[next 0/5] Add support of Ethernet for Aspeed AST2600 SoC
This patch series adds support of Ethernet for Aspeed AST2600 SoC. There are 4 MAC controllers (ftgmac100) in AST2600 that can support 10/100/1000T Ethernet. 4 MDIO controllers are used to connect to PHY chips. The MDIO controller has stand-alone hardware block so we introduce DM_MDIO so that we can use external MDIO driver (aspeed_mdio) instead of integrated MDIO drier in ftgmac100.c. The patch series also revises the MII interface delay for better RMII/RGMII timing margin.
Dylan Hung (5): net: ftgmac100: Add DM_MDIO support net: ftgmac100: Add Aspeed AST2600 support ARM: dts: ast2600: Add MDIO devices configs: ast2600: enable DM_MDIO and MDIO driver clk: ast2600: Revise MII interface delay
arch/arm/dts/ast2600-evb.dts | 68 ++++++++++++++++++++++++++++++++ arch/arm/dts/ast2600.dtsi | 46 ++++++++++++++++++--- configs/evb-ast2600_defconfig | 2 + drivers/clk/aspeed/clk_ast2600.c | 10 ++--- drivers/net/ftgmac100.c | 21 +++++++--- 5 files changed, 132 insertions(+), 15 deletions(-)
Add support for DM_MDIO to connect to PHY. For the systems that have a stand-alone MDIO hardware block, enable CONFIG_DM_MDIO to use driver model for MDIO devices.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- drivers/net/ftgmac100.c | 20 +++++++++++++++----- 1 file changed, 15 insertions(+), 5 deletions(-)
diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index 0687230b4bb4..b6e9526c3b9f 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -220,7 +220,11 @@ static int ftgmac100_phy_init(struct udevice *dev) struct phy_device *phydev; int ret;
- phydev = phy_connect(priv->bus, priv->phy_addr, dev, priv->phy_mode); + if (IS_ENABLED(CONFIG_DM_MDIO)) + phydev = dm_eth_phy_connect(dev); + else + phydev = phy_connect(priv->bus, priv->phy_addr, dev, priv->phy_mode); + if (!phydev) return -ENODEV;
@@ -589,10 +593,16 @@ static int ftgmac100_probe(struct udevice *dev) if (ret) goto out;
- ret = ftgmac100_mdio_init(dev); - if (ret) { - dev_err(dev, "Failed to initialize mdiobus: %d\n", ret); - goto out; + /* + * If DM MDIO is enabled, the MDIO bus will be initialized later in + * dm_eth_phy_connect + */ + if (!IS_ENABLED(CONFIG_DM_MDIO)) { + ret = ftgmac100_mdio_init(dev); + if (ret) { + dev_err(dev, "Failed to initialize mdiobus: %d\n", ret); + goto out; + } }
ret = ftgmac100_phy_init(dev);
else
if (ret) {
goto out;
if (ret) {
goto out;
} } ret = ftgmac100_phy_init(dev);
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Add support of the MAC controller of Aspeed AST2600 SOC. The MAC controller is the same with AST2500, except it has stand-alone MDIO hardware block.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- drivers/net/ftgmac100.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index b6e9526c3b9f..aa719d295f3d 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -644,6 +644,7 @@ static const struct eth_ops ftgmac100_ops = { static const struct udevice_id ftgmac100_ids[] = { { .compatible = "faraday,ftgmac100", .data = FTGMAC100_MODEL_FARADAY }, { .compatible = "aspeed,ast2500-mac", .data = FTGMAC100_MODEL_ASPEED }, + { .compatible = "aspeed,ast2600-mac", .data = FTGMAC100_MODEL_ASPEED }, { } };
-- 2.25.1
There are 4 MDIO bus controllers in AST2600 SOC. Each of them can connect to one or more PHY chips and is flexible to work with the 4 MAC devices in AST2600. On AST2600 EVB, MDIO 0,1,2,3 connect to the PHY chips used by MAC 0,1,2,3 respectively.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- arch/arm/dts/ast2600-evb.dts | 68 ++++++++++++++++++++++++++++++++++++ arch/arm/dts/ast2600.dtsi | 46 +++++++++++++++++++++--- 2 files changed, 109 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/ast2600-evb.dts b/arch/arm/dts/ast2600-evb.dts index 2abd31341c11..4e256d1e2b4e 100644 --- a/arch/arm/dts/ast2600-evb.dts +++ b/arch/arm/dts/ast2600-evb.dts @@ -163,6 +163,74 @@ pinctrl-0 = <&pinctrl_i2c9_default>; };
+&mdio0 { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + ethphy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&mdio1 { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + ethphy1: ethernet-phy@0 { + reg = <0>; + }; +}; + +&mdio2 { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + ethphy2: ethernet-phy@0 { + reg = <0>; + }; +}; + +&mdio3 { + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + ethphy3: ethernet-phy@0 { + reg = <0>; + }; +}; + +&mac0 { + status = "okay"; + phy-mode = "rgmii-rxid"; + phy-handle = <ðphy0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rgmii1_default>; +}; + +&mac1 { + status = "okay"; + phy-mode = "rgmii-rxid"; + phy-handle = <ðphy1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rgmii2_default>; +}; + +&mac2 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <ðphy2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rgmii3_default>; +}; + +&mac3 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <ðphy3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rgmii4_default>; +}; + &scu { mac0-clk-delay = <0x1d 0x1c 0x10 0x17 diff --git a/arch/arm/dts/ast2600.dtsi b/arch/arm/dts/ast2600.dtsi index f121f547e6d4..bdcca69e060d 100644 --- a/arch/arm/dts/ast2600.dtsi +++ b/arch/arm/dts/ast2600.dtsi @@ -193,11 +193,47 @@ interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; };
- mdio: ethernet@1e650000 { - compatible = "aspeed,aspeed-mdio"; - reg = <0x1e650000 0x40>; - resets = <&rst ASPEED_RESET_MII>; - status = "disabled"; + mdio: bus@1e650000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1e650000 0x100>; + + mdio0: mdio@0 { + compatible = "aspeed,ast2600-mdio"; + reg = <0 0x8>; + resets = <&rst ASPEED_RESET_MII>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mdio1_default>; + status = "disabled"; + }; + + mdio1: mdio@8 { + compatible = "aspeed,ast2600-mdio"; + reg = <0x8 0x8>; + resets = <&rst ASPEED_RESET_MII>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mdio2_default>; + status = "disabled"; + }; + + mdio2: mdio@10 { + compatible = "aspeed,ast2600-mdio"; + reg = <0x10 0x8>; + resets = <&rst ASPEED_RESET_MII>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mdio3_default>; + status = "disabled"; + }; + + mdio3: mdio@18 { + compatible = "aspeed,ast2600-mdio"; + reg = <0x18 0x8>; + resets = <&rst ASPEED_RESET_MII>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mdio4_default>; + status = "disabled"; + }; };
mac0: ftgmac@1e660000 {
+&mdio0 {
status = "okay";
#size-cells = <0>;
reg = <0>;
+&mdio1 {
status = "okay";
#size-cells = <0>;
reg = <0>;
+&mdio2 {
status = "okay";
#size-cells = <0>;
reg = <0>;
+&mdio3 {
status = "okay";
#size-cells = <0>;
reg = <0>;
+&mac0 {
status = "okay";
+&mac1 {
status = "okay";
+&mac2 {
status = "okay";
phy-mode = "rgmii";
+&mac3 {
status = "okay";
phy-mode = "rgmii";
#size-cells = <1>;
mdio0: mdio@0 {
reg = <0 0x8>;
mdio1: mdio@8 {
reg = <0x8 0x8>;
mdio2: mdio@10 {
reg = <0x10 0x8>;
mdio3: mdio@18 {
reg = <0x18 0x8>;
}; }; mac0: ftgmac@1e660000 {
-- 2.25.1
Enable DM_MDIO and Aspeed MDIO driver for AST2600 EVB.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- configs/evb-ast2600_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/evb-ast2600_defconfig b/configs/evb-ast2600_defconfig index 5f00d6a944a6..21af905a047a 100644 --- a/configs/evb-ast2600_defconfig +++ b/configs/evb-ast2600_defconfig @@ -54,7 +54,9 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ASPEED=y CONFIG_PHY_REALTEK=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_FTGMAC100=y +CONFIG_ASPEED_MDIO=y CONFIG_PHY=y CONFIG_PINCTRL=y CONFIG_RAM=y
diff --git a/configs/evb-ast2600_defconfig b/configs/evb-ast2600_defconfig index 5f00d6a944a6..21af905a047a 100644 --- a/configs/evb-ast2600_defconfig +++ b/configs/evb-ast2600_defconfig @@ -54,7 +54,9 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ASPEED=y CONFIG_PHY_REALTEK=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_FTGMAC100=y +CONFIG_ASPEED_MDIO=y CONFIG_PHY=y CONFIG_PINCTRL=y CONFIG_RAM=y -- 2.25.1
The clock delay of the RMII/RGMII interface is controlled by SCU340~35C. These values are obtained by measurement and experiments so we simply use macro to define them.
Signed-off-by: Dylan Hung dylan_hung@aspeedtech.com --- drivers/clk/aspeed/clk_ast2600.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/clk/aspeed/clk_ast2600.c b/drivers/clk/aspeed/clk_ast2600.c index 3a92739f5cf5..6441fcbbbd4c 100644 --- a/drivers/clk/aspeed/clk_ast2600.c +++ b/drivers/clk/aspeed/clk_ast2600.c @@ -19,11 +19,11 @@ DECLARE_GLOBAL_DATA_PTR; #define CLKIN_25M 25000000UL
/* MAC Clock Delay settings */ -#define MAC12_DEF_DELAY_1G 0x0041b75d -#define MAC12_DEF_DELAY_100M 0x00417410 -#define MAC12_DEF_DELAY_10M 0x00417410 -#define MAC34_DEF_DELAY_1G 0x0010438a -#define MAC34_DEF_DELAY_100M 0x00104208 +#define MAC12_DEF_DELAY_1G 0x0028a410 +#define MAC12_DEF_DELAY_100M 0x00410410 +#define MAC12_DEF_DELAY_10M 0x00410410 +#define MAC34_DEF_DELAY_1G 0x00104208 +#define MAC34_DEF_DELAY_100M 0x00104208 #define MAC34_DEF_DELAY_10M 0x00104208
2.25.1
Dylan Hung
Ramon Fried
