[U-Boot] [PATCH] ARM64: zynqmp: Remove netdev.h from board file
Including netdev.h is causing compilation warning: + int fecmxc_register_mii_postcall(struct eth_device *dev, int (*cb)(int)); + ^ w+In file included from ../board/xilinx/zynqmp/zynqmp.c:9:0: w+../include/netdev.h:204:41: warning: ‘struct eth_device’ declared inside parameter list [enabled by default] w+../include/netdev.h:204:41: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default]
This patch removes it.
board/xilinx/zynqmp/zynqmp.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 529476b08268..132d724fbdf8 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -6,7 +6,6 @@ */
#include <common.h> -#include <netdev.h> #include <sata.h> #include <ahci.h> #include <scsi.h>
Michal Simek
