[U-Boot] [PATCH] common/image.c: Relocate strings in tables.
Without this, u-boot can crash or print garbage if the original link address no longer points to a valid string.
Signed-off-by: Scott Wood scottwood@freescale.com --- common/image.c | 8 ++++++-- 1 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/common/image.c b/common/image.c index daa68bc..e22c974 100644 --- a/common/image.c +++ b/common/image.c @@ -518,7 +518,11 @@ static char *get_table_entry_name (table_entry_t *table, char *msg, int id) { for (; table->id >= 0; ++table) { if (table->id == id) - return (table->lname); +#ifdef USE_HOSTCC + return table->lname; +#else + return table->lname + gd->reloc_off; +#endif } return (msg); } @@ -579,7 +583,7 @@ static int get_table_entry_id (table_entry_t *table, fprintf (stderr, "\n"); #else for (t = table; t->id >= 0; ++t) { - if (t->sname && strcmp(t->sname, name) == 0) + if (t->sname && strcmp(t->sname + gd->reloc_off, name) == 0) return (t->id); } debug ("Invalid %s Type: %s\n", table_name, name);
Scott Wood
