Re: [PATCH v2 6/7] riscv: Ensure gp is NULL or points to valid data
Hi Sean
From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Sean Anderson Sent: Monday, September 14, 2020 10:23 PM To: u-boot@lists.denx.de Cc: Alan Quey-Liang Kao(高魁良); Leo Yu-Chi Liang(梁育齊); Heinrich Schuchardt; Bin Meng; Rick Chen; Sean Anderson Subject: [PATCH v2 6/7] riscv: Ensure gp is NULL or points to valid data
This allows code to use a construct like `if (gd & gd->...) { ... }` when accessing the global data pointer. Without this change, it was possible for a very early trap to cause _exit_trap to read arbitrary memory. This could cause a second trap, preventing show_regs from being printed.
XIP cannot use locks because flash is not writable. This leaves it vulnerable to the same class of bugs regarding already-pending IPIs as before this series. Fixing that would require finding another method of synchronization, which is outside the scope of this series.
Fixes: 7c6ca03eae ("riscv: additional crash information") Signed-off-by: Sean Anderson seanga2@gmail.com
Changes in v2:
- Set gp early with XIP
arch/riscv/cpu/start.S | 26 +++++++++++++++++++++++--- arch/riscv/lib/interrupts.c | 3 ++- 2 files changed, 25 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 66ca1c7020..a16af79fbe 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -47,6 +47,13 @@ _start: mv tp, a0 mv s1, a1
* Set the global data pointer to a known value in case we get a very
* early trap. The global data pointer will be set its actual value only
* after it has been initialized.
mv gp, zero
la t0, trap_entry csrw MODE_PREFIX(tvec), t0
@@ -85,10 +92,10 @@ call_board_init_f_0: jal board_init_f_alloc_reserve
* Set global data pointer here for all harts, uninitialized at this
* point.
* Save global data pointer for later. We don't set it here because it
* is not initialized yet. */
mv gp, a0
mv s0, a0 /* setup stack */
#if CONFIG_IS_ENABLED(SMP) @@ -109,6 +116,12 @@ call_board_init_f_0: amoswap.w s2, t1, 0(t0) bnez s2, wait_for_gd_init #else
* FIXME: gp is set before it is initialized. If an XIP U-Boot ever
* encounters a pending IPI on boot it is liable to jump to whatever
* memory happens to be in ipi_data.addr on boot.
mv gp, s0 bnez tp, secondary_hart_loop
#endif
@@ -133,6 +146,13 @@ wait_for_gd_init: 1: amoswap.w.aq t1, t1, 0(t0) bnez t1, 1b
* Set the global data pointer only when gd_t has been initialized.
* This was already set by arch_setup_gd on the boot hart, but all other
* harts' global data pointers gets set here.
mv gp, s0
This method seem a little speculative and complicated to read. Otherwise if the board_init_f_init_reserve() be modified in the future and the gp will not synchronize any more. board_init_f_init_reserve is belong generic flow, it can be touch by anyone and anytime.
May I ask some questions ? This patch is trying to prevent printing garbage messages form early trap or early trap itself ? When early trap occurs, how is the status of mtvec ? How the early trap be handled in handle_trap ?
Thanks, Rick
/* register available harts in the available_harts mask */ li t1, 1 sll t1, t1, tp
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index cd47e64487..ad870e98d8 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -78,7 +78,8 @@ static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs)
printf("EPC: " REG_FMT " RA: " REG_FMT " TVAL: " REG_FMT "\n", epc, regs->ra, tval);
if (gd->flags & GD_FLG_RELOC)
/* Print relocation adjustments, but only if gd is initialized */
if (gd && gd->flags & GD_FLG_RELOC) printf("EPC: " REG_FMT " RA: " REG_FMT " reloc adjusted\n\n", epc - gd->reloc_off, regs->ra - gd->reloc_off);
-- 2.28.0
On 9/15/20 10:23 PM, Rick Chen wrote:
Hi Sean
Changes in v2:
mv gp, zero
* point.
mv gp, a0
#endif
mv gp, s0
It is trying to prevent garbase messages and secondary early traps, but not the initial early trap. Printf (and specifically puts) uses gd to determine what function to print with. These functions in turn use gd to find the serial device, etc. However, before accessing gd, puts first checks to see if it is non-NULL. This indicates an existing (perhaps undocumented) assumption that either gd is NULL or it is completely valid.
mtvec will always point to handle_trap after the first few instructions executed by U-Boot. Before that, the prior stage's mtvec will be used. However, because all instructions before setting mtvec are regicter-register moves, I don't think it is likely for there to be a trap (unless there is a bug such as enabling RISCV_ISA_C on a processor which doesn't have that extension).
A more interesting question is "what is the status of gd during an early trap"? I will compare the situation before and after this patch.
Before this patch, gd either points to unexpected data (because it retains the value it did from the prior-stage) or points to uninitialized data (because it has not yet been initialized by board_init_f_init_reserve) until the hart has acquired available_harts_lock. This can cause two problems, depending on the value of gd->flags. If GD_FLG_SERIAL_READY is unset, then some garbage data will be printed to stdout, but there will not be a second trap. However, if GD_FLG_SERIAL_READY is set, then puts will try to print with serial_puts, which will likely cause a second trap.
After this patch, gd is zero up until either a hart has set it in wait_for_gd_init, or until it is set by arch_init_gd. This prevents its usage before its data is initialized because both handle_trap and puts ensure that gd is nonzero before using it. After gd has been set, it is OK to access it because its data has been cleared (and so flags is valid).
The same as a late trap, except _debug_uart_init may not have been called. Fortunately for us, if the prior stage correctly initialized the sifive uart, then it will work without initialization.
And then it is their problem for breaking boot on other boards :)
This commit relies on two assumptions from the rest of U-boot. First, that a check is made that gd is non-NULL before accessing it in code which can be called very early. Second, that arch_init_gd is called after gd is cleared. I think the first is likely to be enforced, given its existance in several functions (in addition to puts, watchdog_reset also does a check). The second is also likely to be enforced, because gd needs to be cleared anyway, and the ordering of 3 lines is unlikely to warrant significant change.
--Sean
Rick Chen
Sean Anderson
