[U-Boot] [PATCH] ARM: uniphier: enable CONFIG_CMD_CONFIG
This command is useful to see which config options are enabled on the running U-Boot image.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
configs/uniphier_ld11_defconfig | 1 + configs/uniphier_ld20_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + 7 files changed, 7 insertions(+)
diff --git a/configs/uniphier_ld11_defconfig b/configs/uniphier_ld11_defconfig index a0aa87b..e5cfab6 100644 --- a/configs/uniphier_ld11_defconfig +++ b/configs/uniphier_ld11_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld11-ref" CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_GPT=y diff --git a/configs/uniphier_ld20_defconfig b/configs/uniphier_ld20_defconfig index 7e3ff5c..6251359 100644 --- a/configs/uniphier_ld20_defconfig +++ b/configs/uniphier_ld20_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld20-ref" CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_GPT=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 44cf4e5..68bca19 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld4-ref" CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig index 30be50f..fc72889 100644 --- a/configs/uniphier_pro4_defconfig +++ b/configs/uniphier_pro4_defconfig @@ -11,6 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-pro4-ref" CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index 00db8b0..7a358e3 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-pxs2-vodka" CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set diff --git a/configs/uniphier_sld3_defconfig b/configs/uniphier_sld3_defconfig index 0be715f..ef5d1e4 100644 --- a/configs/uniphier_sld3_defconfig +++ b/configs/uniphier_sld3_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="uniphier-sld3-ref" CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index cb972b2..85f8da5 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ld20-ref" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_HUSH_PARSER=y +CONFIG_CMD_CONFIG=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_GPT=y
2017-02-21 15:09 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier.
Masahiro Yamada
