[U-Boot-Users] [PATCH] add memory-pattern-test for lwmon5 fpga-post.
--- post/board/lwmon5/fpga.c | 53 +++++++++++++++++++++++++++++++++++++++++++++- 1 files changed, 52 insertions(+), 1 deletions(-)
diff --git a/post/board/lwmon5/fpga.c b/post/board/lwmon5/fpga.c index b48390b..bfb9df7 100644 --- a/post/board/lwmon5/fpga.c +++ b/post/board/lwmon5/fpga.c @@ -41,6 +41,15 @@ DECLARE_GLOBAL_DATA_PTR;
#if CONFIG_POST & CFG_POST_BSPEC3
+/* Testpattern for fpga memorytest */ +static uint pattern[] = { + 0x55555555, + 0xAAAAAAAA, + 0xAA5555AA, + 0x55AAAA55, + 0x0 +}; + static int one_scratch_test(uint value) { uint read_value; @@ -60,9 +69,42 @@ static int one_scratch_test(uint value) return ret; }
+/* FPGA Memory-pattern-test */ +static int fpga_mem_test(void * address) +{ + int ret = 1; + uint read_value; + uint old_value; + uint i = 0; + /* save content */ + old_value = in_be32(address); + + while( pattern[i] != 0) + { + out_be32(address, pattern[i]); + /* read other location (protect against data lines capacity) */ + ret = in_be16((void *)FPGA_VERSION_REG); + /* verify test pattern */ + read_value = in_be32(address); + + if( read_value != pattern[i]){ + post_log("FPGA Memory test failed write %08X, read %08X at address %08X\n", + pattern[i], read_value, address); + ret = 1; + goto out; + } + i++; + } + + ret = 0; +out: + out_be32(address, old_value); + return ret; +} /* Verify FPGA, get version & memory size */ int fpga_post_test(int flags) { + uint address; uint old_value; ushort version; uint read_value; @@ -87,7 +129,16 @@ int fpga_post_test(int flags)
read_value = get_ram_size((void *)CFG_FPGA_BASE_1, 0x4000); post_log("FPGA RAM size: %d bytes\n", read_value); - + + for(address = 0; address < 0x1000; address++) + { + if( fpga_mem_test((void *) (FPGA_RAM_START + 4*address)) == 1){ + ret = 1; + goto out; + } + }; + +out: return ret; }
In message 12106651882830-git-send-email-sascha.laue@liebherr.com you wrote: ...
- while( pattern[i] != 0)
Incorrect brace style. Also incorrect white space. U-Boot requires:
while (pattern[i] != 0) {
Please add a space before the '(' and '{', and remove the apce after the '('.
Line too long.
Please do not add trailing white space.
- for(address = 0; address < 0x1000; address++)
Brace style, white space.
White space.
ret = 1;
goto out;
No semicolon here, please.
