[PATCH v4 0/6] board: siemens: clean up subfolders
This serie depends on the serie: [PATCH 0/6] siemens,am335x: clean up the draco board family
The common folder was initialially created for the common parts of the products based on draco-am355x board family. We have the product lines 'pxm2', 'rut' and the base line unfortunately named 'draco'! Adding the new capricorn-imx8 board family, the files were enhanced without cleanup.
Simplify first EEPROM probe and access that implements both i2c with & without driver model. Use abstraction functions for this.
Move all am355x specifics to a new file 'board_am335x'.
Clean-up includes, config checks, maintainer.
Signed-off-by: Enrico Leto enrico.leto@siemens.com --- Changes for v2: - fix wrong value in CONFIG_IS_ENABLED
Changes for v3: - rebased to the top of next branch
Changes for v4: - remove compiler errors - fix patch style checks
Enrico Leto (6): siemens: eeprom: clean up definitions siemens: eeprom: simplify setup & read siemens draco: i2c: use driver model for u-boot siemens: board: clean up draco products vs common siemens: board: clean up includes siemens: factoryset: use correct config for soc specific implementation
board/siemens/capricorn/board.c | 5 +- board/siemens/common/board.c | 110 ++++++++++++---------------- board/siemens/common/board.h | 24 ++++++ board/siemens/common/board_am335x.c | 58 +++++++++++++++ board/siemens/common/board_am335x.h | 38 ++++++++++ board/siemens/common/factoryset.c | 87 +++++----------------- board/siemens/draco/Makefile | 2 + board/siemens/draco/board.c | 62 +++++----------- board/siemens/draco/board.h | 32 ++------ board/siemens/draco/mux.c | 6 +- board/siemens/pxm2/MAINTAINERS | 2 +- board/siemens/pxm2/Makefile | 2 + board/siemens/pxm2/board.c | 34 +++------ board/siemens/pxm2/board.h | 21 ------ board/siemens/pxm2/mux.c | 6 +- board/siemens/rut/MAINTAINERS | 2 +- board/siemens/rut/Makefile | 2 + board/siemens/rut/board.c | 33 ++------- board/siemens/rut/board.h | 21 ------ board/siemens/rut/mux.c | 5 +- configs/draco-etamin_defconfig | 4 +- configs/draco-rastaban_defconfig | 4 +- configs/draco-thuban_defconfig | 4 +- include/configs/draco-etamin.h | 3 - include/configs/draco-rastaban.h | 3 - include/configs/draco-thuban.h | 3 - 26 files changed, 249 insertions(+), 324 deletions(-) create mode 100644 board/siemens/common/board.h create mode 100644 board/siemens/common/board_am335x.c create mode 100644 board/siemens/common/board_am335x.h delete mode 100644 board/siemens/pxm2/board.h delete mode 100644 board/siemens/rut/board.h
Move the I2C and EEPROM address definitions in common board header.
Reviewed-by: Alexander Sverdlin alexander.sverdlin@siemens.com Signed-off-by: Enrico Leto enrico.leto@siemens.com --- board/siemens/capricorn/board.c | 5 ++--- board/siemens/common/board.c | 6 +++--- board/siemens/common/board.h | 21 +++++++++++++++++++++ board/siemens/common/factoryset.c | 12 ++++++------ board/siemens/draco/board.c | 13 +++++-------- include/configs/draco-etamin.h | 3 --- include/configs/draco-rastaban.h | 3 --- include/configs/draco-thuban.h | 3 --- 8 files changed, 37 insertions(+), 29 deletions(-) create mode 100644 board/siemens/common/board.h
diff --git a/board/siemens/capricorn/board.c b/board/siemens/capricorn/board.c index 924c88e8fab..81fa340ca42 100644 --- a/board/siemens/capricorn/board.c +++ b/board/siemens/capricorn/board.c @@ -28,6 +28,7 @@ #include <asm/arch-imx8/clock.h> #endif #include <linux/delay.h> +#include "../common/board.h" #include "../common/factoryset.h"
#define GPIO_PAD_CTRL \ @@ -337,13 +338,11 @@ void board_late_mmc_env_init(void) }
#ifndef CONFIG_SPL_BUILD -int factoryset_read_eeprom(int i2c_addr); - static int load_parameters_from_factoryset(void) { int ret;
- ret = factoryset_read_eeprom(EEPROM_I2C_ADDR); + ret = factoryset_read_eeprom(SIEMENS_EE_I2C_ADDR); if (ret) return ret;
diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index d077751cbe1..7ad367439c1 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -34,7 +34,8 @@ #include <cpsw.h> #include <watchdog.h> #include <asm/mach-types.h> -#include "../common/factoryset.h" +#include "board.h" +#include "factoryset.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -70,7 +71,6 @@ void sdram_init(void) #endif /* #ifdef CONFIG_SPL_BUILD */
#ifndef CONFIG_SPL_BUILD -#define FACTORYSET_EEPROM_ADDR 0x50 /* * Basic board specific setup. Pinmux has been handled already. */ @@ -88,7 +88,7 @@ int board_init(void) gd->bd->bi_boot_params = CFG_SYS_SDRAM_BASE + 0x100;
#ifdef CONFIG_FACTORYSET - factoryset_read_eeprom(FACTORYSET_EEPROM_ADDR); + factoryset_read_eeprom(SIEMENS_EE_I2C_ADDR); #endif
gpmc_init(); diff --git a/board/siemens/common/board.h b/board/siemens/common/board.h new file mode 100644 index 00000000000..0d5b369028f --- /dev/null +++ b/board/siemens/common/board.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright Siemens AG 2023 + * + * Common board definitions for siemens boards + */ + +#ifndef _BOARD_COMMON_H_ +#define _BOARD_COMMON_H_ + +/* EEPROM @ I2C */ +#define SIEMENS_EE_I2C_BUS 0 +#define SIEMENS_EE_I2C_ADDR 0x50 + +/* EEPROM mapping */ +#define SIEMENS_EE_ADDR_NAND_GEO 0x80 +#define SIEMENS_EE_ADDR_DDR3 0x90 +#define SIEMENS_EE_ADDR_CHIP 0x120 +#define SIEMENS_EE_ADDR_FACTORYSET 0x400 + +#endif /* _BOARD_COMMON_H_ */ diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index 4e36a6f3199..94c671389dc 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -22,11 +22,11 @@ #include <net.h> #include <errno.h> #include <g_dnl.h> +#include "board.h" #include "factoryset.h"
-#define EEPR_PG_SZ 0x80 -#define EEPROM_FATORYSET_OFFSET 0x400 -#define OFF_PG EEPROM_FATORYSET_OFFSET/EEPR_PG_SZ +#define EEPR_PG_SZ 0x80 +#define OFF_PG (SIEMENS_EE_ADDR_FACTORYSET / EEPR_PG_SZ)
/* Global variable that contains necessary information from FactorySet */ struct factorysetcontainer factory_dat; @@ -159,7 +159,7 @@ int factoryset_read_eeprom(int i2c_addr) #endif
#if CONFIG_IS_ENABLED(DM_I2C) - ret = uclass_get_device_by_seq(UCLASS_I2C, EEPROM_I2C_BUS, &bus); + ret = uclass_get_device_by_seq(UCLASS_I2C, SIEMENS_EE_I2C_BUS, &bus); if (ret) goto err;
@@ -171,14 +171,14 @@ int factoryset_read_eeprom(int i2c_addr) if (ret) goto err;
- ret = dm_i2c_read(dev, EEPROM_FATORYSET_OFFSET, hdr, sizeof(hdr)); + ret = dm_i2c_read(dev, SIEMENS_EE_ADDR_FACTORYSET, hdr, sizeof(hdr)); if (ret) goto err; #else if (i2c_probe(i2c_addr)) goto err;
- if (i2c_read(i2c_addr, EEPROM_FATORYSET_OFFSET, 2, hdr, sizeof(hdr))) + if (i2c_read(i2c_addr, SIEMENS_EE_ADDR_FACTORYSET, 2, hdr, sizeof(hdr))) goto err; #endif
diff --git a/board/siemens/draco/board.c b/board/siemens/draco/board.c index 8b13d23aca7..814959583f7 100644 --- a/board/siemens/draco/board.c +++ b/board/siemens/draco/board.c @@ -37,6 +37,7 @@ #include <watchdog.h> #include <linux/delay.h> #include "board.h" +#include "../common/board.h" #include "../common/factoryset.h" #include <nand.h>
@@ -132,16 +133,12 @@ struct am335x_nand_geometry { u8 nand_bus; };
-#define EEPROM_ADDR 0x50 -#define EEPROM_ADDR_DDR3 0x90 -#define EEPROM_ADDR_CHIP 0x120 - static int draco_read_nand_geometry(void) { struct am335x_nand_geometry geo;
/* Read NAND geometry */ - if (i2c_read(EEPROM_ADDR, 0x80, 2, + if (i2c_read(SIEMENS_EE_I2C_ADDR, SIEMENS_EE_ADDR_NAND_GEO, 2, (uchar *)&geo, sizeof(struct am335x_nand_geometry))) { printf("Could not read the NAND geomtery; something fundamentally wrong on the I2C bus.\n"); return -EIO; @@ -164,20 +161,20 @@ static int draco_read_nand_geometry(void) static int read_eeprom(void) { /* Check if baseboard eeprom is available */ - if (i2c_probe(EEPROM_ADDR)) { + if (i2c_probe(SIEMENS_EE_I2C_ADDR)) { printf("Could not probe the EEPROM; something fundamentally wrong on the I2C bus.\n"); return 1; }
#ifdef CONFIG_SPL_BUILD /* Read Siemens eeprom data (DDR3) */ - if (i2c_read(EEPROM_ADDR, EEPROM_ADDR_DDR3, 2, + if (i2c_read(SIEMENS_EE_I2C_ADDR, SIEMENS_EE_ADDR_DDR3, 2, (uchar *)&settings.ddr3, sizeof(struct ddr3_data))) { printf("Could not read the EEPROM; something fundamentally wrong on the I2C bus.\nUse default DDR3 timings\n"); set_default_ddr3_timings(); } /* Read Siemens eeprom data (CHIP) */ - if (i2c_read(EEPROM_ADDR, EEPROM_ADDR_CHIP, 2, + if (i2c_read(SIEMENS_EE_I2C_ADDR, SIEMENS_EE_ADDR_CHIP, 2, (uchar *)&settings.chip, sizeof(settings.chip))) printf("Could not read chip settings\n");
diff --git a/include/configs/draco-etamin.h b/include/configs/draco-etamin.h index 97585a4fd12..6ae85b575b7 100644 --- a/include/configs/draco-etamin.h +++ b/include/configs/draco-etamin.h @@ -69,9 +69,6 @@ /* Physical Memory Map */ #define CFG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */
-#define EEPROM_ADDR_DDR3 0x90 -#define EEPROM_ADDR_CHIP 0x120 - /* nedded by compliance test in read mode */
#undef COMMON_ENV_DFU_ARGS diff --git a/include/configs/draco-rastaban.h b/include/configs/draco-rastaban.h index 0991ebfd00c..1b95606cca9 100644 --- a/include/configs/draco-rastaban.h +++ b/include/configs/draco-rastaban.h @@ -34,9 +34,6 @@ /* Physical Memory Map */ #define CFG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */
-#define EEPROM_ADDR_DDR3 0x90 -#define EEPROM_ADDR_CHIP 0x120 - /* Default env settings */ #define CFG_EXTRA_ENV_SETTINGS \ "hostname=rastaban\0" \ diff --git a/include/configs/draco-thuban.h b/include/configs/draco-thuban.h index f4c04c55ebf..629558e27ec 100644 --- a/include/configs/draco-thuban.h +++ b/include/configs/draco-thuban.h @@ -27,9 +27,6 @@ /* Physical Memory Map */ #define CFG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */
-#define EEPROM_ADDR_DDR3 0x90 -#define EEPROM_ADDR_CHIP 0x120 - /* Default env settings */ #define CFG_EXTRA_ENV_SETTINGS \ "hostname=thuban\0" \
Enrico Leto
