[U-Boot] [PATCH 1/6] imx: iomux-v3: Add iomux-mx25.h
Allow usage of the imx-common/iomux-v3.h framework by including pad settings for the i.MX25. The content of the file is taken from Linux kernel at commit 267dd34, plus the required changes to make it work in U-Boot.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- arch/arm/imx-common/Makefile | 5 +- arch/arm/include/asm/arch-mx25/imx-regs.h | 1 + arch/arm/include/asm/arch-mx25/iomux-mx25.h | 545 +++++++++++++++++++++++++++ 3 files changed, 550 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx25/iomux-mx25.h
diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 9309439..df54040 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -27,8 +27,11 @@ include $(TOPDIR)/config.mk
LIB = $(obj)libimx-common.o
+ifeq ($(SOC),$(filter $(SOC),mx25 mx5 mx6)) +COBJS-y = iomux-v3.o +endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) -COBJS-y = iomux-v3.o timer.o cpu.o speed.o +COBJS-y = timer.o cpu.o speed.o COBJS-$(CONFIG_I2C_MXC) += i2c-mxv7.o endif ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index 5f4b543..08609c1 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -187,6 +187,7 @@ struct aips_regs { #define IMX_CSPI1_BASE (0x43FA4000) #define IMX_KPP_BASE (0x43FA8000) #define IMX_IOPADMUX_BASE (0x43FAC000) +#define IOMUXC_BASE_ADDR IMX_IOPADMUX_BASE #define IMX_IOPADCTL_BASE (0x43FAC22C) #define IMX_IOPADGRPCTL_BASE (0x43FAC418) #define IMX_IOPADINPUTSEL_BASE (0x43FAC460) diff --git a/arch/arm/include/asm/arch-mx25/iomux-mx25.h b/arch/arm/include/asm/arch-mx25/iomux-mx25.h new file mode 100644 index 0000000..c0f5c61 --- /dev/null +++ b/arch/arm/include/asm/arch-mx25/iomux-mx25.h @@ -0,0 +1,545 @@ +/* + * (C) Copyright 2013 ADVANSEE + * Benoît Thébaudeau benoit.thebaudeau@advansee.com + * + * Based on mainline Linux i.MX iomux-mx25.h file: + * Copyright (C) 2009 by Lothar Wassmann LW@KARO-electronics.de + * + * Based on Linux arch/arm/mach-mx25/mx25_pins.h: + * Copyright 2008 Freescale Semiconductor, Inc. All Rights Reserved. + * and Linux arch/arm/plat-mxc/include/mach/iomux-mx35.h: + * Copyright (C) 2009 by Jan Weitzel Phytec Messtechnik GmbH armlinux@phytec.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __IOMUX_MX25_H__ +#define __IOMUX_MX25_H__ + +#include <asm/imx-common/iomux-v3.h> + +/* Pad control groupings */ +#define MX25_KPP_ROW_PAD_CTRL PAD_CTL_PUS_100K_UP +#define MX25_KPP_COL_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_ODE) + +/* + * The naming convention for the pad modes is MX25_PAD_<padname>__<padmode> + * If <padname> or <padmode> refers to a GPIO, it is named GPIO_<unit>_<num> + * See also iomux-v3.h + */ + +/* PAD MUX ALT INPSE PATH PADCTRL */ +enum { + MX25_PAD_A10__A10 = IOMUX_PAD(0x000, 0x008, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A10__GPIO_4_0 = IOMUX_PAD(0x000, 0x008, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A13__A13 = IOMUX_PAD(0x22C, 0x00c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A13__GPIO_4_1 = IOMUX_PAD(0x22C, 0x00c, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A14__A14 = IOMUX_PAD(0x230, 0x010, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A14__GPIO_2_0 = IOMUX_PAD(0x230, 0x010, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A15__A15 = IOMUX_PAD(0x234, 0x014, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A15__GPIO_2_1 = IOMUX_PAD(0x234, 0x014, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A16__A16 = IOMUX_PAD(0x000, 0x018, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A16__GPIO_2_2 = IOMUX_PAD(0x000, 0x018, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A17__A17 = IOMUX_PAD(0x238, 0x01c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A17__GPIO_2_3 = IOMUX_PAD(0x238, 0x01c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A18__A18 = IOMUX_PAD(0x23c, 0x020, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A18__GPIO_2_4 = IOMUX_PAD(0x23c, 0x020, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A18__FEC_COL = IOMUX_PAD(0x23c, 0x020, 0x17, 0x504, 0, NO_PAD_CTRL), + + MX25_PAD_A19__A19 = IOMUX_PAD(0x240, 0x024, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A19__FEC_RX_ER = IOMUX_PAD(0x240, 0x024, 0x17, 0x518, 0, NO_PAD_CTRL), + MX25_PAD_A19__GPIO_2_5 = IOMUX_PAD(0x240, 0x024, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A20__A20 = IOMUX_PAD(0x244, 0x028, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A20__GPIO_2_6 = IOMUX_PAD(0x244, 0x028, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A20__FEC_RDATA2 = IOMUX_PAD(0x244, 0x028, 0x17, 0x50c, 0, NO_PAD_CTRL), + + MX25_PAD_A21__A21 = IOMUX_PAD(0x248, 0x02c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A21__GPIO_2_7 = IOMUX_PAD(0x248, 0x02c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A21__FEC_RDATA3 = IOMUX_PAD(0x248, 0x02c, 0x17, 0x510, 0, NO_PAD_CTRL), + + MX25_PAD_A22__A22 = IOMUX_PAD(0x000, 0x030, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A22__GPIO_2_8 = IOMUX_PAD(0x000, 0x030, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A23__A23 = IOMUX_PAD(0x24c, 0x034, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A23__GPIO_2_9 = IOMUX_PAD(0x24c, 0x034, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_A24__A24 = IOMUX_PAD(0x250, 0x038, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A24__GPIO_2_10 = IOMUX_PAD(0x250, 0x038, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A24__FEC_RX_CLK = IOMUX_PAD(0x250, 0x038, 0x17, 0x514, 0, NO_PAD_CTRL), + + MX25_PAD_A25__A25 = IOMUX_PAD(0x254, 0x03c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_A25__GPIO_2_11 = IOMUX_PAD(0x254, 0x03c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A25__FEC_CRS = IOMUX_PAD(0x254, 0x03c, 0x17, 0x508, 0, NO_PAD_CTRL), + + MX25_PAD_EB0__EB0 = IOMUX_PAD(0x258, 0x040, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB0__AUD4_TXD = IOMUX_PAD(0x258, 0x040, 0x14, 0x464, 0, NO_PAD_CTRL), + MX25_PAD_EB0__GPIO_2_12 = IOMUX_PAD(0x258, 0x040, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_EB1__EB1 = IOMUX_PAD(0x25c, 0x044, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB1__AUD4_RXD = IOMUX_PAD(0x25c, 0x044, 0x14, 0x460, 0, NO_PAD_CTRL), + MX25_PAD_EB1__GPIO_2_13 = IOMUX_PAD(0x25c, 0x044, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_OE__OE = IOMUX_PAD(0x260, 0x048, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__AUD4_TXC = IOMUX_PAD(0x260, 0x048, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__GPIO_2_14 = IOMUX_PAD(0x260, 0x048, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CS0__CS0 = IOMUX_PAD(0x000, 0x04c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS0__GPIO_4_2 = IOMUX_PAD(0x000, 0x04c, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CS1__CS1 = IOMUX_PAD(0x000, 0x050, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS1__NF_CE3 = IOMUX_PAD(0x000, 0x050, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS1__GPIO_4_3 = IOMUX_PAD(0x000, 0x050, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CS4__CS4 = IOMUX_PAD(0x264, 0x054, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__NF_CE1 = IOMUX_PAD(0x264, 0x054, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__UART5_CTS = IOMUX_PAD(0x264, 0x054, 0x13, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__GPIO_3_20 = IOMUX_PAD(0x264, 0x054, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CS5__CS5 = IOMUX_PAD(0x268, 0x058, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__NF_CE2 = IOMUX_PAD(0x268, 0x058, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__UART5_RTS = IOMUX_PAD(0x268, 0x058, 0x13, 0x574, 0, NO_PAD_CTRL), + MX25_PAD_CS5__GPIO_3_21 = IOMUX_PAD(0x268, 0x058, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NF_CE0__NF_CE0 = IOMUX_PAD(0x26c, 0x05c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_NF_CE0__GPIO_3_22 = IOMUX_PAD(0x26c, 0x05c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_ECB__ECB = IOMUX_PAD(0x270, 0x060, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__UART5_TXD_MUX = IOMUX_PAD(0x270, 0x060, 0x13, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__GPIO_3_23 = IOMUX_PAD(0x270, 0x060, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LBA__LBA = IOMUX_PAD(0x274, 0x064, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_LBA__UART5_RXD_MUX = IOMUX_PAD(0x274, 0x064, 0x13, 0x578, 0, NO_PAD_CTRL), + MX25_PAD_LBA__GPIO_3_24 = IOMUX_PAD(0x274, 0x064, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_BCLK__BCLK = IOMUX_PAD(0x000, 0x068, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_BCLK__GPIO_4_4 = IOMUX_PAD(0x000, 0x068, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_RW__RW = IOMUX_PAD(0x278, 0x06c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_RW__AUD4_TXFS = IOMUX_PAD(0x278, 0x06c, 0x14, 0x474, 0, NO_PAD_CTRL), + MX25_PAD_RW__GPIO_3_25 = IOMUX_PAD(0x278, 0x06c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NFWE_B__NFWE_B = IOMUX_PAD(0x000, 0x070, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWE_B__GPIO_3_26 = IOMUX_PAD(0x000, 0x070, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NFRE_B__NFRE_B = IOMUX_PAD(0x000, 0x074, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRE_B__GPIO_3_27 = IOMUX_PAD(0x000, 0x074, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NFALE__NFALE = IOMUX_PAD(0x000, 0x078, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFALE__GPIO_3_28 = IOMUX_PAD(0x000, 0x078, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NFCLE__NFCLE = IOMUX_PAD(0x000, 0x07c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFCLE__GPIO_3_29 = IOMUX_PAD(0x000, 0x07c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NFWP_B__NFWP_B = IOMUX_PAD(0x000, 0x080, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWP_B__GPIO_3_30 = IOMUX_PAD(0x000, 0x080, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_NFRB__NFRB = IOMUX_PAD(0x27c, 0x084, 0x10, 0, 0, PAD_CTL_PKE), + MX25_PAD_NFRB__GPIO_3_31 = IOMUX_PAD(0x27c, 0x084, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D15__D15 = IOMUX_PAD(0x280, 0x088, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D15__LD16 = IOMUX_PAD(0x280, 0x088, 0x01, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_D15__GPIO_4_5 = IOMUX_PAD(0x280, 0x088, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D14__D14 = IOMUX_PAD(0x284, 0x08c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D14__LD17 = IOMUX_PAD(0x284, 0x08c, 0x01, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_D14__GPIO_4_6 = IOMUX_PAD(0x284, 0x08c, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D13__D13 = IOMUX_PAD(0x288, 0x090, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D13__LD18 = IOMUX_PAD(0x288, 0x090, 0x01, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_D13__GPIO_4_7 = IOMUX_PAD(0x288, 0x090, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D12__D12 = IOMUX_PAD(0x28c, 0x094, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D12__GPIO_4_8 = IOMUX_PAD(0x28c, 0x094, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D11__D11 = IOMUX_PAD(0x290, 0x098, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D11__GPIO_4_9 = IOMUX_PAD(0x290, 0x098, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D10__D10 = IOMUX_PAD(0x294, 0x09c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D10__GPIO_4_10 = IOMUX_PAD(0x294, 0x09c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D10__USBOTG_OC = IOMUX_PAD(0x294, 0x09c, 0x06, 0x57c, 0, PAD_CTL_PUS_100K_UP), + + MX25_PAD_D9__D9 = IOMUX_PAD(0x298, 0x0a0, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D9__GPIO_4_11 = IOMUX_PAD(0x298, 0x0a0, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D9__USBH2_PWR = IOMUX_PAD(0x298, 0x0a0, 0x06, 0, 0, PAD_CTL_PKE), + + MX25_PAD_D8__D8 = IOMUX_PAD(0x29c, 0x0a4, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D8__GPIO_4_12 = IOMUX_PAD(0x29c, 0x0a4, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D8__USBH2_OC = IOMUX_PAD(0x29c, 0x0a4, 0x06, 0x580, 0, PAD_CTL_PUS_100K_UP), + + MX25_PAD_D7__D7 = IOMUX_PAD(0x2a0, 0x0a8, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D7__GPIO_4_13 = IOMUX_PAD(0x2a0, 0x0a8, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D6__D6 = IOMUX_PAD(0x2a4, 0x0ac, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D6__GPIO_4_14 = IOMUX_PAD(0x2a4, 0x0ac, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D5__D5 = IOMUX_PAD(0x2a8, 0x0b0, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D5__GPIO_4_15 = IOMUX_PAD(0x2a8, 0x0b0, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D4__D4 = IOMUX_PAD(0x2ac, 0x0b4, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D4__GPIO_4_16 = IOMUX_PAD(0x2ac, 0x0b4, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D3__D3 = IOMUX_PAD(0x2b0, 0x0b8, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D3__GPIO_4_17 = IOMUX_PAD(0x2b0, 0x0b8, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D2__D2 = IOMUX_PAD(0x2b4, 0x0bc, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D2__GPIO_4_18 = IOMUX_PAD(0x2b4, 0x0bc, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D1__D1 = IOMUX_PAD(0x2b8, 0x0c0, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D1__GPIO_4_19 = IOMUX_PAD(0x2b8, 0x0c0, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_D0__D0 = IOMUX_PAD(0x2bc, 0x0c4, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_D0__GPIO_4_20 = IOMUX_PAD(0x2bc, 0x0c4, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD0__LD0 = IOMUX_PAD(0x2c0, 0x0c8, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD0__CSI_D0 = IOMUX_PAD(0x2c0, 0x0c8, 0x12, 0x488, 0, NO_PAD_CTRL), + MX25_PAD_LD0__GPIO_2_15 = IOMUX_PAD(0x2c0, 0x0c8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD1__LD1 = IOMUX_PAD(0x2c4, 0x0cc, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD1__CSI_D1 = IOMUX_PAD(0x2c4, 0x0cc, 0x12, 0x48c, 0, NO_PAD_CTRL), + MX25_PAD_LD1__GPIO_2_16 = IOMUX_PAD(0x2c4, 0x0cc, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD2__LD2 = IOMUX_PAD(0x2c8, 0x0d0, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD2__GPIO_2_17 = IOMUX_PAD(0x2c8, 0x0d0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD3__LD3 = IOMUX_PAD(0x2cc, 0x0d4, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD3__GPIO_2_18 = IOMUX_PAD(0x2cc, 0x0d4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD4__LD4 = IOMUX_PAD(0x2d0, 0x0d8, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD4__GPIO_2_19 = IOMUX_PAD(0x2d0, 0x0d8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD5__LD5 = IOMUX_PAD(0x2d4, 0x0dc, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD5__GPIO_1_19 = IOMUX_PAD(0x2d4, 0x0dc, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD6__LD6 = IOMUX_PAD(0x2d8, 0x0e0, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD6__GPIO_1_20 = IOMUX_PAD(0x2d8, 0x0e0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD7__LD7 = IOMUX_PAD(0x2dc, 0x0e4, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD7__GPIO_1_21 = IOMUX_PAD(0x2dc, 0x0e4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD8__LD8 = IOMUX_PAD(0x2e0, 0x0e8, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD8__FEC_TX_ERR = IOMUX_PAD(0x2e0, 0x0e8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD9__LD9 = IOMUX_PAD(0x2e4, 0x0ec, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD9__FEC_COL = IOMUX_PAD(0x2e4, 0x0ec, 0x15, 0x504, 1, NO_PAD_CTRL), + + MX25_PAD_LD10__LD10 = IOMUX_PAD(0x2e8, 0x0f0, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD10__FEC_RX_ER = IOMUX_PAD(0x2e8, 0x0f0, 0x15, 0x518, 1, NO_PAD_CTRL), + + MX25_PAD_LD11__LD11 = IOMUX_PAD(0x2ec, 0x0f4, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD11__FEC_RDATA2 = IOMUX_PAD(0x2ec, 0x0f4, 0x15, 0x50c, 1, NO_PAD_CTRL), + + MX25_PAD_LD12__LD12 = IOMUX_PAD(0x2f0, 0x0f8, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD12__FEC_RDATA3 = IOMUX_PAD(0x2f0, 0x0f8, 0x15, 0x510, 1, NO_PAD_CTRL), + + MX25_PAD_LD13__LD13 = IOMUX_PAD(0x2f4, 0x0fc, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD13__FEC_TDATA2 = IOMUX_PAD(0x2f4, 0x0fc, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD14__LD14 = IOMUX_PAD(0x2f8, 0x100, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD14__FEC_TDATA3 = IOMUX_PAD(0x2f8, 0x100, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LD15__LD15 = IOMUX_PAD(0x2fc, 0x104, 0x10, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD15__FEC_RX_CLK = IOMUX_PAD(0x2fc, 0x104, 0x15, 0x514, 1, NO_PAD_CTRL), + + MX25_PAD_HSYNC__HSYNC = IOMUX_PAD(0x300, 0x108, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_HSYNC__GPIO_1_22 = IOMUX_PAD(0x300, 0x108, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_VSYNC__VSYNC = IOMUX_PAD(0x304, 0x10c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSYNC__GPIO_1_23 = IOMUX_PAD(0x304, 0x10c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_LSCLK__LSCLK = IOMUX_PAD(0x308, 0x110, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_LSCLK__GPIO_1_24 = IOMUX_PAD(0x308, 0x110, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_OE_ACD__OE_ACD = IOMUX_PAD(0x30c, 0x114, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE_ACD__GPIO_1_25 = IOMUX_PAD(0x30c, 0x114, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CONTRAST__CONTRAST = IOMUX_PAD(0x310, 0x118, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CONTRAST__PWM4_PWMO = IOMUX_PAD(0x310, 0x118, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_CONTRAST__FEC_CRS = IOMUX_PAD(0x310, 0x118, 0x15, 0x508, 1, NO_PAD_CTRL), + + MX25_PAD_PWM__PWM = IOMUX_PAD(0x314, 0x11c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_PWM__GPIO_1_26 = IOMUX_PAD(0x314, 0x11c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_PWM__USBH2_OC = IOMUX_PAD(0x314, 0x11c, 0x16, 0x580, 1, PAD_CTL_PUS_100K_UP), + + MX25_PAD_CSI_D2__CSI_D2 = IOMUX_PAD(0x318, 0x120, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__UART5_RXD_MUX = IOMUX_PAD(0x318, 0x120, 0x11, 0x578, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D2__GPIO_1_27 = IOMUX_PAD(0x318, 0x120, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__CSPI3_MOSI = IOMUX_PAD(0x318, 0x120, 0x17, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_D3__CSI_D3 = IOMUX_PAD(0x31c, 0x124, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D3__GPIO_1_28 = IOMUX_PAD(0x31c, 0x124, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D3__CSPI3_MISO = IOMUX_PAD(0x31c, 0x124, 0x17, 0x4b4, 1, NO_PAD_CTRL), + + MX25_PAD_CSI_D4__CSI_D4 = IOMUX_PAD(0x320, 0x128, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__UART5_RTS = IOMUX_PAD(0x320, 0x128, 0x11, 0x574, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D4__GPIO_1_29 = IOMUX_PAD(0x320, 0x128, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__CSPI3_SCLK = IOMUX_PAD(0x320, 0x128, 0x17, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_D5__CSI_D5 = IOMUX_PAD(0x324, 0x12c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__GPIO_1_30 = IOMUX_PAD(0x324, 0x12c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__CSPI3_RDY = IOMUX_PAD(0x324, 0x12c, 0x17, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D8__GPIO_1_7 = IOMUX_PAD(0x330, 0x138, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_D9__CSI_D9 = IOMUX_PAD(0x334, 0x13c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x33c, 0x144, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_VSYNC__GPIO_1_9 = IOMUX_PAD(0x33c, 0x144, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x340, 0x148, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_HSYNC__GPIO_1_10 = IOMUX_PAD(0x340, 0x148, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x344, 0x14c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_PIXCLK__GPIO_1_11 = IOMUX_PAD(0x344, 0x14c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_I2C1_CLK__I2C1_CLK = IOMUX_PAD(0x348, 0x150, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_CLK__GPIO_1_12 = IOMUX_PAD(0x348, 0x150, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_I2C1_DAT__I2C1_DAT = IOMUX_PAD(0x34c, 0x154, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_DAT__GPIO_1_13 = IOMUX_PAD(0x34c, 0x154, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MOSI__GPIO_1_14 = IOMUX_PAD(0x350, 0x158, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSPI1_MISO__CSPI1_MISO = IOMUX_PAD(0x354, 0x15c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MISO__GPIO_1_15 = IOMUX_PAD(0x354, 0x15c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSPI1_SS0__CSPI1_SS0 = IOMUX_PAD(0x358, 0x160, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__GPIO_1_16 = IOMUX_PAD(0x358, 0x160, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__I2C3_DAT = IOMUX_PAD(0x35c, 0x164, 0x11, 0x528, 1, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__GPIO_1_17 = IOMUX_PAD(0x35c, 0x164, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSPI1_SCLK__CSPI1_SCLK = IOMUX_PAD(0x360, 0x168, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SCLK__GPIO_1_18 = IOMUX_PAD(0x360, 0x168, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CSPI1_RDY__CSPI1_RDY = IOMUX_PAD(0x364, 0x16c, 0x10, 0, 0, PAD_CTL_PKE), + MX25_PAD_CSPI1_RDY__GPIO_2_22 = IOMUX_PAD(0x364, 0x16c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x368, 0x170, 0x10, 0, 0, PAD_CTL_PUS_100K_DOWN), + MX25_PAD_UART1_RXD__GPIO_4_22 = IOMUX_PAD(0x368, 0x170, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x36c, 0x174, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_TXD__GPIO_4_23 = IOMUX_PAD(0x36c, 0x174, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x370, 0x178, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_RTS__CSI_D0 = IOMUX_PAD(0x370, 0x178, 0x11, 0x488, 1, NO_PAD_CTRL), + MX25_PAD_UART1_RTS__GPIO_4_24 = IOMUX_PAD(0x370, 0x178, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x374, 0x17c, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_CTS__CSI_D1 = IOMUX_PAD(0x374, 0x17c, 0x11, 0x48c, 1, NO_PAD_CTRL), + MX25_PAD_UART1_CTS__GPIO_4_25 = IOMUX_PAD(0x374, 0x17c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART2_RXD__UART2_RXD = IOMUX_PAD(0x378, 0x180, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RXD__GPIO_4_26 = IOMUX_PAD(0x378, 0x180, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART2_TXD__UART2_TXD = IOMUX_PAD(0x37c, 0x184, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_TXD__GPIO_4_27 = IOMUX_PAD(0x37c, 0x184, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART2_RTS__UART2_RTS = IOMUX_PAD(0x380, 0x188, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__FEC_COL = IOMUX_PAD(0x380, 0x188, 0x12, 0x504, 2, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__GPIO_4_28 = IOMUX_PAD(0x380, 0x188, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UART2_CTS__FEC_RX_ER = IOMUX_PAD(0x384, 0x18c, 0x12, 0x518, 2, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__UART2_CTS = IOMUX_PAD(0x384, 0x18c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__GPIO_4_29 = IOMUX_PAD(0x384, 0x18c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x388, 0x190, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_CMD__FEC_RDATA2 = IOMUX_PAD(0x388, 0x190, 0x12, 0x50c, 2, NO_PAD_CTRL), + MX25_PAD_SD1_CMD__GPIO_2_23 = IOMUX_PAD(0x388, 0x190, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x38c, 0x194, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_CLK__FEC_RDATA3 = IOMUX_PAD(0x38c, 0x194, 0x12, 0x510, 2, NO_PAD_CTRL), + MX25_PAD_SD1_CLK__GPIO_2_24 = IOMUX_PAD(0x38c, 0x194, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x390, 0x198, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA0__GPIO_2_25 = IOMUX_PAD(0x390, 0x198, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x394, 0x19c, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA1__AUD7_RXD = IOMUX_PAD(0x394, 0x19c, 0x13, 0x478, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA1__GPIO_2_26 = IOMUX_PAD(0x394, 0x19c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x398, 0x1a0, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA2__FEC_RX_CLK = IOMUX_PAD(0x398, 0x1a0, 0x15, 0x514, 2, NO_PAD_CTRL), + MX25_PAD_SD1_DATA2__GPIO_2_27 = IOMUX_PAD(0x398, 0x1a0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA3__FEC_CRS = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0x508, 2, NO_PAD_CTRL), + MX25_PAD_SD1_DATA3__GPIO_2_28 = IOMUX_PAD(0x39c, 0x1a4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW0__GPIO_2_29 = IOMUX_PAD(0x3a0, 0x1a8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_ROW1__KPP_ROW1 = IOMUX_PAD(0x3a4, 0x1ac, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW1__GPIO_2_30 = IOMUX_PAD(0x3a4, 0x1ac, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW2__CSI_D0 = IOMUX_PAD(0x3a8, 0x1b0, 0x13, 0x488, 2, NO_PAD_CTRL), + MX25_PAD_KPP_ROW2__GPIO_2_31 = IOMUX_PAD(0x3a8, 0x1b0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_ROW3__KPP_ROW3 = IOMUX_PAD(0x3ac, 0x1b4, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW3__CSI_LD1 = IOMUX_PAD(0x3ac, 0x1b4, 0x13, 0x48c, 2, NO_PAD_CTRL), + MX25_PAD_KPP_ROW3__GPIO_3_0 = IOMUX_PAD(0x3ac, 0x1b4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_COL0__KPP_COL0 = IOMUX_PAD(0x3b0, 0x1b8, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL0__UART4_RXD_MUX = IOMUX_PAD(0x3b0, 0x1b8, 0x11, 0x570, 1, NO_PAD_CTRL), + MX25_PAD_KPP_COL0__AUD5_TXD = IOMUX_PAD(0x3b0, 0x1b8, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL0__GPIO_3_1 = IOMUX_PAD(0x3b0, 0x1b8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_COL1__KPP_COL1 = IOMUX_PAD(0x3b4, 0x1bc, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL1__UART4_TXD_MUX = IOMUX_PAD(0x3b4, 0x1bc, 0x11, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL1__AUD5_RXD = IOMUX_PAD(0x3b4, 0x1bc, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL1__GPIO_3_2 = IOMUX_PAD(0x3b4, 0x1bc, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_COL2__KPP_COL2 = IOMUX_PAD(0x3b8, 0x1c0, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL2__UART4_RTS = IOMUX_PAD(0x3b8, 0x1c0, 0x11, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL2__AUD5_TXC = IOMUX_PAD(0x3b8, 0x1c0, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL2__GPIO_3_3 = IOMUX_PAD(0x3b8, 0x1c0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_KPP_COL3__KPP_COL3 = IOMUX_PAD(0x3bc, 0x1c4, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL3__UART4_CTS = IOMUX_PAD(0x3bc, 0x1c4, 0x11, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL3__AUD5_TXFS = IOMUX_PAD(0x3bc, 0x1c4, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL3__GPIO_3_4 = IOMUX_PAD(0x3bc, 0x1c4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_MDC__FEC_MDC = IOMUX_PAD(0x3c0, 0x1c8, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__AUD4_TXD = IOMUX_PAD(0x3c0, 0x1c8, 0x12, 0x464, 1, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__GPIO_3_5 = IOMUX_PAD(0x3c0, 0x1c8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_MDIO__FEC_MDIO = IOMUX_PAD(0x3c4, 0x1cc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP), + MX25_PAD_FEC_MDIO__AUD4_RXD = IOMUX_PAD(0x3c4, 0x1cc, 0x12, 0x460, 1, NO_PAD_CTRL), + MX25_PAD_FEC_MDIO__GPIO_3_6 = IOMUX_PAD(0x3c4, 0x1cc, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_TDATA0__FEC_TDATA0 = IOMUX_PAD(0x3c8, 0x1d0, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA0__GPIO_3_7 = IOMUX_PAD(0x3c8, 0x1d0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_TDATA1__FEC_TDATA1 = IOMUX_PAD(0x3cc, 0x1d4, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__AUD4_TXFS = IOMUX_PAD(0x3cc, 0x1d4, 0x12, 0x474, 1, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__GPIO_3_8 = IOMUX_PAD(0x3cc, 0x1d4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_TX_EN__FEC_TX_EN = IOMUX_PAD(0x3d0, 0x1d8, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_EN__GPIO_3_9 = IOMUX_PAD(0x3d0, 0x1d8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_RDATA0__FEC_RDATA0 = IOMUX_PAD(0x3d4, 0x1dc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RDATA0__GPIO_3_10 = IOMUX_PAD(0x3d4, 0x1dc, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_RDATA1__FEC_RDATA1 = IOMUX_PAD(0x3d8, 0x1e0, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RDATA1__GPIO_3_11 = IOMUX_PAD(0x3d8, 0x1e0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_RX_DV__FEC_RX_DV = IOMUX_PAD(0x3dc, 0x1e4, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RX_DV__CAN2_RX = IOMUX_PAD(0x3dc, 0x1e4, 0x14, 0x484, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_FEC_RX_DV__GPIO_3_12 = IOMUX_PAD(0x3dc, 0x1e4, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_FEC_TX_CLK__FEC_TX_CLK = IOMUX_PAD(0x3e0, 0x1e8, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_TX_CLK__GPIO_3_13 = IOMUX_PAD(0x3e0, 0x1e8, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_RTCK__RTCK = IOMUX_PAD(0x3e4, 0x1ec, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__OWIRE = IOMUX_PAD(0x3e4, 0x1ec, 0x11, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__GPIO_3_14 = IOMUX_PAD(0x3e4, 0x1ec, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_DE_B__DE_B = IOMUX_PAD(0x3ec, 0x1f0, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_DE_B__GPIO_2_20 = IOMUX_PAD(0x3ec, 0x1f0, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_TDO__TDO = IOMUX_PAD(0x3e8, 0x000, 0x00, 0, 0, NO_PAD_CTRL), + + MX25_PAD_GPIO_A__GPIO_A = IOMUX_PAD(0x3f0, 0x1f4, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_A__CAN1_TX = IOMUX_PAD(0x3f0, 0x1f4, 0x16, 0, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_A__USBOTG_PWR = IOMUX_PAD(0x3f0, 0x1f4, 0x12, 0, 0, PAD_CTL_PKE), + + MX25_PAD_GPIO_B__GPIO_B = IOMUX_PAD(0x3f4, 0x1f8, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_B__CAN1_RX = IOMUX_PAD(0x3f4, 0x1f8, 0x16, 0x480, 1, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_B__USBOTG_OC = IOMUX_PAD(0x3f4, 0x1f8, 0x12, 0x57c, 1, PAD_CTL_PUS_100K_UP), + + MX25_PAD_GPIO_C__GPIO_C = IOMUX_PAD(0x3f8, 0x1fc, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_C__CAN2_TX = IOMUX_PAD(0x3f8, 0x1fc, 0x16, 0, 0, PAD_CTL_PUS_22K_UP), + + MX25_PAD_GPIO_D__GPIO_D = IOMUX_PAD(0x3fc, 0x200, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_E__LD16 = IOMUX_PAD(0x400, 0x204, 0x02, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_GPIO_D__CAN2_RX = IOMUX_PAD(0x3fc, 0x200, 0x16, 0x484, 1, PAD_CTL_PUS_22K_UP), + + MX25_PAD_GPIO_E__GPIO_E = IOMUX_PAD(0x400, 0x204, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__LD17 = IOMUX_PAD(0x404, 0x208, 0x02, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_GPIO_E__I2C3_CLK = IOMUX_PAD(0x400, 0x204, 0x11, 0x524, 2, NO_PAD_CTRL), + MX25_PAD_GPIO_E__AUD7_TXD = IOMUX_PAD(0x400, 0x204, 0x14, 0, 0, NO_PAD_CTRL), + + MX25_PAD_GPIO_F__GPIO_F = IOMUX_PAD(0x404, 0x208, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__AUD7_TXC = IOMUX_PAD(0x404, 0x208, 0x14, 0, 0, NO_PAD_CTRL), + + MX25_PAD_EXT_ARMCLK__EXT_ARMCLK = IOMUX_PAD(0x000, 0x20c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_EXT_ARMCLK__GPIO_3_15 = IOMUX_PAD(0x000, 0x20c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_UPLL_BYPCLK__UPLL_BYPCLK = IOMUX_PAD(0x000, 0x210, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_UPLL_BYPCLK__GPIO_3_16 = IOMUX_PAD(0x000, 0x210, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_VSTBY_REQ__VSTBY_REQ = IOMUX_PAD(0x408, 0x214, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__AUD7_TXFS = IOMUX_PAD(0x408, 0x214, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__GPIO_3_17 = IOMUX_PAD(0x408, 0x214, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__VSTBY_ACK = IOMUX_PAD(0x40c, 0x218, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__GPIO_3_18 = IOMUX_PAD(0x40c, 0x218, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_POWER_FAIL__POWER_FAIL = IOMUX_PAD(0x410, 0x21c, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__AUD7_RXD = IOMUX_PAD(0x410, 0x21c, 0x14, 0x478, 1, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__GPIO_3_19 = IOMUX_PAD(0x410, 0x21c, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CLKO__CLKO = IOMUX_PAD(0x414, 0x220, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CLKO__GPIO_2_21 = IOMUX_PAD(0x414, 0x220, 0x15, 0, 0, NO_PAD_CTRL), + + MX25_PAD_BOOT_MODE0__BOOT_MODE0 = IOMUX_PAD(0x000, 0x224, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE0__GPIO_4_30 = IOMUX_PAD(0x000, 0x224, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE1__BOOT_MODE1 = IOMUX_PAD(0x000, 0x228, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE1__GPIO_4_31 = IOMUX_PAD(0x000, 0x228, 0x05, 0, 0, NO_PAD_CTRL), + + MX25_PAD_CTL_GRP_DVS_MISC = IOMUX_PAD(0x418, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_FEC = IOMUX_PAD(0x41c, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DVS_JTAG = IOMUX_PAD(0x420, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_NFC = IOMUX_PAD(0x424, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_CSI = IOMUX_PAD(0x428, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_WEIM = IOMUX_PAD(0x42c, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_DDR = IOMUX_PAD(0x430, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DVS_CRM = IOMUX_PAD(0x434, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_KPP = IOMUX_PAD(0x438, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_SDHC1 = IOMUX_PAD(0x43c, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_LCD = IOMUX_PAD(0x440, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_UART = IOMUX_PAD(0x444, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DVS_NFC = IOMUX_PAD(0x448, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DVS_CSI = IOMUX_PAD(0x44c, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DSE_CSPI1 = IOMUX_PAD(0x450, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DDRTYPE = IOMUX_PAD(0x454, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DVS_SDHC1 = IOMUX_PAD(0x458, 0x000, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CTL_GRP_DVS_LCD = IOMUX_PAD(0x45c, 0x000, 0, 0, 0, NO_PAD_CTRL), +}; + +#endif /* __IOMUX_MX25_H__ */
There is no change of behavior, even if some pad control values could probably be simplified.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- board/freescale/mx25pdk/mx25pdk.c | 128 ++++++++++++++++++++++--------------- 1 file changed, 75 insertions(+), 53 deletions(-)
diff --git a/board/freescale/mx25pdk/mx25pdk.c b/board/freescale/mx25pdk/mx25pdk.c index d73e27e..421afea 100644 --- a/board/freescale/mx25pdk/mx25pdk.c +++ b/board/freescale/mx25pdk/mx25pdk.c @@ -21,8 +21,7 @@ #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/imx25-pinmux.h> -#include <asm/arch/sys_proto.h> +#include <asm/arch/iomux-mx25.h> #include <asm/arch/clock.h> #include <mmc.h> #include <fsl_esdhc.h> @@ -43,29 +42,42 @@ struct fsl_esdhc_cfg esdhc_cfg[1] = { }; #endif
+/* + * FIXME: need to revisit this + * The original code enabled PUE and 100-k pull-down without PKE, so the right + * value here is likely: + * 0 for no pull + * or: + * PAD_CTL_PUS_100K_DOWN for 100-k pull-down + */ +#define FEC_OUT_PAD_CTRL 0 + +#define I2C_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | \ + PAD_CTL_ODE) + static void mx25pdk_fec_init(void) { - struct iomuxc_mux_ctl *muxctl; - struct iomuxc_pad_ctl *padctl; - u32 gpio_mux_mode = MX25_PIN_MUX_MODE(5); - u32 gpio_mux_mode0_sion = MX25_PIN_MUX_MODE(0) | MX25_PIN_MUX_SION; - - /* FEC pin init is generic */ - mx25_fec_init_pins(); - - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; - /* - * Set up FEC_RESET_B and FEC_ENABLE_B - * - * FEC_RESET_B: gpio2_3 is ALT 5 mode of pin D12 - * FEC_ENABLE_B: gpio4_8 is ALT 5 mode of pin A17 - */ - writel(gpio_mux_mode, &muxctl->pad_d12); - writel(gpio_mux_mode, &muxctl->pad_a17); - - writel(0x0, &padctl->pad_d12); - writel(0x0, &padctl->pad_a17); + static const iomux_v3_cfg_t fec_pads[] = { + MX25_PAD_FEC_TX_CLK__FEC_TX_CLK, + MX25_PAD_FEC_RX_DV__FEC_RX_DV, + MX25_PAD_FEC_RDATA0__FEC_RDATA0, + NEW_PAD_CTRL(MX25_PAD_FEC_TDATA0__FEC_TDATA0, FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_FEC_TX_EN__FEC_TX_EN, FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_FEC_MDC__FEC_MDC, FEC_OUT_PAD_CTRL), + MX25_PAD_FEC_MDIO__FEC_MDIO, + MX25_PAD_FEC_RDATA1__FEC_RDATA1, + NEW_PAD_CTRL(MX25_PAD_FEC_TDATA1__FEC_TDATA1, FEC_OUT_PAD_CTRL), + + NEW_PAD_CTRL(MX25_PAD_D12__GPIO_4_8, 0), /* FEC_RESET_B */ + NEW_PAD_CTRL(MX25_PAD_A17__GPIO_2_3, 0), /* FEC_ENABLE_B */ + }; + + static const iomux_v3_cfg_t i2c_pads[] = { + NEW_PAD_CTRL(MX25_PAD_I2C1_CLK__I2C1_CLK, I2C_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_I2C1_DAT__I2C1_DAT, I2C_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads));
/* Assert RESET and ENABLE low */ gpio_direction_output(FEC_RESET_B, 0); @@ -78,10 +90,7 @@ static void mx25pdk_fec_init(void) gpio_set_value(FEC_ENABLE_B, 1);
/* Setup I2C pins so that PMIC can turn on PHY supply */ - writel(gpio_mux_mode0_sion, &muxctl->pad_i2c1_clk); - writel(gpio_mux_mode0_sion, &muxctl->pad_i2c1_dat); - writel(0x1E8, &padctl->pad_i2c1_clk); - writel(0x1E8, &padctl->pad_i2c1_dat); + imx_iomux_v3_setup_multiple_pads(i2c_pads, ARRAY_SIZE(i2c_pads)); }
int dram_init(void) @@ -92,9 +101,35 @@ int dram_init(void) return 0; }
+/* + * Set up input pins with hysteresis and 100-k pull-ups + */ +#define UART1_IN_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_100K_UP) +/* + * FIXME: need to revisit this + * The original code enabled PUE and 100-k pull-down without PKE, so the right + * value here is likely: + * 0 for no pull + * or: + * PAD_CTL_PUS_100K_DOWN for 100-k pull-down + */ +#define UART1_OUT_PAD_CTRL 0 + +static void mx25pdk_uart1_init(void) +{ + static const iomux_v3_cfg_t uart1_pads[] = { + NEW_PAD_CTRL(MX25_PAD_UART1_RXD__UART1_RXD, UART1_IN_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_UART1_TXD__UART1_TXD, UART1_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_UART1_RTS__UART1_RTS, UART1_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_UART1_CTS__UART1_CTS, UART1_IN_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + int board_early_init_f(void) { - mx25_uart1_init_pins(); + mx25pdk_uart1_init();
return 0; } @@ -131,21 +166,8 @@ int board_late_init(void) #ifdef CONFIG_FSL_ESDHC int board_mmc_getcd(struct mmc *mmc) { - struct iomuxc_mux_ctl *muxctl; - struct iomuxc_pad_ctl *padctl; - u32 gpio_mux_mode = MX25_PIN_MUX_MODE(5); - - /* - * Set up the Card Detect pin. - * - * SD1_GPIO_CD: gpio2_1 is ALT 5 mode of pin A15 - * - */ - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; - - writel(gpio_mux_mode, &muxctl->pad_a15); - writel(0x0, &padctl->pad_a15); + /* Set up the Card Detect pin. */ + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX25_PAD_A15__GPIO_2_1, 0));
gpio_direction_input(CARD_DETECT); return !gpio_get_value(CARD_DETECT); @@ -153,16 +175,16 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { - struct iomuxc_mux_ctl *muxctl; - u32 sdhc1_mux_mode = MX25_PIN_MUX_MODE(0) | MX25_PIN_MUX_SION; - - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - writel(sdhc1_mux_mode, &muxctl->pad_sd1_cmd); - writel(sdhc1_mux_mode, &muxctl->pad_sd1_clk); - writel(sdhc1_mux_mode, &muxctl->pad_sd1_data0); - writel(sdhc1_mux_mode, &muxctl->pad_sd1_data1); - writel(sdhc1_mux_mode, &muxctl->pad_sd1_data2); - writel(sdhc1_mux_mode, &muxctl->pad_sd1_data3); + static const iomux_v3_cfg_t sdhc1_pads[] = { + NEW_PAD_CTRL(MX25_PAD_SD1_CMD__SD1_CMD, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_CLK__SD1_CLK, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA0__SD1_DATA0, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA1__SD1_DATA1, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA2__SD1_DATA2, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA3__SD1_DATA3, NO_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(sdhc1_pads, ARRAY_SIZE(sdhc1_pads));
esdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC1_CLK); return fsl_esdhc_initialize(bis, &esdhc_cfg[0]);
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- board/freescale/mx25pdk/mx25pdk.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx25pdk/mx25pdk.c b/board/freescale/mx25pdk/mx25pdk.c index 421afea..5e6047f 100644 --- a/board/freescale/mx25pdk/mx25pdk.c +++ b/board/freescale/mx25pdk/mx25pdk.c @@ -30,8 +30,8 @@ #include <fsl_pmic.h> #include <mc34704.h>
-#define FEC_RESET_B IMX_GPIO_NR(2, 3) -#define FEC_ENABLE_B IMX_GPIO_NR(4, 8) +#define FEC_RESET_B IMX_GPIO_NR(4, 8) +#define FEC_ENABLE_B IMX_GPIO_NR(2, 3) #define CARD_DETECT IMX_GPIO_NR(2, 1)
DECLARE_GLOBAL_DATA_PTR;
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- board/karo/tx25/tx25.c | 107 ++++++++++++++++++++++++++++++------------------ 1 file changed, 68 insertions(+), 39 deletions(-)
diff --git a/board/karo/tx25/tx25.c b/board/karo/tx25/tx25.c index 85719a0..2952eba 100644 --- a/board/karo/tx25/tx25.c +++ b/board/karo/tx25/tx25.c @@ -27,9 +27,8 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/imx25-pinmux.h> +#include <asm/arch/iomux-mx25.h> #include <asm/gpio.h> -#include <asm/arch/sys_proto.h>
@@ -42,36 +41,44 @@ void board_init_f(ulong bootflag) #endif
#ifdef CONFIG_FEC_MXC +/* + * FIXME: need to revisit this + * The original code enabled PUE and 100-k pull-down without PKE, so the right + * value here is likely: + * 0 for no pull + * or: + * PAD_CTL_PUS_100K_DOWN for 100-k pull-down + */ +#define FEC_OUT_PAD_CTRL 0 + #define GPIO_FEC_RESET_B IMX_GPIO_NR(4, 7) #define GPIO_FEC_ENABLE_B IMX_GPIO_NR(4, 9)
void tx25_fec_init(void) { - struct iomuxc_mux_ctl *muxctl; - struct iomuxc_pad_ctl *padctl; - u32 gpio_mux_mode = MX25_PIN_MUX_MODE(5); - u32 saved_rdata0_mode, saved_rdata1_mode, saved_rx_dv_mode; + static const iomux_v3_cfg_t fec_pads[] = { + MX25_PAD_FEC_TX_CLK__FEC_TX_CLK, + MX25_PAD_FEC_RX_DV__FEC_RX_DV, + MX25_PAD_FEC_RDATA0__FEC_RDATA0, + NEW_PAD_CTRL(MX25_PAD_FEC_TDATA0__FEC_TDATA0, FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_FEC_TX_EN__FEC_TX_EN, FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_FEC_MDC__FEC_MDC, FEC_OUT_PAD_CTRL), + MX25_PAD_FEC_MDIO__FEC_MDIO, + MX25_PAD_FEC_RDATA1__FEC_RDATA1, + NEW_PAD_CTRL(MX25_PAD_FEC_TDATA1__FEC_TDATA1, FEC_OUT_PAD_CTRL), + + NEW_PAD_CTRL(MX25_PAD_D13__GPIO_4_7, 0), /* FEC_RESET_B */ + NEW_PAD_CTRL(MX25_PAD_D11__GPIO_4_9, 0), /* FEC_ENABLE_B */ + }; + + static const iomux_v3_cfg_t fec_cfg_pads[] = { + MX25_PAD_FEC_RDATA0__GPIO_3_10, + MX25_PAD_FEC_RDATA1__GPIO_3_11, + MX25_PAD_FEC_RX_DV__GPIO_3_12, + };
debug("tx25_fec_init\n"); - /* - * fec pin init is generic - */ - mx25_fec_init_pins(); - - /* - * Set up the FEC_RESET_B and FEC_ENABLE GPIO pins. - * - * FEC_RESET_B: gpio4[7] is ALT 5 mode of pin D13 - * FEC_ENABLE_B: gpio4[9] is ALT 5 mode of pin D11 - */ - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; - - writel(gpio_mux_mode, &muxctl->pad_d13); - writel(gpio_mux_mode, &muxctl->pad_d11); - - writel(0x0, &padctl->pad_d13); - writel(0x0, &padctl->pad_d11); + imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads));
/* drop PHY power and assert reset (low) */ gpio_direction_output(GPIO_FEC_RESET_B, 0); @@ -99,15 +106,10 @@ void tx25_fec_init(void) * RMII mode is selected by FEC_RX_DV which is GPIO 3_12 in mux mode */ /* - * save three current mux modes and set each to gpio mode + * set each mux mode to gpio mode */ - saved_rdata0_mode = readl(&muxctl->pad_fec_rdata0); - saved_rdata1_mode = readl(&muxctl->pad_fec_rdata1); - saved_rx_dv_mode = readl(&muxctl->pad_fec_rx_dv); - - writel(gpio_mux_mode, &muxctl->pad_fec_rdata0); - writel(gpio_mux_mode, &muxctl->pad_fec_rdata1); - writel(gpio_mux_mode, &muxctl->pad_fec_rx_dv); + imx_iomux_v3_setup_multiple_pads(fec_cfg_pads, + ARRAY_SIZE(fec_cfg_pads));
/* * set each to 1 and make each an output @@ -128,19 +130,46 @@ void tx25_fec_init(void) /* * set FEC pins back */ - writel(saved_rdata0_mode, &muxctl->pad_fec_rdata0); - writel(saved_rdata1_mode, &muxctl->pad_fec_rdata1); - writel(saved_rx_dv_mode, &muxctl->pad_fec_rx_dv); + imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); } #else #define tx25_fec_init() #endif
-int board_init() -{ #ifdef CONFIG_MXC_UART - mx25_uart1_init_pins(); +/* + * Set up input pins with hysteresis and 100-k pull-ups + */ +#define UART1_IN_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_100K_UP) +/* + * FIXME: need to revisit this + * The original code enabled PUE and 100-k pull-down without PKE, so the right + * value here is likely: + * 0 for no pull + * or: + * PAD_CTL_PUS_100K_DOWN for 100-k pull-down + */ +#define UART1_OUT_PAD_CTRL 0 + +static void tx25_uart1_init(void) +{ + static const iomux_v3_cfg_t uart1_pads[] = { + NEW_PAD_CTRL(MX25_PAD_UART1_RXD__UART1_RXD, UART1_IN_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_UART1_TXD__UART1_TXD, UART1_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_UART1_RTS__UART1_RTS, UART1_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_UART1_CTS__UART1_CTS, UART1_IN_PAD_CTRL), + }; + + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} +#else +#define tx25_uart1_init() #endif + +int board_init() +{ + tx25_uart1_init(); + /* board id for linux */ gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; return 0;
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- board/syteco/zmx25/zmx25.c | 143 ++++++++++++++++++++++---------------------- 1 file changed, 72 insertions(+), 71 deletions(-)
diff --git a/board/syteco/zmx25/zmx25.c b/board/syteco/zmx25/zmx25.c index 4f37c59..087d856 100644 --- a/board/syteco/zmx25/zmx25.c +++ b/board/syteco/zmx25/zmx25.c @@ -32,91 +32,85 @@ #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/imx25-pinmux.h> -#include <asm/arch/sys_proto.h> +#include <asm/arch/iomux-mx25.h>
int board_init() { - struct iomuxc_mux_ctl *muxctl; - struct iomuxc_pad_ctl *padctl; - struct iomuxc_pad_input_select *inputselect; - u32 gpio_mux_mode0_sion = MX25_PIN_MUX_MODE(0) | MX25_PIN_MUX_SION; - u32 gpio_mux_mode1 = MX25_PIN_MUX_MODE(1); - u32 gpio_mux_mode5 = MX25_PIN_MUX_MODE(5); - u32 gpio_mux_mode6 = MX25_PIN_MUX_MODE(6); - u32 input_select1 = MX25_PAD_INPUT_SELECT_DAISY(1); - u32 input_select2 = MX25_PAD_INPUT_SELECT_DAISY(2); + static const iomux_v3_cfg_t sdhc1_pads[] = { + NEW_PAD_CTRL(MX25_PAD_SD1_CMD__SD1_CMD, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_CLK__SD1_CLK, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA0__SD1_DATA0, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA1__SD1_DATA1, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA2__SD1_DATA2, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_SD1_DATA3__SD1_DATA3, NO_PAD_CTRL), + }; + + static const iomux_v3_cfg_t dig_out_pads[] = { + MX25_PAD_CSI_D8__GPIO_1_7, /* Ouput 1 Ctrl */ + MX25_PAD_CSI_D7__GPIO_1_6, /* Ouput 2 Ctrl */ + NEW_PAD_CTRL(MX25_PAD_CSI_D6__GPIO_1_31, 0), /* Ouput 1 Stat */ + NEW_PAD_CTRL(MX25_PAD_CSI_D5__GPIO_1_30, 0), /* Ouput 2 Stat */ + }; + + static const iomux_v3_cfg_t led_pads[] = { + MX25_PAD_CSI_D9__GPIO_4_21, + MX25_PAD_CSI_D4__GPIO_1_29, + }; + + static const iomux_v3_cfg_t can_pads[] = { + NEW_PAD_CTRL(MX25_PAD_GPIO_A__CAN1_TX, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_GPIO_B__CAN1_RX, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_GPIO_C__CAN2_TX, NO_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_GPIO_D__CAN2_RX, NO_PAD_CTRL), + }; + + static const iomux_v3_cfg_t i2c3_pads[] = { + MX25_PAD_CSPI1_SS1__I2C3_DAT, + MX25_PAD_GPIO_E__I2C3_CLK, + };
icache_enable();
- muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; - inputselect = (struct iomuxc_pad_input_select *)IMX_IOPADINPUTSEL_BASE; - - /* Setup of core volatage selection pin to run at 1.4V */ - writel(gpio_mux_mode5, &muxctl->pad_ext_armclk); /* VCORE GPIO3[15] */ + /* Setup of core voltage selection pin to run at 1.4V */ + imx_iomux_v3_setup_pad(MX25_PAD_EXT_ARMCLK__GPIO_3_15); /* VCORE */ gpio_direction_output(IMX_GPIO_NR(3, 15), 1);
- /* Setup of input daisy chains for SD card pins*/ - writel(gpio_mux_mode0_sion, &muxctl->pad_sd1_cmd); - writel(gpio_mux_mode0_sion, &muxctl->pad_sd1_clk); - writel(gpio_mux_mode0_sion, &muxctl->pad_sd1_data0); - writel(gpio_mux_mode0_sion, &muxctl->pad_sd1_data1); - writel(gpio_mux_mode0_sion, &muxctl->pad_sd1_data2); - writel(gpio_mux_mode0_sion, &muxctl->pad_sd1_data3); + /* Setup of SD card pins*/ + imx_iomux_v3_setup_multiple_pads(sdhc1_pads, ARRAY_SIZE(sdhc1_pads));
/* Setup of digital output for USB power and OC */ - writel(gpio_mux_mode5, &muxctl->pad_csi_d3); /* USB Power GPIO1[28] */ + imx_iomux_v3_setup_pad(MX25_PAD_CSI_D3__GPIO_1_28); /* USB Power */ gpio_direction_output(IMX_GPIO_NR(1, 28), 1);
- writel(gpio_mux_mode5, &muxctl->pad_csi_d2); /* USB OC GPIO1[27] */ + imx_iomux_v3_setup_pad(MX25_PAD_CSI_D2__GPIO_1_27); /* USB OC */ gpio_direction_input(IMX_GPIO_NR(1, 18));
/* Setup of digital output control pins */ - writel(gpio_mux_mode5, &muxctl->pad_csi_d8); /* Ouput 1 Ctrl GPIO1[7] */ - writel(gpio_mux_mode5, &muxctl->pad_csi_d7); /* Ouput 2 Ctrl GPIO1[6] */ - writel(gpio_mux_mode5, &muxctl->pad_csi_d6); /* Ouput 1 Stat GPIO1[31]*/ - writel(gpio_mux_mode5, &muxctl->pad_csi_d5); /* Ouput 2 Stat GPIO1[30]*/ - - writel(0, &padctl->pad_csi_d6); /* Ouput 1 Stat pull up off */ - writel(0, &padctl->pad_csi_d5); /* Ouput 2 Stat pull up off */ + imx_iomux_v3_setup_multiple_pads(dig_out_pads, + ARRAY_SIZE(dig_out_pads));
/* Switch both output drivers off */ gpio_direction_output(IMX_GPIO_NR(1, 7), 0); gpio_direction_output(IMX_GPIO_NR(1, 6), 0);
- /* Setup of key input pin GPIO2[29]*/ - writel(gpio_mux_mode5 | MX25_PIN_MUX_SION, &muxctl->pad_kpp_row0); - writel(0, &padctl->pad_kpp_row0); /* Key pull up off */ + /* Setup of key input pin */ + imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX25_PAD_KPP_ROW0__GPIO_2_29, 0)); gpio_direction_input(IMX_GPIO_NR(2, 29));
/* Setup of status LED outputs */ - writel(gpio_mux_mode5, &muxctl->pad_csi_d9); /* GPIO4[21] */ - writel(gpio_mux_mode5, &muxctl->pad_csi_d4); /* GPIO1[29] */ + imx_iomux_v3_setup_multiple_pads(led_pads, ARRAY_SIZE(led_pads));
/* Switch both LEDs off */ gpio_direction_output(IMX_GPIO_NR(4, 21), 0); gpio_direction_output(IMX_GPIO_NR(1, 29), 0);
/* Setup of CAN1 and CAN2 signals */ - writel(gpio_mux_mode6, &muxctl->pad_gpio_a); /* CAN1 TX */ - writel(gpio_mux_mode6, &muxctl->pad_gpio_b); /* CAN1 RX */ - writel(gpio_mux_mode6, &muxctl->pad_gpio_c); /* CAN2 TX */ - writel(gpio_mux_mode6, &muxctl->pad_gpio_d); /* CAN2 RX */ - - /* Setup of input daisy chains for CAN signals*/ - writel(input_select1, &inputselect->can1_ipp_ind_canrx); /* CAN1 RX */ - writel(input_select1, &inputselect->can2_ipp_ind_canrx); /* CAN2 RX */ + imx_iomux_v3_setup_multiple_pads(can_pads, ARRAY_SIZE(can_pads));
/* Setup of I2C3 signals */ - writel(gpio_mux_mode1, &muxctl->pad_cspi1_ss1); /* I2C3 SDA */ - writel(gpio_mux_mode1, &muxctl->pad_gpio_e); /* I2C3 SCL */ - - /* Setup of input daisy chains for I2C3 signals*/ - writel(input_select1, &inputselect->i2c3_ipp_sda_in); /* I2C3 SDA */ - writel(input_select2, &inputselect->i2c3_ipp_scl_in); /* I2C3 SCL */ + imx_iomux_v3_setup_multiple_pads(i2c3_pads, ARRAY_SIZE(i2c3_pads));
gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
@@ -128,25 +122,32 @@ int board_late_init(void) const char *e;
#ifdef CONFIG_FEC_MXC - struct iomuxc_mux_ctl *muxctl; - u32 gpio_mux_mode2 = MX25_PIN_MUX_MODE(2); - u32 gpio_mux_mode5 = MX25_PIN_MUX_MODE(5); - - /* - * fec pin init is generic - */ - mx25_fec_init_pins(); - - /* - * Set up LAN-RESET and FEC_RX_ERR - * - * LAN-RESET: GPIO3[16] is ALT 5 mode of pin U20 - * FEC_RX_ERR: FEC_RX_ERR is ALT 2 mode of pin R2 - */ - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - - writel(gpio_mux_mode5, &muxctl->pad_upll_bypclk); - writel(gpio_mux_mode2, &muxctl->pad_uart2_cts); +/* + * FIXME: need to revisit this + * The original code enabled PUE and 100-k pull-down without PKE, so the right + * value here is likely: + * 0 for no pull + * or: + * PAD_CTL_PUS_100K_DOWN for 100-k pull-down + */ +#define FEC_OUT_PAD_CTRL 0 + + static const iomux_v3_cfg_t fec_pads[] = { + MX25_PAD_FEC_TX_CLK__FEC_TX_CLK, + MX25_PAD_FEC_RX_DV__FEC_RX_DV, + MX25_PAD_FEC_RDATA0__FEC_RDATA0, + NEW_PAD_CTRL(MX25_PAD_FEC_TDATA0__FEC_TDATA0, FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_FEC_TX_EN__FEC_TX_EN, FEC_OUT_PAD_CTRL), + NEW_PAD_CTRL(MX25_PAD_FEC_MDC__FEC_MDC, FEC_OUT_PAD_CTRL), + MX25_PAD_FEC_MDIO__FEC_MDIO, + MX25_PAD_FEC_RDATA1__FEC_RDATA1, + NEW_PAD_CTRL(MX25_PAD_FEC_TDATA1__FEC_TDATA1, FEC_OUT_PAD_CTRL), + + MX25_PAD_UPLL_BYPCLK__GPIO_3_16, /* LAN-RESET */ + MX25_PAD_UART2_CTS__FEC_RX_ER, /* FEC_RX_ERR */ + }; + + imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads));
/* assert PHY reset (low) */ gpio_direction_output(IMX_GPIO_NR(3, 16), 0);
Legacy iomux support is no longer needed now that all boards have been converted to iomux-v3.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- arch/arm/cpu/arm926ejs/mx25/generic.c | 117 ------- arch/arm/include/asm/arch-mx25/imx25-pinmux.h | 421 ------------------------- arch/arm/include/asm/arch-mx25/sys_proto.h | 32 -- 3 files changed, 570 deletions(-) delete mode 100644 arch/arm/include/asm/arch-mx25/imx25-pinmux.h delete mode 100644 arch/arm/include/asm/arch-mx25/sys_proto.h
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index 679273b..7cbbe65 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -27,7 +27,6 @@ #include <netdev.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/imx25-pinmux.h> #include <asm/arch/clock.h>
#ifdef CONFIG_FSL_ESDHC @@ -248,123 +247,7 @@ int cpu_mmc_init(bd_t *bis) } #endif
-#ifdef CONFIG_MXC_UART -void mx25_uart1_init_pins(void) -{ - struct iomuxc_mux_ctl *muxctl; - struct iomuxc_pad_ctl *padctl; - u32 inpadctl; - u32 outpadctl; - u32 muxmode0; - - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; - muxmode0 = MX25_PIN_MUX_MODE(0); - /* - * set up input pins with hysteresis and 100K pull-ups - */ - inpadctl = MX25_PIN_PAD_CTL_HYS - | MX25_PIN_PAD_CTL_PKE - | MX25_PIN_PAD_CTL_PUE | MX25_PIN_PAD_CTL_100K_PU; - - /* - * set up output pins with 100K pull-downs - * FIXME: need to revisit this - * PUE is ignored if PKE is not set - * so the right value here is likely - * 0x0 for no pull up/down - * or - * 0xc0 for 100k pull down - */ - outpadctl = MX25_PIN_PAD_CTL_PUE | MX25_PIN_PAD_CTL_100K_PD; - - /* UART1 */ - /* rxd */ - writel(muxmode0, &muxctl->pad_uart1_rxd); - writel(inpadctl, &padctl->pad_uart1_rxd); - - /* txd */ - writel(muxmode0, &muxctl->pad_uart1_txd); - writel(outpadctl, &padctl->pad_uart1_txd); - - /* rts */ - writel(muxmode0, &muxctl->pad_uart1_rts); - writel(outpadctl, &padctl->pad_uart1_rts); - - /* cts */ - writel(muxmode0, &muxctl->pad_uart1_cts); - writel(inpadctl, &padctl->pad_uart1_cts); -} -#endif /* CONFIG_MXC_UART */ - #ifdef CONFIG_FEC_MXC -void mx25_fec_init_pins(void) -{ - struct iomuxc_mux_ctl *muxctl; - struct iomuxc_pad_ctl *padctl; - u32 inpadctl_100kpd; - u32 inpadctl_22kpu; - u32 outpadctl; - u32 muxmode0; - - muxctl = (struct iomuxc_mux_ctl *)IMX_IOPADMUX_BASE; - padctl = (struct iomuxc_pad_ctl *)IMX_IOPADCTL_BASE; - muxmode0 = MX25_PIN_MUX_MODE(0); - inpadctl_100kpd = MX25_PIN_PAD_CTL_HYS - | MX25_PIN_PAD_CTL_PKE - | MX25_PIN_PAD_CTL_PUE | MX25_PIN_PAD_CTL_100K_PD; - inpadctl_22kpu = MX25_PIN_PAD_CTL_HYS - | MX25_PIN_PAD_CTL_PKE - | MX25_PIN_PAD_CTL_PUE | MX25_PIN_PAD_CTL_22K_PU; - /* - * set up output pins with 100K pull-downs - * FIXME: need to revisit this - * PUE is ignored if PKE is not set - * so the right value here is likely - * 0x0 for no pull - * or - * 0xc0 for 100k pull down - */ - outpadctl = MX25_PIN_PAD_CTL_PUE | MX25_PIN_PAD_CTL_100K_PD; - - /* FEC_TX_CLK */ - writel(muxmode0, &muxctl->pad_fec_tx_clk); - writel(inpadctl_100kpd, &padctl->pad_fec_tx_clk); - - /* FEC_RX_DV */ - writel(muxmode0, &muxctl->pad_fec_rx_dv); - writel(inpadctl_100kpd, &padctl->pad_fec_rx_dv); - - /* FEC_RDATA0 */ - writel(muxmode0, &muxctl->pad_fec_rdata0); - writel(inpadctl_100kpd, &padctl->pad_fec_rdata0); - - /* FEC_TDATA0 */ - writel(muxmode0, &muxctl->pad_fec_tdata0); - writel(outpadctl, &padctl->pad_fec_tdata0); - - /* FEC_TX_EN */ - writel(muxmode0, &muxctl->pad_fec_tx_en); - writel(outpadctl, &padctl->pad_fec_tx_en); - - /* FEC_MDC */ - writel(muxmode0, &muxctl->pad_fec_mdc); - writel(outpadctl, &padctl->pad_fec_mdc); - - /* FEC_MDIO */ - writel(muxmode0, &muxctl->pad_fec_mdio); - writel(inpadctl_22kpu, &padctl->pad_fec_mdio); - - /* FEC_RDATA1 */ - writel(muxmode0, &muxctl->pad_fec_rdata1); - writel(inpadctl_100kpd, &padctl->pad_fec_rdata1); - - /* FEC_TDATA1 */ - writel(muxmode0, &muxctl->pad_fec_tdata1); - writel(outpadctl, &padctl->pad_fec_tdata1); - -} - void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) { int i; diff --git a/arch/arm/include/asm/arch-mx25/imx25-pinmux.h b/arch/arm/include/asm/arch-mx25/imx25-pinmux.h deleted file mode 100644 index a4c658b..0000000 --- a/arch/arm/include/asm/arch-mx25/imx25-pinmux.h +++ /dev/null @@ -1,421 +0,0 @@ -/* - * iopin settings are controlled by four different sets of registers - * iopad mux control - * individual iopad setup (voltage select, pull/keep, drive strength ...) - * group iopad setup (same as above but for groups of signals) - * input select when multiple inputs are possible - */ - -/* - * software pad mux control - */ -/* SW Input On (Loopback) */ -#define MX25_PIN_MUX_SION (1 << 4) -/* MUX Mode (0-7) */ -#define MX25_PIN_MUX_MODE(mode) ((mode & 0x7) << 0) -struct iomuxc_mux_ctl { - u32 gpr1; - u32 observe_int_mux; - u32 pad_a10; - u32 pad_a13; - u32 pad_a14; - u32 pad_a15; - u32 pad_a16; - u32 pad_a17; - u32 pad_a18; - u32 pad_a19; - u32 pad_a20; - u32 pad_a21; - u32 pad_a22; - u32 pad_a23; - u32 pad_a24; - u32 pad_a25; - u32 pad_eb0; - u32 pad_eb1; - u32 pad_oe; - u32 pad_cs0; - u32 pad_cs1; - u32 pad_cs4; - u32 pad_cs5; - u32 pad_nf_ce0; - u32 pad_ecb; - u32 pad_lba; - u32 pad_bclk; - u32 pad_rw; - u32 pad_nfwe_b; - u32 pad_nfre_b; - u32 pad_nfale; - u32 pad_nfcle; - u32 pad_nfwp_b; - u32 pad_nfrb; - u32 pad_d15; - u32 pad_d14; - u32 pad_d13; - u32 pad_d12; - u32 pad_d11; - u32 pad_d10; - u32 pad_d9; - u32 pad_d8; - u32 pad_d7; - u32 pad_d6; - u32 pad_d5; - u32 pad_d4; - u32 pad_d3; - u32 pad_d2; - u32 pad_d1; - u32 pad_d0; - u32 pad_ld0; - u32 pad_ld1; - u32 pad_ld2; - u32 pad_ld3; - u32 pad_ld4; - u32 pad_ld5; - u32 pad_ld6; - u32 pad_ld7; - u32 pad_ld8; - u32 pad_ld9; - u32 pad_ld10; - u32 pad_ld11; - u32 pad_ld12; - u32 pad_ld13; - u32 pad_ld14; - u32 pad_ld15; - u32 pad_hsync; - u32 pad_vsync; - u32 pad_lsclk; - u32 pad_oe_acd; - u32 pad_contrast; - u32 pad_pwm; - u32 pad_csi_d2; - u32 pad_csi_d3; - u32 pad_csi_d4; - u32 pad_csi_d5; - u32 pad_csi_d6; - u32 pad_csi_d7; - u32 pad_csi_d8; - u32 pad_csi_d9; - u32 pad_csi_mclk; - u32 pad_csi_vsync; - u32 pad_csi_hsync; - u32 pad_csi_pixclk; - u32 pad_i2c1_clk; - u32 pad_i2c1_dat; - u32 pad_cspi1_mosi; - u32 pad_cspi1_miso; - u32 pad_cspi1_ss0; - u32 pad_cspi1_ss1; - u32 pad_cspi1_sclk; - u32 pad_cspi1_rdy; - u32 pad_uart1_rxd; - u32 pad_uart1_txd; - u32 pad_uart1_rts; - u32 pad_uart1_cts; - u32 pad_uart2_rxd; - u32 pad_uart2_txd; - u32 pad_uart2_rts; - u32 pad_uart2_cts; - u32 pad_sd1_cmd; - u32 pad_sd1_clk; - u32 pad_sd1_data0; - u32 pad_sd1_data1; - u32 pad_sd1_data2; - u32 pad_sd1_data3; - u32 pad_kpp_row0; - u32 pad_kpp_row1; - u32 pad_kpp_row2; - u32 pad_kpp_row3; - u32 pad_kpp_col0; - u32 pad_kpp_col1; - u32 pad_kpp_col2; - u32 pad_kpp_col3; - u32 pad_fec_mdc; - u32 pad_fec_mdio; - u32 pad_fec_tdata0; - u32 pad_fec_tdata1; - u32 pad_fec_tx_en; - u32 pad_fec_rdata0; - u32 pad_fec_rdata1; - u32 pad_fec_rx_dv; - u32 pad_fec_tx_clk; - u32 pad_rtck; - u32 pad_de_b; - u32 pad_gpio_a; - u32 pad_gpio_b; - u32 pad_gpio_c; - u32 pad_gpio_d; - u32 pad_gpio_e; - u32 pad_gpio_f; - u32 pad_ext_armclk; - u32 pad_upll_bypclk; - u32 pad_vstby_req; - u32 pad_vstby_ack; - u32 pad_power_fail; - u32 pad_clko; - u32 pad_boot_mode0; - u32 pad_boot_mode1; -}; - -/* - * software pad control - */ -/* Select 3.3 or 1.8 volts */ -#define MX25_PIN_PAD_CTL_DVS_33 (0 << 13) -#define MX25_PIN_PAD_CTL_DVS_18 (1 << 13) -/* Enable hysteresis */ -#define MX25_PIN_PAD_CTL_HYS (1 << 8) -/* Enable pull/keeper */ -#define MX25_PIN_PAD_CTL_PKE (1 << 7) -/* 0 - keeper / 1 - pull */ -#define MX25_PIN_PAD_CTL_PUE (1 << 6) -/* pull up/down strength */ -#define MX25_PIN_PAD_CTL_100K_PD (0 << 4) -#define MX25_PIN_PAD_CTL_47K_PU (1 << 4) -#define MX25_PIN_PAD_CTL_100K_PU (2 << 4) -#define MX25_PIN_PAD_CTL_22K_PU (3 << 4) -/* open drain control */ -#define MX25_PIN_PAD_CTL_OD (1 << 3) -/* drive strength */ -#define MX25_PIN_PAD_CTL_DS_NOM (0 << 1) -#define MX25_PIN_PAD_CTL_DS_HIGH (1 << 1) -#define MX25_PIN_PAD_CTL_DS_MAX (2 << 1) -#define MX25_PIN_PAD_CTL_DS_MAX11 (3 << 1) -/* slew rate */ -#define MX25_PIN_PAD_CTL_SRE_SLOW (0 << 0) -#define MX25_PIN_PAD_CTL_SRE_FAST (1 << 0) -struct iomuxc_pad_ctl { - u32 pad_a13; - u32 pad_a14; - u32 pad_a15; - u32 pad_a17; - u32 pad_a18; - u32 pad_a19; - u32 pad_a20; - u32 pad_a21; - u32 pad_a23; - u32 pad_a24; - u32 pad_a25; - u32 pad_eb0; - u32 pad_eb1; - u32 pad_oe; - u32 pad_cs4; - u32 pad_cs5; - u32 pad_nf_ce0; - u32 pad_ecb; - u32 pad_lba; - u32 pad_rw; - u32 pad_nfrb; - u32 pad_d15; - u32 pad_d14; - u32 pad_d13; - u32 pad_d12; - u32 pad_d11; - u32 pad_d10; - u32 pad_d9; - u32 pad_d8; - u32 pad_d7; - u32 pad_d6; - u32 pad_d5; - u32 pad_d4; - u32 pad_d3; - u32 pad_d2; - u32 pad_d1; - u32 pad_d0; - u32 pad_ld0; - u32 pad_ld1; - u32 pad_ld2; - u32 pad_ld3; - u32 pad_ld4; - u32 pad_ld5; - u32 pad_ld6; - u32 pad_ld7; - u32 pad_ld8; - u32 pad_ld9; - u32 pad_ld10; - u32 pad_ld11; - u32 pad_ld12; - u32 pad_ld13; - u32 pad_ld14; - u32 pad_ld15; - u32 pad_hsync; - u32 pad_vsync; - u32 pad_lsclk; - u32 pad_oe_acd; - u32 pad_contrast; - u32 pad_pwm; - u32 pad_csi_d2; - u32 pad_csi_d3; - u32 pad_csi_d4; - u32 pad_csi_d5; - u32 pad_csi_d6; - u32 pad_csi_d7; - u32 pad_csi_d8; - u32 pad_csi_d9; - u32 pad_csi_mclk; - u32 pad_csi_vsync; - u32 pad_csi_hsync; - u32 pad_csi_pixclk; - u32 pad_i2c1_clk; - u32 pad_i2c1_dat; - u32 pad_cspi1_mosi; - u32 pad_cspi1_miso; - u32 pad_cspi1_ss0; - u32 pad_cspi1_ss1; - u32 pad_cspi1_sclk; - u32 pad_cspi1_rdy; - u32 pad_uart1_rxd; - u32 pad_uart1_txd; - u32 pad_uart1_rts; - u32 pad_uart1_cts; - u32 pad_uart2_rxd; - u32 pad_uart2_txd; - u32 pad_uart2_rts; - u32 pad_uart2_cts; - u32 pad_sd1_cmd; - u32 pad_sd1_clk; - u32 pad_sd1_data0; - u32 pad_sd1_data1; - u32 pad_sd1_data2; - u32 pad_sd1_data3; - u32 pad_kpp_row0; - u32 pad_kpp_row1; - u32 pad_kpp_row2; - u32 pad_kpp_row3; - u32 pad_kpp_col0; - u32 pad_kpp_col1; - u32 pad_kpp_col2; - u32 pad_kpp_col3; - u32 pad_fec_mdc; - u32 pad_fec_mdio; - u32 pad_fec_tdata0; - u32 pad_fec_tdata1; - u32 pad_fec_tx_en; - u32 pad_fec_rdata0; - u32 pad_fec_rdata1; - u32 pad_fec_rx_dv; - u32 pad_fec_tx_clk; - u32 pad_rtck; - u32 pad_tdo; - u32 pad_de_b; - u32 pad_gpio_a; - u32 pad_gpio_b; - u32 pad_gpio_c; - u32 pad_gpio_d; - u32 pad_gpio_e; - u32 pad_gpio_f; - u32 pad_vstby_req; - u32 pad_vstby_ack; - u32 pad_power_fail; - u32 pad_clko; -}; - - -/* - * Pad group drive strength and voltage select - * Same fields as iomuxc_pad_ctl plus ddr type - */ -/* Select DDR type */ -#define MX25_PIN_PAD_CTL_DDR_18 (0 << 11) -#define MX25_PIN_PAD_CTL_DDR_33 (1 << 11) -#define MX25_PIN_PAD_CTL_DDR_MAX (2 << 11) -struct iomuxc_pad_grp_ctl { - u32 grp_dvs_misc; - u32 grp_dse_fec; - u32 grp_dvs_jtag; - u32 grp_dse_nfc; - u32 grp_dse_csi; - u32 grp_dse_weim; - u32 grp_dse_ddr; - u32 grp_dvs_crm; - u32 grp_dse_kpp; - u32 grp_dse_sdhc1; - u32 grp_dse_lcd; - u32 grp_dse_uart; - u32 grp_dvs_nfc; - u32 grp_dvs_csi; - u32 grp_dse_cspi1; - u32 grp_ddrtype; - u32 grp_dvs_sdhc1; - u32 grp_dvs_lcd; -}; - -/* - * Pad input select control - * Select which pad to connect to an input port - * where multiple pads can function as given input - */ -#define MX25_PAD_INPUT_SELECT_DAISY(in) ((in & 0x7) << 0) -struct iomuxc_pad_input_select { - u32 audmux_p4_input_da_amx; - u32 audmux_p4_input_db_amx; - u32 audmux_p4_input_rxclk_amx; - u32 audmux_p4_input_rxfs_amx; - u32 audmux_p4_input_txclk_amx; - u32 audmux_p4_input_txfs_amx; - u32 audmux_p7_input_da_amx; - u32 audmux_p7_input_txfs_amx; - u32 can1_ipp_ind_canrx; - u32 can2_ipp_ind_canrx; - u32 csi_ipp_csi_d_0; - u32 csi_ipp_csi_d_1; - u32 cspi1_ipp_ind_ss3_b; - u32 cspi2_ipp_cspi_clk_in; - u32 cspi2_ipp_ind_dataready_b; - u32 cspi2_ipp_ind_miso; - u32 cspi2_ipp_ind_mosi; - u32 cspi2_ipp_ind_ss0_b; - u32 cspi2_ipp_ind_ss1_b; - u32 cspi3_ipp_cspi_clk_in; - u32 cspi3_ipp_ind_dataready_b; - u32 cspi3_ipp_ind_miso; - u32 cspi3_ipp_ind_mosi; - u32 cspi3_ipp_ind_ss0_b; - u32 cspi3_ipp_ind_ss1_b; - u32 cspi3_ipp_ind_ss2_b; - u32 cspi3_ipp_ind_ss3_b; - u32 esdhc1_ipp_dat4_in; - u32 esdhc1_ipp_dat5_in; - u32 esdhc1_ipp_dat6_in; - u32 esdhc1_ipp_dat7_in; - u32 esdhc2_ipp_card_clk_in; - u32 esdhc2_ipp_cmd_in; - u32 esdhc2_ipp_dat0_in; - u32 esdhc2_ipp_dat1_in; - u32 esdhc2_ipp_dat2_in; - u32 esdhc2_ipp_dat3_in; - u32 esdhc2_ipp_dat4_in; - u32 esdhc2_ipp_dat5_in; - u32 esdhc2_ipp_dat6_in; - u32 esdhc2_ipp_dat7_in; - u32 fec_fec_col; - u32 fec_fec_crs; - u32 fec_fec_rdata_2; - u32 fec_fec_rdata_3; - u32 fec_fec_rx_clk; - u32 fec_fec_rx_er; - u32 i2c2_ipp_scl_in; - u32 i2c2_ipp_sda_in; - u32 i2c3_ipp_scl_in; - u32 i2c3_ipp_sda_in; - u32 kpp_ipp_ind_col_4; - u32 kpp_ipp_ind_col_5; - u32 kpp_ipp_ind_col_6; - u32 kpp_ipp_ind_col_7; - u32 kpp_ipp_ind_row_4; - u32 kpp_ipp_ind_row_5; - u32 kpp_ipp_ind_row_6; - u32 kpp_ipp_ind_row_7; - u32 sim1_pin_sim_rcvd1_in; - u32 sim1_pin_sim_simpd1; - u32 sim1_sim_rcvd1_io; - u32 sim2_pin_sim_rcvd1_in; - u32 sim2_pin_sim_simpd1; - u32 sim2_sim_rcvd1_io; - u32 uart3_ipp_uart_rts_b; - u32 uart3_ipp_uart_rxd_mux; - u32 uart4_ipp_uart_rts_b; - u32 uart4_ipp_uart_rxd_mux; - u32 uart5_ipp_uart_rts_b; - u32 uart5_ipp_uart_rxd_mux; - u32 usb_top_ipp_ind_otg_usb_oc; - u32 usb_top_ipp_ind_uh2_usb_oc; -}; diff --git a/arch/arm/include/asm/arch-mx25/sys_proto.h b/arch/arm/include/asm/arch-mx25/sys_proto.h deleted file mode 100644 index 46db341..0000000 --- a/arch/arm/include/asm/arch-mx25/sys_proto.h +++ /dev/null @@ -1,32 +0,0 @@ -/* - * (C) Copyright 2009 - * Stefano Babic, DENX Software Engineering, sbabic@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _SYS_PROTO_H_ -#define _SYS_PROTO_H_ - -void mx25_uart1_init_pins(void); -#if defined CONFIG_FEC_MXC -extern void mx25_fec_init_pins(void); -#endif - -#endif
Benoît Thébaudeau
