[U-Boot] [PATCH v2 1/2] net: Add Kconfig option for BOOTP_NTPSERVER
Add a Kconfig option for BOOTP_NTPSERVER to enable the DHCP/BOOTP option to configure the sntp server address.
Signed-off-by: Chris Packham judge.packham@gmail.com --- Changes in v2: - update devkit8000 config - remove from config_whitelist.txt
cmd/Kconfig | 4 ++++ configs/devkit8000_defconfig | 1 + include/configs/devkit8000.h | 1 - scripts/config_whitelist.txt | 1 - 4 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index bc1d2f31c010..dfb0fddb7671 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1086,6 +1086,10 @@ config BOOTP_SUBNETMASK default y depends on CMD_BOOTP
+config BOOTP_NTPSERVER + bool "Request & store 'ntpserverip' from BOOTP/DHCP server" + depends on CMD_BOOTP + config BOOTP_PXE bool "Send PXE client arch to BOOTP/DHCP server" default y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index defed2d65a70..4a096b926597 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_NTPSERVER=y CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index dfbbb21a04c7..3b787be9000c 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -82,7 +82,6 @@ #define CONFIG_BOOTP_BOOTFILESIZE #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME -#define CONFIG_BOOTP_NTPSERVER #define CONFIG_BOOTP_TIMEOFFSET #undef CONFIG_BOOTP_VENDOREX
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9eba487ec4c5..0c0862d48db9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -157,7 +157,6 @@ CONFIG_BOOTP_DHCP_REQUEST_DELAY CONFIG_BOOTP_ID_CACHE_SIZE CONFIG_BOOTP_MAY_FAIL CONFIG_BOOTP_NISDOMAIN -CONFIG_BOOTP_NTPSERVER CONFIG_BOOTP_RANDOM_DELAY CONFIG_BOOTP_SEND_HOSTNAME CONFIG_BOOTP_SERVERIP
When the following configuration is set
# CONFIG_CMD_DHCP is not set CONFIG_CMD_BOOTP=y CONFIG_BOOTP_NTPSERVER=y
The following compile error is observed
error: used struct type value where scalar is required if (net_ntp_server) ^~~~~~~~~~~~~~
Resolve this by checking net_ntp_server.s_addr instead.
Signed-off-by: Chris Packham judge.packham@gmail.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- Changes in v2: - collect Ack from Joe
net/bootp.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/bootp.c b/net/bootp.c index efa959971c27..9d7cb5d30c14 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -333,7 +333,7 @@ static void bootp_process_vendor(u8 *ext, int size) debug("net_nis_domain : %s\n", net_nis_domain);
#if defined(CONFIG_CMD_SNTP) && defined(CONFIG_BOOTP_NTPSERVER) - if (net_ntp_server) + if (net_ntp_server.s_addr) debug("net_ntp_server : %pI4\n", &net_ntp_server); #endif }
Chris Packham
Joe Hershberger
