[U-Boot] [PATCH] microblaze: Remove asm/bitops.h from asm/posix_types.h
The patch "include/linux/byteorder: import latest endian definitions from linux" (sha1: eef1cf2d5cf1cae5fb76713e912263dedf110aeb)
Introduced a lot of compilation failures with unknow types. include/linux/byteorder/big_endian.h:45:1: error: unknown type name '__le64' include/linux/byteorder/big_endian.h: In function '__cpu_to_le64p': include/linux/byteorder/big_endian.h:47:18: error: '__le64' undeclared (first use in this function) include/linux/byteorder/big_endian.h:47:18: note: each undeclared identifier is reported only once for each function it appears in include/linux/byteorder/big_endian.h:47:25: error: expected ';' before '__swab64p' include/linux/byteorder/big_endian.h: At top level: include/linux/byteorder/big_endian.h:49:1: error: unknown type name '__le64' include/linux/byteorder/big_endian.h:53:1: error: unknown type name '__le32' include/linux/byteorder/big_endian.h: In function '__cpu_to_le32p': include/linux/byteorder/big_endian.h:55:18: error: '__le32' undeclared (first use in this function) include/linux/byteorder/big_endian.h:55:25: error: expected ';' before '__swab32p' include/linux/byteorder/big_endian.h: At top level: include/linux/byteorder/big_endian.h:57:1: error: unknown type name '__le32' include/linux/byteorder/big_endian.h:61:1: error: unknown type name '__le16' ...
Removing asm/bitops.h solved this problem.
Signed-off-by: Michal Simek monstr@monstr.eu --- arch/microblaze/include/asm/posix_types.h | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/arch/microblaze/include/asm/posix_types.h b/arch/microblaze/include/asm/posix_types.h index 9a2cc66..38dc5aa 100644 --- a/arch/microblaze/include/asm/posix_types.h +++ b/arch/microblaze/include/asm/posix_types.h @@ -16,9 +16,6 @@ #ifndef __MICROBLAZE_POSIX_TYPES_H__ #define __MICROBLAZE_POSIX_TYPES_H__
-#include <asm/bitops.h> - - typedef unsigned int __kernel_dev_t; typedef unsigned long __kernel_ino_t; typedef unsigned long long __kernel_ino64_t;
Michal Simek
