[U-Boot-Users] [PATCH] Bios emulator from Jason Lin
Bios emulator code contains a lot of coding style issues. expecially Cute names. Makefile hasn't header, etc...
Remove problems with warnings and errors for Microblaze cpu.
Signed-off-by: Michal Simek monstr@monstr.eu
diff --git a/drivers/bios_emulator/besys.c b/drivers/bios_emulator/besys.c index 2a8e1a0..505e4ff 100644 --- a/drivers/bios_emulator/besys.c +++ b/drivers/bios_emulator/besys.c @@ -46,6 +46,7 @@ * 16 bit of the io port. * ****************************************************************************/ +#ifdef CONFIG_BIOSEMU
#include "biosemui.h"
@@ -717,3 +718,4 @@ void X86API BE_outl(X86EMU_pioAddr port, u32 val) #endif LOG_outpd(port, val); } +#endif diff --git a/drivers/bios_emulator/bios.c b/drivers/bios_emulator/bios.c index ed5437e..2522379 100644 --- a/drivers/bios_emulator/bios.c +++ b/drivers/bios_emulator/bios.c @@ -40,7 +40,7 @@ * video BIOS. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "biosemui.h"
/*----------------------------- Implementation ----------------------------*/ @@ -319,3 +319,4 @@ void _BE_bios_init(u32 * intrTab) bios_intr_tab[0x6D] = int10; X86EMU_setupIntrFuncs(bios_intr_tab); } +#endif diff --git a/drivers/bios_emulator/biosemu.c b/drivers/bios_emulator/biosemu.c index 06d4ad3..8c51ee3 100644 --- a/drivers/bios_emulator/biosemu.c +++ b/drivers/bios_emulator/biosemu.c @@ -44,7 +44,7 @@ * frambuffer function can work after run the BIOS. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "biosemui.h" #include <malloc.h>
@@ -368,3 +368,4 @@ int X86API BE_int86x(int intno, RMREGS * in, RMREGS * out, RMSREGS * sregs) sregs->gs = M.x86.R_GS; return out->x.ax; } +#endif diff --git a/drivers/bios_emulator/x86emu/debug.c b/drivers/bios_emulator/x86emu/debug.c index 0f58a69..2f776c2 100644 --- a/drivers/bios_emulator/x86emu/debug.c +++ b/drivers/bios_emulator/x86emu/debug.c @@ -36,7 +36,7 @@ * emulator. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "x86emu/x86emui.h" #include <stdarg.h>
@@ -459,3 +459,4 @@ void x86emu_dump_xregs(void) printk("NC "); printk("\n"); } +#endif diff --git a/drivers/bios_emulator/x86emu/decode.c b/drivers/bios_emulator/x86emu/decode.c index 1e2dcfe..c1b754d 100644 --- a/drivers/bios_emulator/x86emu/decode.c +++ b/drivers/bios_emulator/x86emu/decode.c @@ -36,7 +36,7 @@ * instruction decoding and accessess of immediate data via IP. etc. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ @@ -1142,3 +1142,4 @@ unsigned decode_rmXX_address(int mod, int rm) return decode_rm01_address(rm); return decode_rm10_address(rm); } +#endif diff --git a/drivers/bios_emulator/x86emu/ops.c b/drivers/bios_emulator/x86emu/ops.c index d1380ce..40f6724 100644 --- a/drivers/bios_emulator/x86emu/ops.c +++ b/drivers/bios_emulator/x86emu/ops.c @@ -74,7 +74,7 @@ * the got2 sector. Removed some opcode. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "x86emu/x86emui.h" /*----------------------------- Implementation ----------------------------*/
@@ -5429,3 +5429,4 @@ void (*x86emu_optab[256])(u8) __attribute__ ((section(".got2"))) = /* 0xfe */ x86emuOp_opcFE_byte_RM, /* 0xff */ x86emuOp_opcFF_word_RM, }; +#endif diff --git a/drivers/bios_emulator/x86emu/ops2.c b/drivers/bios_emulator/x86emu/ops2.c index 631a340..42b701b 100644 --- a/drivers/bios_emulator/x86emu/ops2.c +++ b/drivers/bios_emulator/x86emu/ops2.c @@ -43,7 +43,7 @@ * got2 sector. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ @@ -1768,3 +1768,4 @@ void (*x86emu_optab2[256])(u8) __attribute__((section(".got2"))) = /* 0xfe */ x86emuOp2_illegal_op, /* 0xff */ x86emuOp2_illegal_op, }; +#endif diff --git a/drivers/bios_emulator/x86emu/prim_ops.c b/drivers/bios_emulator/x86emu/prim_ops.c index e0827d7..9f51ede 100644 --- a/drivers/bios_emulator/x86emu/prim_ops.c +++ b/drivers/bios_emulator/x86emu/prim_ops.c @@ -96,7 +96,7 @@ * By inspection, one gets: bc = a'b + r(a' + b) * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #define PRIM_OPS_NO_REDEFINE_ASM #include "x86emu/x86emui.h"
@@ -2443,3 +2443,4 @@ DB( if (CHECK_SP_ACCESS()) M.x86.R_SP += 4; return res; } +#endif diff --git a/drivers/bios_emulator/x86emu/sys.c b/drivers/bios_emulator/x86emu/sys.c index bb7fcd9..00e286c 100644 --- a/drivers/bios_emulator/x86emu/sys.c +++ b/drivers/bios_emulator/x86emu/sys.c @@ -38,7 +38,7 @@ * functions will have to be overriden by the user library. * ****************************************************************************/ - +#ifdef CONFIG_BIOSEMU #include "x86emu/x86emui.h"
/*------------------------- Global Variables ------------------------------*/ @@ -320,3 +320,4 @@ void X86EMU_prepareForInt(int num) M.x86.R_IP = mem_access_word(num * 4); M.x86.intr = 0; } +#endif
This cannot work; when adding the #ifdef before the #includes (which somehwere include <config.h>) CONFIG_BIOSEMU will *never* be defined.
Michal Simek
