[U-Boot] [PATCH] tools/env: fix cross-compilation
This patch fixes the make infrastructure for the fw_printenv tool such that it is built, by default, as a cross-compilation for the target board when so requested with TOOLSUBDIRS on the U-Boot make command line.
Signed-off-by: Grant Erickson marathon96@gmail.com --- tools/env/Makefile | 18 +++++++++--------- tools/env/README | 19 ++++++++++++++----- 2 files changed, 23 insertions(+), 14 deletions(-)
diff --git a/tools/env/Makefile b/tools/env/Makefile index 28b73da..705d5e8 100644 --- a/tools/env/Makefile +++ b/tools/env/Makefile @@ -23,24 +23,24 @@
include $(TOPDIR)/config.mk
-HOSTSRCS := $(SRCTREE)/lib/crc32.c fw_env.c fw_env_main.c +SRCS := $(SRCTREE)/lib/crc32.c fw_env.c fw_env_main.c HEADERS := fw_env.h
# Compile for a hosted environment on the target -HOSTCPPFLAGS = -idirafter $(SRCTREE)/include \ - -idirafter $(OBJTREE)/include2 \ - -idirafter $(OBJTREE)/include \ - -DUSE_HOSTCC +CPPFLAGS = -Wall \ + -idirafter $(SRCTREE)/include \ + -idirafter $(OBJTREE)/include2 \ + -idirafter $(OBJTREE)/include \ + -DUSE_HOSTCC
ifeq ($(MTD_VERSION),old) -HOSTCPPFLAGS += -DMTD_OLD +CPPFLAGS += -DMTD_OLD endif
all: $(obj)fw_printenv
-# Some files complain if compiled with -pedantic, use HOSTCFLAGS_NOPED -$(obj)fw_printenv: $(HOSTSRCS) $(HEADERS) - $(HOSTCC) $(HOSTCFLAGS_NOPED) $(HOSTLDFLAGS) -o $@ $(HOSTSRCS) +$(obj)fw_printenv: $(SRCS) $(HEADERS) + $(CROSS_COMPILE)gcc $(CPPFLAGS) $(SRCS) -o $@
clean: rm -f $(obj)fw_printenv diff --git a/tools/env/README b/tools/env/README index 3f0d77e..5b02f7d 100644 --- a/tools/env/README +++ b/tools/env/README @@ -2,11 +2,20 @@ This is a demo implementation of a Linux command line tool to access the U-Boot's environment variables.
-In the current version, there is an issue in cross-compilation. -In order to cross-compile fw_printenv, run - make HOSTCC=<your CC cross-compiler> env -in the root directory of the U-Boot distribution. For example, - make HOSTCC=arm-linux-gcc env +To build it for your target board along with U-Boot itself, simply add: + + TOOLSUBDIRS=env + +to your make invocation such as: + + make -C u-boot/source \ + O=$(CURDIR)/u-boot/build \ + TOOLSUBDIRS=env \ + all + +and you will find, for example: + + $(CURDIR)/u-boot/build/tools/env/fw_printenv
For the run-time utiltity configuration uncomment the line #define CONFIG_FILE "/etc/fw_env.config"
how is this any simpler than the existing method ? make tools HOSTCC=some-random-target-gcc
the current tools/ subdir is consistent in its handling. this patch would break that. -mike
Mike,
Because it's broken with respect to how the rest of U-Boot is built. I already specify the cross-compiler via CROSS_COMPILE when I build u-boot.bin and u-boot.img, that I need to specify the same compiler in two different ways to build executables for the same target platform is broken and, it sounds like, as are the rest of the tools subdirectories.
If fw_setenv were a build host-based tool or if it made sense as a build host-based tool, then using HOSTCC would be sensible.
Best,
Grant
no, you specified the toolchain that is appropriate for building bare metal code. it is often times not the same as the toolchain used to build userspace applications for running under Linux. this is not broken behavior. -mike
Grant Erickson
Mike Frysinger
