[U-Boot] [PATCH] net: MVGBE don't automatically select PHYLIB
Not all users of MVGBE need PHYLIB and it increases the size of the openrd images too much.
Fixes: commit ed52ea507f12 ("net: add Kconfig for MVGBE") Signed-off-by: Chris Packham judge.packham@gmail.com Cc: Tom Rini trini@konsulko.com Cc: Stefan Roese sr@denx.de ---
drivers/net/Kconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index c962d7a72c0c..f2cc75f494e8 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -181,7 +181,6 @@ config FTMAC100 config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" depends on KIRKWOOD || ORION5X - select PHYLIB help This driver supports the network interface units in the Marvell Orion5x and Kirkwood SoCs
Thanks, Stefan
Hi Joe,
Joe, are you okay with me pulling this patch via the Marvell repository? As it fixes a size limitation error on some of the Kirkwood board, where I have some device-tree patches queued.
Thanks, Stefan
This results in phylib never being set now as the configs were getting it implicitly. Do any of the boards need it? Thanks!
I compile tested the affected boards and they all build. I've fired this at github and should have some travis results soon.
My mistake was to copy the mvneta kconfig which had the select. Commit ed52ea507f ("net: add Kconfig for MVGBE") didn't remove any CONFIG_PHYLIB lines so if they need it it's already in the board.h file or selected somewhere else.
On 17.05.2018 13:53, Chris Packham wrote:
On Thu, 17 May 2018, 11:09 PM Tom Rini, <trini@konsulko.com mailto:trini@konsulko.com> wrote:
On Thu, May 17, 2018 at 09:03:15PM +1200, Chris Packham wrote: > Not all users of MVGBE need PHYLIB and it increases the size of the > openrd images too much. > > Fixes: commit ed52ea507f12 ("net: add Kconfig for MVGBE") > Signed-off-by: Chris Packham <judge.packham@gmail.com <mailto:judge.packham@gmail.com>> > Cc: Tom Rini <trini@konsulko.com <mailto:trini@konsulko.com>> > Cc: Stefan Roese <sr@denx.de <mailto:sr@denx.de>> > --- > > drivers/net/Kconfig | 1 - > 1 file changed, 1 deletion(-) > > diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig > index c962d7a72c0c..f2cc75f494e8 100644 > --- a/drivers/net/Kconfig > +++ b/drivers/net/Kconfig > @@ -181,7 +181,6 @@ config FTMAC100 > config MVGBE > bool "Marvell Orion5x/Kirkwood network interface support" > depends on KIRKWOOD || ORION5X > - select PHYLIB > help > This driver supports the network interface units in the > Marvell Orion5x and Kirkwood SoCs This results in phylib never being set now as the configs were getting it implicitly. Do any of the boards need it?
Yes, this is also my understanding. ed52ea507f ("net: add Kconfig for MVGBE") selected PHYLIB via Kconfig, which changed the configuration for these Kirkwood boards. *If* some of them needed / selected PHYLIB before this patch, it was most likely done in their config header.
So this patch restores the board configuration again. PHYLIB is not needed for MVGBE - it compiles without it as well.
Thanks, Stefan
On Thu, May 17, 2018 at 09:03:15PM +1200, Chris Packham wrote: > Not all users of MVGBE need PHYLIB and it increases the size of the > openrd images too much. > > Fixes: commit ed52ea507f12 ("net: add Kconfig for MVGBE") > Signed-off-by: Chris Packham <judge.packham@gmail.com mailto:judge.packham@gmail.com> > Cc: Tom Rini <trini@konsulko.com mailto:trini@konsulko.com> > Cc: Stefan Roese <sr@denx.de mailto:sr@denx.de> > --- > > drivers/net/Kconfig | 1 - > 1 file changed, 1 deletion(-) > > diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig > index c962d7a72c0c..f2cc75f494e8 100644 > --- a/drivers/net/Kconfig > +++ b/drivers/net/Kconfig > @@ -181,7 +181,6 @@ config FTMAC100 > config MVGBE > bool "Marvell Orion5x/Kirkwood network interface support" > depends on KIRKWOOD || ORION5X > - select PHYLIB > help > This driver supports the network interface units in the > Marvell Orion5x and Kirkwood SoCs
OK, thanks. Can you please do a v2 with a commit message that reflects this and a Fixes tag?
the
getting
this
CONFIG_PHYLIB
Done http://patchwork.ozlabs.org/patch/915392/ Travis builds running now https://travis-ci.org/cpackham/u-boot/builds/380175749
Chris Packham
Stefan Roese
