[PATCH v2 0/5] toradex: imx: add update_uboot wrapper
This patch series introduces universtal update_uboot wrapper that helps to update U-Boot image on internal storage.
Example of usage:
tftpboot ${loadaddr} ${board_name}/u-boot.img run update_uboot tftpboot ${loadaddr} ${board_name}/SPL run update_spl
v2: - remove uboot_hwpart defition for NAND setups
Igor Opaniuk (5): colibri_imx7: add update_uboot wrapper apalis_imx6: add update_uboot wrapper colibri_imx6: add update_uboot wrapper colibri-imx6ull: add update_uboot wrapper colibri_vf: add update_uboot wrapper
include/configs/apalis_imx6.h | 12 ++++++++++++ include/configs/colibri-imx6ull.h | 7 +++++++ include/configs/colibri_imx6.h | 12 ++++++++++++ include/configs/colibri_imx7.h | 17 +++++++++++++++++ include/configs/colibri_vf.h | 5 +++++ 5 files changed, 53 insertions(+)
Add universal update_uboot wrapper that helps to update U-Boot image on internal storage.
Usage example:
tftpboot ${loadaddr} ${board_name}/u-boot-dtb.imx run update_uboot
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
include/configs/colibri_imx7.h | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index d92db7192e..88e1be1ef5 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -43,6 +43,22 @@ #define CONFIG_NETMASK 255.255.255.0 #define CONFIG_SERVERIP 192.168.10.1
+#if defined(CONFIG_TARGET_COLIBRI_IMX7_EMMC) +#define UBOOT_UPDATE \ + "uboot_hwpart=1\0" \ + "uboot_blk=2\0" \ + "set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && " \ + "setexpr blkcnt ${blkcnt} / 0x200\0" \ + "update_uboot=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && " \ + "mmc write ${loadaddr} ${uboot_blk} ${blkcnt}\0" +#elif defined(CONFIG_TARGET_COLIBRI_IMX7_NAND) +#define UBOOT_UPDATE \ + "update_uboot=nand erase.part u-boot1 && " \ + "nand write ${loadaddr} u-boot1 ${filesize} && " \ + "nand erase.part u-boot2 && " \ + "nand write ${loadaddr} u-boot2 ${filesize}\0" +#endif + #ifndef PARTS_DEFAULT /* Define the default GPT table for eMMC */ #define PARTS_DEFAULT \ @@ -163,6 +179,7 @@ MEM_LAYOUT_ENV_SETTINGS \ NFS_BOOTCMD \ MODULE_EXTRA_ENV_SETTINGS \ + UBOOT_UPDATE \ "boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=\0" \
From: Igor Opaniuk igor.opaniuk@toradex.com Add universal update_uboot wrapper that helps to update U-Boot image on internal storage. Usage example:
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Usage example:
include/configs/apalis_imx6.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 50a4391cd4..800f27ccbb 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -121,6 +121,17 @@ "imx6q-apalis-eval.dtb fat 0 1;" \ "imx6q-apalis-cam-eval.dtb fat 0 1"
+#define UBOOT_UPDATE \ + "uboot_hwpart=1\0" \ + "uboot_blk=8a\0" \ + "uboot_spl_blk=2\0" \ + "set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && " \ + "setexpr blkcnt ${blkcnt} / 0x200\0" \ + "update_uboot=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && " \ + "mmc write ${loadaddr} ${uboot_blk} ${blkcnt}\0" \ + "update_spl=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && " \ + "mmc write ${loadaddr} ${uboot_spl_blk} ${blkcnt}\0" + #define EMMC_BOOTCMD \ "set_emmcargs=setenv emmcargs ip=off root=PARTUUID=${uuid} " \ "ro,noatime rootfstype=ext4 rootwait\0" \ @@ -178,6 +189,7 @@ "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ NFS_BOOTCMD \ + UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ "flash_eth.img && source ${loadaddr}\0" \
include/configs/colibri_imx6.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 95b5a14b59..750463ef47 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -110,6 +110,17 @@ "imx6dl-colibri-eval-v3.dtb fat 0 1;" \ "imx6dl-colibri-cam-eval-v3.dtb fat 0 1"
+#define UBOOT_UPDATE \ + "uboot_hwpart=1\0" \ + "uboot_blk=8a\0" \ + "uboot_spl_blk=2\0" \ + "set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && " \ + "setexpr blkcnt ${blkcnt} / 0x200\0" \ + "update_uboot=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && " \ + "mmc write ${loadaddr} ${uboot_blk} ${blkcnt}\0" \ + "update_spl=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && " \ + "mmc write ${loadaddr} ${uboot_spl_blk} ${blkcnt}\0" + #define EMMC_BOOTCMD \ "set_emmcargs=setenv emmcargs ip=off root=PARTUUID=${uuid} "\ "rw,noatime rootfstype=ext4 " \ @@ -163,6 +174,7 @@ "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ NFS_BOOTCMD \ + UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ "flash_eth.img && source ${loadaddr}\0" \
Usage example:
tftpboot ${loadaddr} ${board_name}/u-boot-nand.imx run update_uboot
include/configs/colibri-imx6ull.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 0c36a57a0e..ea5ba6bfce 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -47,6 +47,12 @@ "ramdisk_addr_r=0x82200000\0" \ "scriptaddr=0x87000000\0"
+#define UBOOT_UPDATE \ + "update_uboot=nand erase.part u-boot1 && " \ + "nand write ${loadaddr} u-boot1 ${filesize} && " \ + "nand erase.part u-boot2 && " \ + "nand write ${loadaddr} u-boot2 ${filesize}\0" + #define NFS_BOOTCMD \ "nfsargs=ip=:::::eth0: root=/dev/nfs\0" \ "nfsboot=run setup; " \ @@ -83,6 +89,7 @@ MEM_LAYOUT_ENV_SETTINGS \ NFS_BOOTCMD \ UBI_BOOTCMD \ + UBOOT_UPDATE \ "console=ttymxc0\0" \ "defargs=user_debug=30\0" \ "dfu_alt_info=" DFU_ALT_NAND_INFO "\0" \
Usage example:
include/configs/colibri_vf.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 40c050a27e..1478ea844e 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -58,6 +58,10 @@ "ramdisk_addr_r=0x82100000\0" \ "scriptaddr=0x87000000\0"
+#define UBOOT_UPDATE \ + "update_uboot=nand erase.part u-boot && " \ + "nand write ${loadaddr} u-boot ${filesize}\0" \ + #define NFS_BOOTCMD \ "nfsargs=ip=:::::eth0: root=/dev/nfs\0" \ "nfsboot=run setup; " \ @@ -112,6 +116,7 @@ NFS_BOOTCMD \ SD_BOOTCMD \ UBI_BOOTCMD \ + UBOOT_UPDATE \ "console=ttyLP0\0" \ "defargs=user_debug=30\0" \ "dfu_alt_info=" DFU_ALT_NAND_INFO "\0" \
Igor Opaniuk
sbabic@denx.de
