[U-Boot] [PATCH 1/1] mtd/cfi: add support for SST 4KB sector granularity
Add support for SST 4KB sector granularity.
Many recent SST flashes, i.e. SST39VF3201B and similar of this family are declared CFI-conformant from SST. They support CFI query, but implement 2 different sector sizes in the same memory: a 64KB sector (they call it "block", std AMD erase cmd=0x30), and a 4KB sector (they call it "sector", erase cmd=0x50). Also, CFI query on these chips, reading from address 0x2dh of cfi query struct, detects a number of secotrs for the 4KB granularity (flinfo shows it).
For all other aspects, they are CFI compliant, so, as Linux do, i think it's a good idea to handle these chips in the CFI driver, with a fixup to allow 4KB granularity, as should be expected, instead of 64KB.
Signed-off-by: Angelo Dureghello sysamfw@gmail.com Cc: Stefan Rose sr@denx.de --- drivers/mtd/cfi_flash.c | 25 ++++++++++++++++++++++++- include/flash.h | 1 + 2 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index b2dfc53..b46f1ca 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1128,7 +1128,7 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) AMD_CMD_ERASE_START); flash_unlock_seq (info, sect); flash_write_cmd (info, sect, 0, - AMD_CMD_ERASE_SECTOR); + info->cmd_erase_sector); break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: @@ -1733,6 +1733,7 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) { info->cmd_reset = AMD_CMD_RESET; + info->cmd_erase_sector = AMD_CMD_ERASE_SECTOR;
cmdset_amd_read_jedec_ids(info); flash_write_cmd(info, 0, info->cfi_offset, FLASH_CMD_CFI); @@ -2003,6 +2004,25 @@ static void flash_fixup_stm(flash_info_t *info, struct cfi_qry *qry) } }
+static void flash_fixup_sst(flash_info_t *info, struct cfi_qry *qry) +{ + /* + * SST, for many recent nor parallel flashes, says they are + * CFI-conformant. This is not true, since qry struct. + * reports a std. AMD command set (0x0002), while SST allows to + * erase two different sector sizes for the same memory. + * 64KB sector (SST call it block) needs 0x30 to be erased. + * 4KB sector (SST call it sector) needs 0x50 to be erased. + * Since CFI query detect the 4KB number of sectors, users expects + * a sector granularity of 4KB, and it is here set. + */ + if (info->device_id == 0x5D23 || /* SST39VF3201B */ + info->device_id == 0x5C23) { /* SST39VF3202B */ + /* set sector granularity to 4KB */ + info->cmd_erase_sector=0x50; + } +} + /* * The following code cannot be run from FLASH! * @@ -2081,6 +2101,9 @@ ulong flash_get_size (phys_addr_t base, int banknum) case 0x0020: flash_fixup_stm(info, &qry); break; + case 0x00bf: /* SST */ + flash_fixup_sst(info, &qry); + break; }
debug ("manufacturer is %d\n", info->vendor); diff --git a/include/flash.h b/include/flash.h index a04ce90..0ba2d33 100644 --- a/include/flash.h +++ b/include/flash.h @@ -44,6 +44,7 @@ typedef struct { ulong buffer_write_tout; /* maximum buffer write timeout */ ushort vendor; /* the primary vendor id */ ushort cmd_reset; /* vendor specific reset command */ + uchar cmd_erase_sector; /* vendor specific erase sect. command */ ushort interface; /* used for x8/x16 adjustments */ ushort legacy_unlock; /* support Intel legacy (un)locking */ ushort manufacturer_id; /* manufacturer id */
Applied to u-boot-cfi-flash/master. Thanks.
Thanks, Stefan
Angelo Dureghello
Stefan Roese
