[U-Boot-Users] Patch for drivers/cfi_flash.c; properly detect write errors.
Hello..
It seems that there is a minor problem in cfi_flash.c that prevents it from detecting that a flash write error has occurred.
The first change in the attached patch is trivial, it just makes the strings output for a protected and a non-protected sector have the same length so the output looks prettier..
The second change is in flash_full_status_check(). We have just called flash_status_check() and then did a switch() on the vendor. For intel, we *should* check if there are any error bits if the previous call returned ERR_OK (Otherwise we will have output an error message in flash_status_check() already.) The original code would only check for error bits if flash_status_check() returns ERR_TIMEOUT.
Applied. Thanks. But please provide a proper CHANGELOG entry next time.
Marcus Hall
