[PULL] u-boot-sh/master-porter
The following changes since commit 9e00b6993f724da9699ef12573307afea8c19284:
Merge tag 'u-boot-dfu-20240215' of https://source.denx.de/u-boot/custodians/u-boot-dfu (2024-02-15 10:26:24 -0500)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master-porter
for you to fetch changes up to 87f9ffbef5e894bbcea99614520c8afd216bbf1a:
ARM: renesas: Enable LTO on R-Car (2024-02-17 22:38:20 +0100)
---------------------------------------------------------------- Marek Vasut (3): ARM: renesas: Disable EFI on R-Car Gen2 ARM: renesas: Set R-Car Gen2 board size limit to 512 kiB ARM: renesas: Enable LTO on R-Car
Niklas Söderlund (1): clk: renesas: Fix broken clocks on all Gen2 boards
Kconfig | 3 ++- arch/arm/Kconfig | 1 + configs/alt_defconfig | 2 ++ configs/blanche_defconfig | 2 ++ configs/gose_defconfig | 2 ++ configs/koelsch_defconfig | 2 ++ configs/lager_defconfig | 2 ++ configs/porter_defconfig | 2 ++ configs/silk_defconfig | 2 ++ configs/stout_defconfig | 2 ++ drivers/clk/renesas/clk-rcar-gen2.c | 9 +++++++++ 11 files changed, 28 insertions(+), 1 deletion(-)
