[U-Boot] [PATCH v2 04/16] i2c: add CONFIG_I2C_MULTI_BUS for soft_i2c and mpc8260 i2c driver.
Signed-off-by: Heiko Schocher hs@denx.de --- cpu/mpc8260/i2c.c | 36 ++++++++++++++++++++++++++++++++++++ drivers/i2c/soft_i2c.c | 36 ++++++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc8260/i2c.c b/cpu/mpc8260/i2c.c index c3af7b6..335177f 100644 --- a/cpu/mpc8260/i2c.c +++ b/cpu/mpc8260/i2c.c @@ -36,6 +36,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#if defined(CONFIG_I2C_MULTI_BUS) +static unsigned int i2c_bus_num __attribute__ ((section ("data"))) = 0; +#endif /* CONFIG_I2C_MULTI_BUS */ + /* uSec to wait between polls of the i2c */ #define DELAY_US 100 /* uSec to wait for the CPM to start processing the buffer */ @@ -765,4 +769,36 @@ i2c_reg_write(uchar chip, uchar reg, uchar val) i2c_write(chip, reg, 1, &val, 1); }
+#if defined(CONFIG_I2C_MULTI_BUS) +/* + * Functions for multiple I2C bus handling + */ +unsigned int i2c_get_bus_num(void) +{ + return i2c_bus_num; +} + +int i2c_set_bus_num(unsigned int bus) +{ + if (bus >= CFG_MAX_I2C_BUS) + return -1; + i2c_bus_num = bus; + + return 0; +} +/* TODO: add 100/400k switching */ +unsigned int i2c_get_bus_speed(void) +{ + return CFG_I2C_SPEED; +} + +int i2c_set_bus_speed(unsigned int speed) +{ + if (speed != CFG_I2C_SPEED) + return -1; + + return 0; +} + +#endif /* CONFIG_I2C_MULTI_BUS */ #endif /* CONFIG_HARD_I2C */ diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 23db2ee..57736da 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -68,6 +68,10 @@ DECLARE_GLOBAL_DATA_PTR; #define PRINTD(fmt,args...) #endif
+#if defined(CONFIG_I2C_MULTI_BUS) +static unsigned int i2c_bus_num __attribute__ ((section ("data"))) = 0; +#endif /* CONFIG_I2C_MULTI_BUS */ + /*----------------------------------------------------------------------- * Local functions */ @@ -230,6 +234,38 @@ static int write_byte(uchar data) return(nack); /* not a nack is an ack */ }
+#if defined(CONFIG_I2C_MULTI_BUS) +/* + * Functions for multiple I2C bus handling + */ +unsigned int i2c_get_bus_num(void) +{ + return i2c_bus_num; +} + +int i2c_set_bus_num(unsigned int bus) +{ + if (bus >= CFG_MAX_I2C_BUS) + return -1; + i2c_bus_num = bus; + + return 0; +} + +/* TODO: add 100/400k switching */ +unsigned int i2c_get_bus_speed(void) +{ + return CFG_I2C_SPEED; +} + +int i2c_set_bus_speed(unsigned int speed) +{ + if (speed != CFG_I2C_SPEED) + return -1; + + return 0; +} +#endif
/*----------------------------------------------------------------------- * if ack == I2C_ACK, ACK the byte so can continue reading, else
Heiko Schocher
