[PATCH 1/2] arm: mvebu: Espressobin: Make SPI env offset compatible with Marvell's U-Boot
Espressobin board comes with Marvell's U-Boot version where U-Boot env is stored in SPI at offset 0x3F0000. This patch changes env offset in Espressobin defconfig file to match Marvell's U-Boot version.
Users who want to use previous or different env offset can still change it in .config file when compiling U-Boot.
Signed-off-by: Pali Rohár pali@kernel.org --- configs/mvebu_espressobin-88f3720_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 933592af88..afcdd947c1 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -6,7 +6,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_MVEBU_ARMADA_37XX=y CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x180000 +CONFIG_ENV_OFFSET=0x3F0000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEBUG_UART_BASE=0xd0012000
Due to different partition layouts in different U-Boot versions, DTS for Espressobin in Linux does not contain any definition of MTD partitions. See commit https://git.kernel.org/stable/c/00954566464a4 for more details.
This patch via ft_board_setup() hook fills current partition layout used by U-Boot, so booted kernel would see correct MTD partitions layout.
U-Boot env partition is calculated from CONFIG_ENV_OFFSET option.
First partition contains secure firmware, ARM trusted firmware and U-Boot with checksums. So it is not possible to replace just one image (e.g. U-Boot) without updating other parts where is stored checksum of U-Boot. Therefore there is no extra partition defined for U-Boot and first partition is called just 'firmware'.
Signed-off-by: Pali Rohár pali@kernel.org --- board/Marvell/mvebu_armada-37xx/board.c | 100 ++++++++++++++++++++ configs/mvebu_espressobin-88f3720_defconfig | 1 + 2 files changed, 101 insertions(+)
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index 031de318c6..7b9c3223ed 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -243,3 +243,103 @@ int board_network_enable(struct mii_dev *bus)
return 0; } + +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + int ret; + int spi_off; + int parts_off; + int part_off; + + /* Fill SPI MTD partitions for Linux kernel on Espressobin */ + if (!of_machine_is_compatible("marvell,armada-3720-espressobin")) + return 0; + + spi_off = fdt_node_offset_by_compatible(blob, -1, "jedec,spi-nor"); + if (spi_off < 0) + return 0; + + /* Do not touch partitions if they are already defined */ + if (fdt_subnode_offset(blob, spi_off, "partitions") >= 0) + return 0; + + parts_off = fdt_add_subnode(blob, spi_off, "partitions"); + if (parts_off < 0) { + printf("Can't add partitions node: %s\n", fdt_strerror(parts_off)); + return 0; + } + + ret = fdt_setprop_string(blob, parts_off, "compatible", "fixed-partitions"); + if (ret < 0) { + printf("Can't set compatible property: %s\n", fdt_strerror(ret)); + return 0; + } + + ret = fdt_setprop_u32(blob, parts_off, "#address-cells", 1); + if (ret < 0) { + printf("Can't set #address-cells property: %s\n", fdt_strerror(ret)); + return 0; + } + + ret = fdt_setprop_u32(blob, parts_off, "#size-cells", 1); + if (ret < 0) { + printf("Can't set #size-cells property: %s\n", fdt_strerror(ret)); + return 0; + } + + /* Add u-boot-env partition */ + + part_off = fdt_add_subnode(blob, parts_off, "partition@u-boot-env"); + if (part_off < 0) { + printf("Can't add partition@u-boot-env node: %s\n", fdt_strerror(part_off)); + return 0; + } + + ret = fdt_setprop_u32(blob, part_off, "reg", CONFIG_ENV_OFFSET); + if (ret < 0) { + printf("Can't set partition@u-boot-env reg property: %s\n", fdt_strerror(ret)); + return 0; + } + + ret = fdt_appendprop_u32(blob, part_off, "reg", CONFIG_ENV_SIZE); + if (ret < 0) { + printf("Can't set partition@u-boot-env reg property: %s\n", fdt_strerror(ret)); + return 0; + } + + ret = fdt_setprop_string(blob, part_off, "label", "u-boot-env"); + if (ret < 0) { + printf("Can't set partition@u-boot-env label property: %s\n", fdt_strerror(ret)); + return 0; + } + + /* Add firmware partition */ + + part_off = fdt_add_subnode(blob, parts_off, "partition@firmware"); + if (part_off < 0) { + printf("Can't add partition@firmware node: %s\n", fdt_strerror(part_off)); + return 0; + } + + ret = fdt_setprop_u32(blob, part_off, "reg", 0); + if (ret < 0) { + printf("Can't set partition@firmware reg property: %s\n", fdt_strerror(ret)); + return 0; + } + + ret = fdt_appendprop_u32(blob, part_off, "reg", CONFIG_ENV_OFFSET); + if (ret < 0) { + printf("Can't set partition@firmware reg property: %s\n", fdt_strerror(ret)); + return 0; + } + + ret = fdt_setprop_string(blob, part_off, "label", "firmware"); + if (ret < 0) { + printf("Can't set partition@firmware label property: %s\n", fdt_strerror(ret)); + return 0; + } + + return 0; +} +#endif diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index afcdd947c1..0c1c92d4ff 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -82,3 +82,4 @@ CONFIG_SHA1=y CONFIG_SHA256=y CONFIG_MVNETA=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_OF_BOARD_SETUP=y
-----Original Message----- From: Pali Rohár pali@kernel.org Sent: Wednesday, August 19, 2020 17:24 To: Stefan Roese sr@denx.de; Kostya Porotchkin kostap@marvell.com Cc: u-boot@lists.denx.de Subject: [EXT] [PATCH 2/2] arm: mvebu: Espressobin: Setup MTD partitions when booting kernel
External Email
Due to different partition layouts in different U-Boot versions, DTS for Espressobin in Linux does not contain any definition of MTD partitions. See commit https://urldefense.proofpoint.com/v2/url?u=https- 3A__git.kernel.org_stable_c_00954566464a4&d=DwIDaQ&c=nKjWec2b6R0m OyPaz7xtfQ&r=- N9sN4p5NSr0JGQoQ_2UCOgAqajG99W1EbSOww0WU8o&m=EH2hF8LOBbgZ NUxvBwhhmIe2uzWWEa_eJ3vAmWPxqmo&s=ei6YI15fI5FM73Z6537XKz_p9 p3nx9nT7qiUvg2o_tU&e= for more details.
This patch via ft_board_setup() hook fills current partition layout used by U- Boot, so booted kernel would see correct MTD partitions layout.
Reviewed-by: Konstantin Porotchkin kostap@marvell.com
return 0; }
+#if defined(CONFIG_OF_BOARD_SETUP) && +defined(CONFIG_ENV_IS_IN_SPI_FLASH) +int ft_board_setup(void *blob, struct bd_info *bd) {
- int ret;
- int spi_off;
- int parts_off;
- int part_off;
- /* Fill SPI MTD partitions for Linux kernel on Espressobin */
- if (!of_machine_is_compatible("marvell,armada-3720-espressobin"))
- spi_off = fdt_node_offset_by_compatible(blob, -1, "jedec,spi-nor");
- if (spi_off < 0)
- /* Do not touch partitions if they are already defined */
- if (fdt_subnode_offset(blob, spi_off, "partitions") >= 0)
- parts_off = fdt_add_subnode(blob, spi_off, "partitions");
- if (parts_off < 0) {
- ret = fdt_setprop_string(blob, parts_off, "compatible", "fixed-
partitions");
- if (ret < 0) {
fdt_strerror(ret));
- ret = fdt_setprop_u32(blob, parts_off, "#address-cells", 1);
- if (ret < 0) {
fdt_strerror(ret));
- ret = fdt_setprop_u32(blob, parts_off, "#size-cells", 1);
- if (ret < 0) {
fdt_strerror(ret));
- /* Add u-boot-env partition */
- part_off = fdt_add_subnode(blob, parts_off, "partition@u-boot-
env");
- if (part_off < 0) {
- ret = fdt_setprop_u32(blob, part_off, "reg", CONFIG_ENV_OFFSET);
- if (ret < 0) {
fdt_strerror(ret));
- ret = fdt_appendprop_u32(blob, part_off, "reg",
CONFIG_ENV_SIZE);
- if (ret < 0) {
fdt_strerror(ret));
- ret = fdt_setprop_string(blob, part_off, "label", "u-boot-env");
- if (ret < 0) {
fdt_strerror(ret));
- /* Add firmware partition */
- part_off = fdt_add_subnode(blob, parts_off, "partition@firmware");
- ret = fdt_setprop_u32(blob, part_off, "reg", 0);
- if (ret < 0) {
fdt_strerror(ret));
CONFIG_ENV_OFFSET);
- if (ret < 0) {
fdt_strerror(ret));
- ret = fdt_setprop_string(blob, part_off, "label", "firmware");
- if (ret < 0) {
fdt_strerror(ret));
2.20.1
return 0; }
- int ret;
- int spi_off;
- int parts_off;
- int part_off;
- if (spi_off < 0)
- ret = fdt_setprop_string(blob, parts_off, "compatible", "fixed-partitions");
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- part_off = fdt_add_subnode(blob, parts_off, "partition@u-boot-env");
- if (ret < 0) {
- ret = fdt_appendprop_u32(blob, part_off, "reg", CONFIG_ENV_SIZE);
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- ret = fdt_appendprop_u32(blob, part_off, "reg", CONFIG_ENV_OFFSET);
- if (ret < 0) {
- if (ret < 0) {
+} +#endif
Can't you just use "mtdparts=" kernel cmdline parameter instead to pass the MTD layout to the kernel?
Thanks, Stefan
Maybe it is possible too, I have not tried it.
I thought that more common is to update DTS file by uboot when loading kernel as it is already done e.g. for ethernet MAC address on Espressobin.
Also I see that uboot has function fdt_fixup_mtdparts() via CONFIG_FDT_FIXUP_PARTITIONS option which do this, but uses uboot MTD code which IIRC cannot initialize SPI NOR.
Anyway, updating DTS has advantage that it is not needed to update existing boot scripts for OS. There are more distributions for Espressobin which have own boot scripts stored on SD card for loading kernel. And therefore to use command line parameters it would be needed to update all of them.
And I see there another problem. For specifying size of mtd partitions in command line, it is required to know offsets of those partitions. And e.g. uboot env partition depends on CONFIG_ENV_OFFSET option which is not available for uboot boot script code.
But if you have other idea, I'm open to also other solutions.
Updating the MAC address is very common, yes. But passing the MTD partition layout via the mtdparts= cmdline is also very common and used very frequently. From my experience, its the defacto recommended method to pass this info and also easier than generating these DTS lines via some code.
Please take a look at the mtdparts U-Boot command and its usage in other targets.
Why not? SPI NOR is also integrated into the U-Boot MTD world as well. Please see this GARDENA MT7688 target, which uses SPI NOR & SPI NAND:
=> mtd list List of MTD devices: * nor0 - type: NOR flash - block size: 0x1000 bytes - min I/O: 0x1 bytes - 0x000000000000-0x000000800000 : "nor0" - 0x000000000000-0x0000000a0000 : "uboot" - 0x0000000a0000-0x0000000b0000 : "uboot_env0" - 0x0000000b0000-0x0000000c0000 : "uboot_env1" - 0x0000000c0000-0x0000000d0000 : "factory" - 0x0000000d0000-0x000000800000 : "unused" * spi-nand0 - device: spi-nand@1 - parent: spi@b00 - driver: spi_nand - type: NAND flash - block size: 0x20000 bytes - min I/O: 0x800 bytes - OOB size: 128 bytes - OOB available: 63 bytes - 0x000000000000-0x000008000000 : "spi-nand0" - 0x000000000000-0x000008000000 : "nand" => mtdparts
device nor0 <spi0.0>, # parts = 5 #: name size offset mask_flags 0: uboot 0x000a0000 0x00000000 0 1: uboot_env0 0x00010000 0x000a0000 0 2: uboot_env1 0x00010000 0x000b0000 0 3: factory 0x00010000 0x000c0000 0 4: unused 0x00730000 0x000d0000 0
device spi-nand0 <spi0.1>, # parts = 1 #: name size offset mask_flags 0: nand 0x08000000 0x00000000 0
active partition: nor0,0 - (uboot) 0x000a0000 @ 0x00000000
defaults: mtdids : spi-nand0=spi0.1,nor0=spi0.0 mtdparts: spi0.0:640k(uboot),64k(uboot_env0),64k(uboot_env1),64k(factory),-(unused);spi0.1:-(nand)
I see. This is an argument I understand. But can't you use the common fdt_fixup_mtdparts() then?
I have not investigated a multi-distribution solution here. Perhaps the common fdt_fixup_mtdparts() is able to handle this?
If not, then I won't stop this current patch. I just wanted to point out the more common and more elegant solutions to you.
Thanks, Stefan
Why not?
I had an impression that U-Boot does not support.
Ok, I'm going to look at it.
In case U-Boot would see MTD SPI partitions, then fdt_fixup_mtdparts() should work.
Why not?
With following config
CONFIG_MTD=y CONFIG_CMD_MTD=y CONFIG_CMD_MTDPARTS=y CONFIG_SPI_FLASH_MTD=y CONFIG_MTDIDS_DEFAULT="nor0=nor0"
I get following result:
=> mtd list List of MTD devices: No MTD device found => mtdparts Device nor0 not found! => sf probe SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB => mtdparts => mtd list List of MTD devices: * nor0 - type: NOR flash - block size: 0x1000 bytes - min I/O: 0x1 bytes - 0x000000000000-0x000000400000 : "nor0"
So main problem is that MTD does not work until I call 'sf probe' in uboot command line.
Why not?
- nor0
- type: NOR flash
Then a dependency seems to be missing here. On my MT7688 board I get this:
U-Boot 2020.07-rc5-00075-g0b7d95531c-dirty (Jun 30 2020 - 09:51:39 +0200)
CPU: MediaTek MT7688A ver:1 eco:2 Boot: DDR2, SPI-NOR 3-Byte Addr, CPU clock from XTAL Clock: CPU: 580MHz, Bus: 193MHz, XTAL: 40MHz Model: GARDENA smart Gateway (MT7688) DRAM: 128 MiB WDT: Started with servicing (60s timeout) Loading Environment from SPI Flash... SF: Detected XM25QH64A with page size 256 Bytes, erase size 4 KiB, total 8 MiB OK F-Data:factory-data version 1 detected Net: eth0: eth@10110000 Hit any key to stop autoboot: 0 => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver ... spi 0 [ + ] mt7621_spi | |-- spi@b00 spi_flash 0 [ + ] spi_flash_std | | |-- spi-flash@0 mtd 0 [ ] spi_nand | | `-- spi-nand@1 ... => mtd list List of MTD devices: * nor0 - type: NOR flash - block size: 0x1000 bytes - min I/O: 0x1 bytes - 0x000000000000-0x000000800000 : "nor0" - 0x000000000000-0x0000000a0000 : "uboot" - 0x0000000a0000-0x0000000b0000 : "uboot_env0" - 0x0000000b0000-0x0000000c0000 : "uboot_env1" - 0x0000000c0000-0x0000000d0000 : "factory" - 0x0000000d0000-0x000000800000 : "unused" * spi-nand0 - device: spi-nand@1 - parent: spi@b00 - driver: spi_nand - type: NAND flash - block size: 0x20000 bytes - min I/O: 0x800 bytes - OOB size: 128 bytes - OOB available: 63 bytes - 0x000000000000-0x000008000000 : "spi-nand0" - 0x000000000000-0x000008000000 : "nand" => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver ... spi 0 [ + ] mt7621_spi | |-- spi@b00 spi_flash 0 [ + ] spi_flash_std | | |-- spi-flash@0 mtd 0 [ + ] spi_nand | | `-- spi-nand@1 ...
As you see, spi_nand is automatically probed by "mtd list". SPI NOR is most likely already probed since its used for ENV storage.
It would be great, if you could check, if and where such a dependency is missing in your case.
Thanks, Stefan
Why not?
- nor0
- type: NOR flash
- nor0
- type: NOR flash
- spi-nand0
- parent: spi@b00
- driver: spi_nand
- type: NAND flash
Thanks, Stefan
Full bootlog is:
U-Boot 2020.10-rc2-00156-gd21f8d2fdf-dirty (Aug 20 2020 - 12:55:39 +0200)
DRAM: 512 MiB Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 5 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0
Then I called mtd commands which I wrote in previous email. Just to note that ENV variables are correctly read from SPI.
In 'dm tree' is: spi 0 [ + ] mvebu_spi | | |-- spi@10600 spi_flash 0 [ + ] jedec_spi_nor | | | `-- spi-flash@0
It looks like that fdt_fixup_mtdparts() is broken.
I added following config lines
CONFIG_MTDIDS_DEFAULT="nor0=nor0" CONFIG_MTDPARTS_DEFAULT="nor0:4032k(firmware),64k(u-boot-env)" CONFIG_FDT_FIXUP_PARTITIONS=y
Then in uboot console I called 'sf probe' and 'boot'.
And Linux kernel thrown following MTD error:
[ 1.038352] spi-nor spi0.0: w25q32dw (4096 Kbytes) [ 1.043403] spi0.0: error parsing ofpart partition /soc/internal-regs@d0000000/spi@10600/flash@0/partition@0 (/soc/internal-regs@d0000000/spi@10600/flash@0)
So I do not know if it makes sense to continue debugging SF <--> MTD layer in Uboot when passing uboot MTD partitions via fdt_fixup_mtdparts() to Linux kernel does not work...
Original patch which in this thread is working fine and kernel correctly see both defined partitions in ft_board_setup() function.
I know that passing mtdparts= is working in general. You need the correct device names though. Perhaps something is wrong here. Hard to say, without looking deeper. Could you please post the complete Linux bootlog of this failing boot attempt?
I understand. You have a working version and it makes not much sense for you to work on an alternative solution. But the fdt_fixup_mtdparts() way provides a common way for all (most?) boards and your's needs to be rewritten for each board. So from this prospective, it definitely makes sense to continue debugging / testing.
I understand. Thanks for at looking into this anyways.
Thanks, Stefan
I sent it to you in private email as log is large.
Well, currently I do not have time to debug other components to figure out what is broken in uboot.
For me it looks like a overkill to enable & configure MTD layer, then attach SF layer to it and all this would be needed only for usage of fdt_fixup_mtdparts() function. And once these layers would be fixed and fully working it would same thing as in this my patch.
Thanks, Stefan
Tested-by: Andre Heider a.heider@gmail.com
Applied to u-boot-marvell/master
Thanks, Stefan
return 0; }
- int ret;
- int spi_off;
- int parts_off;
- int part_off;
- if (spi_off < 0)
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
Viele Grüße, Stefan
-----Original Message----- From: Pali Rohár pali@kernel.org Sent: Wednesday, August 19, 2020 17:24 To: Stefan Roese sr@denx.de; Kostya Porotchkin kostap@marvell.com Cc: u-boot@lists.denx.de Subject: [EXT] [PATCH 1/2] arm: mvebu: Espressobin: Make SPI env offset compatible with Marvell's U-Boot
External Email
diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 933592af88..afcdd947c1 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -6,7 +6,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_MVEBU_ARMADA_37XX=y CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x180000 +CONFIG_ENV_OFFSET=0x3F0000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEBUG_UART_BASE=0xd0012000 -- 2.20.1
Thanks, Stefan
Viele Grüße, Stefan
Thanks, Stefan
Viele Grüße, Stefan
Andre Heider
Kostya Porotchkin
Pali Rohár
Stefan Roese
