[PATCH] smegw01: Use CONFIG_SYS_LOAD_ADDR for loading fitImage
Set CONFIG_SYS_LOAD_ADDR=0x88000000 and use this address for loading fitImage.
Also pass the standard CONFIG_BOOTFILE option to indicate the fitImage file.
Signed-off-by: Eduard Strehlau eduard@lionizers.com Signed-off-by: Fabio Estevam festevam@denx.de --- board/storopack/smegw01/smegw01.env | 14 +++++++------- configs/smegw01_defconfig | 3 +++ 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/board/storopack/smegw01/smegw01.env b/board/storopack/smegw01/smegw01.env index 1263ddac8ed0..528310dd810f 100644 --- a/board/storopack/smegw01/smegw01.env +++ b/board/storopack/smegw01/smegw01.env @@ -48,13 +48,8 @@ commit_mmc= saveenv; fi; console=ttymxc0 -fdt_addr=0x83000000 -fdtfile=imx7d-smegw01.dtb -fit_addr=0x88000000 -image=fitImage -loadaddr=0x80800000 loadbootpart=mmc partconf 1 boot_part -loadimage=load mmc ${mmcdev}:${gpt_partition_entry} ${fit_addr} boot/${image} +loadimage=load mmc ${mmcdev}:${gpt_partition_entry} loadpart=gpt setenv mmc ${mmcdev} rootfs-${mmcpart_committed} mmcargs= setenv bootargs console=${console},${baudrate} root=/dev/mmcblk${mmcdev}p${gpt_partition_entry} rootwait rw SM_ROOT_DEV=${mmcdev} SM_ROOT_PART=${gpt_partition_entry} SM_BOOT_PART=${boot_part} @@ -71,8 +66,13 @@ mmcboot= else run altbootcmd; fi; +#ifdef CONFIG_SYS_BOOT_LOCKED + hab_auth_img ${fileaddr} ${filesize}; +#else + hab_auth_img_or_fail ${fileaddr} ${filesize}; +#endif run mmcargs; - if bootm ${fit_addr}; then + if bootm; then ; else run altbootcmd; diff --git a/configs/smegw01_defconfig b/configs/smegw01_defconfig index 7f1b2bee8e16..616038387e27 100644 --- a/configs/smegw01_defconfig +++ b/configs/smegw01_defconfig @@ -14,6 +14,7 @@ CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_IMX_HAB=y +CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0xa0000000 CONFIG_FIT=y @@ -54,6 +55,8 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ENV_WRITEABLE_LIST=y CONFIG_ENV_ACCESS_IGNORE_FORCE=y +CONFIG_USE_BOOTFILE=y +CONFIG_BOOTFILE="boot/fitImage" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOOTCOUNT_LIMIT=y
From: Eduard Strehlau eduard@lionizers.com Set CONFIG_SYS_LOAD_ADDR=0x88000000 and use this address for loading fitImage. Also pass the standard CONFIG_BOOTFILE option to indicate the fitImage file. Signed-off-by: Eduard Strehlau eduard@lionizers.com Signed-off-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
