[U-Boot] Problem with Porting U-boot on 8308
Hi All,
I am new to Uboot, I am trying to port Uboot on 8308, on single steeping the uboot gets stuck at _start_of_vectors_ Machine check exception. Could anyone please explain what STD_EXCEPTION mean in start.S code and why it happens ? Following are some logs BDI8308_ELAN06>ti Target CPU : MPC83xx (e300c3) Target state : debug mode Debug entry cause : instruction address breakpoint Current PC : 0xfff0017c Current CR : 0x20000000 Current MSR : 0x00003072 Current LR : 0xfff00168 BDI8308_ELAN06>ti Target CPU : MPC83xx (e300c3) Target state : debug mode Debug entry cause : COP halt Current PC : 0xfff00220 Current CR : 0xe6000efc Current MSR : 0xe6000efc Current LR : 0xe6000efc # Step timeout detected The address 0xfff00220 corresponds to Machine check exception in System.map of u-boot code.
Thanks Sharath
Dear Sharath Kurudi,
Please read the documentation what a machine check is and why it happens.
STD_EXCEPTION is a macro that is used to instatiate the code for the standard exception handlers.
Did you try reading the BDI FAQs? IIRC there are some referring to debugging of exception handlers.
Sharath Kurudi
