[U-Boot] [PATCH] sunxi: makes an invisible option for H3-like DRAM controllers
Allwinner SoCs after H3 (e.g. A64, H5, R40, V3s) uses a H3-like DesignWare DRAM controller, which do not have official free DRAM initialization code, but can use modified dram_sun8i_h3.c.
Add a invisible option for easier DRAM initialization code reuse.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- arch/arm/include/asm/arch-sunxi/dram.h | 2 +- arch/arm/mach-sunxi/Makefile | 2 +- board/sunxi/Kconfig | 7 +++++++ 3 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index e0be744dba..c5456658a3 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -24,7 +24,7 @@ #include <asm/arch/dram_sun8i_a33.h> #elif defined(CONFIG_MACH_SUN8I_A83T) #include <asm/arch/dram_sun8i_a83t.h> -#elif defined(CONFIG_MACH_SUN8I_H3) +#elif defined(CONFIG_SUNXI_H3_DW_DRAM) #include <asm/arch/dram_sun8i_h3.h> #elif defined(CONFIG_MACH_SUN9I) #include <asm/arch/dram_sun9i.h> diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index e73114ee64..dc737db4b9 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -48,6 +48,6 @@ obj-$(CONFIG_MACH_SUN7I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o -obj-$(CONFIG_MACH_SUN8I_H3) += dram_sun8i_h3.o +obj-$(CONFIG_SUNXI_H3_DW_DRAM) += dram_sun8i_h3.o obj-$(CONFIG_MACH_SUN9I) += dram_sun9i.o endif diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index e1d4ab148f..4ddd992684 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -42,6 +42,12 @@ config SUNXI_GEN_SUN6I separate ahb reset control registers, custom pmic bus, new style watchdog, etc.
+config SUNXI_H3_DW_DRAM + bool + ---help--- + Select this for sunxi SoCs which uses a DRAM controller like the + DesignWare controller used in H3, mainly SoCs after H3, which do + not have official open-source DRAM initialization code.
choice prompt "Sunxi SoC Variant" @@ -113,6 +119,7 @@ config MACH_SUN8I_H3 select ARCH_SUPPORT_PSCI select SUNXI_GEN_SUN6I select SUPPORT_SPL + select SUNXI_H3_DW_DRAM select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN9I
According to Jens disabling the on-die-termination should set bit 5, not bit 1 in the respective register. Fix this.
Reported-by: Jens Kuske jenskuske@gmail.com Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/dram_sun8i_h3.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_h3.c b/arch/arm/mach-sunxi/dram_sun8i_h3.c index b08b8e67cc..8e2527dee1 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_h3.c +++ b/arch/arm/mach-sunxi/dram_sun8i_h3.c @@ -347,7 +347,7 @@ static int mctl_channel_init(struct dram_para *para) clrsetbits_le32(&mctl_ctl->datx[i].gcr, (0x3 << 4) | (0x1 << 1) | (0x3 << 2) | (0x3 << 12) | (0x3 << 14), - IS_ENABLED(CONFIG_DRAM_ODT_EN) ? 0x0 : 0x2); + IS_ENABLED(CONFIG_DRAM_ODT_EN) ? 0x0 : 0x20);
/* AC PDR should always ON */ setbits_le32(&mctl_ctl->aciocr, 0x1 << 1);
This has already been sent and merged (and it's missing your Signed-off-by).
Maxime
Since it's used on all the newer SoCs, do we need to keep the H3 name in the config option name?
Thanks, Maxime
06.01.2017, 06:16, "Maxime Ripard" maxime.ripard@free-electrons.com:
Good question...
Name it "SUNXI_DW_DRAM"?
(Although I think at least A33 uses the same series of DRAM controller)
Thanks, Maxime
-- Maxime Ripard, Free Electrons Embedded Linux and Kernel engineering http://free-electrons.com
Good question...
Looks good.
Does it? Why do we need a separate DRAM init code then?
Thanks, Maxime
Icenowy Zheng
Maxime Ripard
