, u8 key_schedule[AES_EXPAND_KEY_LENGTH];
debug("encrypt_and_sign: length = %d\n", length); - debug_print_vector("AES key", AES_KEY_LENGTH, key);
/* * The only need for a key is for signing/checksum purposes, so
Signed-off-by: Tom Rini trini@ti.com Acked-by: Tom Warren twarren@nvidia.com
