[U-Boot] [PATCH 1/2] ZFS: Fix compile warning in cmd_zfs.c (GCC 4.6.4 from ELDK 5.2.1)
This patch fixes the following compile warnings:
cmd_zfs.c:177:1: warning: initialization from incompatible pointer type [enabled by default] cmd_zfs.c:177:1: warning: (near initialization for '_u_boot_list_cmd_zfsls.cmd') [enabled by default] cmd_zfs.c:182:1: warning: initialization from incompatible pointer type [enabled by default] cmd_zfs.c:182:1: warning: (near initialization for '_u_boot_list_cmd_zfsload.cmd') [enabled by default]
Signed-off-by: Stefan Roese sr@denx.de Cc: Jorgen Lundman lundman@lundman.net --- common/cmd_zfs.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_zfs.c b/common/cmd_zfs.c index d580f7b..1df0c4d 100644 --- a/common/cmd_zfs.c +++ b/common/cmd_zfs.c @@ -46,7 +46,7 @@ #define DOS_FS_TYPE_OFFSET 0x36 #define DOS_FS32_TYPE_OFFSET 0x52
-static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char *filename = NULL; int dev; @@ -146,7 +146,7 @@ int zfs_print(const char *entry, const struct zfs_dirhook_info *data)
-static int do_zfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +static int do_zfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { const char *filename = "/"; int part;
This patch fixes the following compile warning: zfs.c:2006:1: warning: 'zfs_label' defined but not used [-Wunused-function] zfs.c:2029:1: warning: 'zfs_uuid' defined but not used [-Wunused-function]
Signed-off-by: Stefan Roese sr@denx.de Cc: Jorgen Lundman lundman@lundman.net --- fs/zfs/zfs.c | 51 --------------------------------------------------- 1 file changed, 51 deletions(-)
diff --git a/fs/zfs/zfs.c b/fs/zfs/zfs.c index 360f723..2db45b1 100644 --- a/fs/zfs/zfs.c +++ b/fs/zfs/zfs.c @@ -2002,49 +2002,6 @@ zfs_fetch_nvlist(device_t dev, char **nvlist) return err; }
-static int -zfs_label(device_t device, char **label) -{ - char *nvlist; - int err; - struct zfs_data *data; - - data = zfs_mount(device); - if (!data) - return ZFS_ERR_BAD_FS; - - err = int_zfs_fetch_nvlist(data, &nvlist); - if (err) { - zfs_unmount(data); - return err; - } - - *label = zfs_nvlist_lookup_string(nvlist, ZPOOL_CONFIG_POOL_NAME); - free(nvlist); - zfs_unmount(data); - return ZFS_ERR_NONE; -} - -static int -zfs_uuid(device_t device, char **uuid) -{ - struct zfs_data *data; - - data = zfs_mount(device); - if (!data) - return ZFS_ERR_BAD_FS; - - *uuid = malloc(17); /* %016llx + nil */ - if (!*uuid) - return ZFS_ERR_OUT_OF_MEMORY; - - /* *uuid = xasprintf ("%016llx", (long long unsigned) data->pool_guid);*/ - snprintf(*uuid, 17, "%016llx", (long long unsigned) data->pool_guid); - zfs_unmount(data); - - return ZFS_ERR_NONE; -} - /* * zfs_open() locates a file in the rootpool by following the * MOS and places the dnode of the file in the memory address DNODE. @@ -2325,14 +2282,6 @@ zfs_ls(device_t device, const char *path, struct zfs_data *data; int err; int isfs; -#if 0 - char *label = NULL; - - zfs_label(device, &label); - if (label) - printf("ZPOOL label '%s'\n", - label); -#endif
data = zfs_mount(device); if (!data)
This and 2/2 are now applied to u-boot/master, thanks!
Stefan Roese
