[U-Boot-Users] [PATCH 3/4] Add new MPC8548CDS board with DDR II
Part 3 of 4 adding new MPC85448CDS board
diff -Nru --exclude=CVS u-boot/cpu/mpc85xx/start.S u-boot-pq3/cpu/mpc85xx/start.S --- u-boot/cpu/mpc85xx/start.S 2004-08-01 18:03:10.000000000 -0500 +++ u-boot-pq3/cpu/mpc85xx/start.S 2005-05-06 14:34:41.000004000 -0500 @@ -174,6 +174,9 @@ mtspr BUCSR,r0 /* disable branch prediction */ mtspr MAS4,r0 mtspr MAS6,r0 +#if defined(CONFIG_ENABLE_36BIT_PHYS) + mtspr MAS7,r0 +#endif isync
/* Setup interrupt vectors */ @@ -354,6 +357,9 @@ /* Enable Time Base and Select Time Base Clock */ lis r0,HID0_EMCP@h /* Enable machine check */ ori r0,r0,0x4000 /* time base is processor clock */ +#if defined(CONFIG_ENABLE_36BIT_PHYS) + ori r0,r0,0x0080 /* enable MAS7 updates */ +#endif mtspr HID0,r0
#if defined(CONFIG_ADDR_STREAMING) diff -Nru --exclude=CVS u-boot/doc/README.mpc85xxads u-boot-pq3/doc/README.mpc85xxads --- u-boot/doc/README.mpc85xxads 2005-02-10 12:36:00.000000000 -0600 +++ u-boot-pq3/doc/README.mpc85xxads 2005-03-04 15:23:00.000000000 -0600 @@ -191,10 +191,10 @@
4.4 Reflash U-boot Image using U-boot
- => tftp 10000 u-boot.bin - => protect off fff80000 ffffffff - => erase fff80000 ffffffff - => cp.b 10000 fff80000 80000 + tftp 10000 u-boot.bin + protect off fff80000 ffffffff + erase fff80000 ffffffff + cp.b 10000 fff80000 80000
4.5 Reflash U-Boot with a BDI-2000 diff -Nru --exclude=CVS u-boot/doc/README.mpc85xxcds u-boot-pq3/doc/README.mpc85xxcds --- u-boot/doc/README.mpc85xxcds 2004-11-01 15:53:05.000000000 -0600 +++ u-boot-pq3/doc/README.mpc85xxcds 2005-05-05 09:42:58.000002000 -0500 @@ -135,8 +135,8 @@ SW4=10001000
-CPU Card Switches ------------------ +8555/41 CPU Card Switches +-------------------------
Most switches on the CPU Card should not be changed. However, the frequency can be changed by setting SW3: @@ -160,6 +160,45 @@ SW4=11111110
+8548 CPU Card Switches +---------------------- +And, just to be confusing, in this set of switches: + + ON = 1 + OFF = 0 + +Default + SW1=11111101 + SW2=10011111 + SW3=11001000 (8X) (2:1) + SW4=11110011 + + SW3=X000XXXX == CORE:CCB 4:1 + X001XXXX == CORE:CCB 9:2 + X010XXXX == CORE:CCB 1:1 + X011XXXX == CORE:CCB 3:2 + X100XXXX == CORE:CCB 2:1 + X101XXXX == CORE:CCB 5:2 + X110XXXX == CORE:CCB 3:1 + X111XXXX == CORE:CCB 7:2 + XXXX0000 == CCB:SYSCLK 16:1 + XXXX0001 == RESERVED + XXXX0010 == CCB:SYSCLK 2:1 + XXXX0011 == CCB:SYSCLK 3:1 + XXXX0100 == CCB:SYSCLK 4:1 + XXXX0101 == CCB:SYSCLK 5:1 + XXXX0110 == CCB:SYSCLK 6:1 + XXXX0111 == RESERVED + XXXX1000 == CCB:SYSCLK 8:1 + XXXX1001 == CCB:SYSCLK 9:1 + XXXX1010 == CCB:SYSCLK 10:1 + XXXX1011 == RESERVED + XXXX1100 == CCB:SYSCLK 12:1 + XXXX1101 == CCB:SYSCLK 20:1 + XXXX1110 == RESERVED + XXXX1111 == RESERVED + + eDINK Info ----------
diff -Nru --exclude=CVS u-boot/drivers/cfi_flash.c u-boot-pq3/drivers/cfi_flash.c --- u-boot/drivers/cfi_flash.c 2005-05-05 14:05:10.000006000 -0500 +++ u-boot-pq3/drivers/cfi_flash.c 2005-05-06 11:22:06.000006000 -0500 @@ -209,7 +209,9 @@ static int flash_detect_cfi (flash_info_t * info); static ulong flash_get_size (ulong base, int banknum); static int flash_write_cfiword (flash_info_t * info, ulong dest, cfiword_t cword); +#ifdef POLLING_AMD_DQ7 static int Data_Polling_Check(flash_info_t * info, cfiptr_t cptr, cfiword_t cword); +#endif static int flash_full_status_check (flash_info_t * info, cfiptr_t cptr, cfiword_t cword, ulong tout, char *prompt); #ifdef CFG_FLASH_USE_BUFFER_WRITE static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, int len); @@ -771,6 +773,7 @@ return retval; }
+#ifdef POLLING_AMD_DQ7 /* ---------------------------------------------------------------------- * Polling DQ7 for AMD flash * Edited by York Sun (yorksun@freescale.com) @@ -832,6 +835,7 @@ else return ERR_OK; } +#endif /* POLLING_AMD_DQ7 */
/*----------------------------------------------------------------------- * wait for XSR.7 to be set. Time out with an error if it does not. diff -Nru --exclude=CVS u-boot/examples/stubs.c u-boot-pq3/examples/stubs.c --- u-boot/examples/stubs.c 2005-05-05 14:15:40.000001000 -0500 +++ u-boot-pq3/examples/stubs.c 2004-10-21 13:58:17.000000000 -0500 @@ -136,7 +136,7 @@ * implementation. On the other hand, asm() statements with * arguments can be used only inside the functions (gcc limitation) */ -#if GCC_VERSION < 3004 +#if GCC_VERSION < 3003 static #endif /* GCC_VERSION */ void __attribute__((unused)) dummy(void) diff -Nru --exclude=CVS u-boot/include/asm-ppc/immap_85xx.h u-boot-pq3/include/asm-ppc/immap_85xx.h --- u-boot/include/asm-ppc/immap_85xx.h 2005-02-09 14:49:14.000000000 -0600 +++ u-boot-pq3/include/asm-ppc/immap_85xx.h 2005-05-04 13:49:42.000010000 -0500 @@ -81,21 +81,27 @@ uint cs1_config; /* 0x2084 - DDR Chip Select Configuration */ uint cs2_config; /* 0x2088 - DDR Chip Select Configuration */ uint cs3_config; /* 0x208c - DDR Chip Select Configuration */ - char res5[120]; + char res5[112]; + uint ext_refrec; /* 0x2100 - DDR SDRAM Extended Refresh Recovery */ + uint timing_cfg_0; /* 0x2104 - DDR SDRAM Timing Configuration Register 0 */ uint timing_cfg_1; /* 0x2108 - DDR SDRAM Timing Configuration Register 1 */ uint timing_cfg_2; /* 0x210c - DDR SDRAM Timing Configuration Register 2 */ uint sdram_cfg; /* 0x2110 - DDR SDRAM Control Configuration */ - char res6[4]; + uint sdram_cfg_2; /* 0x2114 - DDR SDRAM Control Configuration 2 */ uint sdram_mode; /* 0x2118 - DDR SDRAM Mode Configuration */ - char res7[8]; + uint sdram_mode_2; /* 0x211c - DDR SDRAM Mode Configuration 2*/ + uint sdram_md_cntl; /* 0x2120 - DDR SDRAM Mode Control */ uint sdram_interval; /* 0x2124 - DDR SDRAM Interval Configuration */ -#ifdef MPC85xx_DDR_SDRAM_CLK_CNTL - char res7_5[8]; + uint sdram_data_init; /* 0x2128 - DDR SDRAM Data initialization */ + char res6[4]; uint sdram_clk_cntl; /* 0x2130 - DDR SDRAM Clock Control */ - char res8[3276]; -#else - char res8[3288]; -#endif + char res7[20]; + uint init_address; /* 0x2148 - DDR training initialization address */ + uint init_ext_address; /* 0x214C - DDR training initialization extended address */ + char res8_1[2728]; + uint ip_rev1; /* 0x2BF8 - DDR IP Block Revision 1 */ + uint ip_rev2; /* 0x2BFC - DDR IP Block Revision 2 */ + char res8_2[512]; uint data_err_inject_hi; /* 0x2e00 - DDR Memory Data Path Error Injection Mask High */ uint data_err_inject_lo; /* 0x2e04 - DDR Memory Data Path Error Injection Mask Low */ uint ecc_err_inject; /* 0x2e08 - DDR Memory Data Path Error Injection Mask ECC */ @@ -120,6 +126,8 @@ } ccsr_ddr_t;
+ + /* I2C Registers(0x3000-0x4000) */
typedef struct ccsr_i2c { @@ -158,6 +166,7 @@
#if defined(CONFIG_MPC8540) \ || defined(CONFIG_MPC8541) \ + || defined(CONFIG_MPC8548) \ || defined(CONFIG_MPC8555) /* DUART Registers(0x4000-0x5000) */ typedef struct ccsr_duart { @@ -1545,7 +1554,9 @@ uint ddrdllcr; /* 0xe0e10 - DDR DLL control register */ char res12[12]; uint lbcdllcr; /* 0xe0e20 - LBC DLL control register */ - char res13[61915]; + char res13[256]; + uint ddrioovcr; /* 0xe0f24 - DDR IO Override Control */ + char res14[61659]; } ccsr_gur_t;
typedef struct immap { diff -Nru --exclude=CVS u-boot/include/asm-ppc/processor.h u-boot-pq3/include/asm-ppc/processor.h --- u-boot/include/asm-ppc/processor.h 2005-05-05 13:45:14.000007000 -0500 +++ u-boot-pq3/include/asm-ppc/processor.h 2005-05-06 14:44:20.000007000 -0500 @@ -420,6 +420,7 @@ #define SPRN_MAS4 0x274 /* MMU Assist Register 4 */ #define SPRN_MAS5 0x275 /* MMU Assist Register 5 */ #define SPRN_MAS6 0x276 /* MMU Assist Register 6 */ +#define SPRN_MAS7 0x3B0 /* MMU Assist Register 7 */
#define SPRN_IVOR32 0x210 /* Interrupt Vector Offset Register 32 */ #define SPRN_IVOR33 0x211 /* Interrupt Vector Offset Register 33 */ @@ -584,6 +585,7 @@ #define MAS4 SPRN_MAS4 #define MAS5 SPRN_MAS5 #define MAS6 SPRN_MAS6 +#define MAS7 SPRN_MAS7
/* Device Control Registers */
@@ -792,6 +794,8 @@ #define SVR_8560 0x8070 #define SVR_8555 0x8079 #define SVR_8541 0x807A +#define SVR_8548 0x8031 +#define SVR_8548_E 0x8039
/* I am just adding a single entry for 8260 boards. I think we may be diff -Nru --exclude=CVS u-boot/include/configs/MPC8540ADS.h u-boot-pq3/include/configs/MPC8540ADS.h --- u-boot/include/configs/MPC8540ADS.h 2005-02-10 12:36:00.000000000 -0600 +++ u-boot-pq3/include/configs/MPC8540ADS.h 2005-05-04 13:49:42.000003000 -0500 @@ -49,10 +49,12 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ -#define CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_DDR_DLL /* possible DLL fix needed */ #define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */
+#define CONFIG_DDR_ECC /* only for ECC DDR module */ +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +
/* * sysclk for MPC85xx diff -Nru --exclude=CVS u-boot/include/configs/MPC8541CDS.h u-boot-pq3/include/configs/MPC8541CDS.h --- u-boot/include/configs/MPC8541CDS.h 2005-02-09 14:49:24.000000000 -0600 +++ u-boot-pq3/include/configs/MPC8541CDS.h 2005-05-04 13:49:42.000003000 -0500 @@ -41,9 +41,12 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ -#define CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_DDR_DLL /* possible DLL fix needed */ -#define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ +#undef CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ + +#define CONFIG_DDR_ECC /* only for ECC DDR module */ +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +
/* * When initializing flash, if we cannot find the manufacturer ID, diff -Nru --exclude=CVS u-boot/include/configs/MPC8548CDS.h u-boot-pq3/include/configs/MPC8548CDS.h --- u-boot/include/configs/MPC8548CDS.h 1969-12-31 18:00:00.000000000 -0600 +++ u-boot-pq3/include/configs/MPC8548CDS.h 2005-05-06 14:36:27.000003000 -0500 @@ -0,0 +1,507 @@ +/* + * Copyright 2004 Freescale Semiconductor. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * mpc8548cds board configuration file + * + * Please refer to doc/README.mpc85xxcds for more info. + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 /* MPC8548 specific */ +#define CONFIG_MPC8548CDS 1 /* MPC8548CDS board specific */ + +#undef CONFIG_PCI +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ +#define CONFIG_DDR_DLL /* possible DLL fix needed */ +#define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ + +#define CONFIG_DDR_ECC /* only for ECC DDR module */ +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef + + +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash associated with the CDS board. + * This allows booting from a promjet. + */ +#define CONFIG_ASSUME_AMD_FLASH + +#define MPC85xx_DDR_SDRAM_CLK_CNTL /* 85xx has clock control reg */ + +#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif +#define CONFIG_SYS_CLK_FREQ get_clock_freq() /* sysclk for MPC85xx */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_ADDR_STREAMING /* toggle addr streaming */ + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS 1 + + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ + +#undef CFG_DRAM_TEST /* memory test, takes time */ +#define CFG_MEMTEST_START 0x00200000 /* memtest works on */ +#define CFG_MEMTEST_END 0x00400000 + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CFG_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ +#define CFG_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ +#define CFG_IMMR CFG_CCSRBAR /* PQII uses CFG_IMMR */ + +/* + * DDR Setup + */ +#define CFG_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CFG_SDRAM_BASE CFG_DDR_SDRAM_BASE + +#define SPD_EEPROM_ADDRESS 0x51 /* DDR DIMM */ + +/* + * Make sure required options are set + */ +#ifndef CONFIG_SPD_EEPROM +#error ("CONFIG_SPD_EEPROM is required") +#endif + +#undef CONFIG_CLOCKS_IN_MHZ + + +/* + * Local Bus Definitions + */ + +/* + * FLASH on the Local Bus + * Two banks, 8M each, using the CFI driver. + * Boot from BR0/OR0 bank at 0xff00_0000 + * Alternate BR1/OR1 bank at 0xff80_0000 + * + * BR0, BR1: + * Base address 0 = 0xff00_0000 = BR0[0:16] = 1111 1111 0000 0000 0 + * Base address 1 = 0xff80_0000 = BR1[0:16] = 1111 1111 1000 0000 0 + * Port Size = 16 bits = BRx[19:20] = 10 + * Use GPCM = BRx[24:26] = 000 + * Valid = BRx[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 1111 1000 0000 0001 0000 0000 0001 = ff801001 BR0 + * 1111 1111 0000 0000 0001 0000 0000 0001 = ff001001 BR1 + * + * OR0, OR1: + * Addr Mask = 8M = ORx[0:16] = 1111 1111 1000 0000 0 + * Reserved ORx[17:18] = 11, confusion here? + * CSNT = ORx[20] = 1 + * ACS = half cycle delay = ORx[21:22] = 11 + * SCY = 6 = ORx[24:27] = 0110 + * TRLX = use relaxed timing = ORx[29] = 1 + * EAD = use external address latch delay = OR[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 1111 1000 0000 0110 1110 0110 0101 = ff806e65 ORx + */ + +#define CFG_FLASH_BASE 0xff000000 /* start of FLASH 8M */ + +#define CFG_BR0_PRELIM 0xff801001 +#define CFG_BR1_PRELIM 0xff001001 + +#define CFG_OR0_PRELIM 0xff806e65 +#define CFG_OR1_PRELIM 0xff806e65 + +#define CFG_FLASH_BANKS_LIST {0xff800000, CFG_FLASH_BASE} +#define CFG_MAX_FLASH_BANKS 2 /* number of banks */ +#define CFG_MAX_FLASH_SECT 128 /* sectors per device */ +#undef CFG_FLASH_CHECKSUM +#define CFG_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CFG_MONITOR_BASE TEXT_BASE /* start of monitor */ + +#define CFG_FLASH_CFI_DRIVER +#define CFG_FLASH_CFI +#define CFG_FLASH_EMPTY_INFO + + +/* + * SDRAM on the Local Bus + */ +#define CFG_LBC_SDRAM_BASE 0xf0000000 /* Localbus SDRAM */ +#define CFG_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ + +/* + * Base Register 2 and Option Register 2 configure SDRAM. + * The SDRAM base address, CFG_LBC_SDRAM_BASE, is 0xf0000000. + * + * For BR2, need: + * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 + * port-size = 32-bits = BR2[19:20] = 11 + * no parity checking = BR2[21:22] = 00 + * SDRAM for MSEL = BR2[24:26] = 011 + * Valid = BR[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 + * + * FIXME: CFG_LBC_SDRAM_BASE should be masked and OR'ed into + * FIXME: the top 17 bits of BR2. + */ + +#define CFG_BR2_PRELIM 0xf0001861 + +/* + * The SDRAM size in MB, CFG_LBC_SDRAM_SIZE, is 64. + * + * For OR2, need: + * 64MB mask for AM, OR2[0:7] = 1111 1100 + * XAM, OR2[17:18] = 11 + * 9 columns OR2[19-21] = 010 + * 13 rows OR2[23-25] = 100 + * EAD set for extra time OR[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 + */ + +#define CFG_OR2_PRELIM 0xfc006901 + +#define CFG_LBC_LCRR 0x00030004 /* LB clock ratio reg */ +#define CFG_LBC_LBCR 0x00000000 /* LB config reg */ +#define CFG_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ +#define CFG_LBC_MRTPR 0x00000000 /* LB refresh timer prescal*/ + +/* + * LSDMR masks + */ +#define CFG_LBC_LSDMR_RFEN (1 << (31 - 1)) +#define CFG_LBC_LSDMR_BSMA1516 (3 << (31 - 10)) +#define CFG_LBC_LSDMR_BSMA1617 (4 << (31 - 10)) +#define CFG_LBC_LSDMR_RFCR16 (7 << (31 - 16)) +#define CFG_LBC_LSDMR_PRETOACT7 (7 << (31 - 19)) +#define CFG_LBC_LSDMR_ACTTORW7 (7 << (31 - 22)) +#define CFG_LBC_LSDMR_ACTTORW6 (6 << (31 - 22)) +#define CFG_LBC_LSDMR_BL8 (1 << (31 - 23)) +#define CFG_LBC_LSDMR_WRC4 (0 << (31 - 27)) +#define CFG_LBC_LSDMR_CL3 (3 << (31 - 31)) + +#define CFG_LBC_LSDMR_OP_NORMAL (0 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_ARFRSH (1 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_SRFRSH (2 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_MRW (3 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_PRECH (4 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_PCHALL (5 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_ACTBNK (6 << (31 - 4)) +#define CFG_LBC_LSDMR_OP_RWINV (7 << (31 - 4)) + +/* + * Common settings for all Local Bus SDRAM commands. + * At run time, either BSMA1516 (for CPU 1.1) + * or BSMA1617 (for CPU 1.0) (old) + * is OR'ed in too. + */ +#define CFG_LBC_LSDMR_COMMON ( CFG_LBC_LSDMR_RFCR16 \ + | CFG_LBC_LSDMR_PRETOACT7 \ + | CFG_LBC_LSDMR_ACTTORW7 \ + | CFG_LBC_LSDMR_BL8 \ + | CFG_LBC_LSDMR_WRC4 \ + | CFG_LBC_LSDMR_CL3 \ + | CFG_LBC_LSDMR_RFEN \ + ) + +/* + * The CADMUS registers are connected to CS3 on CDS. + * The new memory map places CADMUS at 0xf8000000. + * + * For BR3, need: + * Base address of 0xf8000000 = BR[0:16] = 1111 1000 0000 0000 0 + * port-size = 8-bits = BR[19:20] = 01 + * no parity checking = BR[21:22] = 00 + * GPMC for MSEL = BR[24:26] = 000 + * Valid = BR[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 1000 0000 0000 0000 1000 0000 0001 = f8000801 + * + * For OR3, need: + * 1 MB mask for AM, OR[0:16] = 1111 1111 1111 0000 0 + * disable buffer ctrl OR[19] = 0 + * CSNT OR[20] = 1 + * ACS OR[21:22] = 11 + * XACS OR[23] = 1 + * SCY 15 wait states OR[24:27] = 1111 max is suboptimal but safe + * SETA OR[28] = 0 + * TRLX OR[29] = 1 + * EHTR OR[30] = 1 + * EAD extra time OR[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 1111 1111 0000 0000 1111 1111 0111 = fff00ff7 + */ + +#define CADMUS_BASE_ADDR 0xf8000000 +#define CFG_BR3_PRELIM 0xf8000801 +#define CFG_OR3_PRELIM 0xfff00ff7 + +#define CONFIG_L1_INIT_RAM +#define CFG_INIT_RAM_LOCK 1 +#define CFG_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CFG_INIT_RAM_END 0x4000 /* End of used area in RAM */ + +#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +#define CFG_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CFG_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 2 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CFG_NS16550 +#define CFG_NS16550_SERIAL +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK get_bus_freq(0) + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} + +#define CFG_NS16550_COM1 (CFG_CCSRBAR+0x4500) +#define CFG_NS16550_COM2 (CFG_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CFG_HUSH_PARSER +#ifdef CFG_HUSH_PARSER +#define CFG_PROMPT_HUSH_PS2 "> " +#endif + +/* I2C */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_EEPROM_ADDR 0x57 +#define CFG_I2C_SLAVE 0x7F +#define CFG_I2C_NOPROBES {0x69} /* Don't probe these addrs */ + +/* + * General PCI + * Addresses are mapped 1-1. + */ +#define CFG_PCI1_MEM_BASE 0x80000000 +#define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE +#define CFG_PCI1_MEM_SIZE 0x20000000 /* 512M */ +#define CFG_PCI1_IO_BASE 0xe2000000 +#define CFG_PCI1_IO_PHYS CFG_PCI1_IO_BASE +#define CFG_PCI1_IO_SIZE 0x1000000 /* 16M */ + +#define CFG_PCI2_MEM_BASE 0xa0000000 +#define CFG_PCI2_MEM_PHYS CFG_PCI2_MEM_BASE +#define CFG_PCI2_MEM_SIZE 0x20000000 /* 512M */ +#define CFG_PCI2_IO_BASE 0xe3000000 +#define CFG_PCI2_IO_PHYS CFG_PCI2_IO_BASE +#define CFG_PCI2_IO_SIZE 0x1000000 /* 16M */ + + +#if defined(CONFIG_PCI) + +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +#undef CONFIG_EEPRO100 +#undef CONFIG_TULIP + +#if !defined(CONFIG_PCI_PNP) + #define PCI_ENET0_IOADDR 0xe0000000 + #define PCI_ENET0_MEMADDR 0xe0000000 + #define PCI_IDSEL_NUMBER 0x0c /*slot0->3(IDSEL)=12->15*/ +#endif + +#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */ + +#endif /* CONFIG_PCI */ + + +#if defined(CONFIG_TSEC_ENET) + +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI 1 +#endif + +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_MPC85XX_TSEC1 1 +#define CONFIG_MPC85XX_TSEC2 1 +#undef CONFIG_MPC85XX_FEC +#define TSEC1_PHY_ADDR 0 +#define TSEC2_PHY_ADDR 1 +#define FEC_PHY_ADDR 3 +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define FEC_PHYIDX 0 +#define CONFIG_ETHPRIME "MOTO ENET0" + +#endif /* CONFIG_TSEC_ENET */ + +/* + * Environment + */ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_ADDR (CFG_MONITOR_BASE + 0x40000) +#define CFG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ +#define CFG_ENV_SIZE 0x2000 + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#if defined(CONFIG_PCI) +#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ + | CFG_CMD_PCI \ + | CFG_CMD_PING \ + | CFG_CMD_I2C \ + | CFG_CMD_MII) +#else +#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ + | CFG_CMD_PING \ + | CFG_CMD_I2C \ + | CFG_CMD_MII) +#endif +#include <cmd_confdefs.h> + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_LOAD_ADDR 0x2000000 /* default load address */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ +#define CFG_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/ + +/* Cache Configuration */ +#define CFG_DCACHE_SIZE 32768 +#define CFG_CACHELINE_SIZE 32 +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ +#endif + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +/* The mac addresses for all ethernet interface */ +#if defined(CONFIG_TSEC_ENET) +#define CONFIG_ETHADDR 00:E0:0C:00:00:FD +#define CONFIG_HAS_ETH1 +#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD +#define CONFIG_HAS_ETH2 +#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD +#endif + +#define CONFIG_IPADDR 192.168.1.253 + +#define CONFIG_HOSTNAME unknown +#define CONFIG_ROOTPATH /nfsroot +#define CONFIG_BOOTFILE your.uImage + +#define CONFIG_SERVERIP 192.168.1.1 +#define CONFIG_GATEWAYIP 192.168.1.1 +#define CONFIG_NETMASK 255.255.255.0 + +#define CONFIG_LOADADDR 200000 /*default location for tftp and bootm*/ + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs*/ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "consoledev=ttyS1\0" \ + "ramdiskaddr=400000\0" \ + "ramdiskfile=your.ramdisk.u-boot\0" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "bootm $loadaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "bootm $loadaddr $ramdiskaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND + +#endif /* __CONFIG_H */ diff -Nru --exclude=CVS u-boot/include/configs/MPC8555CDS.h u-boot-pq3/include/configs/MPC8555CDS.h --- u-boot/include/configs/MPC8555CDS.h 2005-02-09 14:49:24.000000000 -0600 +++ u-boot-pq3/include/configs/MPC8555CDS.h 2005-05-04 13:49:42.000003000 -0500 @@ -41,9 +41,12 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ -#define CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_DDR_DLL /* possible DLL fix needed */ -#define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ +#undef CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ + +#define CONFIG_DDR_ECC /* only for ECC DDR module */ +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +
/* * When initializing flash, if we cannot find the manufacturer ID, diff -Nru --exclude=CVS u-boot/include/configs/MPC8560ADS.h u-boot-pq3/include/configs/MPC8560ADS.h --- u-boot/include/configs/MPC8560ADS.h 2005-02-09 14:49:14.000000000 -0600 +++ u-boot-pq3/include/configs/MPC8560ADS.h 2005-05-04 13:49:42.000004000 -0500 @@ -46,10 +46,12 @@ #undef CONFIG_ETHER_ON_FCC /* cpm FCC ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ -#define CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_DDR_DLL /* possible DLL fix needed */ #define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */
/* * sysclk for MPC85xx diff -Nru --exclude=CVS u-boot/include/configs/PM854.h u-boot-pq3/include/configs/PM854.h --- u-boot/include/configs/PM854.h 2005-04-03 18:11:41.000000000 -0500 +++ u-boot-pq3/include/configs/PM854.h 2005-05-06 11:09:42.000003000 -0500 @@ -45,10 +45,12 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #undef CONFIG_SPD_EEPROM /* do not use SPD EEPROM for DDR setup*/ -#define CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_DDR_DLL /* possible DLL fix needed */ #define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */
Jon Loeliger
