Re: [U-Boot-Users] problems with booting kernel!
haigao g_hai@huawei.com wrote:
=> printenv bootcmd=bootp 1000000; setenv bootargs root=ramfs console=ttyS00,9600
Pls check your environment settings above. Perhaps you should set like this: bootcmd=bootp; setenv bootargs console=ttyS0,9600 root=/dev/nfs rw ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname)::off; bootm
'root=ramfs and console=ttyS00' is quite strange for me.
ethact=i82559#0
My ethact is 'ethact=SCC ETHERNET'.
## Checking Image at 01000000 ...
Image Name: Linux-2.4.24-pre2
Uhmmm, I suspect you use the kernel source in ELDK3.0.
Right?
Booting progress->[0x8 ]## Current stack ends at 0x0FFB1BB8 => set upper l imit to 0x00800000
## cmdline at 0x007FFF00 ... 0x007FFF00
bd address = 0x0FFB1FC8
memstart = 0x00000000
memsize = 0x10000000
flashstart = 0xFF000000
flashsize = 0x00800000
flashoffset = 0x00000000
sramstart = 0x00000000
sramsize = 0x00000000
bootflags = 0x00000001
intfreq = -165.-993 MHz
The value is a little weird to me. Maybe sth wrong on Power-on init circuit. My custom board also had such a fault with CPU freq. and hanged later.
Booting progress->[0xe ]No initrd
I guess you didn't have ramdisk on your target for you didn't set 'ramdisk_addr'. This is also the reason why I suggest you use 'root=/dev/nfs' rather than 'root=/dev/ram' in bootargs.
## Transferring control to Linux (at address 00000000) ...
--Boundary_(ID_MEOpiNTH9mtRQP5BVjrzNw) Content-type: text/html; charset=gb2312 Content-transfer-encoding: 7BIT
Pls never send HTML to this list. Plain text is well accepted. W.D. don't like to see it. :-)
Sam
_________________________________________________________ Do You Yahoo!? 150万曲MP3疯狂搜,带您闯入音乐殿堂 http://music.yisou.com/ 美女明星应有尽有,搜遍美图、艳图和酷图 http://image.yisou.com 1G就是1000兆,雅虎电邮自助扩容! http://cn.rd.yahoo.com/mail_cn/tag/1g/*http://cn.mail.yahoo.com/event/mail_1...
It's not only a matter of liking or disliking. It has to do with the ability to use standard text processing tools to process the stuff, like a simple "grep" to search for something. All the other issues like waste of bandwidht and storage capacity to be added, of ocurse.
Oops, me and my big mouth. Well, maybe we could add some post rules on u-boot maillist subscribe URL clearly, like PLAIN TEXT ONLY maillist. Or give the new subscriber some tips when he gets a successful subscription. There are also other similar problems, like 'gzip' some small pacth, which make it unreadable on maillist. This way, I think we could make the maillist more readable. And also to save us from posting such remainders online every now and then.
Sam
This is standard netiquette. There should (in theory, I know) be no need to metion this at all. But there should also be no need to point ouit that posters are expected to read the documentation and the FAQs and search the mailing list archives and use google and do allt he other usual things ...
Maybe we should really set up posting rules (pronbaly similar to those on the linux-arm lists)and actually reject messages that contain "garbage". It's just that I don't know how or if at all I can set up such filtering on the SF mailing lists. I doubt I can do it there.
Sam Song
