Re: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hello Venkatesh,
Is there any news on the status of this patch? I'm working with a Zynq 7z020 system where 2 Flashes operate in parallel QSPI mode. This patch is essential for the correct Flash erase in U-Boot v2025.01-rc3.
Without this patch Flash erase fails on every second multiple of Flash erase section size (FESS). Failing means that the Flash erase is not initiated or successful. I.e., the Flash section is not altered.
For example, lets assume a FESS with 0x20000 (128 kiB).
sf test 00000 20000 # Works sf test 20000 20000 # Fails sf test 40000 20000 # Works sf test 60000 20000 # Fails # ...
Note that executing
sf erase 20000 20000 SF: 131072 bytes @ 0x20000 Erased: OK
shows OK even though the Flash sector were not erased.
In case you have any new/rebased patches you want me to test, I would be happy to do so. I'm looking forward getting this patch into mainline U-Boot.
Best Regards,
Dominik
Content provided within this e-mail including any attachments, is for the use of the intended recipients and may contain Rohde & Schwarz company restricted information. Any unauthorized use, disclosure, or distribution of this communication in whole or in part is strictly prohibited. If you are not the intended recipient, please notify the sender by reply email or by telephone and delete the communication in its entirety.
Hi Dominik, Could you please let me know the details of the flash? I will check from my side.
Thanks Venkatesh From: Dominik Wernberger dominik.wernberger@rohde-schwarz.com Sent: Tuesday, December 3, 2024 5:21 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Cc: git (AMD-Xilinx) git@amd.com; jagan@amarulasolutions.com; Simek, Michal michal.simek@amd.com; trini@konsulko.com; u-boot@lists.denx.de; vigneshr@ti.com Subject: Re: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hello Venkatesh,
Note that executing
Best Regards,
Dominik
Hi Venkatesh,
Thanks for such a fast response.
Running ‘sf probe’ gives: Flash: SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
To be correct we use 2x MT25QL256ABA1EW9 [1, 2] which is basically the same as the n25q256a reported by sf. In defconfig I’ve specified CONFIG_ENV_SECT_SIZE=0x00040000 which is divided by 2 in parallel memories logic [3], resulting in the 128 KiB per Flash chip.
If you need any further information, please let me know.
[1] https://www.micron.com/products/storage/nor-flash/serial-nor/part-catalog/pa... [2] https://xonstorage.blob.core.windows.net/pdf/micron_mt25ql256aba1ew90sit_apr... [3] https://lore.kernel.org/all/20240926045508.1492638-3-venkatesh.abbarapu@amd....
BR Dominik
From: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Sent: Tuesday, December 3, 2024 1:01 PM To: Wernberger Dominik (1GS4) dominik.wernberger@rohde-schwarz.com Cc: git (AMD-Xilinx) git@amd.com; jagan@amarulasolutions.com; Simek, Michal michal.simek@amd.com; trini@konsulko.com; u-boot@lists.denx.de; vigneshr@ti.com Subject: *EXT* RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Thanks Venkatesh From: Dominik Wernberger <dominik.wernberger@rohde-schwarz.commailto:dominik.wernberger@rohde-schwarz.com> Sent: Tuesday, December 3, 2024 5:21 PM To: Abbarapu, Venkatesh <venkatesh.abbarapu@amd.commailto:venkatesh.abbarapu@amd.com> Cc: git (AMD-Xilinx) <git@amd.commailto:git@amd.com>; jagan@amarulasolutions.commailto:jagan@amarulasolutions.com; Simek, Michal <michal.simek@amd.commailto:michal.simek@amd.com>; trini@konsulko.commailto:trini@konsulko.com; u-boot@lists.denx.demailto:u-boot@lists.denx.de; vigneshr@ti.commailto:vigneshr@ti.com Subject: Re: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hello Venkatesh,
Note that executing
Best Regards,
Dominik
Hi Dominik, I have tried on the zc706 board and didn’t see any issues with the parallel configuration. This is the upstream commit f96e5133184aac377b54bd61f8abf78710f2ee56 + patch attached Zynq> sf probe 0 0 0 SF: Detected n25q512ax3 with page size 512 Bytes, erase size 128 KiB, total 128 MiB Verified with the below tests and didn’t see any issue. Log: U-Boot 2025.01-rc3-00046-gf96e5133184a-dirty (Dec 04 2024 - 19:50:42 +0530)
CPU: Zynq 7z045 Silicon: v3.1 Model: Xilinx ZC706 board DRAM: ECC disabled 1 GiB jedec_spi_nor flash@0: has no valid 'reg' property (0) Core: 31 devices, 19 uclasses, devicetree: board Flash: 0 Bytes NAND: 0 MiB MMC: mmc@e0100000: 0 Loading Environment from nowhere... OK In: serial@e0001000 Out: serial@e0001000 Err: serial@e0001000 Net: ZYNQ GEM: e000b000, mdio bus e000b000, phyaddr 7, interface rgmii-id
Warning: ethernet@e000b000 (eth0) using random MAC address - b6:69:a8:60:e2:de eth0: ethernet@e000b000 Hit any key to stop autoboot: 0 Zynq> sf probe 0 0 0 SF: Detected n25q512ax3 with page size 512 Bytes, erase size 128 KiB, total 128 MiB Zynq> time sf erase 0x0 0x2000000;mw.b 0x8000 aabbccdd 0x2000000;time sf write 0x8000 0x0 0x2000000;mw.b 0x8008000 0x0 0x2000000;time sf read 0x8008000 0x0 0x2000000;cmp.b 0x8000 0x8008000 0x2000000 SF: 33554432 bytes @ 0x0 Erased: OK
time: 3 minutes, 37.604 seconds device 0 offset 0x0, size 0x2000000 SF: 33554432 bytes @ 0x0 Written: OK
time: 47.074 seconds device 0 offset 0x0, size 0x2000000 SF: 33554432 bytes @ 0x0 Read: OK
time: 5.411 seconds Total of 33554432 byte(s) were the same Zynq> time sf erase 0x0 0x4000000; mw.b 0x10000000 dd 0x4000000; time sf write 0x10000000 0x0 0x4000000; mw.b 0x20000000 0x0 0x4000000; time sf read 0x20000000 0x0 0x4000000; cmp.b 0x10000000 0x20000000 0x4000000 SF: 67108864 bytes @ 0x0 Erased: OK
time: 6 minutes, 45.941 seconds device 0 offset 0x0, size 0x4000000 SF: 67108864 bytes @ 0x0 Written: OK
time: 1 minutes, 34.443 seconds device 0 offset 0x0, size 0x4000000 SF: 67108864 bytes @ 0x0 Read: OK
time: 10.821 seconds Total of 67108864 byte(s) were the same Zynq> time sf erase 0x0 0x8000000;mw.b 0x8000 aabbccdd 0x8000000;time sf write 0x8000 0x0 0x8000000;mw.b 0x8008000 0x0 0x8000000;time sf read 0x8008000 0x0 0x8000000;cmp.b 0x8000 0x8008000 0x8000000 SF: 134217728 bytes @ 0x0 Erased: OK
time: 12 minutes, 50.601 seconds device 0 whole chip SF: 134217728 bytes @ 0x0 Written: OK
time: 3 minutes, 6.852 seconds device 0 whole chip SF: 134217728 bytes @ 0x0 Read: OK
time: 21.643 seconds Total of 134217728 byte(s) were the same Zynq>
Let me know if you have any questions.
Thanks Venkatesh
From: Dominik Wernberger dominik.wernberger@rohde-schwarz.com Sent: Tuesday, December 3, 2024 5:57 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Cc: git (AMD-Xilinx) git@amd.com; jagan@amarulasolutions.com; Simek, Michal michal.simek@amd.com; trini@konsulko.com; u-boot@lists.denx.de; vigneshr@ti.com Subject: RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hi Venkatesh,
BR Dominik
From: Abbarapu, Venkatesh <venkatesh.abbarapu@amd.commailto:venkatesh.abbarapu@amd.com> Sent: Tuesday, December 3, 2024 1:01 PM To: Wernberger Dominik (1GS4) <dominik.wernberger@rohde-schwarz.commailto:dominik.wernberger@rohde-schwarz.com> Cc: git (AMD-Xilinx) <git@amd.commailto:git@amd.com>; jagan@amarulasolutions.commailto:jagan@amarulasolutions.com; Simek, Michal <michal.simek@amd.commailto:michal.simek@amd.com>; trini@konsulko.commailto:trini@konsulko.com; u-boot@lists.denx.demailto:u-boot@lists.denx.de; vigneshr@ti.commailto:vigneshr@ti.com Subject: *EXT* RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hello Venkatesh,
Note that executing
Best Regards,
Dominik
Hi Venkatesh,
I applied your attached patch to v2025.01-rc3 (commit 3073246d1be682071d8b3d07d06c2484907aed60) and confirm that your patch resolves my Flash erase issue. The following commands now work correctly.
sf probe sf test 0 100000
Just for clarification, were you able to reproduce the original issue on your side?
Thank you very much!
Best Regards
Dominik
From: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Sent: Thursday, December 5, 2024 6:46 AM To: Wernberger Dominik (1GS4) dominik.wernberger@rohde-schwarz.com Cc: git (AMD-Xilinx) git@amd.com; jagan@amarulasolutions.com; Simek, Michal michal.simek@amd.com; trini@konsulko.com; u-boot@lists.denx.de; vigneshr@ti.com Subject: *EXT* RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Thanks Venkatesh
From: Dominik Wernberger <dominik.wernberger@rohde-schwarz.commailto:dominik.wernberger@rohde-schwarz.com> Sent: Tuesday, December 3, 2024 5:57 PM To: Abbarapu, Venkatesh <venkatesh.abbarapu@amd.commailto:venkatesh.abbarapu@amd.com> Cc: git (AMD-Xilinx) <git@amd.commailto:git@amd.com>; jagan@amarulasolutions.commailto:jagan@amarulasolutions.com; Simek, Michal <michal.simek@amd.commailto:michal.simek@amd.com>; trini@konsulko.commailto:trini@konsulko.com; u-boot@lists.denx.demailto:u-boot@lists.denx.de; vigneshr@ti.commailto:vigneshr@ti.com Subject: RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hi Venkatesh,
BR Dominik
Hello Venkatesh,
Note that executing
Best Regards,
Dominik
Hi Dominik, Thanks for letting me know that the parallel configuration is working with the patch. Yes…I too observed the issue, so sent these patches https://lore.kernel.org/u-boot/20241118090544.21956-1-venkatesh.abbarapu@amd... https://lore.kernel.org/u-boot/20241018082644.22495-1-venkatesh.abbarapu@amd...
Thanks Venkatesh From: Dominik Wernberger dominik.wernberger@rohde-schwarz.com Sent: Thursday, December 5, 2024 4:00 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Cc: git (AMD-Xilinx) git@amd.com; jagan@amarulasolutions.com; Simek, Michal michal.simek@amd.com; trini@konsulko.com; u-boot@lists.denx.de; vigneshr@ti.com Subject: RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Hi Venkatesh,
Best Regards
Dominik
From: Abbarapu, Venkatesh <venkatesh.abbarapu@amd.commailto:venkatesh.abbarapu@amd.com> Sent: Thursday, December 5, 2024 6:46 AM To: Wernberger Dominik (1GS4) <dominik.wernberger@rohde-schwarz.commailto:dominik.wernberger@rohde-schwarz.com> Cc: git (AMD-Xilinx) <git@amd.commailto:git@amd.com>; jagan@amarulasolutions.commailto:jagan@amarulasolutions.com; Simek, Michal <michal.simek@amd.commailto:michal.simek@amd.com>; trini@konsulko.commailto:trini@konsulko.com; u-boot@lists.denx.demailto:u-boot@lists.denx.de; vigneshr@ti.commailto:vigneshr@ti.com Subject: *EXT* RE: [PATCH] mtd: spi-nor: Fix the qspi parallel memory issues
Thanks Venkatesh
Hi Venkatesh,
BR Dominik
Hello Venkatesh,
Note that executing
Best Regards,
Dominik
Abbarapu, Venkatesh
Dominik Wernberger
