[PATCH] ARM: imx: Add OCRAM_S into iMX8M MMU tables
The OCRAM_S is regular memory, just like the OCRAM, add it to the MMU tables so it can be used and cached.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/imx8m/soc.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 5456c10fb17..225e4e12500 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -104,6 +104,13 @@ static struct mm_region imx8m_mem_map[] = { .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* OCRAM_S */ + .virt = 0x180000UL, + .phys = 0x180000UL, + .size = 0x8000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_OUTER_SHARE }, { /* TCM */ .virt = 0x7C0000UL,
Hi Marek,
On Thu, 2021-02-25 at 21:52 +0100, Marek Vasut wrote:
Caution: EXT Email
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach- imx/imx8m/soc.c index 5456c10fb17..225e4e12500 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -104,6 +104,13 @@ static struct mm_region imx8m_mem_map[] = { .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* OCRAM_S */ + .virt = 0x180000UL, + .phys = 0x180000UL, + .size = 0x8000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_OUTER_SHARE }, { /* TCM */ .virt = 0x7C0000UL, -- 2.30.0
OCRAM_S is used by ATF and SPL to pass DDR CSR data. It is better not use it in u-boot to avoid any DDR issue. And this imx8m_mem_map will be modified at runtime to get rid of optee memory. When OCRAM_S is added, the index used in enable_caches and dram_init need update as well.
Best regards, Ye Li
On 2/26/21 8:15 AM, Ye Li wrote:
Hi Marek,
Caution: EXT Email
Where is this implemented ?
The MMU table entry does not trigger any IO to the OCRAM_S , it merely makes it cacheable .
I'm not sure I understand this. What kind of modification are you talking about ? The DRAM entry offset should be determined automatically, so there shouldn't be any need to hand-tune ad-hoc offsets.
Hi Marek,
On Fri, 2021-02-26 at 13:44 +0100, Marek Vasut wrote:
Caution: EXT Email
Hi Marek,
Caution: EXT Email
See below definition in drivers/ddr/imx/imx8m/Kconfig
config SAVED_DRAM_TIMING_BASE hex "Define the base address for saved dram timing" help after DRAM is trained, need to save the dram related timming info into memory for low power use. OCRAM_S is used for this purpose on i.MX8MM. default 0x180000
That's fine to add a map, just remind to use it carefully since it already used by ATF.
You also need below change, the index for DRAM1 is used in codes to help remove the OPTEE space from MMU table.
--- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -167,10 +167,10 @@ void enable_caches(void) * please make sure that entry initial value matches * imx8m_mem_map for DRAM1 */ - int entry = 5; + int entry = 6; u64 attrs = imx8m_mem_map[entry].attrs; - while (i < CONFIG_NR_DRAM_BANKS && entry < 8) { + while (i < CONFIG_NR_DRAM_BANKS && entry < 9) { if (gd->bd->bi_dram[i].start == 0) break; imx8m_mem_map[entry].phys = gd->bd-
bi_dram[i].start;
@@ -212,7 +212,7 @@ int dram_init(void) gd->ram_size = sdram_size; /* also update the SDRAM size in the mem_map used externally */ - imx8m_mem_map[5].size = sdram_size; + imx8m_mem_map[6].size = sdram_size; #ifdef PHYS_SDRAM_2_SIZE gd->ram_size += PHYS_SDRAM_2_SIZE;
Best regards, Ye Li
On 2/27/21 7:26 AM, Ye Li wrote:
Hi Marek,
So, this just defines some sort of value. Note that some boards do override this value to NOT point into OCRAM_S .
I think what you wanted to point me to is drivers/ddr/imx/imx8m/ddr_init.c: 248 dram_config_save(dram_timing, CONFIG_SAVED_DRAM_TIMING_BASE); which writes regular memory. And that regular memory can very well be cacheable.
Not necessarily, use git grep SAVED_DRAM_TIMING_BASE configs/ and see how some boards change the default in configs/ .
OK, then this hard-coding of random offset is nasty and should be fixed. For example iterate over imx8m_mem_map[] and detect entry which has PA
= 0x40000000 , that's your DRAM.
bi_dram[i].start;
The OCRAM_S is regular memory, just like the OCRAM, add it to the MMU tables so it can be used and cached. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
Ye Li
