[U-Boot] [PATCH] OMAP5: uEVM: Fix pinmux for USB support
Set mux mode to GPIO for the pads used for HSIC USB device reset.
Remove useless pinmux for USBB1_HSIC - the OMAP5432 does not have this port bonded out.
Signed-off-by: Lubomir Popov lpopov@mm-sol.com --- I shall again point out that this mux_data.h file comes from the sEVM board without any modification at all and has to be carefully fixed. This patch addresses the USB reset function only.
board/ti/omap5_uevm/mux_data.h | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/board/ti/omap5_uevm/mux_data.h b/board/ti/omap5_uevm/mux_data.h index a82795d..054ada6 100644 --- a/board/ti/omap5_uevm/mux_data.h +++ b/board/ti/omap5_uevm/mux_data.h @@ -47,8 +47,7 @@ const struct pad_conf_entry core_padconf_array_essential[] = { {SDCARD_DATA3, (PTU | IEN | M0)}, /* SDCARD_DATA3*/ {UART3_RX_IRRX, (PTU | IEN | M0)}, /* UART3_RX_IRRX */ {UART3_TX_IRTX, (M0)}, /* UART3_TX_IRTX */ - {USBB1_HSIC_STROBE, (PTU | IEN | M0)}, /* USBB1_HSIC_STROBE */ - {USBB1_HSIC_DATA, (PTU | IEN | M0)}, /* USBB1_HSIC_DATA */ + {USBB2_HSIC_STROBE, (PTU | IEN | M0)}, /* USBB2_HSIC_STROBE */ {USBB2_HSIC_DATA, (PTU | IEN | M0)}, /* USBB2_HSIC_DATA */ {USBB3_HSIC_STROBE, (PTU | IEN | M0)}, /* USBB3_HSIC_STROBE*/ @@ -57,6 +56,8 @@ const struct pad_conf_entry core_padconf_array_essential[] = { {USBD0_HS_DM, (IEN | M0)}, /* USBD0_HS_DM */ {USBD0_SS_RX, (IEN | M0)}, /* USBD0_SS_RX */
+ {HSI2_ACWAKE, (PTD | M6)}, /* GPIO3_79: ETH_nRST */ + {HSI2_CAFLAG, (PTD | M6)}, /* GPIO3_80: H_USBH_NRESET */ };
const struct pad_conf_entry wkup_padconf_array_essential[] = { @@ -114,8 +115,6 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {HSI2_CAREADY, (IEN | M0)}, /* HSI2_CAREADY */ {HSI2_ACREADY, (OFF_EN | M0)}, /* HSI2_ACREADY */ {HSI2_CAWAKE, (IEN | PTD | M0)}, /* HSI2_CAWAKE */ - {HSI2_ACWAKE, (M0)}, /* HSI2_ACWAKE */ - {HSI2_CAFLAG, (IEN | PTD | M0)}, /* HSI2_CAFLAG */ {HSI2_CADATA, (IEN | PTD | M0)}, /* HSI2_CADATA */ {HSI2_ACFLAG, (M0)}, /* HSI2_ACFLAG */ {HSI2_ACDATA, (M0)}, /* HSI2_ACDATA */
Lubomir Popov
