[U-Boot] [PATCH] net: designware: Zap trailing backslash
Trailing backslashes are necessary only in macros, not in the actual code, so remove them.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/designware.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index a6c39c3..2447bc7 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -107,8 +107,8 @@ static void tx_descs_init(struct dw_eth_dev *priv)
#if defined(CONFIG_DW_ALTDESCRIPTOR) desc_p->txrx_status &= ~(DESC_TXSTS_TXINT | DESC_TXSTS_TXLAST | - DESC_TXSTS_TXFIRST | DESC_TXSTS_TXCRCDIS | \ - DESC_TXSTS_TXCHECKINSCTRL | \ + DESC_TXSTS_TXFIRST | DESC_TXSTS_TXCRCDIS | + DESC_TXSTS_TXCHECKINSCTRL | DESC_TXSTS_TXRINGEND | DESC_TXSTS_TXPADDIS);
desc_p->txrx_status |= DESC_TXSTS_TXCHAIN; @@ -155,7 +155,7 @@ static void rx_descs_init(struct dw_eth_dev *priv) desc_p->dmamac_next = &desc_table_p[idx + 1];
desc_p->dmamac_cntl = - (MAC_MAX_FRAME_SZ & DESC_RXCTRL_SIZE1MASK) | \ + (MAC_MAX_FRAME_SZ & DESC_RXCTRL_SIZE1MASK) | DESC_RXCTRL_RXCHAIN;
desc_p->txrx_status = DESC_RXSTS_OWNBYDMA; @@ -321,14 +321,14 @@ static int _dw_eth_send(struct dw_eth_dev *priv, void *packet, int length)
#if defined(CONFIG_DW_ALTDESCRIPTOR) desc_p->txrx_status |= DESC_TXSTS_TXFIRST | DESC_TXSTS_TXLAST; - desc_p->dmamac_cntl |= (length << DESC_TXCTRL_SIZE1SHFT) & \ + desc_p->dmamac_cntl |= (length << DESC_TXCTRL_SIZE1SHFT) & DESC_TXCTRL_SIZE1MASK;
desc_p->txrx_status &= ~(DESC_TXSTS_MSK); desc_p->txrx_status |= DESC_TXSTS_OWNBYDMA; #else - desc_p->dmamac_cntl |= ((length << DESC_TXCTRL_SIZE1SHFT) & \ - DESC_TXCTRL_SIZE1MASK) | DESC_TXCTRL_TXLAST | \ + desc_p->dmamac_cntl |= ((length << DESC_TXCTRL_SIZE1SHFT) & + DESC_TXCTRL_SIZE1MASK) | DESC_TXCTRL_TXLAST | DESC_TXCTRL_TXFIRST;
desc_p->txrx_status = DESC_TXSTS_OWNBYDMA; @@ -368,7 +368,7 @@ static int _dw_eth_recv(struct dw_eth_dev *priv, uchar **packetp) /* Check if the owner is the CPU */ if (!(status & DESC_RXSTS_OWNBYDMA)) {
- length = (status & DESC_RXSTS_FRMLENMSK) >> \ + length = (status & DESC_RXSTS_FRMLENMSK) >> DESC_RXSTS_FRMLENSHFT;
/* Invalidate received data */
Applied, thanks.
Best regards, Marek Vasut
Bin Meng
