[PATCH v2 0/2] sandbox: enable testing SYSRESET_WATCHDOG
With CONFIG_SYSRESET_WATCHDOG=y the sandbox can use a watchdog based system reset. To make this work calling sandbox_wdt_expire_now() must lead to a reset.
Further we need CONFIG_WDT_GPIO=n to actually call the right watchdog. Adjust the watchdog test to avoid a build error.
With this change we can test the development suggested in
[PATCH 0/4] Improved sysreset/watchdog uclass integration https://lists.denx.de/pipermail/u-boot/2021-August/458656.html
v2: move test changes to Makefile
Heinrich Schuchardt (2): test/dm: fix watchdog test sandbox: fix sandbox_wdt_expire_now()
drivers/watchdog/sandbox_wdt.c | 1 + test/dm/Makefile | 4 +++- 2 files changed, 4 insertions(+), 1 deletion(-)
For successful execution of the watchdog test we need both the GPIO as well as the SANDBOX watchdog.
Avoid a build failure for CONFIG_WDT_GPIO=n.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: move changes to Makefile --- test/dm/Makefile | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/test/dm/Makefile b/test/dm/Makefile index 7de013f636..548649f8e8 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -106,6 +106,8 @@ obj-$(CONFIG_TIMER) += timer.o obj-$(CONFIG_DM_USB) += usb.o obj-$(CONFIG_DM_VIDEO) += video.o obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o -obj-$(CONFIG_WDT) += wdt.o +ifeq ($(CONFIG_WDT_GPIO)$(CONFIG_WDT_SANDBOX),yy) +obj-y += wdt.o +endif endif endif # !SPL
On Tue, 2 Nov 2021 at 12:44, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Applied to u-boot-dm, thanks!
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: no change --- drivers/watchdog/sandbox_wdt.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/watchdog/sandbox_wdt.c b/drivers/watchdog/sandbox_wdt.c index e05d82789f..535614f04d 100644 --- a/drivers/watchdog/sandbox_wdt.c +++ b/drivers/watchdog/sandbox_wdt.c @@ -39,6 +39,7 @@ static int sandbox_wdt_reset(struct udevice *dev) static int sandbox_wdt_expire_now(struct udevice *dev, ulong flags) { sandbox_wdt_start(dev, 1, flags); + sandbox_reset();
return 0; }
v2: no change
v2: no change
