[U-Boot] [PATCH 3/3] armv8: ls1088aqds: Add support of LS1088AQDS
This patch add support of LS1088AQDS platform.
The LS1088A QorIQTM Development System (QDS) is a high-performance computing, evaluation, and development platform that supports the LS1088A QorIQ Architecture processor.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com --- arch/arm/Kconfig | 11 + arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 21 + arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c | 2 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1088a-qds.dts | 70 +++ board/freescale/ls1088a/Kconfig | 16 + board/freescale/ls1088a/MAINTAINERS | 10 +- board/freescale/ls1088a/Makefile | 1 + board/freescale/ls1088a/ddr.c | 119 +--- board/freescale/ls1088a/ddr.h | 9 +- board/freescale/ls1088a/eth_ls1088aqds.c | 650 +++++++++++++++++++++ board/freescale/ls1088a/ls1088a.c | 106 +++- board/freescale/ls1088a/ls1088a_qixis.h | 5 + configs/ls1088aqds_qspi_defconfig | 27 + configs/ls1088ardb_qspi_defconfig | 6 - include/configs/ls1088a_common.h | 8 +- include/configs/ls1088aqds.h | 403 +++++++++++++ 19 files changed, 1321 insertions(+), 147 deletions(-) create mode 100644 arch/arm/dts/fsl-ls1088a-qds.dts create mode 100644 board/freescale/ls1088a/eth_ls1088aqds.c create mode 100644 configs/ls1088aqds_qspi_defconfig create mode 100644 include/configs/ls1088aqds.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0c63dfe..435a8f8 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -776,6 +776,17 @@ config TARGET_LS2080A_SIMU development platform that supports the QorIQ LS2080A Layerscape Architecture processor.
+config TARGET_LS1088AQDS + bool "Support ls1088aqds" + select ARCH_LS1088A + select ARM64 + select ARMV8_MULTIENTRY + help + Support for NXP LS1088AQDS platform + The LS1088A Development System (QDS) is a high-performance + development platform that supports the QorIQ LS1088A + Layerscape Architecture processor. + config TARGET_LS2080AQDS bool "Support ls2080aqds" select ARCH_LS2080A diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 630bb78..b3565a5 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -88,7 +88,7 @@ config PSCI_RESET depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && !TARGET_LS2080A_EMU && \ !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ !TARGET_LS2080ARDB && !TARGET_LS1012AQDS && \ - !TARGET_LS1088ARDB && \ + !TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index a418c91..bf48918 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -229,6 +229,27 @@ config FSL_TZASC_1 config FSL_TZASC_2 bool
+config SYS_FSL_ERRATUM_A008336 + bool + +config SYS_FSL_ERRATUM_A009801 + bool + +config SYS_FSL_ERRATUM_A009803 + bool + +config SYS_FSL_ERRATUM_A009942 + bool + +config SYS_FSL_ERRATUM_A010165 + bool + +config SYS_FSL_ERRATUM_A008511 + bool + +config SYS_FSL_ERRATUM_A008850 + bool + endmenu
menu "Layerscape clock tree configuration" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c index 9f89bd0..9f5cdd5 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c @@ -30,6 +30,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x20, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 2, 2 } }, {0x35, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 3 } }, {0x36, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 3 } }, + {0x3A, {SGMII3, PCIE1, SGMII1, SGMII2 }, {3, 5, 3, 3 } }, {} }; static struct serdes_config serdes2_cfg_tbl[] = { @@ -39,6 +40,7 @@ static struct serdes_config serdes2_cfg_tbl[] = { {0x0E, {PCIE1, PCIE1, PCIE2, SATA1 }, {7, 7, 6, 9 } }, {0x13, {PCIE1, PCIE1, PCIE3, PCIE3 }, {7, 7, 7, 7 } }, {0x14, {PCIE1, PCIE2, PCIE3, PCIE3 }, {5, 5, 7, 7 } }, + {0x3C, {NONE, PCIE2, NONE, PCIE3 }, {0, 5, 0, 6 } }, {} };
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 337d99d..f5a22ba 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -24,6 +24,7 @@ #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif +#include <fsl_immap.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5ac8ea3..2ec5c12 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -164,6 +164,7 @@ dtb-$(CONFIG_LS102XA) += ls1021a-qds-duart.dtb \ ls1021a-iot-duart.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb \ + fsl-ls1088a-qds.dtb \ fsl-ls1088a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ diff --git a/arch/arm/dts/fsl-ls1088a-qds.dts b/arch/arm/dts/fsl-ls1088a-qds.dts new file mode 100644 index 0000000..9b7bef4 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds.dts @@ -0,0 +1,70 @@ +/* + * NXP ls1088a QDS board device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "fsl-ls1088a.dtsi" + +/ { + model = "NXP Layerscape 1088a QDS Board"; + compatible = "fsl,ls1088a-qds", "fsl,ls1088a"; + aliases { + spi0 = &qspi; + spi1 = &dspi; + }; +}; + +&dspi { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <1000000>; /* input clock */ + }; + + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <1>; + }; + + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <2>; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; diff --git a/board/freescale/ls1088a/Kconfig b/board/freescale/ls1088a/Kconfig index a4d8223..1ada661 100644 --- a/board/freescale/ls1088a/Kconfig +++ b/board/freescale/ls1088a/Kconfig @@ -1,3 +1,19 @@ +if TARGET_LS1088AQDS + +config SYS_BOARD + default "ls1088a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1088aqds" + +endif + if TARGET_LS1088ARDB
config SYS_BOARD diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS index 1abbf91..e1e6d4b 100644 --- a/board/freescale/ls1088a/MAINTAINERS +++ b/board/freescale/ls1088a/MAINTAINERS @@ -5,5 +5,11 @@ S: Maintained F: board/freescale/ls1088a/ F: include/configs/ls1088ardb.h F: configs/ls1088ardb_qspi_defconfig -F: configs/ls1088ardb_sdcard_defconfig -F: configs/ls1088ardb_sdcard_qspi_defconfig + +LS1088AQDS BOARD +M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com +M: Ashish Kumar Ashish.Kumar@nxp.com +S: Maintained +F: board/freescale/ls1088a/ +F: include/configs/ls1088aqds.h +F: configs/ls1088aqds_qspi_defconfig diff --git a/board/freescale/ls1088a/Makefile b/board/freescale/ls1088a/Makefile index e997cf1..bdcce9e 100644 --- a/board/freescale/ls1088a/Makefile +++ b/board/freescale/ls1088a/Makefile @@ -6,4 +6,5 @@
obj-y += ls1088a.o obj-$(CONFIG_TARGET_LS1088ARDB) += eth_ls1088ardb.o +obj-$(CONFIG_TARGET_LS1088AQDS) += eth_ls1088aqds.o obj-y += ddr.o diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index 8903ff0..61b6212 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -25,19 +25,14 @@ void fsl_ddr_board_options(memctl_options_t *popts, if (!pdimm->n_ranks) return;
- /* - * we use identical timing for all slots. If needed, change the code - * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; - */ - pbsp = udimms[ctrl_num]; + pbsp = udimms[0];
/* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr * freqency and n_banks specified in board_specific_parameters table. */ ddr_freq = get_ddr_freq(0) / 1000000; while (pbsp->datarate_mhz_high) { - if (pbsp->n_ranks == pdimm->n_ranks && - (pdimm->rank_density >> 30) >= pbsp->rank_gb) { + if (pbsp->n_ranks == pdimm->n_ranks) { if (ddr_freq <= pbsp->datarate_mhz_high) { popts->clk_adjust = pbsp->clk_adjust; popts->wrlvl_start = pbsp->wrlvl_start; @@ -63,51 +58,18 @@ void fsl_ddr_board_options(memctl_options_t *popts, panic("DIMM is not supported by this board"); } found: -#if defined(CONFIG_EMU) debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n" "\tclk_adjust %d, wrlvl_start %d, wrlvl_ctrl_2 0x%x, wrlvl_ctrl_3 0x%x\n", pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb, pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, pbsp->wrlvl_ctl_3); -#else - debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", - pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); - - pdimm[0].dq_mapping[0] = 0x15; - pdimm[0].dq_mapping[1] = 0x35; - pdimm[0].dq_mapping[2] = 0x0b; - pdimm[0].dq_mapping[3] = 0x2c; - pdimm[0].dq_mapping[4] = 0x15; - pdimm[0].dq_mapping[5] = 0x35; - pdimm[0].dq_mapping[6] = 0x15; - pdimm[0].dq_mapping[7] = 0x35; - pdimm[0].dq_mapping[8] = 0xc; - pdimm[0].dq_mapping[9] = 0; - pdimm[0].dq_mapping[10] = 0; - pdimm[0].dq_mapping[11] = 0; - pdimm[0].dq_mapping[12] = 0; - pdimm[0].dq_mapping[13] = 0; - pdimm[0].dq_mapping[14] = 0; - pdimm[0].dq_mapping[15] = 0; - pdimm[0].dq_mapping[16] = 0; - pdimm[0].dq_mapping[17] = 0; - - /* force DDR bus width to 32 bits */ - popts->data_bus_width = 1; + + popts->data_bus_width = 0; /* 64b data bus */ popts->otf_burst_chop_en = 0; popts->burst_length = DDR_BL8; - popts->bstopre = 0; /* enable auto precharge */ -#endif + popts->bstopre = 0; /* enable auto precharge */
- /* - * Factors to consider for half-strength driver enable: - * - number of DIMMs installed - */ -#if defined(CONFIG_EMU) - popts->half_strength_driver_enable = 1; -#else popts->half_strength_driver_enable = 0; -#endif /* * Write leveling override */ @@ -122,10 +84,10 @@ found: /* Enable ZQ calibration */ popts->zq_en = 1;
-#if defined(CONFIG_EMU) +#if defined(CONFIG_TARGET_LS1088AQDS) popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | - DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ + DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; #else popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_60ohm); popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_100ohm) | @@ -134,73 +96,6 @@ found: popts->cpo_sample = 0x6d; }
-#ifdef CONFIG_SYS_DDR_RAW_TIMING -dimm_params_t ddr_raw_timing = { - .n_ranks = 1, - .rank_density = 4294967296u, - .capacity = 4294967296u, - .primary_sdram_width = 64, - .ec_sdram_width = 8, - .registered_dimm = 0, - .mirrored_dimm = 1, - .n_row_addr = 15, - .n_col_addr = 10, - .bank_addr_bits = 0, - .bank_group_bits = 2, - .edc_config = 2, - .burst_lengths_bitmask = 0x0c, - - .tckmin_x_ps = 938, - .tckmax_ps = 1500, - .caslat_x = 0x000DFA00, - .taa_ps = 13500, - .trcd_ps = 13500, - .trp_ps = 13500, - .tras_ps = 33000, - .trc_ps = 46500, - .trfc1_ps = 260000, - .trfc2_ps = 160000, - .trfc4_ps = 110000, - .tfaw_ps = 21000, - .trrds_ps = 3700, - .trrdl_ps = 5300, - .tccdl_ps = 5355, - .refresh_rate_ps = 7800000, - .dq_mapping[0] = 0x00, - .dq_mapping[1] = 0x00, - .dq_mapping[2] = 0x00, - .dq_mapping[3] = 0x00, - .dq_mapping[4] = 0x00, - .dq_mapping[5] = 0x00, - .dq_mapping[6] = 0x00, - .dq_mapping[7] = 0x00, - .dq_mapping[8] = 0x00, - .dq_mapping[9] = 0x00, - .dq_mapping[10] = 0x00, - .dq_mapping[11] = 0x00, - .dq_mapping[12] = 0x00, - .dq_mapping[13] = 0x00, - .dq_mapping[14] = 0x00, - .dq_mapping[15] = 0x00, - .dq_mapping[16] = 0x00, - .dq_mapping[17] = 0x00, - .dq_mapping_ors = 1, -}; - -int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, - unsigned int controller_number, - unsigned int dimm_number) -{ - static const char dimm_model[] = "Fixed DDR on board"; - - if (dimm_number == 0) - memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); - memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); - memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); - - return 0; -} -#endif
phys_size_t initdram(int board_type) { diff --git a/board/freescale/ls1088a/ddr.h b/board/freescale/ls1088a/ddr.h index 1658c22..bfc5dae 100644 --- a/board/freescale/ls1088a/ddr.h +++ b/board/freescale/ls1088a/ddr.h @@ -33,9 +33,14 @@ static const struct board_specific_parameters udimm0[] = { {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, {2, 2300, 0, 4, 9, 0x0A0C0D11, 0x1214150E,}, {} +#elif defined(CONFIG_TARGET_LS1088AQDS) + {2, 1666, 0, 8, 8, 0x0A0A0C0E, 0x0F10110C,}, + {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 4, 9, 0x0A0C0D11, 0x1214150E,}, + {} #else - {2, 2140, 0, 4, 4, 0x0, 0x0}, - {1, 2140, 0, 4, 4, 0x0, 0x0}, + {2, 2140, 0, 8, 4, 0x0, 0x0}, + {1, 2140, 0, 8, 4, 0x0, 0x0}, {} #endif }; diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c new file mode 100644 index 0000000..3e78ac7 --- /dev/null +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -0,0 +1,650 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/fsl_serdes.h> +#include <hwconfig.h> +#include <fsl_mdio.h> +#include <malloc.h> +#include <fm_eth.h> +#include <i2c.h> +#include <miiphy.h> +#include <fsl-mc/ldpaa_wriop.h> + +#include "../common/qixis.h" + +#include "ls1088a_qixis.h" + +#define MC_BOOT_ENV_VAR "mcinitcmd" + +#ifdef CONFIG_FSL_MC_ENET + +#define SFP_TX 0 + + /* - In LS1088A A there are only 16 SERDES lanes, spread across 2 SERDES banks. + * Bank 1 -> Lanes A, B, C, D, + * Bank 2 -> Lanes A,B, C, D, + */ + + /* Mapping of 8 SERDES lanes to LS1088A QDS board slots. A value of '0' here + * means that the mapping must be determined dynamically, or that the lane + * maps to something other than a board slot. + */ + +static u8 lane_to_slot_fsm1[] = { + 0, 0, 0, 0, 0, 0, 0, 0 +}; + +/* On the Vitesse VSC8234XHG SGMII riser card there are 4 SGMII PHYs + * housed. + */ + +static int xqsgii_riser_phy_addr[] = { + XQSGMII_CARD_PHY1_PORT0_ADDR, + XQSGMII_CARD_PHY2_PORT0_ADDR, + XQSGMII_CARD_PHY3_PORT0_ADDR, + XQSGMII_CARD_PHY4_PORT0_ADDR, + XQSGMII_CARD_PHY3_PORT2_ADDR, + XQSGMII_CARD_PHY1_PORT2_ADDR, + XQSGMII_CARD_PHY4_PORT2_ADDR, + XQSGMII_CARD_PHY2_PORT2_ADDR, +}; + +static int sgmii_riser_phy_addr[] = { + SGMII_CARD_PORT1_PHY_ADDR, + SGMII_CARD_PORT2_PHY_ADDR, + SGMII_CARD_PORT3_PHY_ADDR, + SGMII_CARD_PORT4_PHY_ADDR, +}; + +/* Slot2 does not have EMI connections */ +#define EMI_NONE 0xFF +#define EMI1_RGMII1 0 +#define EMI1_RGMII2 1 +#define EMI1_SLOT1 2 + +static const char * const mdio_names[] = { + "LS1088A_QDS_MDIO0", + "LS1088A_QDS_MDIO1", + "LS1088A_QDS_MDIO2", + DEFAULT_WRIOP_MDIO2_NAME, +}; + +struct ls1088a_qds_mdio { + u8 muxval; + struct mii_dev *realbus; +}; + +static void sgmii_configure_repeater(int dpmac) +{ + struct mii_dev *bus; + uint8_t a = 0xf; + int i, j, ret; + unsigned short value; + const char *dev = "LS1088A_QDS_MDIO2"; + int i2c_addr[] = {0x58, 0x59, 0x5a, 0x5b}; + int i2c_phy_addr = 0; + int phy_addr = 0; + + uint8_t ch_a_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_a_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + uint8_t ch_b_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_b_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + + /* Set I2c to Slot 1 */ + i2c_write(0x77, 0, 0, &a, 1); + + switch (dpmac) { + case 1: + i2c_phy_addr = i2c_addr[1]; + phy_addr = 4; + break; + case 2: + i2c_phy_addr = i2c_addr[0]; + phy_addr = 0; + break; + case 3: + i2c_phy_addr = i2c_addr[3]; + phy_addr = 0xc; + break; + case 7: + i2c_phy_addr = i2c_addr[2]; + phy_addr = 8; + break; + } + + /* Check the PHY status */ + ret = miiphy_set_current_dev(dev); + if (ret > 0) + goto error; + + bus = mdio_get_current_dev(); + debug("Reading from bus %s\n", bus->name); + + ret = miiphy_write(dev, phy_addr, 0x1f, 3); + if (ret > 0) + goto error; + + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + + mdelay(10); + + if ((value & 0xfff) == 0x401) { + miiphy_write(dev, phy_addr, 0x1f, 0); + printf("DPMAC %d:PHY is ..... Configured\n", dpmac); + return; + } + + for (i = 0; i < 4; i++) { + for (j = 0; j < 4; j++) { + a = 0x18; + i2c_write(i2c_phy_addr, 6, 1, &a, 1); + a = 0x38; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + a = 0x4; + i2c_write(i2c_phy_addr, 8, 1, &a, 1); + + i2c_write(i2c_phy_addr, 0xf, 1, + &ch_a_eq[i], 1); + i2c_write(i2c_phy_addr, 0x11, 1, + &ch_a_ctl2[j], 1); + + i2c_write(i2c_phy_addr, 0x16, 1, + &ch_b_eq[i], 1); + i2c_write(i2c_phy_addr, 0x18, 1, + &ch_b_ctl2[j], 1); + + a = 0x14; + i2c_write(i2c_phy_addr, 0x23, 1, &a, 1); + a = 0xb5; + i2c_write(i2c_phy_addr, 0x2d, 1, &a, 1); + a = 0x20; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + + if ((value & 0xfff) == 0x401) { + printf("DPMAC %d :PHY is configured ", + dpmac); + printf("after setting repeater 0x%x\n", + value); + i = 5; + j = 5; + } else { + printf("DPMAC %d :PHY is failed to ", + dpmac); + printf("configure the repeater 0x%x\n", value); + } + } + } + miiphy_write(dev, phy_addr, 0x1f, 0); +error: + if (ret) + printf("DPMAC %d ..... FAILED to configure PHY\n", dpmac); + return; +} + +static void qsgmii_configure_repeater(int dpmac) +{ + uint8_t a = 0xf; + int i, j; + int i2c_phy_addr = 0; + int phy_addr = 0; + int i2c_addr[] = {0x58, 0x59, 0x5a, 0x5b}; + + uint8_t ch_a_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_a_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + uint8_t ch_b_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_b_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + + const char *dev = mdio_names[EMI1_SLOT1]; + int ret = 0; + unsigned short value; + + /* Set I2c to Slot 1 */ + i2c_write(0x77, 0, 0, &a, 1); + + switch (dpmac) { + case 7: + case 8: + case 9: + case 10: + i2c_phy_addr = i2c_addr[2]; + phy_addr = 8; + break; + + case 3: + case 4: + case 5: + case 6: + i2c_phy_addr = i2c_addr[3]; + phy_addr = 0xc; + break; + } + + /* Check the PHY status */ + ret = miiphy_set_current_dev(dev); + ret = miiphy_write(dev, phy_addr, 0x1f, 3); + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + mdelay(10); + if ((value & 0xf) == 0xf) { + miiphy_write(dev, phy_addr, 0x1f, 0); + printf("DPMAC %d :PHY is ..... Configured\n", dpmac); + return; + } + + for (i = 0; i < 4; i++) { + for (j = 0; j < 4; j++) { + a = 0x18; + i2c_write(i2c_phy_addr, 6, 1, &a, 1); + a = 0x38; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + a = 0x4; + i2c_write(i2c_phy_addr, 8, 1, &a, 1); + + i2c_write(i2c_phy_addr, 0xf, 1, &ch_a_eq[i], 1); + i2c_write(i2c_phy_addr, 0x11, 1, &ch_a_ctl2[j], 1); + + i2c_write(i2c_phy_addr, 0x16, 1, &ch_b_eq[i], 1); + i2c_write(i2c_phy_addr, 0x18, 1, &ch_b_ctl2[j], 1); + + a = 0x14; + i2c_write(i2c_phy_addr, 0x23, 1, &a, 1); + a = 0xb5; + i2c_write(i2c_phy_addr, 0x2d, 1, &a, 1); + a = 0x20; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + mdelay(1); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + mdelay(10); + if ((value & 0xf) == 0xf) { + miiphy_write(dev, phy_addr, 0x1f, 0); + printf("DPMAC %d :PHY is ..... Configured\n", + dpmac); + return; + } + } + } +error: + printf("DPMAC %d :PHY ..... FAILED to configure PHY\n", dpmac); + return; +} + +static const char *ls1088a_qds_mdio_name_for_muxval(u8 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u8 muxval) +{ + struct mii_dev *bus; + const char *name = ls1088a_qds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +static void ls1088a_qds_enable_SFP_TX(u8 muxval) +{ + u8 brdcfg9; + + brdcfg9 = QIXIS_READ(brdcfg[9]); + brdcfg9 &= ~BRDCFG9_SFPTX_MASK; + brdcfg9 |= (muxval << BRDCFG9_SFPTX_SHIFT); + QIXIS_WRITE(brdcfg[9], brdcfg9); +} + +static void ls1088a_qds_mux_mdio(u8 muxval) +{ + u8 brdcfg4; + + if (muxval <= 5) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_EMISEL_MASK; + brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); + QIXIS_WRITE(brdcfg[4], brdcfg4); + } +} + +static int ls1088a_qds_mdio_read(struct mii_dev *bus, int addr, + int devad, int regnum) +{ + struct ls1088a_qds_mdio *priv = bus->priv; + + ls1088a_qds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int ls1088a_qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct ls1088a_qds_mdio *priv = bus->priv; + + ls1088a_qds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int ls1088a_qds_mdio_reset(struct mii_dev *bus) +{ + struct ls1088a_qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int ls1088a_qds_mdio_init(char *realbusname, u8 muxval) +{ + struct ls1088a_qds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate ls1088a_qds MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate ls1088a_qds private data\n"); + free(bus); + return -1; + } + + bus->read = ls1088a_qds_mdio_read; + bus->write = ls1088a_qds_mdio_write; + bus->reset = ls1088a_qds_mdio_reset; + sprintf(bus->name, ls1088a_qds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + + return mdio_register(bus); +} + +/* + * Initialize the dpmac_info array. + * + */ +static void initialize_dpmac_to_slot(void) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + switch (serdes1_prtcl) { + case 0x12: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[2] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[3] = EMI1_SLOT1 - 1; + break; + case 0x15: + case 0x1D: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[2] = EMI_NONE; + lane_to_slot_fsm1[3] = EMI_NONE; + break; + case 0x1E: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[2] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[3] = EMI_NONE; + break; + case 0x3A: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI_NONE; + lane_to_slot_fsm1[2] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[3] = EMI1_SLOT1 - 1; + break; + + default: + printf("%s qds: WRIOP: Unsupported SerDes1 Protocol 0x%02x\n", + __func__, serdes1_prtcl); + break; + } +} + +void ls1088a_handle_phy_interface_sgmii(int dpmac_id) +{ + struct mii_dev *bus; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + int *riser_phy_addr; + char *env_hwconfig = getenv("hwconfig"); + + if (hwconfig_f("xqsgmii", env_hwconfig)) + riser_phy_addr = &xqsgii_riser_phy_addr[0]; + else + riser_phy_addr = &sgmii_riser_phy_addr[0]; + + switch (serdes1_prtcl) { + case 0x12: + case 0x15: + case 0x1E: + case 0x3A: + switch (dpmac_id) { + case 1: + wriop_set_phy_address(dpmac_id, riser_phy_addr[1]); + break; + case 2: + wriop_set_phy_address(dpmac_id, riser_phy_addr[0]); + break; + case 3: + wriop_set_phy_address(dpmac_id, riser_phy_addr[3]); + break; + case 7: + wriop_set_phy_address(dpmac_id, riser_phy_addr[2]); + break; + default: + printf("WRIOP: Wrong DPMAC%d set to SGMII", dpmac_id); + break; + } + break; + default: + printf("%s qds: WRIOP: Unsupported SerDes1 Protocol 0x%02x\n", + __func__, serdes1_prtcl); + return; + } + dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; + bus = mii_dev_for_muxval(EMI1_SLOT1); + wriop_set_mdio(dpmac_id, bus); +} + +void ls1088a_handle_phy_interface_qsgmii(int dpmac_id) +{ + struct mii_dev *bus; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + switch (serdes1_prtcl) { + case 0x1D: + case 0x1E: + switch (dpmac_id) { + case 3: + case 4: + case 5: + case 6: + wriop_set_phy_address(dpmac_id, dpmac_id + 9); + break; + case 7: + case 8: + case 9: + case 10: + wriop_set_phy_address(dpmac_id, dpmac_id + 1); + break; + } + + dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; + bus = mii_dev_for_muxval(EMI1_SLOT1); + wriop_set_mdio(dpmac_id, bus); + break; + default: + printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + serdes1_prtcl); + break; + } +} + +void ls1088a_handle_phy_interface_xsgmii(int i) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + switch (serdes1_prtcl) { + case 0x15: + case 0x1D: + case 0x1E: + wriop_set_phy_address(i, i + 26); + ls1088a_qds_enable_SFP_TX(SFP_TX); + break; + default: + printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + serdes1_prtcl); + break; + } +} +#endif + +int board_eth_init(bd_t *bis) +{ + int error = 0, i; + char *mc_boot_env_var; +#ifdef CONFIG_FSL_MC_ENET + struct memac_mdio_info *memac_mdio0_info; + char *env_hwconfig = getenv("hwconfig"); + + initialize_dpmac_to_slot(); + + memac_mdio0_info = (struct memac_mdio_info *)malloc( + sizeof(struct memac_mdio_info)); + memac_mdio0_info->regs = + (struct memac_mdio_controller *) + CONFIG_SYS_FSL_WRIOP1_MDIO1; + memac_mdio0_info->name = DEFAULT_WRIOP_MDIO1_NAME; + + /* Register the real MDIO1 bus */ + fm_memac_mdio_init(bis, memac_mdio0_info); + + /* Register the muxing front-ends to the MDIO buses */ + ls1088a_qds_mdio_init(DEFAULT_WRIOP_MDIO1_NAME, EMI1_RGMII1); + ls1088a_qds_mdio_init(DEFAULT_WRIOP_MDIO1_NAME, EMI1_RGMII2); + ls1088a_qds_mdio_init(DEFAULT_WRIOP_MDIO1_NAME, EMI1_SLOT1); + + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + switch (wriop_get_enet_if(i)) { + case PHY_INTERFACE_MODE_QSGMII: + ls1088a_handle_phy_interface_qsgmii(i); + break; + case PHY_INTERFACE_MODE_SGMII: + ls1088a_handle_phy_interface_sgmii(i); + break; + case PHY_INTERFACE_MODE_XGMII: + ls1088a_handle_phy_interface_xsgmii(i); + break; + default: + break; + + if (i == 16) + i = NUM_WRIOP_PORTS; + } + } + + mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); + error = cpu_eth_init(bis); + + if (hwconfig_f("xqsgmii", env_hwconfig)) { + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + switch (wriop_get_enet_if(i)) { + case PHY_INTERFACE_MODE_QSGMII: + qsgmii_configure_repeater(i); + break; + case PHY_INTERFACE_MODE_SGMII: + sgmii_configure_repeater(i); + break; + default: + break; + } + + if (i == 16) + i = NUM_WRIOP_PORTS; + } + } +#endif + error = pci_eth_init(bis); + return error; +} diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index b3ade52..0c8c2a5 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -49,11 +49,18 @@ int checkboard(void) "100 separate SSCG"}; int clock;
+#ifdef CONFIG_TARGET_LS1088AQDS + printf("Board: LS1088A-QDS, "); +#else printf("Board: LS1088A-RDB, "); - +#endif sw = QIXIS_READ(arch); printf("Board Arch: V%d, ", sw >> 4); +#ifdef CONFIG_TARGET_LS1088AQDS printf("Board version: %c, boot from ", (sw & 0xf) + 'A' - 1); +#else + printf("Board version: %c, boot from ", (sw & 0xf) + 'A'); +#endif
memset((u8 *)buf, 0x00, ARRAY_SIZE(buf));
@@ -64,7 +71,27 @@ int checkboard(void) puts("SD card\n"); #endif switch (sw) { +#ifdef CONFIG_TARGET_LS1088AQDS case 0: + case 1: + case 2: + case 3: + case 4: + case 5: + case 6: + case 7: + printf("vBank: %d\n", sw); + break; + case 8: + puts("PromJet\n"); + break; + case 15: + puts("IFCCard\n"); + break; + case 14: +#else + case 0: +#endif puts("QSPI:"); sw = QIXIS_READ(brdcfg[0]); sw = (sw & QIXIS_QMAP_MASK) >> QIXIS_QMAP_SHIFT; @@ -81,11 +108,15 @@ int checkboard(void) break; }
+#ifdef CONFIG_TARGET_LS1088AQDS printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); /* the timestamp string contains "\n" at the end */ printf(" on %s", qixis_read_time(buf)); +#else + printf("CPLD: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); +#endif
/* * Display the actual SERDES reference clocks as configured by the @@ -113,9 +144,13 @@ int checkboard(void)
bool if_board_diff_clk(void) { +#ifdef CONFIG_TARGET_LS1088AQDS + u8 diff_conf = QIXIS_READ(brdcfg[11]); + return diff_conf & 0x40; +#else u8 diff_conf = QIXIS_READ(dutcfg[11]); - return diff_conf & 0x80; +#endif }
unsigned long get_board_sys_clk(void) @@ -177,7 +212,7 @@ void board_retimer_init(void) { u8 reg;
- /* Retimer is connected to I2C1_CH7_CH5 */ + /* Retimer is connected to I2C1_CH5 */ select_i2c_ch_pca9547(I2C_MUX_CH5);
/* Access to Control/Shared register */ @@ -197,26 +232,10 @@ void board_retimer_init(void) reg |= 0x4; i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1);
- /* Enable override divider select and Enable Override Output Mux */ - i2c_read(I2C_RETIMER_ADDR, 9, 1, ®, 1); - reg |= 0x24; - i2c_write(I2C_RETIMER_ADDR, 9, 1, ®, 1); - - /* Select VCO Divider to full rate (000) */ - i2c_read(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); - reg &= 0x8f; - i2c_write(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); - - /* Selects active PFD MUX Input as Re-timed Data (001) */ - i2c_read(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); - reg &= 0x3f; - reg |= 0x20; - i2c_write(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); - /* Set data rate as 10.3125 Gbps */ - reg = 0x0; + reg = 0x90; i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1); - reg = 0xb0; + reg = 0xb3; i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1); reg = 0x90; i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1); @@ -225,6 +244,51 @@ void board_retimer_init(void) reg = 0xcd; i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1);
+ /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR, 0x2F, 1, ®, 1); + reg &= 0x0f; + reg |= 0x70; + i2c_write(I2C_RETIMER_ADDR, 0x2F, 1, ®, 1); + +#ifdef CONFIG_TARGET_LS1088AQDS + /* Retimer is connected to I2C1_CH5 */ + select_i2c_ch_pca9547(I2C_MUX_CH5); + + /* Access to Control/Shared register */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR2, 0xff, 1, ®, 1); + + /* Read device revision and ID */ + i2c_read(I2C_RETIMER_ADDR2, 1, 1, ®, 1); + debug("Retimer version id = 0x%x\n", reg); + + /* Enable Broadcast. All writes target all channel register sets */ + reg = 0x0c; + i2c_write(I2C_RETIMER_ADDR2, 0xff, 1, ®, 1); + + /* Reset Channel Registers */ + i2c_read(I2C_RETIMER_ADDR2, 0, 1, ®, 1); + reg |= 0x4; + i2c_write(I2C_RETIMER_ADDR2, 0, 1, ®, 1); + + /* Set data rate as 10.3125 Gbps */ + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR2, 0x60, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR2, 0x61, 1, ®, 1); + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR2, 0x62, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR2, 0x63, 1, ®, 1); + reg = 0xcd; + i2c_write(I2C_RETIMER_ADDR2, 0x64, 1, ®, 1); + + /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR2, 0x2F, 1, ®, 1); + reg &= 0x0f; + reg |= 0x70; + i2c_write(I2C_RETIMER_ADDR2, 0x2F, 1, ®, 1); +#endif /*return the default channel*/ select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); } diff --git a/board/freescale/ls1088a/ls1088a_qixis.h b/board/freescale/ls1088a/ls1088a_qixis.h index 9757d1b..4790461 100644 --- a/board/freescale/ls1088a/ls1088a_qixis.h +++ b/board/freescale/ls1088a/ls1088a_qixis.h @@ -31,4 +31,9 @@ #define QIXIS_SDCLK1_165 0x2 #define QIXIS_SDCLK1_100_SP 0x3
+#define BRDCFG4_EMISEL_MASK 0xE0 +#define BRDCFG4_EMISEL_SHIFT 5 +#define BRDCFG9_SFPTX_MASK 0x10 +#define BRDCFG9_SFPTX_SHIFT 4 + #endif diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig new file mode 100644 index 0000000..3511d92 --- /dev/null +++ b/configs/ls1088aqds_qspi_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088AQDS=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y + +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 223d581..a0559a7 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -9,19 +9,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" -CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y -CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 5f976b8..f882d6a 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -33,9 +33,6 @@ #define CONFIG_SPI_FLASH_BAR #define CONFIG_SKIP_LOWLEVEL_INIT
-/* Flat Device Tree Definitions */ -/* #define CONFIG_OF_LIBFDT */ - #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */
#define CONFIG_VERY_BIG_RAM @@ -140,6 +137,11 @@ unsigned long long get_qixis_addr(void);
/* Command line configuration */ #define CONFIG_CMD_ENV +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_MII +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT
/* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h new file mode 100644 index 0000000..b1189ea --- /dev/null +++ b/include/configs/ls1088aqds.h @@ -0,0 +1,403 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088A_QDS_H +#define __LS1088A_QDS_H + +#include "ls1088a_common.h" + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_DISPLAY_BOARDINFO_LATE +#else +#define CONFIG_DISPLAY_BOARDINFO +#endif + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +#if defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (2 * 1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#endif + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_QIXIS_I2C_ACCESS +#define SYS_NO_FLASH +#define CONFIG_SYS_I2C_EARLY_INIT /* swap get_board_sys_clk else part here*/ +#undef CONFIG_CMD_IMLS +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 +#else +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() +#endif + +#define COUNTER_FREQUENCY_REAL (CONFIG_SYS_CLK_FREQ/4) +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 + +#define CONFIG_DDR_SPD +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + + +/* + * IFC Definitions + */ +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +#define CONFIG_SYS_NOR_AMASK_EARLY IFC_AMASK(64*1024*1024) + +#define CONFIG_SYS_NOR0_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR0_CSPR_EARLY \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH1_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EARLY \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH1_BASE_PHYS_EARLY) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(12) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1a) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#ifndef SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ + CONFIG_SYS_FLASH_BASE + 0x40000000} +#endif +#endif + +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_MAX_ECCPOS 256 +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#define CONFIG_FSL_QIXIS +#define CONFIG_SYS_I2C_FPGA_ADDR 0x66 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_QMAP_MASK 0xe0 +#define QIXIS_QMAP_SHIFT 5 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x0e +#define QIXIS_LBMAP_ALTBANK 0x2e +#define QIXIS_LBMAP_SD 0x00 +#define QIXIS_LBMAP_SD_QSPI 0x0e +#define QIXIS_LBMAP_QSPI 0x0e +#define QIXIS_RCW_SRC_SD 0x40 +#define QIXIS_RCW_SRC_QSPI 0x62 +#define QIXIS_RST_CTL_RESET 0x41 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_RST_FORCE_MEM 0x01 +#define QIXIS_STAT_PRES1 0xb +#define QIXIS_SDID_MASK 0x07 +#define QIXIS_ESDHC_NO_ADAPTER 0x7 + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS_EARLY) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define SYS_FPGA_CSPR_FINAL (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) + +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64*1024) +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(0) +#else +#define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(12) +#endif +/* QIXIS Timing parameters*/ +#define SYS_FPGA_CS_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define SYS_FPGA_CS_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define SYS_FPGA_CS_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0x3E)) +#define SYS_FPGA_CS_FTIM3 0x0 + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR2_FINAL SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK2 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS2_FTIM0 SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 SYS_FPGA_CS_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR_EARLY +#define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK_EARLY +#define CONFIG_SYS_AMASK1_FINAL CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR3_FINAL CONFIG_SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_CS_FTIM3 +#endif + +#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000 + +/* + * I2C bus multiplexer + */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* Secondary multiplexer */ +#define I2C_RETIMER_ADDR 0x18 +#define I2C_RETIMER_ADDR2 0x19 +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH5 0xD + +/* +* RTC configuration +*/ +#define RTC +#define CONFIG_RTC_PCF8563 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Channel 3*/ +#define CONFIG_CMD_DATE + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* QSPI device */ +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SYS_FSL_QSPI_AHB +#endif + +#ifdef CONFIG_FSL_DSPI +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_SST +#define CONFIG_SPI_FLASH_EON +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_CS 0 +#endif +#endif + +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_FSL_MEMAC + +/* MMC */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#define CONFIG_ESDHC_DETECT_QUIRK ((readb(QIXIS_BASE + QIXIS_STAT_PRES1) & \ + QIXIS_SDID_MASK) != QIXIS_ESDHC_NO_ADAPTER) + +/* Initial environment variables */ +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1100000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=sf probe 0:0;sf read 0x80000000 0x300000 0x100000;" \ + "sf read 0x80100000 0x800000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" + +#ifdef CONFIG_FSL_MC_ENET +#define CONFIG_FSL_MEMAC +#define CONFIG_PHYLIB +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_TERANETICS +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1d +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F + +#define XQSGMII_CARD_PHY1_PORT0_ADDR 0x0 +#define XQSGMII_CARD_PHY1_PORT1_ADDR 0x1 +#define XQSGMII_CARD_PHY1_PORT2_ADDR 0x2 +#define XQSGMII_CARD_PHY1_PORT3_ADDR 0x3 +#define XQSGMII_CARD_PHY2_PORT0_ADDR 0x4 +#define XQSGMII_CARD_PHY2_PORT1_ADDR 0x5 +#define XQSGMII_CARD_PHY2_PORT2_ADDR 0x6 +#define XQSGMII_CARD_PHY2_PORT3_ADDR 0x7 +#define XQSGMII_CARD_PHY3_PORT0_ADDR 0x8 +#define XQSGMII_CARD_PHY3_PORT1_ADDR 0x9 +#define XQSGMII_CARD_PHY3_PORT2_ADDR 0xa +#define XQSGMII_CARD_PHY3_PORT3_ADDR 0xb +#define XQSGMII_CARD_PHY4_PORT0_ADDR 0xc +#define XQSGMII_CARD_PHY4_PORT1_ADDR 0xd +#define XQSGMII_CARD_PHY4_PORT2_ADDR 0xe +#define XQSGMII_CARD_PHY4_PORT3_ADDR 0xf + +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "DPMAC1@xgmii" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#endif + +#undef CONFIG_CMDLINE_EDITING +#include <config_distro_defaults.h> +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(MMC, mmc, 0) \ + func(SCSI, scsi, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1088A_QDS_H */
Ashish Kumar
