[U-Boot] MACB and DM9000 support for AT91SAM9260
Hi All,
We have a board with 2 ethernet ports: one on the macb and the other on a dm9000-chip. Got them both working under linux but the dm9000 doesn't get a MAC-address assigned now. I would like to give the dm9000 its MAC-address in U-Boot via a environment-variable. Because I'm new to U-Boot, I do not see how I can initialise the dm9000 (eth_init()) and macb (which is initialised via eth_init() in eth.c). To me it looks like macb & dm9000 driver are using a different type of driver concept. How can this problem be tackled?
Greetings Frank
I don't know much about dm9000, but the macb driver is initialized by calling macb_eth_initalize() once for each instance you want to use. So assuming dm9000 has something similar, you'll just have to call both of them from board_eth_init() in the order you prefer.
Haavard
I think that the mac address of the dm9000 is on the eeprom. Linux write it using ethtool. Take a look at the dm9000_write_eeprom in the linux code. I think that if you want to use enviroment variable of u-boot, you must write in the eeprom only if the value is different from the enviroment variable.
Haavard
Michael
This is certainly a good option, maybe I try to make the dm9000x-driver a eth_device. But if this is too hard than this will be my fall-back scenario.
{------- I think that the mac address of the dm9000 is on the eeprom. Linux write
of
Haavard
Michael _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Frank v/d Schoot
Frank van der Schoot
Haavard Skinnemoen
michael
