[U-Boot-Users] [PATCH] remove wrong entry for 512MiB NAND Flash
See commit 0ea4a7558f3c5b894e46da4b2be120edf002a86d in the Linux kernel
Signed-off-by: Joachim Jaeger Joachim_Jaeger@digi.com
Following patch allows use of NAND-Flash device from Samsung with 2kByte page size.
In nand_ids.c, existed an entry for a 512MiB NAND Flash with 512 byte page size and an ID code of the 2kByte page size NAND Flash, which made it impossible to access the NAND Flash with 2kByte page size.
drivers/nand/nand_ids.c | 2 -- 1 files changed, 0 insertions(+), 2 deletions(-)
2673238075a21f0195203fb0a6dab8e7d1081e49 diff --git a/drivers/nand/nand_ids.c b/drivers/nand/nand_ids.c index 8b58736..2b77d76 100644 --- a/drivers/nand/nand_ids.c +++ b/drivers/nand/nand_ids.c @@ -67,8 +67,6 @@ struct nand_flash_dev nand_flash_ids[] =
{"NAND 256MiB 3,3V 8-bit", 0x71, 512, 256, 0x4000, 0},
- {"NAND 512MiB 3,3V 8-bit", 0xDC, 512, 512, 0x4000, 0}, - /* These are the new chips with large page size. The pagesize * and the erasesize is determined from the extended id bytes */
Joachim Jaeger
