[U-Boot] [PATCH] tegra20: display: fix checking of return value
The calling code seems a bit in doubt about the return value of fdtdec_lookup_phandle. Since it returns a negative value on error (and fdt_node_offset_by_phandle as well), check for that.
cc: Wei Ni wni@nvidia.com Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl ---
arch/arm/cpu/armv7/tegra20/display.c:331:26: warning: comparison of constant 0 with boolean expression is always false [-Wtautological-constant-out-of-range-compare]
if (!config->panel_node < 0) { ~~~~~~~~~~~~~~~~~~~ ^ ~
NOT tested on hw. --- arch/arm/cpu/armv7/tegra20/display.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/tegra20/display.c b/arch/arm/cpu/armv7/tegra20/display.c index 488f0c6..fd77f3f 100644 --- a/arch/arm/cpu/armv7/tegra20/display.c +++ b/arch/arm/cpu/armv7/tegra20/display.c @@ -328,7 +328,7 @@ static int tegra_display_decode_config(const void *blob, rgb = fdt_subnode_offset(blob, node, "rgb");
config->panel_node = fdtdec_lookup_phandle(blob, rgb, "nvidia,panel"); - if (!config->panel_node < 0) { + if (config->panel_node < 0) { debug("%s: Cannot find panel information\n", __func__); return -1; }
Tested-by: Stephen Warren swarren@nvidia.com
(On Seaboard/Springbank; booted via tegrarcm and the LCD still works)
Jeroen Hofstee
Stephen Warren
