[PATCH v2] drivers: net: fsl_enetc: Pass on primary MAC address to Linux
Passes on the primary address used by u-boot to Linux. The code does a DT fix-up for ENETC PFs and sets the primary MAC address in IERB. The address in IERB is restored on ENETC PCI functions at FLR.
Signed-off-by: Alex Marginean alexandru.marginean@nxp.com ---
The code is called fom ft_board_setup in board/freescale/ls1028a/ls1028a.c mostly for consistency with other LS parts. I'm open to suggestions though.
Changes in v2: - fixed warning for fdt_fixup_enetc_mac being implicitly declared
board/freescale/ls1028a/ls1028a.c | 5 +++ drivers/net/fsl_enetc.c | 65 ++++++++++++++++++++++++++++++- drivers/net/fsl_enetc.h | 3 ++ 3 files changed, 72 insertions(+), 1 deletion(-)
diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index a9606b8865..1a82c95402 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -25,6 +25,7 @@ #include <fdtdec.h> #include <miiphy.h> #include "../common/qixis.h" +#include "../drivers/net/fsl_enetc.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -150,6 +151,10 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_icid(blob);
+#ifdef CONFIG_FSL_ENETC + fdt_fixup_enetc_mac(blob); +#endif + return 0; } #endif diff --git a/drivers/net/fsl_enetc.c b/drivers/net/fsl_enetc.c index 0ca7e838a8..3c043888db 100644 --- a/drivers/net/fsl_enetc.c +++ b/drivers/net/fsl_enetc.c @@ -14,6 +14,69 @@
#include "fsl_enetc.h"
+#define ENETC_DRIVER_NAME "enetc_eth" + +/* + * sets the MAC address in IERB registers, this setting is persistent and + * carried over to Linux. + */ +static void enetc_set_ierb_primary_mac(struct udevice *dev, int devfn, + const u8 *enetaddr) +{ +#ifdef CONFIG_ARCH_LS1028A +/* + * LS1028A is the only part with IERB at this time and there are plans to change + * its structure, keep this LS1028A specific for now + */ +#define IERB_BASE 0x1f0800000ULL +#define IERB_PFMAC(pf, vf, n) (IERB_BASE + 0x8000 + (pf) * 0x100 + (vf) * 8 \ + + (n) * 4) + +static int ierb_fn_to_pf[] = {0, 1, 2, -1, -1, -1, 3}; + + u16 lower = *(const u16 *)(enetaddr + 4); + u32 upper = *(const u32 *)enetaddr; + + if (ierb_fn_to_pf[devfn] < 0) + return; + + out_le32(IERB_PFMAC(ierb_fn_to_pf[devfn], 0, 0), upper); + out_le32(IERB_PFMAC(ierb_fn_to_pf[devfn], 0, 1), (u32)lower); +#endif +} + +/* sets up primary MAC addresses in DT/IERB */ +void fdt_fixup_enetc_mac(void *blob) +{ + struct pci_child_platdata *ppdata; + struct eth_pdata *pdata; + struct udevice *dev; + struct uclass *uc; + char path[256]; + int offset; + int devfn; + + uclass_get(UCLASS_ETH, &uc); + uclass_foreach_dev(dev, uc) { + if (!dev->driver || !dev->driver->name || + strcmp(dev->driver->name, ENETC_DRIVER_NAME)) + continue; + + pdata = dev_get_platdata(dev); + ppdata = dev_get_parent_platdata(dev); + devfn = PCI_FUNC(ppdata->devfn); + + enetc_set_ierb_primary_mac(dev, devfn, pdata->enetaddr); + + snprintf(path, 256, "/soc/pcie@1f0000000/ethernet@%x,%x", + PCI_DEV(ppdata->devfn), PCI_FUNC(ppdata->devfn)); + offset = fdt_path_offset(blob, path); + if (offset < 0) + continue; + fdt_setprop(blob, offset, "mac-address", pdata->enetaddr, 6); + } +} + /* * Bind the device: * - set a more explicit name on the interface @@ -583,7 +646,7 @@ static const struct eth_ops enetc_ops = { };
U_BOOT_DRIVER(eth_enetc) = { - .name = "enetc_eth", + .name = ENETC_DRIVER_NAME, .id = UCLASS_ETH, .bind = enetc_bind, .probe = enetc_probe, diff --git a/drivers/net/fsl_enetc.h b/drivers/net/fsl_enetc.h index 0bb4cdff47..e441891468 100644 --- a/drivers/net/fsl_enetc.h +++ b/drivers/net/fsl_enetc.h @@ -226,4 +226,7 @@ int enetc_mdio_read_priv(struct enetc_mdio_priv *priv, int addr, int devad, int enetc_mdio_write_priv(struct enetc_mdio_priv *priv, int addr, int devad, int reg, u16 val);
+/* sets up primary MAC addresses in DT/IERB */ +void fdt_fixup_enetc_mac(void *blob); + #endif /* _ENETC_H */
Am 2019-12-10 15:55, schrieb Alex Marginean:
I don't get the reason why this is done in a proprietary way. What is the difference between any other network interface whose hardware address is set up in the generic u-boot code.
Also, shouldn't write_hwaddr callback be implemented instead of the enetc_set_ierb_primary_mac()?
-michael
Changes in v2:
- fdt_fixup_enetc_mac(blob);
- sets the MAC address in IERB registers, this setting is persistent
and
- carried over to Linux.
const u8 *enetaddr)
- LS1028A is the only part with IERB at this time and there are
plans to change
- its structure, keep this LS1028A specific for now
+ (n) * 4)
wrong indendation
- u16 lower = *(const u16 *)(enetaddr + 4);
- u32 upper = *(const u32 *)enetaddr;
- if (ierb_fn_to_pf[devfn] < 0)
return;
it would be easier to read if ierb_fn_to_pf[devfn] would be assigned to a local variable.
- out_le32(IERB_PFMAC(ierb_fn_to_pf[devfn], 0, 0), upper);
- out_le32(IERB_PFMAC(ierb_fn_to_pf[devfn], 0, 1), (u32)lower);
+#endif +}
- struct pci_child_platdata *ppdata;
- struct eth_pdata *pdata;
- struct udevice *dev;
- struct uclass *uc;
- char path[256];
- int offset;
- int devfn;
- uclass_get(UCLASS_ETH, &uc);
- uclass_foreach_dev(dev, uc) {
continue;
if (offset < 0)
continue;
- Bind the device:
- .name = ENETC_DRIVER_NAME, .id = UCLASS_ETH, .bind = enetc_bind, .probe = enetc_probe,
Hi Michael,
At the moment, the Linux driver ignored the device tree and only reads the POR values of the SIPMAR registers. The reset value of those comes from the IERB space, which U-Boot is configuring. So it would be good if that behavior keeps working.
It would also be good if the Linux driver called of_get_mac_address, so it needs the device tree binding for that. That's why both fixups are performed, and why the generic function is not used.
As for the write_hwaddr callback instead of enetc_set_primary_mac_addr, that is valid but I suppose it is outside the scope of this patch. That function is related to the runtime MAC address and not to the MAC passed to Linux.
-michael
Changes in v2:
and
const u8 *enetaddr)
plans to change
+ (n) * 4)
wrong indendation
return;
Alex, after you address this feedback from Michael, you can add my:
Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com
+#endif +}
struct uclass *uc;
char path[256];
int offset;
int devfn;
continue;
if (offset < 0)
continue;
- Bind the device:
Regards, -Vladimir
Hi Vladimir,
Am 2019-12-11 13:46, schrieb Vladimir Oltean:
Hi Michael,
yes, but u-boot already sets the mac-address/local-mac-address property in the device tree already in a generic way, see fdt_fixup_ethernet().
according to the comment in eth-uclass.c this is not for (u-boot) runtime:
/* * Devices need to write the hwaddr even if not started so that Linux * will have access to the hwaddr that u-boot stored for the device. * This is accomplished by attempting to probe each device and calling * their write_hwaddr() operation. */
and the runtime mac address for u-boot is already set enetc_start().
-michael
On 12/11/2019 2:16 PM, Michael Walle wrote:
Hi Vladimir,
Hi Michael,
does a
I think fdt_fixup_ethernet is not a good choice for us. The issue is that it ties Linux DT to device indexes in U-Boot. That's a problem if we plug an Eth PCI card in, we would need to change Linux DT, which is definitely not desirable. We actually do use PCI Eth cards with some of our boards and U-Boot does pick those up and indexes shift.
Also U-Boot and Linux DTs have to be in sync all the time, if we disable one port in U-Boot but not in Linux we would mix up MAC addresses.
So as far as using generic fix-up code I'm all for it, but in this case we would need some platform specific rules to match Linux DT nodes to U-Boot eth addresses.
-michael
This is fine, I'll move the IERB code to write_hwaddr.
Alex
Hi Alex,
Am 2019-12-11 16:37, schrieb Alexandru Marginean:
Hi Vladimir,
Hi Michael,
are you sure? afaik it works by reading the /alias/ethernetN phandles which gets ethNaddr assigned if you set the FDT_SEQ_MACADDR_FROM_ENV config option. I've just tried it, here is my linux dts diff
--- a/arch/arm64/boot/dts/freescale/fsl-ls1028a.dtsi +++ b/arch/arm64/boot/dts/freescale/fsl-ls1028a.dtsi @@ -17,6 +17,11 @@ #address-cells = <2>; #size-cells = <2>;
+ aliases { + ethernet0 = &enetc_port0; + ethernet1 = &enetc_port1; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -761,10 +766,12 @@ enetc_port0: ethernet@0,0 { compatible = "fsl,enetc"; reg = <0x000000 0 0 0 0>; + local-mac-address = [ 00 00 00 00 00 00 ]; }; enetc_port1: ethernet@0,1 { compatible = "fsl,enetc"; reg = <0x000100 0 0 0 0>; + local-mac-address = [ 00 00 00 00 00 00 ]; }; enetc_mdio_pf3: mdio@0,3 { compatible = "fsl,enetc-mdio";
That way the mapping between ethNaddr and the network device can also be changed by the user by changing the linux device tree.
also, uboot should respect the /aliases/ethernetN, too.
BTW what will be the source of the network addresses, the u-boot environment variables? (which might be set either by the user or some kind of board specific code).
I see. But that shouldn't happen with the code above. But are you sure that this
will work then? in my config (just enetc-0) there is only one eth device
# dm tree [snip] pci 2 [ + ] pci_generic_ecam |-- pcie@1f0000000 eth 0 [ + ] enetc_eth | |-- enetc-0 mdio 0 [ + ] enetc_mdio | |-- emdio-3 pci_generi 0 [ ] pci_generic_drv | |-- pci_4:0.4 dsa 0 [ ] felix-switch | |-- felix-switch pci_generi 1 [ ] pci_generic_drv | `-- pci_4:1f.0 [snip]
-michael
This will also only be called if the device is not disabled in u-boot, from what I see. So it might be better to "fix" this.
I bet you are not the first/only one which needs this kind of "how do we propagate the hardware address to linux" where the devices might be unused in u-boot. There must be a better way to do this ;)
-michael
Hi Michael,
On 12/11/2019 6:03 PM, Michael Walle wrote:
Hi Alex,
Hi Vladimir,
Hi Michael,
does a
I don't disagree with any of that, but that's not the issue I mentioned. I meant actual PCI cards being plugged in, I didn't mean having disabled ECAM functions.
In your example DT enetc port 0 is tied to /aliases/ethernet0 and to ethaddr, enetc port 1 is tied to /aliases/ethernet1 and to eth1addr.
A LS1028 board with a PCI Eth card plugged in shows this:
Net: e1000: 68:05:ca:66:bf:bd eth0: e1000#0 [PRIME], eth1: enetc-0, eth2: enetc-2, eth3: swp0, eth4: swp1, eth5: swp2, eth6: swp3
In this case eth0 is the e1000 card and it uses ethaddr, enetc port 0 is eth1 and uses eth1addr. The fix-up to /aliases/ethernet0 in your example makes enetc port 0 get the MAC address of the PCI card. If the PCI card is removed then enetc port 0 ends up being eth0 in U-Boot and and actually use ethaddr, not eth1addr. To make this work with a PCI card plugged in one would need to change the aliases in Linux DT, which is not a fun thing to do.
Yes, the environment variables. As far as I know these come preset from the factory. The reference boards usually come with stickers too, listing the preset MAC addresses.
Yeah, I guess that's no better either way. U-Boot wouldn't be able to fix-up addresses for interfaces it didn't know about, yes. It works if Linux doesn't use some interfaces that U-Boot does, the MAC addresses per port would match between U-Boot and Linux. That case isn't too useful though, if they differ it's probably the other way around, and U-Boot has fewer interfaces.
There is no simple solution to satisfy all cases really. Using an index encoded in the DT to identify a given interface isn't OK, in my example there's a PCI card that gets probed first and then all IDs shift up. Fixing up addresses for interfaces U-Boot doesn't know about is also a problem, as the fix-up code should stay clear of eth addresses used by live interfaces, on the assumption that those should continue using them. Assume the device has two interfaces, first one is disabled in U-Boot but enabled in Linux. Should it use ethaddr in Linux, or eth1addr? Ethaddr is associated with 2nd interface in U-Boot and it makes sense to maintain that association in Linux.
-michael
-michael
Yeah, I'm sure others bumped into this before. For sure fdt_fixup_ethernet as defined now can't cover all cases. It can only rely on the U-Boot interface index which is volatile with plug-in PCI cards. We could introduce some new index for integrated interfaces that's set by the driver, maybe improve on existing req_seq. In current code req_seq is not too useful, as dev->seq is allocated in order of discovery, so it doesn't help if 2nd found device requests seq 0, that's already in use. But that could probably be improved.
For now I think I'll stick to current code, proprietary as it is and with the limitation that U-Boot has to enable interfaces that Linux uses. I am open to any better suggestions though.
Thanks! Alex
Hi Alex,
Am 2019-12-11 22:01, schrieb Alexandru Marginean:
Hi Michael,
Hi Alex,
Hi Vladimir,
Hi Michael,
Am 2019-12-10 15:55, schrieb Alex Marginean: > Passes on the primary address used by u-boot to Linux. The code does a > DT > fix-up for ENETC PFs and sets the primary MAC address in IERB. The > address > in IERB is restored on ENETC PCI functions at FLR.
Mh, I've just tried this and it seems that this is even worse. Because if you set the ethaddr, uboot will complain about mismatching ethernet addresses.
so here is already the first problem, see above. Just to be sure, I don't argue against having the environment as the source (actually we do import the mac addresses from our eeprom into the environment), just to make you aware that there is an underlying problem.
I've tried to use the aliases in u-boot, too. Unfortunately, the e1000 will get the first slot, regardless that /aliases/ethernet0 is a phandle to enetc-0. I guess that is the actual problem here. Because if that would work then everything else would fall into place. (except the write_hwaddr()).
mhh just to let you know some cases we have: (1) enetc-0, enetc-1 in u-boot enetc-0, enetc-1, enetc-2 (and switch) in linux (2) enetc-1 in u-boot all enetc's and switch in linux (3a) well the "standard" ones where linux == uboot (3b) "standard one" but just enetc-1, skipping enetc-0
correct, and i guess that is the actual problem here. If it would be appended to a pre-defined list (aka /aliases in u-boot) then there wouldn't be any shift.
If you say ethNaddr always maps to /alias/ethernetN, you won't have a problem, will you? Other than ethXaddr might be unused.
Also consider the following: - you have consecutive mac addresses - u-boot uses enetc-1, enetc-0 is disabled, it would use ethaddr lets say (its ..:00) - linux uses enetc-0 and enetc-1, then if it is not shifted, enetc-0 will have (..:01) and enetc-1 stays with (..:00).
Although it doesn't impact the function, it still looks bad.
-michael
-michael
Please don't take that shortcut because it will be a pain to get it cleaned-up and retain backwards compatibility :( Also like explained above, it already falls short if you have ethaddr defined.
see above and like you've described it. append any plugable interfaces at the end of the predefined list (with probably empty slots in used ethNaddr).
-michael
On 12/12/2019 1:12 PM, Michael Walle wrote:
Hi Alex,
Hi Michael,
Hi Alex,
Hi Vladimir,
Hi Michael,
On Wed, 11 Dec 2019 at 00:48, Michael Walle michael@walle.cc wrote: > > Am 2019-12-10 15:55, schrieb Alex Marginean: > > Passes on the primary address used by u-boot to Linux. The > code does a > > DT > > fix-up for ENETC PFs and sets the primary MAC address in IERB. > The > > address > > in IERB is restored on ENETC PCI functions at FLR. > > > I don't get the reason why this is done in a proprietary way. > What is > the > difference between any other network interface whose hardware > address is > set up in the generic u-boot code. > > Also, shouldn't write_hwaddr callback be implemented instead of the > enetc_set_ierb_primary_mac()? >
Between ethaddr from eeprom and e1000 ROM address? Yes, it will complain.
I know, we waste the 1st address from environment if there's a card plugged in, and having more cards makes it worse.
I don't think aliases in U-Boot DT help really, these are all PCI devices, the card and enetc/ECAM. They are probed on the PCI bus, not from DT.
OK, these look reasonable to me, but we need a new solution to make them work.
These interfaces have to be probed from the PCI bus. Using /aliases to fix ip dev->seq may work for devices used by U-Boot, it's not so obvious how U-Boot would keep track of indexes of devices it doesn't know about though. I hope we can come up with something simpler than that.
It doesn't look neat, but it's workable.
-michael
-michael
-michael
All solutions based on the interface index fall short, the index is really volatile if PCI cards are involved.
So here's two alternatives I can think of:
- have the index nailed in place for relevant interfaces, including the ones U-Boot doesn't even use. That could be done introducing a static range of indexes, which is not used for plug-in cards. Since this should be backward compatible we don't want to mess with IDs in use on current platforms, so we would need to move the static IDs up. Say there's a
#define ETH_STATIC_INDEX_BASE 0x10
enetc could do something like:
dev->req_seq = ETH_STATIC_INDEX_BASE + fno.
meaning PF0, 1, 2, 6 get eth indexes 0x10, 0x11, 0x12, 0x16.
The DT fix-up code could use this base when processing the Linux DT, so /aliases/ethernet0 gets eth10addr, /aliases/ethernet1 gets eth11addr and so on.
Cards like e1000 are left with 0 based index, so they don't interfere with this ID range if they are not too many, and MAC addresses between U-Boot and Linux are preserved even if U-Boot doesn't use all the interfaces. that, or
- move away for using the index to make this association. How about having an allocation scheme that associates the device, not its probing index with the MAC address. It could be based on the name, like 'enetc-0-addr=..:00' or device topology, bus/function for pci, like 'eth-pci:4:00.0-addr=..:00'. These kind of schemes would not depend on what is enabled in U-Boot either, but they would require some more specific support for matching enetc-0 or pci:4:00.0 to a Linux DT node.
Thoughts, any better ideas?
Thanks! Alex
By proprietary do you mean IERB?
Network cards normally have a ROM which comes preset from the factory with default MAC addresses. At run-time drivers can use the default address or replace it. The MAC address in IERB is the default MAC address for ENETC interfaces at run-time, this address is available to the driver/stack after issuing an FLR and in the absence of a DT node for the PCI function. We can pass MAC addresses to Linux through DT alone, but that's more of a hassle if Linux decides to assign the PCI function to a guest or user-space app. Using the IERB values doesn't require any fix-up for guest DTs.
IERB is not actually a ROM though and we need U-Boot to set factory MAC addresses into IERB some time before Linux boots.
OK, makes sense, I will move the code there.
I'll send a v3, Thanks! Alex
-michael
and
plans to change
wrong indendation
Am 2019-12-11 14:04, schrieb Alexandru Marginean:
I meant the fdt fixups for mac-address/local-mac-address which is not handled in the generic u-boot code, see my previous mail.
Because if it would, then there would be no need for the board specific code below (just the one function call actually).
Understood.
-michael
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Alex Marginean Sent: Tuesday, December 10, 2019 8:26 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com; Claudiu Manoil claudiu.manoil@nxp.com; Vladimir Oltean vladimir.oltean@nxp.com Subject: [PATCH v2] drivers: net: fsl_enetc: Pass on primary MAC address to Linux
Patch applied (after removing extra spaces in description) in u-boot-fsl-qoriq/master -priyankajain
participants (5)
Alex Marginean
Alexandru Marginean
Michael Walle
Priyanka Jain
Vladimir Oltean
