[U-Boot-Users] [PATCH 1/3] Convert mpc7448hpc2 to CONFIG_OF_LIBFDT
This was configured to use the deprecated CONFIG_OF_FLAT_TREE, change to CONFIG_OF_LIBFDT.
WARNING: This conversion was untested because I do not have a board to test it on.
NOTE: The FDT blob (DTS) must have an /aliases/ethernet0 and (optionally) /aliases/ethernet1 property for the ethernet to work.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- board/freescale/mpc7448hpc2/mpc7448hpc2.c | 9 +++++++ cpu/74xx_7xx/cpu.c | 35 ++++++++++++---------------- include/configs/mpc7448hpc2.h | 2 +- 3 files changed, 25 insertions(+), 21 deletions(-)
diff --git a/board/freescale/mpc7448hpc2/mpc7448hpc2.c b/board/freescale/mpc7448hpc2/mpc7448hpc2.c index 81846eb..fcbebc0 100644 --- a/board/freescale/mpc7448hpc2/mpc7448hpc2.c +++ b/board/freescale/mpc7448hpc2/mpc7448hpc2.c @@ -105,3 +105,12 @@ ft_board_setup (void *blob, bd_t *bd) } } #endif + +#if defined(CONFIG_OF_BOARD_SETUP) +void +ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); +} +#endif diff --git a/cpu/74xx_7xx/cpu.c b/cpu/74xx_7xx/cpu.c index 9c8998b..a6e3426 100644 --- a/cpu/74xx_7xx/cpu.c +++ b/cpu/74xx_7xx/cpu.c @@ -44,6 +44,11 @@ #include <74xx_7xx.h> #include <asm/cache.h>
+#if defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#include <fdt_support.h> +#endif + #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> #endif @@ -301,29 +306,19 @@ watchdog_reset(void)
-#ifdef CONFIG_OF_FLAT_TREE -void -ft_cpu_setup (void *blob, bd_t *bd) +#ifdef CONFIG_OF_LIBFDT +void ft_cpu_setup(void *blob, bd_t *bd) { - u32 *p; - ulong clock; - int len; - - clock = bd->bi_busfreq; + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "timebase-frequency", bd->bi_busfreq / 4, 1); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "bus-frequency", bd->bi_busfreq, 1); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "clock-frequency", bd->bi_intfreq, 1);
- p = ft_get_prop (blob, "/cpus/" OF_CPU "/bus-frequency", &len); - if (p != NULL) - *p = cpu_to_be32 (clock); + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize);
-#if defined(CONFIG_TSI108_ETH) - p = ft_get_prop (blob, "/" OF_TSI "/ethernet@6200/address", &len); - memcpy (p, bd->bi_enetaddr, 6); -#endif - -#if defined(CONFIG_HAS_ETH1) - p = ft_get_prop (blob, "/" OF_TSI "/ethernet@6600/address", &len); - memcpy (p, bd->bi_enet1addr, 6); -#endif + fdt_fixup_ethernet(blob, bd); } #endif /* ------------------------------------------------------------------------- */ diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h index f614e67..c01d0a5 100644 --- a/include/configs/mpc7448hpc2.h +++ b/include/configs/mpc7448hpc2.h @@ -75,7 +75,7 @@ #define CFG_PROMPT_HUSH_PS2 "> "
/* Pass open firmware flat tree */ -#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
#define OF_CPU "PowerPC,7448@0"
Jerry Van Baren
