[U-Boot] [PATCH v2] pinctrl: Kconfig: sort pinctrl config options to prevent future clutter
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together.
However, we now rewrite all chip-specific driver options to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters).
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
Changes in v2: - sort options alphabetically and use a common naming (i.e. always start with CONFIG_PINCTRL_) for chip-specific drivers
drivers/pinctrl/Kconfig | 154 ++++++++++++++++++++++------------------- drivers/pinctrl/Makefile | 2 +- drivers/pinctrl/ath79/Makefile | 4 +- 3 files changed, 86 insertions(+), 74 deletions(-)
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 355aeae..2acd6f6 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -105,7 +105,7 @@ config SPL_PINCONF
if PINCTRL || SPL_PINCTRL
-config AR933X_PINCTRL +config PINCTRL_AR933X bool "QCA/Athores ar933x pin control driver" depends on DM && SOC_AR933X help @@ -114,98 +114,118 @@ config AR933X_PINCTRL both the GPIO definitions and pin control functions for each available multiplex function.
-config QCA953X_PINCTRL +config PINCTRL_AT91 + bool "AT91 pinctrl driver" + depends on DM + help + This option is to enable the AT91 pinctrl driver for AT91 PIO + controller. + + AT91 PIO controller is a combined gpio-controller, pin-mux and + pin-config module. Each I/O pin may be dedicated as a general-purpose + I/O or be assigned to a function of an embedded peripheral. Each I/O + pin has a glitch filter providing rejection of glitches lower than + one-half of peripheral clock cycle and a debouncing filter providing + rejection of unwanted pulses from key or push button operations. You + can also control the multi-driver capability, pull-up and pull-down + feature on each I/O pin. + +config PINCTRL_AT91PIO4 + bool "AT91 PIO4 pinctrl driver" + depends on DM + help + This option is to enable the AT91 pinctrl driver for AT91 PIO4 + controller which is available on SAMA5D2 SoC. + +config PINCTRL_PIC32 + bool "Microchip PIC32 pin-control and pin-mux driver" + depends on DM && MACH_PIC32 + default y + help + Supports individual pin selection and configuration for each + remappable peripheral available on Microchip PIC32 + SoCs. This driver is controlled by a device tree node which + contains both GPIO defintion and pin control functions. + +config PINCTRL_QCA953X bool "QCA/Athores qca953x pin control driver" depends on DM && SOC_QCA953X help Support pin multiplexing control on QCA/Athores qca953x SoCs. - The driver is controlled by a device tree node which contains - both the GPIO definitions and pin control functions for each - available multiplex function. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
config ROCKCHIP_RK3036_PINCTRL bool "Rockchip rk3036 pin control driver" depends on DM help - Support pin multiplexing control on Rockchip rk3036 SoCs. The driver is - controlled by a device tree node which contains both the GPIO - definitions and pin control functions for each available multiplex - function. + Support pin multiplexing control on Rockchip rk3036 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
config ROCKCHIP_RK3188_PINCTRL bool "Rockchip rk3188 pin control driver" depends on DM help - Support pin multiplexing control on Rockchip rk3188 SoCs. The driver - is controlled by a device tree node which contains both the GPIO - definitions and pin control functions for each available multiplex - function. + Support pin multiplexing control on Rockchip rk3188 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
config ROCKCHIP_RK3288_PINCTRL bool "Rockchip rk3288 pin control driver" depends on DM help - Support pin multiplexing control on Rockchip rk3288 SoCs. The driver - is controlled by a device tree node which contains both the GPIO - definitions and pin control functions for each available multiplex - function. - -config PINCTRL_AT91 - bool "AT91 pinctrl driver" - depends on DM - help - This option is to enable the AT91 pinctrl driver for AT91 PIO - controller. AT91 PIO controller is a combined gpio-controller, - pin-mux and pin-config module. Each I/O pin may be dedicated as - a general-purpose I/O or be assigned to a function of an embedded - peripheral. Each I/O pin has a glitch filter providing rejection of - glitches lower than one-half of peripheral clock cycle and - a debouncing filter providing rejection of unwanted pulses from key - or push button operations. You can also control the multi-driver - capability, pull-up and pull-down feature on each I/O pin. + Support pin multiplexing control on Rockchip rk3288 SoCs.
-config PINCTRL_AT91PIO4 - bool "AT91 PIO4 pinctrl driver" - depends on DM - help - This option is to enable the AT91 pinctrl driver for AT91 PIO4 - controller which is available on SAMA5D2 SoC. + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
config ROCKCHIP_RK3328_PINCTRL bool "Rockchip rk3328 pin control driver" depends on DM help - Support pin multiplexing control on Rockchip rk3328 SoCs. The driver - is controlled by a device tree node which contains both the GPIO - definitions and pin control functions for each available multiplex - function. + Support pin multiplexing control on Rockchip rk3328 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
config ROCKCHIP_RK3399_PINCTRL bool "Rockchip rk3399 pin control driver" depends on DM help - Support pin multiplexing control on Rockchip rk3399 SoCs. The driver - is controlled by a device tree node which contains both the GPIO - definitions and pin control functions for each available multiplex - function. + Support pin multiplexing control on Rockchip rk3399 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
config PINCTRL_SANDBOX bool "Sandbox pinctrl driver" depends on SANDBOX help - This enables pinctrl driver for sandbox. Currently, this driver - actually does nothing but print debug messages when pinctrl - operations are invoked. + This enables pinctrl driver for sandbox.
-config PIC32_PINCTRL - bool "Microchip PIC32 pin-control and pin-mux driver" - depends on DM && MACH_PIC32 - default y + Currently, this driver actually does nothing but print debug + messages when pinctrl operations are invoked. + +config PINCTRL_SINGLE + bool "Single register pin-control and pin-multiplex driver" + depends on DM help - Supports individual pin selection and configuration for each remappable - peripheral available on Microchip PIC32 SoCs. This driver is controlled - by a device tree node which contains both GPIO defintion and pin control - functions. + This enables pinctrl driver for systems using a single register for + pin configuration and multiplexing. TI's AM335X SoCs are examples of + such systems. + + Depending on the platform make sure to also enable OF_TRANSLATE and + eventually SPL_OF_TRANSLATE to get correct address translations.
config PINCTRL_STI bool "STMicroelectronics STi pin-control and pin-mux driver" @@ -213,28 +233,20 @@ config PINCTRL_STI default y help Support pin multiplexing control on STMicrolectronics STi SoCs. + The driver is controlled by a device tree node which contains both - the GPIO definitions and pin control functions for each available multiplex - function. + the GPIO definitions and pin control functions for each available + multiplex function.
config PINCTRL_STM32 bool "ST STM32 pin control driver" depends on DM help - Supports pin multiplexing control on stm32 SoCs. The driver is - controlled by a device tree node which contains both the GPIO - definitions and pin control functions for each available multiplex - function. + Supports pin multiplexing control on stm32 SoCs.
-config PINCTRL_SINGLE - bool "Single register pin-control and pin-multiplex driver" - depends on DM - help - This enables pinctrl driver for systems using a single register for - pin configuration and multiplexing. TI's AM335X SoCs are examples of - such systems. - Depending on the platform make sure to also enable OF_TRANSLATE and - eventually SPL_OF_TRANSLATE to get correct address translations. + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function.
endif
diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index bbb2480..17a7173 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -13,7 +13,7 @@ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o
obj-$(CONFIG_PINCTRL_UNIPHIER) += uniphier/ -obj-$(CONFIG_PIC32_PINCTRL) += pinctrl_pic32.o +obj-$(CONFIG_PINCTRL_PIC32) += pinctrl_pic32.o obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ obj-$(CONFIG_PINCTRL_MESON) += meson/ obj-$(CONFIG_PINCTRL_MVEBU) += mvebu/ diff --git a/drivers/pinctrl/ath79/Makefile b/drivers/pinctrl/ath79/Makefile index dcea10a..c87a9aa 100644 --- a/drivers/pinctrl/ath79/Makefile +++ b/drivers/pinctrl/ath79/Makefile @@ -2,5 +2,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_AR933X_PINCTRL) += pinctrl_ar933x.o -obj-$(CONFIG_QCA953x_PINCTRL) += pinctrl_qca953x.o +obj-$(CONFIG_PINCTRL_AR933X) += pinctrl_ar933x.o +obj-$(CONFIG_PINCTRL_QCA953x) += pinctrl_qca953x.o
Am 19.04.2017 um 15:42 schrieb Philipp Tomsich:
Changes in v2:
if you rename Kconfig symbols, you also have to adapt the defconfig files. E.g.
$ git grep -n AR933X_PINCTRL -- configs/ configs/ap121_defconfig:43:CONFIG_AR933X_PINCTRL=y
- depends on DM
- help
controller.
- depends on DM
- help
- default y
- help
multiplex function.
function.
multiplex function.
function.
multiplex function.
function.
- depends on DM
- help
- depends on DM
- help
multiplex function.
function.
multiplex function.
function.
multiplex function.
- default y
- depends on DM help
functions.
such systems.
- The driver is controlled by a device tree node which contains both
function.
multiplex function.
function.
- depends on DM
- help
such systems.
multiplex function.
endif
Daniel Schwierzeck
Philipp Tomsich
